salazar_ Δημ. September 2, 2013 Δημ. September 2, 2013 Εδω θα βρειτε ενα καλο review της συσκευης http://miuiandroid.com/community/threads/xiaomi-hongmi-review-by-kiswum.21922/ Παράθεση
tsopanos Δημ. September 2, 2013 Δημ. September 2, 2013 Παντως ειναι παραλογο που δεν εμπορευεται η ιδια η Xiaomi τα κινητα της,το συγκεκριμενο κοστιζει κατω απο 100 ευρω στην Κινα 166 το πουλαει το Ibugou. Παράθεση
guideman Δημ. September 7, 2013 Δημ. September 7, 2013 Εδω ενας το εχει αγορασει (απο το buygou) και γραφει review: Posted by Herman Goeloe on 2013-9-4 19:28:42 Hi there, I would like to let you know that this phone is great, but needs (and probably will get) improvements. Here is a short resume: As mentioned, this phone does not have 3G which can be used outside China. You can use internet, but with limited speed (~35 kbps). This speed is enough for Whatsapp, Instant messaging and e-mail traffic. Visiting the mobile FB page takes too long, but it is nearly possible. Connecting to Wi-Fi is no problem and it reaches the same speed as my Xiaomi Mi2. Dual-sim works perfect and you can be called on both phonenumbers. You are also able to choose which simcard you will be using for your internet connection. The camera of this phone is great at daylight, but it is not good when you want to use it at dawn/in the night. The phone I've tested had problems with the browser, it hang a lot. I've tested it with Opera and this worked great. No problems with the browser. GPS and mediatek often have difficulties, but if you use it for Navigation, then it works perfect. There is something strange when you want to use it for apps like Sports Tracker, you can have unrealistic speeds. Overall this phone is great, Xiaomi is a good company who will update the phone every week with patches. I'm sure that most issues will be solved very soon. The only thing which cannot be changed is the lack of 3G, but I hope the white version of the Hongmi will have this installed. Chinese and English are the standard languages for Xiaomi phones, but you can use a keyboard design from your own country. You can also download search for apps in the "Market" for instance "Google" to download Google Play. I hope I gave you a short impression about this phone. Take care, Kiswum p.s. search for me on a search engine "Kiswum Hongmi" for a bigger review. Απ οτι λεει, το GPS κανει καποια νερα..:( κατα τα γνωστα, στους ΜΤΚ.. Παράθεση ΓΙΩΡΓΟΣ:clap:
mertaghon2 Δημ. September 7, 2013 Δημ. September 7, 2013 διαβασα απο την πηγη το review αυτο και αν καταλαβα ορθως,η πλοηγηση με gps λεειβπως μια χαρα ειναι. το sports tracker. απλα δε συνεργαζεται με το gps επι του παροντος. οποτε καλα ειμαστε στον τομεα gps για την ωρα.. Παράθεση να πάρου samsung λέου,να σώσ την κεφαλή μ!!, μα δε μ' αφήνει η htc που έχω στο..ε:Xε..στη ψχ μ!
plankton69 Δημ. September 7, 2013 Δημ. September 7, 2013 Μεγάλο φάουλ για μένα η ασυμβατότητα στο Sports Tracker, διότι το χρησιμοποιώ αρκετά. Μακάρι να το στρώσουν βέβαια, αλλά αν είναι από το hardware δύσκολο... Παράθεση plankton69 - Χρήστος iPhone XS 64GB / iPhone 4 8GB
tsopanos Δημ. September 7, 2013 Δημ. September 7, 2013 http://www.anybuying.com/phones/xiaomi-hongmi-phone.html δειτε τιμη εδω,το ξερει κανεις το καταστημα? Παράθεση
bull2oo4 Δημ. September 7, 2013 Δημ. September 7, 2013 υπάρχει κάτι αντίστοιχο με το sportstarcker που να λειτουργεί σωστά σε MTK MT6589Τ επεξεργαστή? Παράθεση Samsung Note 3 White :( RIP (Σπασμένη οθόνη) Microsoft Lumia 640XL Xiaomi Redmi Note 4 3/64 Pipo w2
plankton69 Δημ. September 7, 2013 Δημ. September 7, 2013 υπάρχει κάτι αντίστοιχο με το sportstarcker που να λειτουργεί σωστά σε MTK MT6589Τ επεξεργαστή? Το endomodo μου έρχεται στο μυαλό, αλλά δεν ξέρω τι γίνεται με την υποστήριξη των MTK... Παράθεση plankton69 - Χρήστος iPhone XS 64GB / iPhone 4 8GB
guideman Δημ. September 7, 2013 Δημ. September 7, 2013 http://www.anybuying.com/phones/xiaomi-hongmi-phone.html δειτε τιμη εδω,το ξερει κανεις το καταστημα?Μαλλον τιμη κραχτης μου κανει.. διαβασα απο την πηγη το review αυτο και αν καταλαβα ορθως,η πλοηγηση με gps λεειβπως μια χαρα ειναι.. οποτε καλα ειμαστε στον τομεα gps για την ωρα..Εμενα ετσι που τα γραφει δεν μου ειναι και 100% ξεκαθαρος.. Το endomodo μου έρχεται στο μυαλό, αλλά δεν ξέρω τι γίνεται με την υποστήριξη των MTK...Κι αυτο προβλημα εχει με τα ΜΤΚ.. Παντως παιδια, για να κανουμε συγκρισεις, για το Oppo R819 που ειναι στα ιδια (οχι σε τιμη βεβαια..) γραφουν καλα πραγματα για το GPS του.. Παράθεση ΓΙΩΡΓΟΣ:clap:
mertaghon2 Δημ. September 7, 2013 Δημ. September 7, 2013 περιμενουμε οποτε κιαλλο review guideman,πριν αποφασισουμε:) εγω φοβαμαι απο την xiaomi μην το 1gb ram το υπερφορτωνει με βλακειες. κατι τετοιο δεν εκανε στο mia,ή κανω λαθος:confused:? Παράθεση να πάρου samsung λέου,να σώσ την κεφαλή μ!!, μα δε μ' αφήνει η htc που έχω στο..ε:Xε..στη ψχ μ!
guideman Δημ. September 8, 2013 Δημ. September 8, 2013 (edited) "Το καλο το πραμμα αργει" λεει η παροιμια, οπως επισης και "οποιος βιαζεται σκονταφτει" αλλα και αλλα πολλα.. Οποιος περιμενει και δεν βιαζεται, ποτε δεν εχασε.. Γνωμη μου. Οσο για το Μ2Α, δεν εχεις αδικο, αν και προσωπικα δεν το θεωρω ανασταλτικο παραγοντα αγορας. Edited September 8, 2013 by guideman Παράθεση ΓΙΩΡΓΟΣ:clap:
tsopanos Δημ. September 8, 2013 Δημ. September 8, 2013 http://www.myphone.gr/forum/showthread.php?t=372330&page=3 διαβαστε το πρωτο ποστ με το ΣΑΡ των Xiaomi. Παράθεση
mertaghon2 Δημ. September 8, 2013 Δημ. September 8, 2013 http://www.myphone.gr/forum/showthread.php?t=372330&page=3 διαβαστε το πρωτο ποστ με το ΣΑΡ των Xiaomi. για καποιον κακο :) λογο δεν μπορω με τον φιλο γουγλη να βρω τα manual-pdf των xiaomi κινητων που δοκιμασα....:( απο εκει θα εχουμε εικονα για το σαρ. φιλε τσοπανο εννοειται τραγικα τα νουμερα που δειχνει σε εικονα στην 2η σελιδα (οχι στην τριτη,που ποσταρες,αλλαξεε τοο:p)στο thread που ποσταρες ομως πρεπει να τσεκαρουμε αν ισχυουν,πολυυυυυυυυυ συχνα ποσταρονται λαθος νουμερα. φυσικα αν εχουν πανω απο 0,8 τα xiaomi,εγω αποχωρω απο εδω:lol: αμφιβαλλω μωρε ομως,στο mi2a αφου ειναι Mtk cpu,ιδιο περιπου σαρ στο 0,7-0,8 που εχουν ολα δεν επρεπε?? διορθωστε με:) Παράθεση να πάρου samsung λέου,να σώσ την κεφαλή μ!!, μα δε μ' αφήνει η htc που έχω στο..ε:Xε..στη ψχ μ!
salazar_ Δημ. September 8, 2013 Δημ. September 8, 2013 για καποιον κακο :) λογο δεν μπορω με τον φιλο γουγλη να βρω τα manual-pdf των xiaomi κινητων που δοκιμασα....:( απο εκει θα εχουμε εικονα για το σαρ. φιλε τσοπανο εννοειται τραγικα τα νουμερα που δειχνει σε εικονα στην 2η σελιδα (οχι στην τριτη,που ποσταρες,αλλαξεε τοο:p)στο thread που ποσταρες ομως πρεπει να τσεκαρουμε αν ισχυουν,πολυυυυυυυυυ συχνα ποσταρονται λαθος νουμερα. φυσικα αν εχουν πανω απο 0,8 τα xiaomi,εγω αποχωρω απο εδω:lol: αμφιβαλλω μωρε ομως,στο mi2a αφου ειναι Mtk cpu,ιδιο περιπου σαρ στο 0,7-0,8 που εχουν ολα δεν επρεπε?? διορθωστε με:) Το MI2A εχει Snapdragon Παράθεση
mertaghon2 Δημ. September 8, 2013 Δημ. September 8, 2013 Το MI2A εχει Snapdragon axa:p,ωραιος σαλαζαρ, οποτε το red rice που εχει mtk 6589, δεν θα χει περιπου ιδιο σαρ με ολα τα αλλα κινεζικα, ή οτι κεραια θαλει βαζει ο καθενας?:confused: Παράθεση να πάρου samsung λέου,να σώσ την κεφαλή μ!!, μα δε μ' αφήνει η htc που έχω στο..ε:Xε..στη ψχ μ!
plankton69 Δημ. September 8, 2013 Δημ. September 8, 2013 Κι αυτο προβλημα εχει με τα ΜΤΚ.. Παντως παιδια, για να κανουμε συγκρισεις, για το Oppo R819 που ειναι στα ιδια (οχι σε τιμη βεβαια..) γραφουν καλα πραγματα για το GPS του.. Ωχ, να φανταστώ το ίδιο και με Foursquare, 3rd party GPS κλπ; Γενικότερα, ο,τι απαιτεί GPS έχει θέμα; Παράθεση plankton69 - Χρήστος iPhone XS 64GB / iPhone 4 8GB
guideman Δημ. September 8, 2013 Δημ. September 8, 2013 Ωχ, να φανταστώ το ίδιο και με Foursquare, 3rd party GPS κλπ; Γενικότερα, ο,τι απαιτεί GPS έχει θέμα; Προφανως... Μη βιαζεστε παντως να κανετε focus, ας κυκλοφορησει πρωτα (το WCDMA) και θα μαθουμε.. Παράθεση ΓΙΩΡΓΟΣ:clap:
patrik Δημ. September 11, 2013 Δημ. September 11, 2013 http://sphotos-g.ak.fbcdn.net/hphotos-ak-ash3/1078803_562965457072385_ ΠΡΟΣΟΧΗ, δεν υποστηριζει ελληνικο 3G τελικα αυτο ισχυει??? το εχει παραγγειλει κανεις? το ζαχαρωνω http://www.aliexpress.com/item/Free-SG-shipping-New-2013-Original-Xiaomi-Red-rice-MTK6589T-Smart-phone1GB-RAM-4GB-ROM-Qual/1243623653.html Παράθεση
tsopanos Δημ. September 12, 2013 Δημ. September 12, 2013 τελικα αυτο ισχυει??? το εχει παραγγειλει κανεις? το ζαχαρωνω http://www.aliexpress.com/item/Free-SG-shipping-New-2013-Original-Xiaomi-Red-rice-MTK6589T-Smart-phone1GB-RAM-4GB-ROM-Qual/1243623653.html http://www.banggood.com/Xiaomi-Hongmi-4_7-Inch-4G-ROM-Andriod-4_2-Quad-Core-Smart-Phone-Red-p-83282.html φθηνοτερο εδω,το εχω δει και με 189 αλλα δεν θυμαμαι που Παράθεση
guideman Δημ. September 12, 2013 Δημ. September 12, 2013 τελικα αυτο ισχυει???ισχυει...νομιζω ομως καποιος το εχει παραγγειλει.. Παράθεση ΓΙΩΡΓΟΣ:clap:
tsopanos Δημ. September 12, 2013 Δημ. September 12, 2013 ισχυει...νομιζω ομως καποιος το εχει παραγγειλει.. Περιμενουμε την εκδοση την ευρωπαικη,αλλα δουλευει με wi-fi αυτο,οχι με 3g Παράθεση
aristidis540 Δημ. September 12, 2013 Δημ. September 12, 2013 σκεφτομουν αυτο το κινητακι αλλα εαν ειναι πραγματικα τα σαρ που αναφερονται ,τοτε πρεπει να ψαχτω αλλου. Παράθεση siemens s35i->sony ericsson t100->siemens s65->sony ericsson k750->eten x600->htc diamond->htc diamond 2->xperia ray (ποτέ Nokia :cool:)
thelogiatro Δημ. September 12, 2013 Δημ. September 12, 2013 Γεια σας, Το εχει βρει κανεις στα 130$; αν ναι σε ποιο σάιτ κανενα νεο για την εκδοση με το 3g για Ελλαδα; Παράθεση
guideman Δημ. October 13, 2013 Δημ. October 13, 2013 (edited) http://www.gizchina.com/2013/09/30/china-unicom-version-wcdma-xiaomi-red-rice-gets-network-license/ Σιγα σιγα να ετοιμαζομαστε... Εδω και ενα τεστ. Η αποδοση του gps φαινεται χωρις κανενα προβλημα. http://forum.xda-developers.com/showthread.php?t=2413406 Edited October 13, 2013 by guideman Παράθεση ΓΙΩΡΓΟΣ:clap:
dimzan Δημ. October 14, 2013 Δημ. October 14, 2013 http://www.gizchina.com/2013/09/30/china-unicom-version-wcdma-xiaomi-red-rice-gets-network-license/ Σιγα σιγα να ετοιμαζομαστε... Εδω και ενα τεστ. Η αποδοση του gps φαινεται χωρις κανενα προβλημα. http://forum.xda-developers.com/showthread.php?t=2413406 μακαρι να ερθει σε καλη τιμη, δηλαδη κατω απο 180$. Αλλα πιστευω πως με τοσο ντορο που εχει γινει γυρω απ το ονομα της xiaomi τα ηλεκτρονικα καταστηματα θα το βαλουν πανω απο 200$, ή καπου εκει. για να δουμε, μακαρι να βγω ψευτης Παράθεση
