anna2 Δημ. December 10, 2013 Δημ. December 10, 2013 anna2 δοκίμασες τελικά για cwm? Δεν πέρασε ούτε με το SP Flash Tool. Έβγαλε error και σταμάτησε. Πάλι καλά που δεν μπρικαρίστηκε. Παράθεση Φιλικά.Γιώργος.
Chryssostomos Δημ. December 10, 2013 Δημ. December 10, 2013 (edited) Δεν πέρασε ούτε με το SP Flash Tool. Έβγαλε error και σταμάτησε. Πάλι καλά που δεν μπρικαρίστηκε. ύποπτο αυτό. Σχεδόν όλοι με flash tool το περνάνε...να δω τι θα κάνουμε. edit. μάλλον διορθωτικές οδηγίες για sp ft 1) Unzip all the packages that you have attached 2) Install the drivers ----> are in the folder labeled "SP_Drivers_V1.x" and you have to call them during the installation of the device 3) Turn off your phone and detach the battery 4) Run the program flash_tool.exe 5) Select the file and select SCARTTER_LOADING MT65xx_Android_scatter_emmc.txt (it's inside the folder CWM), select "FROM DL All With Checksum". 6) Press the button to download flash_tool -----> to me with the download button reported an error, I clicked firmware - Upgrade 7) Connect your phone (switched off and without battery) 8) wait has ended (the time required is around 5 minutes) 9) disconnect the phone and run it into recovery (hold down both volume up button + volume down key + power button until the logo appears on ignition Edited December 10, 2013 by Chryssostomos Παράθεση Xiaomi 12 Pro
anna2 Δημ. December 10, 2013 Δημ. December 10, 2013 ύποπτο αυτό. Σχεδόν όλοι με flash tool το περνάνε...να δω τι θα κάνουμε. edit. μάλλον διορθωτικές οδηγίες για sp ft 1) Unzip all the packages that you have attached 2) Install the drivers ----> are in the folder labeled "SP_Drivers_V1.x" and you have to call them during the installation of the device 3) Turn off your phone and detach the battery 4) Run the program flash_tool.exe 5) Select the file and select SCARTTER_LOADING MT65xx_Android_scatter_emmc.txt (it's inside the folder CWM), select "FROM DL All With Checksum". 6) Press the button to download flash_tool -----> to me with the download button reported an error, I clicked firmware - Upgrade 7) Connect your phone (switched off and without battery) 8) wait has ended (the time required is around 5 minutes) 9) disconnect the phone and run it into recovery (hold down both volume up button + volume down key + power button until the logo appears on ignition Το έκανα και με τον παραπάνω τρόπο. Δυστυχώς τζίφος. Παράθεση Φιλικά.Γιώργος.
Chryssostomos Δημ. December 10, 2013 Δημ. December 10, 2013 δε ξέρω τι να πω. βλέπω να μένουμε χωρίς cwm.... Παράθεση Xiaomi 12 Pro
Efthimis13 Δημ. December 11, 2013 Δημ. December 11, 2013 Παιδια καλημερα.... H ΕΛΤΑ λεει το εξης ΚΛΕΙΣΙΜΟ ΑΠΟ Κ.Δ.ΑΕΡΟΔΡΟΜΙΟΥ 10-12-2013 10:37 Κ.Δ.ΑΕΡΟΔΡΟΜΙΟΥ φανταζομαι λοιπον οτι σημερα το πρωι αν παω στην ΕΛΤΑ θα το εχω και γω στα χερια μου μετα απο 2 βδομαδες αναμονης... Ερωτηση 1η: Ποση ωρα πρεπει να το αφησω να κανει το 1ο φορτισμα??? Ερωτηση 2η: Βλεπω οτι στα προηγουμα σχολια αναφερεστε πολυ στο CWM και στις αποτυχημενες προσπαθειες να το βαλετε!!!Τι ακριβως ειναι το CWM???και γιατι ειναι τοσο σημαντικο να μπει? Ερωτηση 3η: Επειδη πολλα διαβαζω και δεν καταλαβαινω τα περισσοτερα...Συνοπτικα...Τι ενεργειες πρεπει να κανουμε για να "φτιαξουμε" το κινητο...? Απ οτι εχω καταλαβει εχουν κατεβασει πολλοι τη ρομ123 απ τη needrom... Tη βαζουμε αυτη....τι αλλο πρεπει να κανουμε? Ευχαριστω προκαταβολικα... Παράθεση
anna2 Δημ. December 11, 2013 Δημ. December 11, 2013 Firmware Upgrade δεν πάτησα..... Η συνέχεια απόψε το βράδυ. ClockWork Mod (CWM) είναι ένα custom recovery για συσκευές Android. Μας επιτρέπει να πάρουμε backup την τρέχουσα ROM της συσκευής μας και να την επαναφέρουμε αν κάτι πάει στραβά. Επίσης μας δίνει την δυνατότητα να φλασάρουμε στη συσκευή μας custom roms. Παράθεση Φιλικά.Γιώργος.
Chryssostomos Δημ. December 11, 2013 Δημ. December 11, 2013 Παιδια καλημερα.... H ΕΛΤΑ λεει το εξης ΚΛΕΙΣΙΜΟ ΑΠΟ Κ.Δ.ΑΕΡΟΔΡΟΜΙΟΥ 10-12-2013 10:37 Κ.Δ.ΑΕΡΟΔΡΟΜΙΟΥ φανταζομαι λοιπον οτι σημερα το πρωι αν παω στην ΕΛΤΑ θα το εχω και γω στα χερια μου μετα απο 2 βδομαδες αναμονης... Ερωτηση 1η: Ποση ωρα πρεπει να το αφησω να κανει το 1ο φορτισμα??? Ερωτηση 2η: Βλεπω οτι στα προηγουμα σχολια αναφερεστε πολυ στο CWM και στις αποτυχημενες προσπαθειες να το βαλετε!!!Τι ακριβως ειναι το CWM???και γιατι ειναι τοσο σημαντικο να μπει? Ερωτηση 3η: Επειδη πολλα διαβαζω και δεν καταλαβαινω τα περισσοτερα...Συνοπτικα...Τι ενεργειες πρεπει να κανουμε για να "φτιαξουμε" το κινητο...? Απ οτι εχω καταλαβει εχουν κατεβασει πολλοι τη ρομ123 απ τη needrom... Tη βαζουμε αυτη....τι αλλο πρεπει να κανουμε? Ευχαριστω προκαταβολικα... Δεν είναι ανάγκη να περάσεις cwm στο κινητό,αν δεν θέλεις να περάσεις μια custom rom. Αυτό γίνεται και με το SP Flash tool. Στη φόρτιση θα το αφήσεις κανονικά μέχρι να φορτίσει,δεν χρειάζεται παραπάνω. Αν θέλεις βάλε και την rom 123 απο το Needrom. Αυτά με λίγα λόγια. Παράθεση Xiaomi 12 Pro
anna2 Δημ. December 11, 2013 Δημ. December 11, 2013 Εσύ πότε το παραλαμβάνεις Χρυσσόστομε; Παράθεση Φιλικά.Γιώργος.
Chryssostomos Δημ. December 11, 2013 Δημ. December 11, 2013 Εσύ πότε το παραλαμβάνεις Χρυσσόστομε; Αύριο πρώτα ο θεός. Δε περνάει κάθε μέρα ο ταχυδρόμος οπότε συνήθως το παίρνω με μια μέρα καθυστέρηση. Παράθεση Xiaomi 12 Pro
anna2 Δημ. December 11, 2013 Δημ. December 11, 2013 Πήγαινε στα ΕΛΤΑ της περιοχής σου με το tracking number και ζήτα το εφ' όσον έχεις δει ότι βρίσκεται εκεί. Παράθεση Φιλικά.Γιώργος.
admen Δημ. December 11, 2013 Δημ. December 11, 2013 σε αυτη την ρομ εδω http://www.needrom.com/mobile/lenovo-a850-rom-s123-root-google-play/ υπαρχει μια recovery που περνιεται πανευκολα απ οτι διαβαζω με το Mobileuncle Tools που κατεβαζουμε απο το Google Play και μεσω αυτης της cwm φλασαρεται και αυτη η ρομ Παράθεση
Chryssostomos Δημ. December 11, 2013 Δημ. December 11, 2013 (edited) Πήγαινε στα ΕΛΤΑ της περιοχής σου με το tracking number και ζήτα το εφ' όσον έχεις δει ότι βρίσκεται εκεί. το ξέρω απλά,γράφει ότι είναι στο κέντρο διαλογής όχι στο κατάστημα. σε αυτη την ρομ εδω http://www.needrom.com/mobile/lenovo-a850-rom-s123-root-google-play/ υπαρχει μια recovery που περνιεται πανευκολα απ οτι διαβαζω με το Mobileuncle Tools που κατεβαζουμε απο το Google Play και μεσω αυτης της cwm φλασαρεται και αυτη η ρομ στην ουσία είναι το ίδιο αρχείο που έχω δώσει και εγώ. άντε να το πάρω να αρχίσω τα πειράματα. Edited December 11, 2013 by navi55 συνεχόμενα posts Παράθεση Xiaomi 12 Pro
PP6210 Δημ. December 11, 2013 Δημ. December 11, 2013 το ξέρω απλά,γράφει ότι είναι στο κέντρο διαλογής όχι στο κατάστημα. . μην πας πριν γράψει "προς παράδοση", το πιό πιθανό είνια να μην το βρίσκουν καν.... Παράθεση
Chryssostomos Δημ. December 11, 2013 Δημ. December 11, 2013 (edited) μην πας πριν γράψει "προς παράδοση", το πιό πιθανό είνια να μην το βρίσκουν καν.... Πήγα πριν λίγο και το πήρα απο το κέντρο διαλογής!!!:D έχω την εντύπωση ότι υποστηρίζει απο τη μάνα του την δυνατότητα να πάνε οι εφαρμογες στην SD. έχει 2 επιλογές: USB Storage SD Storage. Λοιπόν όντως anna2 δε κάνουν κάτι αυτά τα recovery,απλά στο γυρνάνε στο αγγλικό. Θα δοκιμάσω να το κάνω με έναν οδηγό απο εδώ:http://www.myphone.gr/forum/showthread.php?t=375197 μπας και γίνει τίποτα. Με την rom που μου ήρθε,έχει κανονικά την επιλογή να πηγαίνουν στην sd η κάρτα,άρα προς το παρών δεν την αλλάζω. Το κακό είναι πως πολλές απο τις εφαρμογές που δουλεύω,δεν πάνε έτσι κ αλλιώς στην sd. Μέχρι στιγμής όλα κομπλέ! Edited December 11, 2013 by Chryssostomos Παράθεση Xiaomi 12 Pro
anna2 Δημ. December 11, 2013 Δημ. December 11, 2013 Καλορίζικο Χρυσόστομε. Σε τι χρώμα το πήρες; Παράθεση Φιλικά.Γιώργος.
Chryssostomos Δημ. December 11, 2013 Δημ. December 11, 2013 Μαύρο το πήρα.Με κόκκινη θήκη Nilkin.Βέβαια το κόκκινο δεν είναι και τόσο αντρικό αλλά τι να κάνουμε... Δοκίμασα και με τον οδηγό που έχω βάλει παραπάνω,αλλά τζίφος.δε ξέρω αν κάνω κάτι λάθος. Παράθεση Xiaomi 12 Pro
anna2 Δημ. December 11, 2013 Δημ. December 11, 2013 Μαύρο το πήρα.Με κόκκινη θήκη Nilkin.Βέβαια το κόκκινο δεν είναι και τόσο αντρικό αλλά τι να κάνουμε... Δοκίμασα και με τον οδηγό που έχω βάλει παραπάνω,αλλά τζίφος.δε ξέρω αν κάνω κάτι λάθος. Εγώ το πήρα λευκό και του έβαλα διάφανη (Crystal) Imak θήκη και είναι υπέροχο. Δεν κάνουμε κάτι λάθος. Το αρχείο είναι μάπα.Είναι το stock english android recovery. Έχω αυτή τη ROM. Μετά την εγκατάσταση είχε κινέζικο recovery και περνώντας ένα από αυτά τα αρχεία απλά το άλλαξε σε αγγλικό. Παράθεση Φιλικά.Γιώργος.
Chryssostomos Δημ. December 11, 2013 Δημ. December 11, 2013 Όταν το πηρες εσυ δεν είχε επιλογή για αποθήκευση στηνsd ;εμένα έχει. Παράθεση Xiaomi 12 Pro
Administrators athanaso77 Δημ. December 12, 2013 Author Administrators Δημ. December 12, 2013 Όταν το πηρες εσυ δεν είχε επιλογή για αποθήκευση στηνsd ;εμένα έχει. Και σου δουλεύει κανονικά; Περνάει τις εφαρμογές στην κάρτα; Παράθεση
dalamaidis Δημ. December 12, 2013 Δημ. December 12, 2013 Καλημερα παιδια. Κατοχος εμος galaxy s3 με σπασμενη οθονη αποφασισα να παω για το a850. Εχω καποιες ερωτησεις. Gps κλειδωνει γρηγορα? Σε ποσα λεπτα περιπου? Ποιο site μου προτεινετε ωστε να το εχω σε 3 εβδομαδες και να υπαρχει μια υποτυπωδης αξιοπιστια? Αν υπαρχει καποιος απο Λαρισα ή Θεσσαλονικη που να το εχει ας στειλει ενα πμ γιατι θα ηθελα να το δω (την οθονη του περισσοτερο γιατι με προβληματιζει η αναλυση της) Στα 125 ευρω νομιζω οτι ειναι οτι πιο vfm υπαρχει για phablet Μαλλον για λευκο παω Ευχαριστω για τον χρονο σας Παράθεση :hunter:
Administrators athanaso77 Δημ. December 12, 2013 Author Administrators Δημ. December 12, 2013 Το GPS του σε καμία περίπτωση δεν μπορεί να συγκριθεί με αυτό του s3 που είχες, ωστόσο με το κατάλληλο πείραγμα θα κανεις τη δουλειά σου. Τα γνωστά site που αναφέρονται εδώ ειναι αξιόπιστα, το ποτέ όμως θα το πάρεις εξαρτάται και απο τα δικά μας εδώ ταχυδρομεία με ότι αυτό συνεπάγεται ενόψει των γιορτών. Παράθεση
dalamaidis Δημ. December 12, 2013 Δημ. December 12, 2013 Οταν λες πειραγμα εννοεις εγκατασταση της ρομ με αυτη που προτεινετε παραπανω? Δεν εχω ασχολειθει και πολυ με πειραγματα κλπ Παράθεση :hunter:
Administrators athanaso77 Δημ. December 12, 2013 Author Administrators Δημ. December 12, 2013 Οταν λες πειραγμα εννοεις εγκατασταση της ρομ με αυτη που προτεινετε παραπανω? Δεν εχω ασχολειθει και πολυ με πειραγματα κλπ Όχι... εννοώ αυτό. Παράθεση
Chryssostomos Δημ. December 12, 2013 Δημ. December 12, 2013 Και σου δουλεύει κανονικά; Περνάει τις εφαρμογές στην κάρτα; ναι κανονικά. Παράθεση Xiaomi 12 Pro
george418 Δημ. December 12, 2013 Δημ. December 12, 2013 (edited) Απο που το πήρες φιλέ και ηρθε με την ROM 123; Edited December 12, 2013 by george418 Παράθεση LENOVO A820,ZTE V967S,LENOVO A850,THL T200
