Mozilla Firefox - The «Ultimate» thread
eLeKtriK EyE
εχω μια απορια εδω και μερικες μερες που εβαλα την 4 (RC) και τωρα την τελικη (λογικα)!
οταν εχω μερικες καρτελες ανοιχτες και θελω να κλεισω την αλεπου,για οποιονδηποτε λογο...δεν με ρωταει για αποθηκευση των καρτελων.... απλα με ρωταει οτι προκειτε να κλεισετε πολλες καρτελες....!
εχω και το Addon Tabmix plus αλλα δεν εχω δει καμια ρυθμισει εκει ...!!
εψαξα στις ρυθμισεις παντου...δεν βρηκα κατι ..!
απο την 3.6 που το ειχα..και εκανα αναβαθμιση στην 4...δεν λειτουργει...!
καμια ιδεα..?!
Samsung Galaxy S8 plus
Samsung Galaxy S7 Edge
Samsung Galaxy Alpha
Samsung TV ue55h6800 Curved
Samsung Watch Gear
Mozilla has released Firefox 4. The final build comes less than two weeks after Release Candidate 1. The company originally found no major problems in the RC1 build, and decided to release RC1 as the final version, but then changed its mind. An RC2 build was quietly pushed out on March 18, 2011 with a few fixes, and today the final bits appeared on Mozilla's servers.
If you're already running a previous build of Firefox 4 you should see an automatic update starting tomorrow. Alternatively, you can download the final build directly for Windows, Mac OS X, and Linux 32-bit/64-bit. The final version supports 83 languages.
Mozilla is letting users update Firefox versions 3.5 and 3.6 to 4.0 without the need to navigate to a download page. Firefox 4.0 was supposed to be released tomorrow, and while the download links are up, we expect that the official launch will be announced in the next 24 hours. For more information on what's changed throughout the development of version 4.0, check out the release notes.
Mozilla was originally planning on having Firefox 4 out by the end of last year, but it has had to delay the release multiple times. The company has fixed more than 7,000 bugs in the 12 betas and a few more in the two RC builds.
Mozilla has been struggling to get Firefox 4.0 out the door. As a result, the company has announced that in 2011, not only will we see Firefox 4.0, but we will also see Firefox 5.0, Firefox 6.0, and Firefox 7.0. The first 5.0 builds are already in the making; the next version is targeted for a late June 2011 release.
πατα ctrl+T
Ούτε κι έτσι ανοίγει νέα καρτέλα. Τελικά το έψαξα λίγο και εγκατέστησα το tab mix plus. Τώρα ανοίγει κανονικά!
καμια ιδεα..?!
νομιζω οτι ειναι επειδη εχεις και αλλο παραθυρο με την αλεπου ανοικτο :)
Learn Colemak, the better keyboard layout! :happy:
Μην αφήνεις τα μικρά μυαλά να σε πείσουν ότι τα όνειρα σου είναι πολύ μεγάλα.
To εικονίδιο του New Tab που το βρίσκει κανείς με δεξί κλικ δίπλα στο μενού και κατόπιν επιλέγοντας customize δεν υπάρχει πλέον; Βρίσκω το New Window αλλά όχι το tab.
Στο μενού δίπλα από τη λέξη File υπάρχει ένα λευκό τετραγωνάκι με μια μαύρη κουκίδα εντός. Τί στο καλό είναι αυτό;
Τελικα μολις το βρηκα..!
επιλογες Tabmix Plus -> Συνεδρια
με ειχε ξεφυγει αυτο το σημειο...!
:):p
Samsung Watch Gear
για ριξε ενα σκρινσοτ να καταλαβω τι λες:)
στο default theme δεν υπάρχει τέτοιο ''τετραγωνάκι''....παίζει να είναι bugάκι του theme..;)
και γω χωρις θεματα, κλπ δε βλεπω κατι.
Ευχαριστώ!
με τον 4 τα add ons flashgot,tab mix plus adblock plus ειναι συμβατα η να περιμενω?
adblock είναι οκ. Για τα άλλα δεν ξέρω οπότε ας το επιβεβαιώσει κάποιος άλλος. :)
Εξαιρετικός ο FF4. Έχει καλύψει σχεδόν όλες τις ελλείψεις του σε σχέση με τον Chrome ενώ έχει και 2-3 πραγματάκια επιπλέον (app tabs, panorama) που δεν είναι τρομερά αλλά βολεύουν αρκετά.
-Candygram.
-Candygram, my foot. You get out of here before I call the police. You're the shark, and you know it.
-Wait. I-I'm only a dolphin, ma'am.
Don't you mean Chromezilla 4??
:rolleyes:
"Our lives are not our own.
From womb to tomb, we are bound to others, past and present.
And by each crime and every kindness, we birth our future."
η αλεπού είναι μακράν ο αγαπημένος μου browser εδώ και πολλά χρόνια. Αλλά τον τελευταίο καιρό με είχαν κερδίσει ο opera και ο chrome κυρίως λόγω της πιο γρήγορης ανταπόκρισής τους και της μεγαλύτερης ελεύθερης επιφάνειάς τους σε σχέση με παλιότερες εκδόσεις της αλεπούς.
Σήμερα κατέβασα το 4, το χρησιμοποιώ απροβλημάτιστα εδώ και 3 ωρίτσες περίπου, το ζόρισα επίτηδες με flash και κάμποσα tabs ανοιχτά αλλά πάει καλά. φτου φτου. έγινε default και ελπίζω να μη με απογοητεύσει :/
χμμ...περίεργο..το ίδιο μου συμβαίνει στο σπίτι, αλλά όχι στο γραφείο, όπου το new tab φαίνεται κανονικά...:confused:
πολλοί επίσης έχουν θέμα με το κουμπάκι των bookmarks...δοκιμάζω ένα restore defaults στο παράθυρο του customize και επανέρχομαι...
edit:μπααα...τζίφος...new tab button is nowhere...:worry:
Edited by Nikos_s3
To βρήκα Νίκο. Όταν πατήσεις στο customize τότε θα δεις την μπάρα του firefox να αλλάζει. Αν μετακινήσεις το παράθυρο του customize πιο κάτω τότε στο κάτω δεξί μέρος της μπάρας θα δεις το κουμπάκι του new tab. Σύρε εκεί που θες και είσαι οκ.
http://www.myphone.gr/gallery/data/500/thumbs/ff2.jpg
καλα... δεν παιζεσαι!!!
ωραιος!
:rolleyes:
looool...thaaaanks mate...:up:
γιατί όμως εμένα κάτι μου λέει ότι στην 3.6.* είχα και το κουμπάκι ''new tab'' και το ''+'' στο τέλος του tab bar? :worry:
παιδια, αντιμετωπιζω ενα προβλημα.
σε ασχετες στιγμες και οταν κανω διπλο κλικ ή παταω τη ροδελα του ποντικιου, μου ανοιγει σε νεο tab μια ιστοσελιδα για φθηνες πτησεις, ξενοδοχεια, κλπ.
εχω σκαναρει με τα παντα και δε βρεθηκε προβλημα.
λετε να ναι καμια ρυθμιση στον forefox?
Στον 4.0 εβγαλαν την επιλογη να κανεις μονος σου ελεγχο για update? Στην "Βοηθεια" το ειχαν οι παλαιοτερες εκδοσεις, τωρα δεν το βρισκω.
Πάρε τηλέφωνο τη μοναξιά σου, ή βγες ξανά στο δρόμο της φωτιάς!!
Κάθε φορά που ανοίγεις τη Βοήθεια, ο Mozilla κάνει από μόνος του έλεγχο για ενημερώσεις. Αυτό τουλάχιστον έχω καταλάβει.
Σου τα' δωσα όλα όχι όμως και το θάνατό μου. Αυτό άσε με να το κρατήσω εγώ.
http://img412.imageshack.us/img412/1559/28923n.gif
Καλό Πάσχα!
νομιζω ειναι καποιο malware :worry:
