[Windows Tablets] Tips, Tools και Apps
alex_gate_7
Taskfabric(desktop program->UWP App)
Taskfabric - Task & Project Manager with Mind Maps and To Do Lists for you and your team
From 59.99$ --->>> free until 13/6/2016!!
Features
•Easy to use, intuitive task manager with multiple themes
•Supports leading project management methods (like GTD, Contexts, PMBOK, PRINCE2)
•Syncs across all your devices. Access your tasks from anywhere anytime
•Give your projects structure: subtasks, sub-projects, sub-contexts
•Supports you during meetings (AID classification - Action, Information, Decision)
•Makes task delegation and tracking easy (RACI matrix - Responsible, Accountable, Consulted, Informed)
•Review by date (daily, weekly, monthly) or by duration
apps.25764.13510798887461949.0115daf1-43b8-4524-b961-a6ca6a981a9a.dfc60f68-e339-4a70-b0d2-c4fdf523bc55?w=580&h=326&q=60&mode=letterbox&background=black
apps.46331.13510798887461949.cfdbc0df-789b-4489-8b85-afed0282ae9f.54037365-4ed4-4260-84ee-6814b5092086?w=580&h=326&q=60&mode=letterbox&background=black
apps.10299.13510798887461949.5cdc2e1e-510f-480f-9827-ccb1d3a4d9be.3d64be4a-5cc7-4fd9-994b-75cbe9bccae9?w=580&h=326&q=60&mode=letterbox&background=black
ΠΡΟΣΟΧΗ!
Υπαρχει περιπτωση σε 32Bit windows να μην εμφανιζεται ως συμβατο,οποταν χρησιμοποιηστε καποια 64Bit μηχανημα να το κατεβασετε.
Edited by ector7
  • Απαντήσεις 309
Προσφορά με μόλις 1 ευρώ η παρακάτω εφαρμογη για 2 ημέρες ακόμα.
Photo Editor Pro | Polarr
https://www.microsoft.com/en-us/store/apps/app/9nblggh1npnc?tduid=(21355141d34c486dc0b33182072bc979)(266696)(1018132)(950267651)()
Sent from my iPad Air 2
Εκ νεου προσφορά στο 1 ευρω για 4 ημέρες ακόμα σε όσους δεν πρόλαβαν την προηγούμενη.
Και άλλη μια ενδιαφέρουσα εφαρμογη με έκπτωση για 1 ημέρα ακόμα.
Developer Submission: New update of PhotoSmile! Bring positive emotions in your life!
http://mspoweruser.com/developer-submission-new-update-photosmile-bring-positive-emotions-life/
Features
-App allows to take the best photos with your smile!
-It provides protection from the sad and inexpressive photos.
-Rich integration with Photo Library.
-Ability to edit photos from Photo Library.
-Available editing functions: crop, filters, effects, blur, brightness and contrast adjustment, image rotation.
-User-friendly interface.
-Cool design.
http://uploads.tapatalk-cdn.com/20160522/73c5fcbd3a356a0653929a9eeb8b8084.jpg
http://uploads.tapatalk-cdn.com/20160522/0d9a5c471d8bab50fa99bbde55735f93.jpg
Edited by alextrela
Καλησπέρα.θα ηθελα να κανω μια ερωτηση.εχω ενα tablet dual boot στο οποίο το κινεζικά .πβς μπορουμε να αλλακοθμε την φως στα συστήματος ετσι ώστε να το αλλάξω.ευχαρισρω
Υπογραφή εκτός Ο.Π.Χ.
Δεν ξέρω αν πρέπει να ρωτήσω εδώ μέσα, έχω ένα asus vivo tab 8 και έχω την εξής απορία: Στην εφαρμογή Χάρτες (χρήσιμη σε μένα μιας και το tablet έχει gps) βρίσκει κανονικά τις οδούς όμως κάθε φορά που ξεκινάνε οι οδηγίες μου γράφει cannot download voice και δεν έχω φωνητικές οδηγίες, μόνο από τον χάρτη βλέπω για το πως θα πάω...κάνω κάτι λάθος; Δεν έχει υποστήριξη για οδηγίες στα Ελληνικά; Είναι πολύ σημαντικό για μένα αυτό με την πλοήγηση και ήταν ένας από τους λόγους που πήρα το συγκεκριμένο οπότε θα εκτιμούσα πολύ την όποια βοήθειά σας. Ευχαριστώ εκ των προτέρων.
Take a look at Plex's universal Windows 10 app
http://www.windowscentral.com/sites/wpcentral.com/files/styles/larger/public/field/image/2016/06/plex-windows-10-2.jpg?itok=5wR8IuEh
http://www.windowscentral.com/sites/wpcentral.com/files/styles/larger/public/field/image/2016/06/plex-windows-10-1.jpg?itok=0Djs25jE
http://www.windowscentral.com/sites/wpcentral.com/files/styles/larger/public/field/image/2016/06/plex-windows-10-6.jpg?itok=Zsyj1OPs
http://www.windowscentral.com/sites/wpcentral.com/files/styles/larger/public/field/image/2016/06/plex-windows-10-8.jpg?itok=Q6O1vMyk
Autodesk SketchBook is an professional grade drawing app for Windows 10
http://mspoweruser.com/autodesk-sketchbook-professional-grade-drawing-app-windows-10/
The app features:
Natural drawing experience, easy to learn toolset, and clean interface designed to maximize your drawing space
Canvas sizes up to 10,000 by 10,000
Unlimited undo stack – undo back to your first brush stroke
Brush and color controls that collapse into convenient pucks for instant access
SketchBook includes a free mode with one layer and a limited toolset. Autodesk also sells a SketchBook Pro subscription which delivers the ability to use SketchBook on any device for as long as your subscription is active. If you buy it in the Windows Store, and your SketchBook account will unlock all Pro tools on all your other devices.
Sketchbook Pro delivers:
Unlimited layers (Pro exclusive)
Over 140 preset brushes (Pro exclusive)
Fill tool with solid, linear gradient, and radial gradient fill (Pro exclusive)
Ruler and symmetry tools, including X and Y axis symmetry (Pro exclusive)
All new Stroke Stabilizer tool for perfectly smooth lines, even when your lines are less than perfect (Pro exclusive)
Access all Pro features across all your devices (Pro exclusive)
https://www.youtube.com/watch?v=HlS1sYNBcCo
http://uploads.tapatalk-cdn.com/20160626/4aaa5b98fb750caf21239d99a80bcc77.jpg
καλημερα σας
θα ηθελα να κανω μια ερωτηση.εχω ενα tablet το οποιο εχει μεσα διπλο λειτουργικο android και windows.στο android οταν μπαινω στο playstore μου γραφει σφαλμα με τον διακομιστη παρολο που ειμαι συνδεδεμενος με το wifi.οταν μαπινω στα windows ειναι ολα στα κινεζικα και δεν μπορω να αλλαξω γλωσσα.οταν ζηταω να κανω και αναβαθμιση μου λεει οτι δεν υπαρχουν windows στην συσκευη.λογικα θα ειναι το λειτουργικο μια απλη εκδοση των windows γιατι οταν παω να κατεβασω πακετα γλωσσων κτλ για να κανω την αλλαγη δεν υπαρχει πουθενα αυτη η εντολη.μπορει καποιος εαν ξερει να με βοηθησει?ευχαριστω
καλημερα σας
Όλες τις γλώσσες υποστηρίζουν τα Windows εφόσον πρόκειται για αυθεντική έκδοση τους.
http://www.howtogeek.com/232659/how-to-change-the-display-language-in-windows-10/
Τώρα οι Κινέζοι τι είδους έκδοση βάζουν δεν εχω εμπειρία.
Edited by alextrela
  • 1 month later...
Δωρεάν η παρακάτω πολυ αξιόλογη εφαρμογη για 2 ημέρες ακόμα.
MyScript brings their amazing pen-based note-taking app to Windows 10 and the Surface
http://mspoweruser.com/script-brings-amazing-pen-based-note-taking-app-windows-10-surface/
https://www.microsoft.com/en-us/store/p/nebo/9nblggh4nlb0
Features
-Edit and format with your active pen – Interactive Ink allows you to write, insert or remove content and space, decorate and apply styles, using only your pen.
-Add rich content – draw interactive diagrams with elements that you can edit, delete and move around. Write editable equations; get calculated results or conversion to LaTeX.
-Draw freeform sketches, and annotate pictures.
-Export to Microsoft Word – handwritten notes can be exported to Word or sent via email. Headings, paragraphs, list, color, bold, highlight, are all preserved.
-Smart layout – canvas is unlimited, blocks are resizable and ink will adjust to new size and device orientation.
-Search – search and find handwritten ink and text in your note, including in your diagrams.
-Store your notes – organize your notes in pages, notebooks and folders. Export or import your notebooks.
http://uploads.tapatalk-cdn.com/20160829/595693064e6b9feae68b4ed120cd5ada.jpg
Μέχρι 30/9 η προσφορά σύμφωνα με το store.
(σχεδόν) πάντα φιλικά, Αλέξης
Ναι μάλλον ανανεώθηκε διότι προχθές έγραφε για 2 ημέρες οταν το έγραψα.
Kodi comes to the Windows Store for Windows 10 PCs
https://mspoweruser.com/kodi-comes-windows-store-windows-10-pcs/
Kodi today released its new app for Windows 10 PCs on the Windows Store. In a blog post, Kodi’s CFO, Martijn Kaijser stated that the company is using Centennial (aka Desktop App Converter) to bring its classic Win32 app to the Windows Store.
http://uploads.tapatalk-cdn.com/20160921/d8e2bcc023dcd234f7a84f2cf69ac19a.jpg
Προσθετω το link απο το store και να αναφερω οτι ειναι σε BETA φαση ακομη και συμφωνα με αναφορες ,δουλευουν για να γινει διαθεσιμο και σε xbox&mobile.
Kodi
apps.46982.13510798887593391.e1d9d6a5-a4ff-47ab-b9c9-935a218327ef.898b30ef-0fa2-4e71-a7a1-3988e483016e?w=1399&h=787&q=60
apps.51413.13510798887593391.ec1c47f4-6679-40d4-94fd-06877ae3b92a.fd35adca-9ed0-4c14-b14f-f7eb76125aed?w=1399&h=787&q=60
apps.45389.13510798887593391.26f1b5d4-a0a1-4c78-87cc-ddd1a2afcaaa.dafeb76f-7e18-4364-83b6-7dc64cabd691?w=1399&h=787&q=60
apps.49040.13510798887593391.a3a5601c-e852-41a6-a87e-42de7901a7a2.18588dfa-93b8-44cc-b57f-22f8e07f0102?w=1399&h=787&q=60
apps.30718.13510798887593391.6806a653-65ad-43ad-a57e-5ed2c4f00458.583613b3-93a0-417d-bd0e-8018036ad99e?w=1399&h=787&q=60
  • 1 month later...
Σχετικά με το Nebo, μετά από μια μικρή δοκιμή, να προσθέσω ότι είναι μέχρι στιγμής η καλύτερη λύση για αναγνώριση γραφής στα Win10. Όσοι έχουν active pen είναι αμαρτία να μην το χρησιμοποιούν. Δωρεάν μέχρι τέλος Οκτωβρίου.
Mobiles: Motorola Startac 85, Ericsson T18S, Nokia 7110, Nokia 6210, Siemens SL42, Siemens SX1, Sony Ericsson W800i, Motorola SLVR L7, Nokia 6300, Nokia E71, Nokia 5230, Motorola Fire XT311, Alcatel 997D, Sony Xperia Z Ultra, Motorola E4 plus
Έχει μόνο αγγλικά όμως.
Έχει και ελληνικά και αρκετές ακόμα γλώσσες. Άλλωστε σε παλαιότερες εκδόσεις windows οι εφαρμογές της Myscript ήταν η μόνη σχετικά αξιόπιστη λύση για αναγνώριση ελληνικής γραφής. Ψάχνουμε λίγο πριν γράψουμε.
Την έχω εδώ και παρα πολυ καιρό αλλα ελληνικά δεν βρήκα. Δώσε ένα link μήπως έχω κάποια άλλη εφαρμογή (αν και το αποκλείω).
