[Επίσημο] Nokia N95 8GB
nervous
Καινούριο firmware έρχεται για το Ν95 8GB v20.0.016
Changes/improvements made from MCU SW 15.0.015 to version 20.0.016
New features:
* Automatic Screen Rotation (ASR)
* Support for new combo memory added
Browser:
* Improvement when creating a voice call from WAP page.
* Improvements to embedded video functionality in browser.
* Sending email via browser flash plugin improvements.
Messaging:
* Mail in HTML format handling from Gmail IMAP server improved.
Connectivity:
* WLAN connection stability improvements
* BT connection stability improvements with certain BT headsets
* USB connection stability improvements
Telephony:
* Voice call handling improvements after certain type U.S.S.D
message receiving.
* Stability improvements to gallery for case when there's lot of
content in Gallery
* Improvements to switch application
* Voicemail icon handling improvements
Localization corrections:
* Deletion of all contacts now possible even more than 6000 contacts
in phonebook
* Startup functionality improvements
περισσότερα εδώ : http://www.symbian-freak.com/quides/firmware/logs/new_n95_8gb_firmware_v20_change_log.htm
New firmware version for Nokia N95 8GB will be available progressively at the official Nokia Points and Nokia
Service Points in the next few days and should be available soon on the NSU as well.
3210-3310-8210-8310-6510-7250-3100-6230-6060-6280-E65-N82+2630-C7-SIII Mini-Moto G 2014-Redmi Note2 prime-Redmi Note3 Pro-Redmi Pro Χ25-Redmi 5 Plus-Mi A2
  • Απαντήσεις 5,2χιλ.
20.0.016: New firmware update for N95 8GB is on the way
New firmware version for the Nokia N95 8GB is on the way and brings Automatic Screen Rotation and Support for new combo memory added.
Changes/improvements made from MCU SW 15.0.015 to version 20.0.016:
New features:
  • Automatic Screen Rotation
  • Support for new combo memory added
Browser:
  • Improvement when creating a voice call from WAP page
  • Improvements to embedded video functionality in browser
  • Sending email via browser flash plugin improvements
Messaging:
  • Mail in HTML format handling from Gmail IMAP server improved
Connectivity:
  • WLAN connection stability improvements
  • BT connection stability improvements with certain BT headsets
  • USB connection stability improvements
Telephony:
  • Voice call handling improvements after certain type U.S.S.D message receiving
  • Stability improvements to gallery for case when there's lot of content in Gallery
  • Improvements to switch application
  • Voicemail icon handling improvements
  • Deletion of all contacts now possible even more than 6000 contacts in phonebook
  • Startup functionality improvements
dmarccos με πρόλαβες.:p
ΩΡΑΙΑ ΝΕΑ!!!!!! ε παιδιά δεν πιστευω να είναι τίποτα πρωταπριλιάτικο;)
Όχι, τουλάχιστον από εμάς...:rolleyes:
Αν ειναι οντως ετσι ,αρκετα ενδιαφερον ειναι το παραπανω,
περα απο τις υπολοιπες βελτιωσεις .:happy:
Το συναντησα στο Ν800 internet tablet, αν ειναι οντως αυτο.
Ουσιαστικα "δανειζεται" μνημη απο την καρτα αποθηκευσης
για περισσοτερη RAM ως virtual extended memory.
Στο Ν800 πχ δανειζεται μεχρι και 128ΜΒ.
Δειτε το screenshot για περισσοτερα:
http://img220.imageshack.us/img220/5710/screenshot00yj6.jpg
Και ελεγα γιατι ενα τετοιο feature να λειπει απο ενα series60 ..
Μπραβο στην Νοκια !
iPhone 5S Space Grey
για περισσοτερη RAM.
Μπραβο στην Νοκια !
Αυτό εννοεί... και ψάχνω να βρω τι είναι αυτό το νέο χαρακτηριστικό.:ninja:
Κάτι σαν την εικονική μνήμη τους υπολογιστές. Καλό...!:up:
Αν και δεν έχει ανάγκη το συγκεκριμένο μοντέλο, άλλα έχουν.:shifty:
Άραγε θα το δούμε να υιοθετείται και στα υπόλοιπα S60 αυτό το χαρακτηριστικό, είτε έχουν αρκετή hardware RAM μνήμη είτε όχι??? :confused:
Δεν έχεις ελληνικά;
Αν δεν έχει, τότε θα πρέπει να περάσεις την ελληνική έκδοση λογισμικού.
Δεν γίνεται αλλιώς.
ΚΑΙ ΠΩΣ ΤΟ ΚΑΝΩ ΑΥΤΟ? ΕΚΑΝΑ ΑΝΑΒΑΘΜΙΣΗ ΛΟΓΙΣΜΙΚΟΥ ΜΕ ΤΑ CODES ΕΛΛΑΔΑΣ.ΑΛΛΑ ΔΕΝ ΕΧΕΙ ΕΛΛΗΝΙΚΑ
nMIL
Κατι δεν εκανες σωστα τοτε,εισαι σιγουρος οτι αλλαξες το product code ? :rolleyes:
Διαβάστε πριν ρωτήσετε: S60 Platform FAQ
http://www.myphone.gr/forum/showthread.php?p=2253377#post2253377
@speedex
Απλά θα βάλεις αυτό το product code: 0550801:)
Πολύ καλά τα νέα για την αναβάθμιση! Αν και θα ήθελα να βελτιωνόταν η ταχύτητα σύνδεσης με usb κατι που μάλλον οφείλεται στο hardware...
Γειά σας, υπάρχει τρόπος στον browser του τηλεφώνου μας να ανοίξω δεύτερη σελίδα? Ρωτάω γιατί στη σχολή μου για παράδειγμα, κάνεις login στην πρώτη σελίδα για να αποκτήσεις access στο ασύρματο δίκτυο και πρέπει να την έχεις ανοιχτή για να συνεχίσεις το σερφάρισμα, ή οτιδήποτε άλλο στο internet.
έκανα ακριβως αυτο που διάβασα και το μόνο που δεν ειδα ήταν όταν έκλεισα το NSS δεν άνοιξε μόνο του το software update. μπορει αυτό να είναι πρόβλημα?
nMIL
Καθώς είσαι ήδη μέσα σε μια σελίδα, πάτα Επιλογές > Μετάβαση σε διεύθυνση.
Θα ανοίξει καινούριο παράθυρο για τη νέα σελίδα.
Πατώντας πίσω εμφανίζονται όλες οι σελίδες που έχεις επισκεφτεί.
Τελειώνοντας τη διαδικασία με το NSS, ανοίγεις εσύ το NSU. Δεν ανοίγει από μόνο του.
isws kapoios na metafrasei tis veltiwseis tis neas version euxaristw
Μπορείς να κάνεις δουλεία σου με το babelfish.;)
Ισως να το κανουμε αυτο ,αφου πρωτα μεταφρασεις
αυτα που γραφεις χρησιμοποιωντας Ελληνικους μικρους χαρακτηρες ...
Καλησπερα παιδια..το Automatic Screen Rotation ειναι και καλα σαν το προγραμμα rotate me?
Μολις βγει το firmware θα το περασω γιατι ακομα ειμαι με την 10.0.21..:)
Ναι, ακριβώς!
Αλλά αν κρίνω σε σχέση με του N82 (γιατί το έχει ήδη ενσωματωμένο), θα το ξανά βάλεις το rotateMe.
Itchrist86 αυτό δοκίμαζα και εγώ αλλά με ρωτάει μετά : κλείσιμο της σελίδας (της προηγούμενης), πατάω όχι και μετά δεν κάνει τίποτα, δεν ανοίγει την καινούργια..
Ευχαριστώ για την απάντηση.
Γενική ερώτηση: Είδα ότι μπορείς να βάλεις βίντεο αντί για ήχο κλήσης, υπάρχει τρόπος ή πρόγραμμα που να βάζεις για κάθε επαφή ξεχωριστά βίντεο ή ήχο κλήσης χωρίς να ομαδοποιήσεις τις επαφές σου? (νομίζω μπορείς να βάλεις για κάθε ομάδα διαφορετικό ήχο-βίντεο)
για την επαφη που θελεις πας μεσα στον καταλογο, μπαινεις στην επαφη επιλογες ηχος κλησης και τον επιλεγεις
Για την νέα διάθεση λογισμικού του N95-8G:
Μπορούμε να ενημερωθούμε επίσημα από την Nokia, μόλις διατεθεί:
http://europe.nokia.com/A4577224
Product code: 0550801 (εισαγωγής Alpha Copy)
Nokia Software Updater (Greek)
http://nds1.nokia.com/files/support/global/phones/software/NokiaSoftwareUpdaterSetup_el.exe
Eυχαριστώ!
ΜΕΓΙΑ !!!:) τα εχουμε πει χιλιες φορες η εμφανιση του στιγματος ειναι δωρεαν οπως και το λογισμικο χαρτων την νοκια τωρα η πλοηγηση καθε αυτη χρεωνεται με το μηνα απο την νοκια (αγοραζεις αδεια) εκτός όμως απο τους χάρτες της νοκια μπορεις να βάλεις αλλα συμβατά προγράμματα που είναι δωρεάν παιρεταίρω πληροφορίες μπορείς να πάρεις απο τα αντοίστιχα θέματα του nokia maps , garmin και sygic:happy:
ck
