[Επίσημο] Nokia 7610
Itchrist86
Αυτο ειναι ενα post απο το nokiafree forum. σχεδον συμφονω μαζι του η μαλλον θα θελα να συμφωνω!!
Mono and stereo are the same sound quality, but stereo uses 2 channels. thats the only difference.
What stereo is: READ BEFORE ΧΧΧΧΧING
I'm sorry but I've seen the question too much and I have to set it straight.
Web Definitions of Stereo:
"A method of producing sound where the audio is mixed in two different channels. This is so that the human ears can detect direction that the sound is coming from. Usually it is used with music to give a fuller, more natural sound. It has two separate audio channels."
http://www.cpinternet.com/~dkrantz/glossary.html
"Two-channel system feeding left and right speakers."
http://www.geocities.com/SunsetStri.../2353/gloss.htm
SOUND QUALITY IS NOT A FACTOR. From one of my earlier posts, here's an explanation of what stereo is and does:
Far as I know, quality of stereo and mono sound is the same. The difference is that stereo has two channels of sound to create a surround sound effect e.g. like when you watch a movie with headsets and certains sounds come out of the left ear but not the right. If you watched the same part of this movie with mono sound, the sounds would simply sound the same when they come out of both ears because the two sound channels are combined into one, so you don't know the direction of the sound. I'm pretty sure quality has nothing to do with it.
Reasons for using stereo: surround effect, fx in songs
Reasons for using mono: less data (only one channel instead of two) and therefor less power needed to decode both channels and less space required for digital music (why ultramp3 only plays mono). Stereo is more like playing two NEARLY identical sound tracks at the same time, just in different ears. Moreover, by making a sound mono, you automatically cut the file size down greatly (tip for converting vids and compressing mp3)
Final summation: Sure it's a pity when it's not there, but you probably won't notice stereo effects, nor should they effect your phone shopping.
The "unwired" revolution began...
_http://www.myphone.gr/forum/image.php?type=sigpic&userid=6201&dateline=1272991407
  • Απαντήσεις 4,8χιλ.
Αρχικό Μήνυμα από το μέλος killing_you2 (21 Ιούλ. 2004 , 20:00)
aa sobara???
den to 3erame pes tou !!!
paidia exw mia erotisi gia sas: enas filos prospathei na mou steilei mesw BT ena mp3, girw sta 5mb. Opws katalavnenete, den pezei na xwesei sti vasiki mnimi twn 8mb, mias k ta perissotera einai katileimena. Yparxei lysh gia auto? diladi na paei me ti mia stin mmc, i thelei aparaitita metafora apo pc sto kinito?
Αρχικό Μήνυμα από το μέλος eytydim (21 Ιούλ. 2004 , 10:10)
Οι golla που έχει ο Γερμανος ταιριάζουν και είναι και αισυητικά καλές. Σε Nokia δεν βρήκα κάτι που να τεριάζει και να είναι και ωραίο.
Εγω χρησιμοποιω μια δερματινη μεταφορας της SE για το Κ700ι και χωραει μια χαρα.
Απλα ειναι θηκη μεταφορας και δεν μπορεις να το χρησμοποικσεις.
Τιμη 15€ ;)
Αρχικό Μήνυμα από το μέλος meres (21 Ιούλ. 2004 , 23:39)
Βέβαια και υπάρχει λύση. Πηγαίνεις μηνύματα, ρυθμίσεις, άλλο, μνήμη σε χρήση και επιλέγεις memory card και ότι σου έρχεται σαν μήνυμα πηγαίνει κατευθείαν στον φάκελο E:/system/mail/
paidia thelw na perasw kati paixnidia se morfi jar kai ayta gia na ta perasw xreiazomai kapoion file manager gia na xeirizomai ta arxeia tou kinitou apo to pc. pou mporw na vrw ena manager gia to pc sumvato me to 7610 opws o file manager tis epocware??
Δεν κατάλαβα φίλε μου τι ζητάς. Έχεις εγκαταστήσει κάποιον file manager στο κινητό σου; Αν ναι, δεν χρειάζεσαι τίποτα άλλο. Πηγαίνεις, το βρίσκεις, πατάς πάνω του και αρχίζει αυτόματα η εγκατάσταση. Όπως ακριβώς και τα .sis καμία διαφορά.
Αν δεν έχεις βάλει κάποιον, μπορείς να κάνεις το ίδιο με τον manager που έχει εγκατεστημενο ήδη η συσκευή μέσα.
Αρχικό Μήνυμα από το μέλος martinixp2000 (22 Ιούλ. 2004 , 01:19)
Φιλε μου το μονο που χρειαζεσαι ειναι το PC Suite που ειναι στο CD-ROM που εχει το τηλεφωνο οταν το αγορασες. :)
Αρχικό Μήνυμα από το μέλος eytydim (21 Ιούλ. 2004 , 19:14)
Την έχω δοκιμάσει την θήκη,αυτήν χρησημοποιώ τώρα. Το προστατεύει αρκετά καλά εώς τέλεια θα έλεγα. Το κινητό μου έπεσε, δυστηχώς 3 φορές από σχετικά μεγάλο ύψος και ευτηχώς δεν έχει ούτε ένα σημαδάκι ούτε ένα πρόβλημα. Το μόνο που φαίνεται από το κινητό είναι λίγο η πάνω αριστερή και λίγο η πάνω δεξιά γωνία, αλλά πολύ λιγο και εξακολουθούν να προστατεύονται. Δοκίμασε την πάντως πριν την πάρεις.Εμένα με βόλεψε πολύ.
Eίχες δίκιο πήγα πάλι και κατέληξα στην suede χρώματος μπέζ. Η θήκη του έρχεται γάντι και το καλύπτει ολόκληρο αν και στην αρχη μπήκε με λίγο ζόρι αλλά μετα έστρωσε μια χαρά. Πολύ όμορφα χρώματα και ωραίος σχεδιασμός παρεπιτώντος 15 ευρώ. Όποιος ενδιαφέρεται στο site http://www.golla.fi και σε καταστήματα ΟΤΕ SHOP που το βρήκα εγώ ή και ΓΕΡΜΑΝΟ απ' οτι λέει ο eytydim.
Ευχαριστώ και πάλι.
Παιδια επιτελους το πηρα κι εγω το κινητο! Τι να πω ειναι ο,τι καλυτερο εχω δει ειναι απιστευτα ομορφο και ευχρηστο! Οσο για τις θηκες golla απο το γερμανο εχω ηδη αγορασει 2 (κοκκινη και πρασινη) οντως ειναι οτι πρεπει για το κινητο. Επισης δοκιμασα τα ακουστικα απο 7210 και παιζουν μια χαρα. Θα ηθελα να ρωτησω κατι, εχει εγκαταστησει κανεις το Ultra MP3? φοβαμαι να το βαλω γιατι οταν το ειχα βαλει στο N gage σταματησε να βαζει τα mp3 για ηχους κλησης, συμβαινει και με το 7610 αυτο? Και κατι αλλο πηγα να εγκαταστησω το Stacker και μου λεει οτι η εφαρμογη ενδεχεται να μην ειναι συμβατη με το τηλεφωνο τι να κανω να το βαλω ή θα το χαλασω?
[sIGPIC][/sIGPIC]Μέγιστο μέγεθος εικόνας υπογραφής 420x150 pixels και 16ΚΒytes.
παιδια το προβλημα το οτι τα java δεν εχουν ηχο συμβαινει μονο σε εμενα??????
Αρχικό Μήνυμα από το μέλος martinixp2000 (22 Ιούλ. 2004 , 16:55)
ta arxeia .jar den exoun kanena arxeio sis wste na to xrisimoiei to pc suite kai na mpainei to paixnidi.
Απλως περνας το αρχειο jar οπως ειναι στο κινητο με το Nokia application installer και μπαινει κανονικα και ολοκληρωνεις την εγκατασταση απο το κινητο. Το ξερω γιατι το εκανα πριν απο λιγο.
Κανε δεξι κλικ στο αρχειο και αποστολη απο το pc σου και
στο κινητο σου ,χωρις να χρησιμοποησεις το
pc suite. Η εφαρμογη jar ερχεται στο κινητο σου σαν
μυνημα και κανεις μετα εγκατασταση
iPhone 5S Space Grey
Αρχικό Μήνυμα από το μέλος freyarip (22 Ιούλ. 2004 , 14:57)
οραια τοτε καιρος ειναι να αλλαξεις και το avatar σου χεχε!!!(TETOIA ΑVATARS ΔΕΝ ΧΩΡΑΝΕ ΣΤΟ THREAD ΜΑΣ!! :p )
αυτο ειναι το νεο σου avatar... http://www.nokiausa.com/images/phn/nav/ph_7610_lrg_trans_sml.gif
WELCOME TO THE CLUB....
Αρχικό Μήνυμα από το μέλος freyarip (22 Ιούλ. 2004 , 16:57)
Egw dokimasa ta akoustika tou 7250i kai den douleuoun.
To Ultra MP3 douleuei kanonika kai ta mp3 mpainoun san hxoi klisis.
To Stacker, kalutera na mhn to baleis.
Πλήκτρα: Nokia 3310 > 3510i > 7250i > 7610 > Sony Ericsson W580 > W595
Πλήκτρα / Αφή: HTC Touch Diamond > Sony Ericsson Xperia mini pro
Πλήκτρα: Nokia 113 > Samsung C3530 > E1182 > Nokia 114
Αφή: LG G2 > Samsung Galaxy S7 Edge > S8+ > Huawei Mate 20 Pro > Samsung Galaxy S21 Ultra > S23 Ultra
Smart Watch: Samsung Gear S2 Classic > S3 Classic > Samsung Galaxy Watch4 Classic
Αρχικό Μήνυμα από το μέλος killing_you2 (22 Ιούλ. 2004 , 16:57)
Ta java games ennoeis?
Emena exoun ola hxo.
Γνωρίζουμε πότε θα βγει νέο firmware γιατί αυτά τα κολλήματα ανά 5" στους ήχους είναι problem!
Όσο οι νόμοι των μαθηματικών ανταποκρίνονται στην πραγματικότητα, δεν είναι σαφείς, και όσο σαφείς είναι, δεν ανταποκρίνονται στην πραγματικότητα.
Albert Einstein
Αρχικό Μήνυμα από το μέλος Crypton-R- (22 Ιούλ. 2004 , 17:11)
Και μενα δεν ειχαν ηχο και πηγα στο προφιλ και ενεργοποιησα τους ηχους προειδοποιησης και τωρα εχω κανονικα ηχο. Δοκιμασε το
Gia sas. Meno londino ke thelo na paro neo simvoleo stin athina stin vodafone me to 7610 otan tha katevo ya diakopesw se 10 meres. Mporite na mu pite an episima iparxi to 7610 sta vodafone stores tis athinas ke an tha ine eukolo na to pari i den kiklofori akoma>?
Guest lagoudakis
Αρχικό Μήνυμα από το μέλος gemikon (22 Ιούλ. 2004 , 19:54)
εχει 1 μηνα που κυκλοφορει φιλε μου,το εχουν ολοι ;)
Αρχικό Μήνυμα από το μέλος freyarip (22 Ιούλ. 2004 , 17:47)
επιτελους, ναι αυτο εφταιγε γιατι εγω νομιζα οτι ηταν bug του κινητου!!
να ρωτησω κατι αλλο. εχετε παιξει το SANGO? ειναι κινεζικο αλλα πιστευω ειναι το καλυτερο rpg (οχι οτι εχω παιξει πολλα!! :p ) που εχω παιξει στο κινητο! δοκημαστε το ειναι τρομερο!
μπορειτε να το βρειτε στο mirc.
jerei kanenaw giati ta ΤΙΜ ΜΑΓΑΖΙΑ δεν εχουν το 7610?τι στο καλο κανουν και καθυστερουν?μια ζωη γραμμενους μας εχουν!και κατι τελευταιο....ειμαι μεταξυ 6600 και 7610 πολυ επιλεκτικα μπορει να με βοηθησει καποιος στην εππιλογη μου?ευχαριστω πολυ και σορυ αν ειναι λιγο(η.... πολυ!) off topic h ervthsh moy!
Αρχικό Μήνυμα από το μέλος ilka71 (23 Ιούλ. 2004 , 00:35)
Παρε το 7610 φιλε μου, ειναι ποιο σταθερο συν ολα τα αλλα.
Δες την αναλυτικη παρουσιαση του MSK
Αναλυτική Παρουσίαση: Nokia 7610
