azuli Δημ. June 19, 2016 Δημ. June 19, 2016 (edited) rr 5.7.0 http://forum.xda-developers.com/a310/development/rom-resurrection-remix-5-7-0-micromax-t3401640 λογικα θα εχει ψιλοσταθερα data, εχει βαση την cm r46 και το gps θα δουλευει.Παιζει να ναι καλη θα την τσεκαρω το βραδυ ResurrectionRemix - v5.7.0 - 2016-06-16 The Changelog - Android Update 6.0.1_r43-> 6.0.1_r46 - Android N style "No recents" activity - Add animations to quick settings tiles - Add interpolators to qs tiles animation - Add new bunch of alpha and smart layer headers - Add per app controls for LP keyguard notifications - Remove LightStatusbar dark icon mode & make statusbar gradient - Configurable LockClock & Date Text Sizes - Improve some headers - BatteryService: Fully charged notification toggle - Visualizer: Let visualizer fill the entire available screen - Only show keyguard panel if on lockscreen + no activity on top - Update sb headset vector - Update keyguard weather layout - SystemUI: fix NPE when configuring blur layer - SystemUI: fix multi touch gestures and extra jank - SysUI: Simplify Code for Battery Icon Tint - SysUI:Fix a Recents Styles Default - SysUI: Fix SystemUI Crash on Notification Guts Media - Don't lookup application keyguard notification visibility unnecessarily - SystemUI: Add support for persistent usb drive notification. - SysUI: Fix Secure Lockscreen Pulldown Switch - SystemUI: fix NFC tile sometimes hiding - Fix possibility of slim recents icon fc - Fix a glitch causing shadow not to be reset when header disabled - DocumentsUI : Hide advanced menu option when in forced mode - SystemUI: fix one more misbehaving shadow - Settings: Update performance settings icon - Settings:Disable Weather Provider By Default - Settings : Fix dashboard colors default and reset values - Recovery : Update RR script banner - Themes : Update statusbar notify icon - SmartBar: Add app picker as an action - Give Pulse & Fling a Little CPU boost - Pulse:imrpove Reset Logic - Update Translations - All updates from CM - Bugfixes and improvements ----- προσθήκη μηνύματος 3 λεπτά μετά την υποβολή του προηγούμενου ----- Με μία sim vodafone και δεν βλέπει sim ούτε σε μενα περιεργη φαση.Ισως φταινε οι sim.. εγω ειμαι με wind (data μονο) και Q (κλησεις,sms) και δεν ειχα προβλημα σε καμια Edited June 19, 2016 by azuli Παράθεση
markosch Δημ. June 19, 2016 Δημ. June 19, 2016 Πέρασα Lg ρομ και το τηλέφωνο είναι λειτουργικότατο απλώς καμιά φορά μου κάνει νέρα το wifi ελάχστες φορές. ίσως θέλει ξανά πέρασμα.μήπως θέλει το wifi fix zip? γιατί στο wifi βλέπω nvram κλπ... πάντως είναι πολύ βολική και πολύ εύχρηστη από άλλες ρομ που έχω flasarei. Και η snap camera εβγαλα φωτό σε μια εκδήλωση που πήγα και από 50 μέτρα απόσταση τα πρόσωπα φαινονταν καθαρά.... χωρίς zoom έβγαλα. από το zoom στο pc φαινότανε καθαρό.με zoom δεν δοκίμασα αλλά τώρα με αυτήν την ρομ είμαι ικανοποιημένος. ένα θέμα μου είναι όταν είμαι σε airplane mode. δεν με αφήνει να ανόιξω το wifi με τπτ. Παράθεση [sIGPIC][/sIGPIC]
jpower73 Δημ. June 19, 2016 Δημ. June 19, 2016 Και οι νέες xosp και pacman, δεν βλέπουν σιμς. Δοκίμασα όλους τους πιθανούς συνδυασμούς. Φλασαρα και ξεφλασαρα πάνω από 20 φορές το τηλέφωνο, ώστε να εντοπίσω που είναι το πρόβλημα και να ενημερώσω για το τι φταίει ... Δοκίμασα με μια κάρτα vf και με 2 καρτες wind kai vf Δυστυχώς, τίποτα. Δοκίμασα με 3 διαφορετικα ρικοβερι, με φορμαρισμένη ιντερναλ και φορμαρισμένη κάρτα 2gb που είχε μόνο την ρομ, γκαπς, πατς.... Ελπίζω η rr 570 να μην έχει θέμα ----- προσθήκη μηνύματος 3 λεπτά μετά την υποβολή του προηγούμενου ----- Και η snap camera εβγαλα φωτό σε μια εκδήλωση που πήγα και από 50 μέτρα απόσταση τα πρόσωπα φαινονταν καθαρά.... χωρίς zoom έβγαλα. . Στο είπα... Θα με θυμηθείς.. ;) Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
rantosp Δημ. June 19, 2016 Δημ. June 19, 2016 Και οι νέες xosp και pacman, δεν βλέπουν σιμς. Δοκίμασα όλους τους πιθανούς συνδυασμούς. Φλασαρα και ξεφλασαρα πάνω από 20 φορές το τηλέφωνο, ώστε να εντοπίσω που είναι το πρόβλημα και να ενημερώσω για το τι φταίει ... Δοκίμασα με μια κάρτα vf και με 2 καρτες wind kai vf Δυστυχώς, τίποτα. Δοκίμασα με 3 διαφορετικα ρικοβερι, με φορμαρισμένη ιντερναλ και φορμαρισμένη κάρτα 2gb που είχε μόνο την ρομ, γκαπς, πατς.... Ελπίζω η rr 570 να μην έχει θέμα ----- προσθήκη μηνύματος 3 λεπτά μετά την υποβολή του προηγούμενου ----- Στο είπα... Θα με θυμηθείς.. ;) Το ίδιο πρόβλημα και με αυτή στην sim... μήπως φταίνε τα πατσακια για a310? Παράθεση
azuli Δημ. June 19, 2016 Δημ. June 19, 2016 για να παρουμε backup με titanium στην εξωτερικη αν βγαζει fail (σε marshmallow) Δουλευει. Παράθεση
azuli Δημ. June 19, 2016 Δημ. June 19, 2016 (edited) Οσοι εχετε προβλημα με τις sim δοκιμαστε να βαλετε ενα cpb με ygdp/flashtool αμεσως πριν το φλασαρισμα της mm που θελετε να βαλετε,να καθαρισετε το τηλεφωνο σας.(και ολα τα wipes κανονικα μετα πριν το φλασαρισμα της mm εννοειται) Μονο τοτε θα ειστε σιγουροι αν ειναι θεμα καρτας sim/παροχου η οχι. Μολις εβαλα την νεα rr,κανονικα τις βλεπω τις καρτες και εδω.Περισσοτερα later Edited June 19, 2016 by azuli Παράθεση
jpower73 Δημ. June 19, 2016 Δημ. June 19, 2016 Το ίδιο πρόβλημα και με αυτή στην sim... μήπως φταίνε τα πατσακια για a310? Κι αυτό το τσέκαρα... Τίποτα..... Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
azuli Δημ. June 19, 2016 Δημ. June 19, 2016 Κι αυτό το τσέκαρα... Τίποτα..... εγω βρηκα κατι αλλο ομως. Ο τυπος που ανεβασε την νεα rr δεν ανεβασε a310 patch και προτεινε αυτο της προηγουμενης rr. Πηγα να το δοκιμασω λιγη ωρα αφου ειχα βαλει την rr και ω!Πανε οι sim για παντα! Επρεπε να ξαναφλασαρω απο την αρχη για να τις ξαναδω. Το εκανα 3 φορες για να μαι σιγουρος,και στις 3 οποτε φλασαρα το patch εχανε τις sim. Οποτε (στην συγκεκριμενη περιπτωση τουλαχιστον) εφταιγε το λαθος patch.Πρεπει καθε φορα να εχει φτιαχτει για την συγκεκριμενη rom,δεν ειναι universal. Oποτε μηπως εσεις που εχετε θεμα φλασαρετε λαθος a310 patch? Eπισης δεν θελει φλασαρισμα καπακι με την rom και τα open gapps αλλα μονο του μετα απο 1-2 reboot τουλαχιστον. ----- προσθήκη μηνύματος 41 δευτ. μετά την υποβολή του προηγούμενου ----- Το ίδιο πρόβλημα και με αυτή στην sim... μήπως φταίνε τα πατσακια για a310? μαλλον μεσα εισαι. Παράθεση
jpower73 Δημ. June 19, 2016 Δημ. June 19, 2016 (edited) Έχω δοκιμάσει κσι χωρίς πατς. Τιποτα.... Πάντως, υποπτεύομαι κι εγω ότι εκεί είναι το πρόβλημα. Διότι από ένα τσεκ που εκανα στα ζιπ των ρομ, δεν βρήκα κάτι που να δείχνει διαφορά. Εκτός κι αν είναι κάτι μέσα στο Framework οπότε θέλει ψάξιμο... Rantosp, Δοκίμασε να Φλασαρεις την RESSURECTION REMIX 570 ή την Pac-Man και μετά τα γκαπς, κάνε ριμπουτ σε ρικοβερι και Φλασαρε το a310 patch από την cm13.... Αν δεις σιμ, πες μας.... Τοτε, λύθηκε το πρόβλημα... :D Πάντως, δε κάθε περίπτωση, είναι περίεργο, να εμφανίζεται σε κάποια τηλέφωνα και σε άλλα όχι... Θα συμπληρώσω οτι την cm13, την Φλασαρω με philz και όλα τα σχετικά νε την μια. Δλδ, ρομ, γκαπς, πατς, gionee patch ... No problem... . Edited June 19, 2016 by jpower73 Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
azuli Δημ. June 19, 2016 Δημ. June 19, 2016 παντως εγω που δεν ειχα ποτε προβλημα με τις sim στις cm13 based roms,με το που φλασαρα patch που δεν εκανε εξαφανιστηκαν οι sim. Εκτος κι αν παιζει τετοια τρελη συμπτωση,νομιζω οτι το προβλημα εκει μαλλον ειναι.Τουλαχιστον το συγκεκριμενο patch που ηταν για παλιοτερη rr αυτο μου εκανε,και μαλιστα εκανα την διαδικασια 3 φορες για να σιγουρευτω οτι αυτο φταιει,και αυτο εφταιγε. Για να σιγουρευτεις οτι δεν σου δημιουργει θεμα καποια σαβουρα απο παλιοτερα φλασαρισματα,αν εχεις δυνατοτητα βαλε ενα cpb πρωτα και μετα την rom Παράθεση
jpower73 Δημ. June 19, 2016 Δημ. June 19, 2016 Αζουλι, δεν θα μπριζωσω το τηλέφωνο.. Με αυτα που διαβάζω τελευταία, προτιμώ νσ το αποφυγω.... Θα δοκιμάσω, αργότερα, αυτό που έγραψα πριν.... Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
azuli Δημ. June 19, 2016 Δημ. June 19, 2016 no problem.. Προσπαθω να βοηθησω με καποιες ιδεες να βρουν ακρη οσοι εχουν προβλημα με την εγκατασταση. Τα τηλεφωνα μας ειναι ιδια,αυτο που διαφερει ειναι ο τροπος που βαζει ο καθενας την rom πιστευω. Παράθεση
jpower73 Δημ. June 19, 2016 Δημ. June 19, 2016 Το a310 patch της cm13 r46, δεν είναι συμβατό με xosp + Pac-Man. Οπότε, δεν ισχύει αυτό που έγραψα... .. . Ok, man Πάντως, όσο διαφορετικός και να ναι, εχω καλύψει όλες τις περιπτώσεις, όλους τους πιθανούς συνδυασμούς. Αύριο θα κατεβάσω την 570, και θα την τεστάρω. Έστω και χωρίς πατς. Αρκεί να δει κάρτες.... Προς το παρόν, ξαναγυρθσα σε ένα nandroid της LG G3... Πολύ ωραία ρομ..... :happy: Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
mindtrapper Δημ. June 20, 2016 Δημ. June 20, 2016 Κάνετε dismount τα data και system partition πριν φλασάρετε ή μπα; :) Παράθεση
georgeIII Δημ. June 20, 2016 Δημ. June 20, 2016 Κάνετε dismount τα data και system partition πριν φλασάρετε ή μπα; :) Δεν έχω διαβάσει κάπου να λέει ότι χρειάζεται Παράθεση
mindtrapper Δημ. June 20, 2016 Δημ. June 20, 2016 Λέω να το δοκιμάσουν όσοι έχουν πρόβλημα με τις sim. Παράθεση
jpower73 Δημ. June 20, 2016 Δημ. June 20, 2016 Το χω δοκιμάσει κι αυτό.. Όλους τους συνδυασμούς mount Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
savvas_p25 Δημ. June 20, 2016 Δημ. June 20, 2016 Το χω δοκιμάσει κι αυτό.. Όλους τους συνδυασμούς mount Δοκιμασες την καινούργια RR; Παράθεση
jpower73 Δημ. June 20, 2016 Δημ. June 20, 2016 Όχι ακόμη.... Είμαι εκτός... ... Έτσι μου ρχεται να ανεβάσω την ν2 της LG G3... :mad: Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
savvas_p25 Δημ. June 20, 2016 Δημ. June 20, 2016 Όχι ακόμη.... Είμαι εκτός... ... Έτσι μου ρχεται να ανεβάσω την ν2 της LG G3... :mad: Και δεν την ανεβαζεις;πριν λίγο διάβαζα γνωστό ρωσσικό φόρουμ και έγραφαν για την cool ui που είχες ανεβάσει! Παράθεση
jpower73 Δημ. June 20, 2016 Δημ. June 20, 2016 Για ααααα, δώσε λινκ, να δω τι λένε....;) Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
savvas_p25 Δημ. June 20, 2016 Δημ. June 20, 2016 Για ααααα, δώσε λινκ, να δω τι λένε....;) http://4pda.ru/forum/index.php?showtopic=535435&st=880#entry32009915 Παράθεση
ObiGoSu Δημ. June 20, 2016 Δημ. June 20, 2016 Καλησπέρα. Μια ερώτηση: Είμαι με CM 12.1 και εδώ και λίγο καιρό, το τηλέφωνο κλείνει στο 40% της μπαταρίας ανεξαρτήτου χρήσης. Με το που το βάζω να φορτίσει μου δείχνει ότι ξεκινάει να φορτίζει από 0%. Έχει γίνει calibrate. Αρχίζει να με αποχαιρετά η μπαταρία? Ή να δοκιμάσω καμιά αλλαγή rom? Καμία ιδέα παίδες? Παράθεση
jpower73 Δημ. June 20, 2016 Δημ. June 20, 2016 (edited) http://4pda.ru/forum/index.php?showtopic=535435&st=880#entry32009915 A , Είναι παλιά σχόλια.. Νόμιζα ότι μιλούσαν για το συγκεκριμένο upload Πάντως, αυτή που ανέβασα, είναι καθαρή.. ----- προσθήκη μηνύματος 67 δευτ. μετά την υποβολή του προηγούμενου ----- Καμία ιδέα παίδες? 99% μπαταρία... Αν δεν βαριέσαι, δοκίμασε και μία άλλη ρομ. Edited June 20, 2016 by jpower73 Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
