Coolpad F1 (8297W)
Πως μπορούμε να απελευθερώσουμε χώρο στη ρομ του συστήματος; (έτσι το λέει στο τιτανιουμ)
Το χασαμε το κορμι πατριωτη!!!! [sIGPIC][/sIGPIC]
  • Απαντήσεις 26,8χιλ.
  • jpower73
    3461
  • azuli
    1779
  • grgz
    1033
  • mixanikosgr
    890
Δεν χρειάζεται κατι τετοιο..
Γιατί να το κάνεις....?
Μπορείς να καθαρίσεις χώρο στην ιντερναλ....
Όπου συστεμ ρομ+διαθεσιμη ιντερναλ =8γιγα
Funtouch 1.32 by Xiaojie
http://bbs.ydss.cn/thread-567832-1-1.html
Link... http://pan.baidu.com/s/1qWwt6MS
Android version: 4.2
ROM writer: XIAOJIE
ROM number: Funtouch_VIVO1.32.0_
Based on the latest Funtouch_VIVO1.32.0_ production
Open full ROOT
Fix store
Fix camera
Pixel 1300W
Compiling the minimum brightness ...
Fix icon sizes
Boot if you apply theme
Coolui 4.4.046
Android version: 4.4
ROM writer: qianmo
Introduction to ROM features: Cool God F1 China Unicom (8297W) lock screen theme hack speed calls the status bar Flash Viper audio
Based on the latest official version
Add a perfect Root permissions,
Add speed display
Adding screen lock
Add advanced power management to quickly reboot the phone
Add screen Assistant features, desktop with one hand, place the bottom of the screen three buttons
Add lightning flash lights, phone text messages, Flash tips
Added Viper, sound effects, perfect sound, top-quality driven
Add XX c rack, premium theme download
Screened official advertising push service
Streamline desktop database, remove the remaining icons
Moderate streamlining the APK system application, remove useless SO run file
Improving global touch response
Increase the sensitivity screen slide
Optimized desktop responsiveness
Open kernel support init.d
Optimize memory management increases stability
Optimal standby high frequencies and reduce standby power consumption
WiFi optimization improve the acceptance rate
Improve video quality enhance the photo effect
Open GPU rendering
Battery performance optimization
http://bbs.ydss.cn/thread-592115-1-1.html
D/l link....
http://pan.baidu.com/s/1dDyjmKT
Edited by jpower73
CoolPad F1 :D
Redmi Note 9 Pro 6-128
Επειδή μου λέει ότι έχω free μόνο 15.9mb.λιγα δεν είναι;
Αδιάφορα είναι... Το σύστημα δεσμευσε αυτα που ήθελε και τέλος...
Δεν πρόκειται να αλλάξει κατι στην ιντερναλ αυτο το στοιχειο.
Σε μενα με εμυι αφήνει 48,2 μβ ελεύθερα.
Αν πάλι θες να το αυξήσεις, με τιτανιουμ, διεγραψε system apps.. Με προσοχή, όμως...
* επι παραδειγματι, μόλις διεγραψα την εφαρμογη συστήματος huawei pay. System rom =51,2mb
Δεν κερδισα κάτι σε ιντερναλ.
Η μοναδική περίπτωση που ισως θα σου χρειαζοταν, ειναι να σπρωξεις στο συστημα εφαρμογες χρήστη.
Π.χ. να μετατρέψεις την lenovo camera απο απλή εφαρμογή, σε εφαρμογή συστηματος
Edited by jpower73
CoolPad F1 :D
Έλεγα μήπως επιβραδύνει το τηλέφωνο και τις λειτουργίες γενικότερα, αλλά αφού δεν επηρεάζει, Οκ. Ίσως διαγράψω μόνο κάποια system apps που έχω απ την αρχή παγώσει
της εριξα μια ματια δεν εχει ελληνικα θελει gapps εχει αρκετες κινεζιες καλος ηχος με dolby atmos νομιζω δεν αξιζει περισοτερα
aosp 4.4.2 αρα δεν είναι lollipop στρωτη είναι μεχρι τωρα εχει αρκετα καλούδια είναι root δεν εχει κινεζικα εχει nova launser καλη φενεται αν και είναι νωρις δεν λειπει κατι βασικο.......βλεπουμε
το λινκ είναι google drive
απο τα screenshot μοιαζει με lollipop παντως
Mystic os http://pan.baidu.com/wap/link?uk=1730917217&shareid=3946212223&third=0
Την δοκίμασε κανένας?
φρανκεσταιν κι αυτη
----- προσθήκη μηνύματος 63 δευτ. μετά την υποβολή του προηγούμενου -----
http://www.movilesdualsim.com/tema/android-l-mod-material_reloaded.94174/ εδώ βρήκα κατά τύχη μια aosp εξευγενισμένη την παλευω θα ενημερωσω
ενδιαφερουσα μονο για το λογο οτι ειναι βασισμενη σε maucat
τωρα που είμαι ζεστος την εβαλα και αυτή είναι μια aosp που μοιαζει εκπληκτικα με την προηγουμενη που δοκιμασα από το ισπανικο σιτε είναι λιγο ποι φτωχη σε εφαρμογες θελει gapps εχει αρκετα κινεζικα φευγουν όμως ευκολα και σε αυτή δεν φενεται να λειπει κατι βασικο συνεχιζω το ψαξιμο θα επανελθω μαλλον αυριο εχει και μπαλαα
Καλησπερα στα παιδια του φορουμ.Αρχικα να ευχαριατησω τον κουςκους που φροντιζει και ανεβαζει καθε εβδομάδα updates απο μιυι.τρομερη ρομ και σταθερη.εχουν επιλυθει τα θεματα με το σημα 100%.την εχω πανω στο κινητο κανα 2 μηνες απροβληματιστα.Επισης σκεφτομαι να παρω σετ οθονης.τι κου προτεινεται να παρω(δωστε λινκ) και αν καποιος βαζει οθονες απο εδω ας ενημερωσει γιατι δεν εχω ιδεα.Ευχαριστω εκ των προτερων.
Τι εννοείς, ότι θέλεις να αλλάξεις οθόνη;
Για κάποιο λόγο, και στο προηγούμενο update αλλά και σε αυτό δεν μπορώ να αποθηκεύσω τις φωτογραφίες στην κάρτα μνήμης με καμμία εφαρμογή πέραν της default κάμερας.
Με την Lenovo Super Camera, αν αλλάξω τον φάκελο αποθήκευσης σε κάποιον του τηλεφώνου, δουλεύει. Στην LG Camera όμως, που αυτήν χρησιμοποιώ, δεν δουλεύει ούτε αυτό, γιατί δεν μπορεί να κρατήσει σαν φάκελο αποθήκευσης κάποιον άλλον πέραν του αρχικού που είχα.
Είχα μια εφαρμογή που μπορούσε να αποθηκεύσει το αρχείο apk από μια ήδη εγκατεστημένη εφαρμογή. Το θέμα είναι ότι την έχασα ξέρετε καμία να κάνει το ιδιο;
μπορουμε να κανουμε βιντεοκληση με την τελευταια maucat? εχει στις ρυθμισεις της καρτας σιμ αλλα οχι στον dialer
Μ'αρέσει που μερικοί ρωτάτε για κάποιες ρομ αν είναι kitkat ή lollipop. Πότε θα πάρετε χαμπάρι ότι δε θα βγει ΠΟΤΕ lollipop για την κουλπαντάρα;;; :lol:
apk extractor
