LeEco Le Max 2 (X820 / X821 / Χ822 Global - X825 / Χ829 U.S.)
Paul64
Απλά ο server RR μάλλον έχει πολύ traffic παιδιά δοκιμάστε αργότερα η το βράδυ αργά
Η Ρομ περιλαμβάνει Smart Charging latest kernel update 8.0 and March security patches
LeMax2-X820 LegionOS / LeMax2-X822 DerpFest
Xiaomi RN3Pro-MIUI10_9.3.14
Xiaomi RN9Pro-MIUI-12.5.5-RJWMIX
Ok, ευχαριστούμε Χρήστο.
Latest official TWRP x2-3.5.1_9-0 with advanced tools is out.
--- Available Tools --
* Manage system/user files with AromaFileManager. No need root.
* Root / Unroot your device with latest Magisk v22 or SU
* Force push adb and take logs if device not booting.
* Flash global splash and remove chinese
* Clear your FP if you facing lockscreen/login issues
* Repair your fingerprint sensor
* Restore / Clear battery stats
* Remove your PIN/Pattern in case you forgot them.
* Remove / clear your fingerprints
* EFS fix for sim/data issues
* Treblize your device if you came from EUI stock rom
* Mount - Backup - Restore for all available partitions.
* Including - introducing new tool for stock/custom rom debloat.
* Includes the ability to restore stock persist.img.
Flash through TWRP like any other flash ZIP.
Enjoy..
BlueTheme
StockTheme
• Device : LeEco LeMax2
• OctaviOS Version : 2.2
• Maintainer : CrisBalGreece
• Build Date : 11/04/2021
• Build Type : Vanilla | GAPPS
• Downloadg :- Here
• Support Group ( LeMax2): @CBG_LeMax2
• Official community group : @OctaviOS_Chat
• XDA thread
• Download : Here
#OctaviOS #LeMax2 #x2
LegionOS v3.8 Official | LeEco LeMax2 | x2
▪️ Build date: 2021-04-09
▪️ Security Patch: April 2021
▪️ Android Version: 11
▪️ Download :- VANILLA GAPPS
▪️ Changelog :- Source | VANILLA
▪️ By @CrisBalGreece
▪️ Support : Rom | Device
#LegionOS #LeMax2 #x2
Edited by CrisBal
OctaviOS new test builds with tethering switch issue fixed. Test if you want.
Dirty Flash over latest release will work.
OctaviOS-Vanilla TetheringFixTest 2021.04.15
https://drive.google.com/u/0/uc?id=1N7o3ZwkV-MLAcZsMcQIRMcAqTAfJcqvA&export=download
OctaviOS-Gapps TetheringFixTest 2021.04.15
https://drive.google.com/u/0/uc?id=1AE0BokN579J_mwbRJdi2ebhXvSYZdv-7&export=download
Latest official TWRP x2-3.5.2_9-0 with advanced tools is out.
* Root / Unroot your device with latest Magisk v22.1 or SU.
Magisk apk is now under sdcard/Magisk file in case you want to install it after zip Flash.
* Reboot directly to system after zip flash.
* Repair your PassPattern locks
* Including - introducing new tool for stock rom debloat.
Enjoy..
BlueTheme. https://drive.google.com/u/0/uc?id=1U4yvGDwQyyxupR7lvJiH5AGuILF5xNJC&export=download
StockTheme
https://drive.google.com/file/d/1rM6SynXU7Duhjxi-fLaoDie5GVHt9iqY/view?usp=sharing
Μετα απο πολλες φορτισεις της μπαταριας HSABAT μπορω να πω οτι αξιζει η αλλαγη της. Με την ρομ της υπογραφης μου αν και πιθανον να παω σε rr 8.6.7 βγαζω 4,5 ωρες sot ισως και παραπανω. Απο τις ρομ android 11 ποια ειναι η πιο σταθερη αν εχει δοκιμασει κανεις και αν αξιζει να πας σε android 11.
Coolpad f1 (Great F1) - AEX MODDED LITE by jpower
Leeco Le Max 2 X820 6gb - 64gb (RROS-Q-8.7.3-20210920-x2-20210920)
19/March/2020 by C.B.G.)
• DotOS Version : 5.0.1 - Android 11
• Build Date : 19/04/2021
• Download :- Here
• Source Changelog :- Here
• Official DotOS community group : @dotos
• EAS kernel compatible
#DotOS #LeMax2 #x2
Αν δεν έχεις προβλήματα μείνε εκεί που δουλεύουν όλα και screen cast. Όπως και στην TR φυσικά
• OctaviOS Version : 2.3
• Build Date : 24/04/2021
• Downloadg :- Here
• XDA thread
New Official DerpFest with Gapps-Build For LeEco-x2-LeMax2 20200513
By :CrisBalGreece
Build Date: 13/May/2020
⬇️ Official Download
⬇️ Direct Download
Changelog
Derp Website
C.B.G. Telegram Group
*Flash Guide*
- Make Sure You have my latest 3.3.1-3 TWRP or official 3.3.1-0/1
- If you are on 05.06.2020 just make the update (through ROM updater) or download it and flash dirty.
- Clean flash installation> Make wipe two caches , data, system and vendor.
- Flash Rom
- Reboot to system.
- Enjoy Derpfest...
*NOTICE*
Rom includes Pixel Gapps..DO NOT flash others.
Build is enforcing is Google certified and passes CTS by default.
*Fast changelog
- Fixed DerpQuest>Menu keys> shortcuts
- Small BS 7.1-OC plus improvements
- Rebased all of my trees and sepolicies
- Added the open source consumerir HAL+bridge and enabled VNDK
- Added the fix for miracast
- All IR Remotes Universal working now.
-Including permanently green tint fix in front camera
Extras
CPU Profiles, kernel, firmware and more
https://sourceforge.net/projects/derpfest-10-x2/files/
Καλημέρα, από eui 30s-v24 με android6 πρέπει πρώτα να κάνω treble το κινητό?
και μετά ακολουθώ ότι διαβάζω στην παράθεση ή και κάτι άλλο?
έχω δώσει στη γυναίκα μου πλέον το κινητό (1+ χρόνο) και δεν της αναγνωρίζει κάτι xiaomi τύπου airpods . παίζει μουσική αλλά δεν στέλνει ήχο κλήσεων...
είπα με την ευκαιρία να της το αναβαθμίσω.
ευχαριστώ!
Ποιο firmware και modem πρεπει να εχω; και που βλεπω ποιες εκδόσεις έχω;
Στάλθηκε από το LEX820 μου χρησιμοποιώντας Tapatalk
ευχαριστώ!
Καλή η DerpFestαλλα δεν υπάρχουν ενημερώσεις πλέον. Βάλε καλύτερα την RR που 3χει ενημερώσεις. Λογικά δεν χρειάζεται να κάνεις τίποτα θα γίνουν όλα αυτόματα απλά για να τρέχει 4 φορές πιο γρήγορα κάντο f2fs.
-How to convert your data and cache partitions to f2fs-
WARNING: This will erase all data stored on your internal storage/sdcard!!
Instructions
- Reboot to TWRP
- Tap "wipe"
- Tap "advanced wipe"
- Check the box for "data"
- Tap "repair or change file system"
- Tap "change file system"
- Tap "f2fs"
- Swipe to change
- Go back and make the same procedure for "cache" partition
- Reboot to recovery and flash your new ROM. Now you are with f2fs.
TIP: If you want to downgrade ROM to EUI or another that doesn't support f2fs follow the same procedure backward.
Αν έχεις 820 822 30s latest
Ann έχεις 825 829 20s US
Αν έχεις 821 India version 21s firmware
Find your model according region and flash the proper firmware https://www.phonemore.com/models/leeco/le-max-2/
419Dev full firmware
https://mega.nz/#!gH41yAZJ!oaVQPB9EdBNJKWcA_PGVtMGhAOaRI7qCbSOhq_K5Ajg
466Dev Full firmware
https://mega.nz/#!JUkH3IhI!QUZnqVAzf1Zy6dZnjMSPHll93FZgeBqy15Zi9-5vC54
20s China full firmware
https://mega.nz/#!VbB0mRqJ...KTzXMaa4KbQBaE
23s China full firmware
https://mega.nz/#!0cUg3DKT!CfcdCo8fVDwKm3Zutey7vwsz8kTme0LjMb46MXg1FO0
26s China full firmware
https://mega.nz/#!wF8GwRbD!0H5a9Pn_1b_l1ImTZNokXdrHT3_Trw4tA10IGrt-Wp4
28s China full firmware
https://drive.google.com/open?id=1vICKm2pmKLnLmRrlm78HiKFBKvBsgCyX
30s China+Latest 466D modem
https://sourceforge.net/projects/derpfest-10-x2/files/firmware/30s_C.B.G.ROMs_firmware-update.zip/download
16s india full firmware
https://mega.nz/#!QWRylLxZ!GpR0QUq6Z8rAZ5U3bgCfI9GFFx5cp2C3KpsWJqdvxzs
19s india full firmware
https://mega.nz/#!YCRB2BRJ!LXkljo8BP6OHx8U12wmk8LJAGRmI6nyKUgi7sWTf3Xo
21s India full firmware https://t.me/CBG_LeMax2/47852
x825/x829 5.8.016s USA edition full firmware update
https://mega.nz/#!4SYXmQaa!gi2RLyuNhZ4PnoUWPq3BWaE0dR5veJahjCZWC5XTY8w
x825/x829 5.9.020s USA edition full firmware update https://t.me/CBG_LeMax2/47860
Modem (Only Modems)
https://yadi.sk/d/5v2p3F7o3GJBxn
Make LeEco account
https://m.youtube.com/watch?v=sNPVOIvlcjI
New Official RR-OS 8.6.9 Andoid 10 build for LeEco LeMax2 (x2) is available
by CrisBalGreece
Build date: 13 May 2021
File size: 0.87G
Version: Official
▫️ Download
▫️ Changelog
- May security patches
- Including latest B.S. 8.0.1 kernel
- Including LeEco IR
Enjoy...
Info: Due to RR server maintenance is available only manually for now.
Update through ROM manually for now.
Gapps not included. Flash OpenGapps nano/pico or other's
#x2 #Get_Resurrected
Άλλαξα τη μπαταρία με τη γνωστή της Hsbat. Τι πρέπει να κάνω από calibration; Στο μενού φαίνεται ακόμα να είναι 3200 mah.
Και έτσι θα φαινεται για πάντα εκτός κι αν πας με ρομ που εχω δώσει patch αλλά είναι παλιές. Μην αγχώνεσαι..μια χαρά είναι κι έτσι..
Ευχαριστώ για την απάντηση Chris.
Δε με πολυαπασχολεί το τι δείχνει το μενού. Κυρίως με ενδιαφέρει αν χρειάζεται να τρέξω κάποιο πρόγραμμα για καλιμπράρισμα της μπαταρίας και, αν ναι, ποιο;
Παιδιά εσείς που αλλάξατε μπαταρία που την αλλάξατε;
έχω ένα x722 που μάλλον φταίει η μπαταρία αλλά σε 2-3 που πήγα δεν αναλαμβάνουν αλλαγή.
Πέραν οτι δεν έχουν μπαταρία, καλά μπορώ να την αγοράσω απ' το internet και να την πάω.
Λογικά με τον ίδιο τρόπο αλλάζουν και στο LeMax2 (πρέπει να βγει η οθόνη).
Leeco Cool1 4/64 Gold
Μετά από αρκετό ψάξιμο βρήκα κι εγώ κάποιον (στη Χαλκίδα που μένω) ο οποίος να το αναλάβει, γιατί πραγματικά δεν είναι πολύ εύκολο. Σημειωτέον ότι άφησε μια μικροατέλεια στην οθόνη, καθώς προκλήθηκε μια ελαφριά ανομοιογένεια στον οπίσθιο φωτισμό των LED, ευτυχώς ορατή μόνο υπό γωνία.
Δε γινόταν αλλιώς πάντως, γιατί η μπαταρία είχε εξαντληθεί και δεν έβγαζε μια ώρα με την οθόνη αναμμένη...
μπαταρία από που πήρες; Ali ή από Ελλάδα;
Αν γυρίσεις και διαβάσεις μερικές σελίδες πίσω θα βρεις πληροφορίες από αρκετά παιδιά για την αλλαγή μπαταρίας που έκαναν και θα κατατοπιστείς αρκετά.
Ανάλογα βέβαια και που μένεις.
Εγώ Θεσσαλονίκη άλλαξα. (Αν είσαι και εσύ Θεσσαλονίκη, πες να ξαναγράψω τα στοιχεία του καταστήματος αν σ' ενδιαφέρει)
Την μπαταρία την παραγγέλνεις εσύ.
Εγώ έτυχε πήρα από Άμαζον.
Οι περισσότεροι από Αλί και απ ότι λένε είναι ευχαριστημένοι, οπότε δες το και εσύ.
Οι περισσότεροι σου λένε ότι δεν αναλαμβάνουν τυχόν σπάσιμο.
Οπότε μάλλον αναλαμβάνεις το ρίσκο.
Εγώ την άλλαξα με 20 ευρώ συν 16 που είχα δώσει να την παραγγείλω.
Από τον Σεπτέμβριο την έχω και από την αρχή το κινητό έγινε όπως ήταν καινούριο.
Πλέον μετά από 9 μήνες έχω μπαταρία για 3.5 ώρες σόσιαλ και οθόνη, ενώ είχε φτάσει να μου κρατάει με την παλιά το πολύ 1.5 ώρα.
Καλή συνέχεια να έχεις και προσωπικά θεωρώ ότι αξίζει, γιατί το τηλέφωνο μας δεν έχει να ζηλέψει τίποτα ακόμα και σήμερα και στην τελική έστω και σαν δεύτερο παρά αξίζει !!!
