beez Δημ. November 27, 2004 Δημ. November 27, 2004 paidia exo er8ei kipro kai exo ferei ena zyxel 652H na dokimaso, gnorizei kaneis ta multiplex kai vp/vci settings pou xrisimopoiei i CYTA oste na mporeso na to setaro? pira tin CYTA kai mou eipane oti mporo na valo diko mou modem alla prepei na miliso se texniko tin deutera..kai distixos aurio epistrefo stin a8ina. an mporouse kapoios na voi8isei 8a imoun ipoxreos Παράθεση
beez Δημ. November 27, 2004 Δημ. November 27, 2004 apo to manual tou B-focus ... A newly installed router is configured as RFC 1483 bridged. The following sections explain how this default setting can be modified. As a first step, Permanent Virtual Circuits (PVC) and Virtual Channel Connection (VCC) should be defined in the ATM network. These definitions are performed at the top of the WAN Setup dialog box. Define: • VPI within the range of 0 to 255. • VCI within the range of 0 to 65535. • The type of encapsulation, either LLC/SNAP or Vc Multiplexing. • Whether NAT is supported. At the bottom of the WAN Setup dialog box there is a table showing current definitions. You can add, remove or edit lines. In order to apply the new or updated definitions to the router, you must save the new definitions via the configuration software to the router’s flash memory and then reboot the router. kai ta username kai pass pou ziti8ikan..me asximo tropo vevaia In the User name field type admin, in the Password field type Bezeqwow, and click OK. The Access Control window appears, presenting a List of Users. to modem otan erxete douleuei se bridged mode Παράθεση
beez Δημ. November 27, 2004 Δημ. November 27, 2004 heheeh profanos i cyta exei allaksei ta username kai pass..anarotieme an to pass einai auto pou grafete kato apo to modem me stilo...8a itan to pio logiko gia na min psaxnoun na vroune to pass..alla pio na einai to username? ektos an iparxei master username/pass kapoios mesa apo tin etairia 8a to kserei Παράθεση
Hunter Δημ. November 27, 2004 Δημ. November 27, 2004 εαν η CYTA παρεχεο αυτο τον router χωρις χρεωση στον πελατη τοτε καλα κανει και αλλαζει το username και password. Εαν ομως το πληρωνεις το router ε τοτε πρεπει να απαιτησετε να σας τα δωσουν........ Παράθεση Έρωτας: Κορυφαίο ιδιοτελές συναίσθημα, αναφέρεται μόνο στις ερωτικές σχέσεις (όπως δείχνει και το όνομα του). Δίνεις τα πάντα στον άλλο και περιμένεις τα πάντα από αυτόν. Παραδίδεσαι ψυχή τε και σώματι και επιθυμείς το ίδιο από το ταίρι σου. Για μένα ο αληθινός μεγαλειώδης έρωτας, αυτός που θα σταματήσει το χρόνο, είναι πιο σπάνιος και προσωπικά πιο επιθυμητός από την αγάπη.
Mikkailos Δημ. November 28, 2004 Δημ. November 28, 2004 distixos oute egw 3erw ta settings tis cytas, kai an ta 3eri kapios tha itan wraia na mas ta pi.. exw diabasi to manual ala prospika den mboro kan na kanw access ton router. Blepw apo to pc mou oti to default gateway ine to 10.140.0.1 kai to xrisimopio ala den fenete na ginete tipota.. pio port xrisimopiate gia na mbite ston router? Παράθεση
beez Δημ. November 28, 2004 Δημ. November 28, 2004 file mikailo gia na mpeis ston router prepei na eisai sto idio subnet.. vale ip 192.168.1.30 netmask 255.255.255.0 gateway 192.168.1.1 afise dns opos einai kai kane ok kai isos na xreiastei na kaneis repair tin sindesi..otan pleon 8a exeis tin ip 192.168.1.30 i kapoia alli sto subnet ektos apo tin 1.1 pou tin exei o router..mporeis na anoiksei ena webbrowser kai na grapseis 192.168.1.1 gia na mpeis sto menu tou router..to port einai to std http Παράθεση
makis_thess Δημ. February 4, 2005 Δημ. February 4, 2005 Το πρωην 131 που τωρα εγινε 11888 και απο 13/02/2005 και ωρα 00:00 θα ανεβουν ΚΙ΄Α.Λ.Λ.Ο η χρεωσης!!! ΑΠΟ ΨΗΦΙΑΚΕΣ ΓΡΑΜΜΕΣ :0,34 € ΧΩΡΙΣ φπα ΑΠΟ ΑΝΑΛΟΓΙΚΕΣ ΓΡΑΜΜΕΣ :13 ΜΟΝΑΔΕΣ πΟΤΕ ΧΩΡΙΣ φπα ΑΠΟ ΚΑΡΤΟΤΗΛΕΦΩΝΟ :13 ΠΑΛΜΟΥΣ με φπα ΑΠΟ ΧΡΟΝΟΚΑΡΤΑ πΟΤΕ :0,4185 € με φπα εδω ειναι και το Δελτιο τυπου! :mad: :wacko: :mad: γιαυτο αν θελετε ''ΠΛΗΡΟΦΟΡΙΕΣ ΤΗΛΕΦΩΝΙΚΟΥ ΚΑΤΑΛΟΓΟΥ'' Καλα ειναι να μπειτε στη σελιδα τους ΕΔΩ και θα χρεωθητε 1 μοναδα και θα μπορειτε να ψαχνετε τηλεφωνα για 4,5λεπτα την μερα η περιπου 9 τη νυχτα (ΕΠΑΚ εννοω) Παράθεση :up: Myphone Meeting @ Thessaloniki 14/12/14 ! XARISETO.GR Μην το πετάς... XariseTo.gr ! 2030.gr Οδηγος camping
Gka Δημ. February 5, 2005 Δημ. February 5, 2005 Επίσης οι "αρχικλέφτες" χρεώνουν και το μήνυμα που ενημερώνει, όταν καλέσεις 131, για το νέο αριθμό κλήσης :mad: :down: Παράθεση
Panagioths Δημ. February 5, 2005 Δημ. February 5, 2005 Επίσης οι "αρχικλέφτες" χρεώνουν και το μήνυμα που ενημερώνει, όταν καλέσεις 131, για το νέο αριθμό κλήσης :mad: :down: Σοβαρα? Το εχεις ελεγξει με isdn? ΕΛΕΟΣ αν το χρεωνουν αυτο....... :wacko: Παράθεση Βλέπεις πράγματα και αναρωτιέσαι "Γιατί;" Αλλά εγώ ονειρεύομαι πράγματα που δεν υπήρξαν ποτέ και λέω "Γιατί όχι;"
Gka Δημ. February 5, 2005 Δημ. February 5, 2005 Σοβαρα? Το εχεις ελεγξει με isdn? ΕΛΕΟΣ αν το χρεωνουν αυτο....... :wacko: Ο λογαριασμός είναι ο τελευταίος που ήρθε, είχα pstn. Παράθεση
dapper Δημ. February 6, 2005 Δημ. February 6, 2005 Ο μαλακ@ς ο ο.τ.ε. συνεχίζει ακόμα και τώρα (που είναι έτυμος για φούντο) την κλασική τακτική --άρμεγμα οπού μπορεί και όσο μπορεί—ειλικρινά ρε πεδία ΒΑΡΕΘΗΚΑ χτες μου ηρθε ο λογαριασμός μου, και κάπου στα 30 e είναι μονο τα παγία (στο κινητό ρε γαμοτο μου πληρώνω τόσο πάγιο αλλά μου δίνει και free 4 ώρες ομιλίας) αα! παραλίγο να ξεχάσω την τρομερή έκπτωση που είχα με τις οτεεπιλογες για 150 αστικές ειχα το τρομεροοοοοοοο ποσό των -0.02 e. :X :X Φτάνει πια θα πάρω τηλ. Των αγαπητό μπιν λαντεν και θα πάμε να τους τα ανατινάξουμε όλααααααααααα. Παράθεση http://briefcase.pathfinder.gr/download/dapper/29955/456253/0/248200.jpg
Φίλιππος Δημ. February 6, 2005 Δημ. February 6, 2005 Για να συγρκίνετε, η αντίστοιχη χρέωση στο γερμανικό 141 είναι 99cents/λεπτό+20cents εφάπαξ Παράθεση http://img163.exs.cx/img163/999/t6xo.png
M_e_v Δημ. February 6, 2005 Δημ. February 6, 2005 paidia x8es pira til sto 131 kai mou eipe oti einai minima xwris xrewsi i enimerwsi gia tin allagi tou ari8mou.. lene psemata dld? poso praaktiko einai omws gia kapoion pou den exei dsl, na anoigei pc, na mpainei internet, gia na dei ena til enos delivery px.. k an exeis k pstn opws egw.. 8a pareis k 8a xrew8eis ti 8a kaneis.. sucksss... Παράθεση "..είναι οι άνθρωποι, μου έλεγες πουλιά..σαν χειμωνιάσει πάντα μακρυά πετάνε..κ έρχονται ίσως να σε δουν κάποια βραδιά..αν έχουν σπάσει τα φτερά τους..ή αν πεινάνε.."
makis_thess Δημ. February 6, 2005 Δημ. February 6, 2005 poso praaktiko einai omws gia kapoion pou den exei dsl, na anoigei pc, na mpainei internet, gia na dei ena til enos delivery px.. k an exeis k pstn opws egw.. 8a pareis k 8a xrew8eis ti 8a kaneis.. sucksss... απλα ειναι τα πραγματα. ΠΡΩΤΟΝ: η περνεις (131) 11888 και χρεωνεσε (14 μοναδες οτε)=0,40 περιπου Η ΔΕΥΤΕΡΟΝ: ανοιγεις τον Η/Υ συνδεεσε και χρεωνεσε (αν ειναι ημερα*) για περιπου 4.5λεπτα ΜΙΑ ΜΟΝΑΔΑ = 0,03 περιπου δηλ.διαφορα 0,40-0,03=0,37€ και αν δεν καταλεβες ειναι οσο 1 ΩΡΑ ΣΤΟ ΙΝΤΕΡΝΕΤ (αν ειναι μερα*) *=(0,35€ επακ μερα) και (0,17€ επακ νυχτα) αρα πες μου τωρα τι συμφερη?? Παράθεση :up: Myphone Meeting @ Thessaloniki 14/12/14 ! XARISETO.GR Μην το πετάς... XariseTo.gr ! 2030.gr Οδηγος camping
spartak Δημ. February 6, 2005 Δημ. February 6, 2005 Ο ΟΤΕ απλά ευθυγραμμίζεται με καθυστέρηση με τα τιμολόγια που ισχύουν σε αρκετές ευρωπαικές χώρες για κλήση σε υπηρεσίες καταλόγου. Ήδη ανέφερε ο Φίλιππος τη Γερμανία. Παράθεση
myphone-fan Δημ. February 7, 2005 Δημ. February 7, 2005 απλα ειναι τα πραγματα. ΠΡΩΤΟΝ: η περνεις (131) 11888 και χρεωνεσε (14 μοναδες οτε)=0,40 περιπου Η ΔΕΥΤΕΡΟΝ: ανοιγεις τον Η/Υ συνδεεσε και χρεωνεσε (αν ειναι ημερα*) για περιπου 4.5λεπτα ΜΙΑ ΜΟΝΑΔΑ = 0,03 περιπου δηλ.διαφορα 0,40-0,03=0,37€ και αν δεν καταλεβες ειναι οσο 1 ΩΡΑ ΣΤΟ ΙΝΤΕΡΝΕΤ (αν ειναι μερα*) *=(0,35€ επακ μερα) και (0,17€ επακ νυχτα) αρα πες μου τωρα τι συμφερη?? Το τί συμφέρει το γνωρίζουμε όλοι στο myphone πολύ καλά... Το πρόβλημα είναι για αυτούς που δεν έχουν σύνδεση στο internet ή/και Η/Υ και ακόμα και για εμάς τους ίδιους στην περίπτωση που βρισκόμαστε κάπου (π.χ. καρτοτηλέφωνο) και χρειαζόμαστε επειγόντως πληροφορίες τηλεφωνικού καταλόγου. :!: Παράθεση
Don_VitoCorleone Δημ. February 7, 2005 Δημ. February 7, 2005 Ο ΟΤΕ απλά ευθυγραμμίζεται με καθυστέρηση με τα τιμολόγια που ισχύουν σε αρκετές ευρωπαικές χώρες για κλήση σε υπηρεσίες καταλόγου. Ήδη ανέφερε ο Φίλιππος τη Γερμανία. Perimenoume kai thn "efthigramish" me toys misthous ths Germanias...... Παράθεση
arkon Δημ. February 7, 2005 Δημ. February 7, 2005 Perimenoume kai thn "efthigramish" me toys misthous ths Germanias...... Εχω την εντυπωση οτι οσον αφορα τους μισθους θα μεινουμε στο περιμενε :rolleyes: :rolleyes: Παράθεση http://www.myphone.gr/mp1/support/myphoneuser.jpg
spartak Δημ. February 7, 2005 Δημ. February 7, 2005 Εχω την εντυπωση οτι οσον αφορα τους μισθους θα μεινουμε στο περιμενε :rolleyes: :rolleyes: Και κάτι παραπάνω από το περίμενε! :( Παράθεση
Don_VitoCorleone Δημ. February 7, 2005 Δημ. February 7, 2005 Sto "koimhsou kai h tyxh sou doulevei" Παράθεση
makis_thess Δημ. February 7, 2005 Δημ. February 7, 2005 Το τί συμφέρει το γνωρίζουμε όλοι στο myphone πολύ καλά... Το πρόβλημα είναι για αυτούς που δεν έχουν σύνδεση στο internet ή/και Η/Υ και ακόμα και για εμάς τους ίδιους στην περίπτωση που βρισκόμαστε κάπου (π.χ. καρτοτηλέφωνο) και χρειαζόμαστε επειγόντως πληροφορίες τηλεφωνικού καταλόγου. :!: Και αυτο το κανονισει ο καλος μας ο Ποτε γιαυτο θα κανει pocket "τηλεφωνικο καταλογο" Τσεπης!!!! :lol: :lol: Παράθεση :up: Myphone Meeting @ Thessaloniki 14/12/14 ! XARISETO.GR Μην το πετάς... XariseTo.gr ! 2030.gr Οδηγος camping
myphone-fan Δημ. February 8, 2005 Δημ. February 8, 2005 Perimenoume kai thn "efthigramish" me toys misthous ths Germanias...... Καθώς επίσης και την ευθυγράμμιση των "πακέτων" προσφορών για φθηνότερες κλήσεις, φαινόμενο που ευδοκιμεί όχι μόνο στη Γερμανία αλλά και σε πολλές άλλες χώρες... :rolleyes: Παράθεση
VaradeRo Δημ. February 11, 2005 Δημ. February 11, 2005 Προφανώς η αναφορά στις χρεώσεις που ισχύουν σε άλλες ευρωπαϊκές χώρες είναι ενδεικτική της τακτικής που ακολουθούνται από τους τηλεπικοινωνιακούς οργανισμούς. Εννοείται πως δεν τίθεται ζήτημα σύγκρισης τιμής και μισθών. Σε καθεστώς ελεύθερης οικονομίας ζούμε και τις τιμές τις καθορίζει ο ανταγωνισμός (yeah, right :rolleyes: ) Ανεξάρτητα από το αν υπάρχει δυνατότητα επιλογής της πιο συμφέρουσας για τον καθένα διαδικασίας ανεύρεσης αριθμού συνδρομητή (τυπωμένος κατάλογος, CD, internet), οι κλήσεις στο 118xx είναι (εδώ και πολύ καιρό) υπηρεσίες προστιθέμενης αξίας και για αυτό χρεώνονται παραπάνω από μια αστική κλήση. Είναι τουλάχιστον απλοϊκό να συγκρίνονται με το κόστος πρόσβασης στο internet που απαιτεί από τον ενδιαφερόμενο να έχει υπολογιστή με πρόσβαση στο internet. Σε τελική ανάλυση, δεν είμαστε όλη μέρα στο σπίτι ή στο γραφείο. Μπορεί να ψάχνουμε κάποιο τηλέφωνο ενώ είμαστε στο δρόμο και τότε ίσως είμαστε αναγκασμένοι να καλέσουμε στην ανάλογη υπηρεσία καταλόγου της εταιρείας κινητής τηλεφωνίας. Ο συνδρομητής στις υπόλοιπες ευρωπαϊκές χώρες μπορεί να επιλέξει πού θα καλέσει για να λάβει την ενημέρωση που χρειάζεται. Για παράδειγμα στη Γερμανία μπορείς να καλέσεις στο 11883. Φυσικά και υπάρχει χρέωση, η οποία είναι μικρότερη από αυτήν της D.T. Πουθενά στην Ευρώπη δεν δίνονται δωρεάν τέτοιες πληροφορίες και για αυτό το λόγο η συγκεκριμένη υπηρεσία αποτελεί πεδίο δραστηριότητας ιδωτικών εταιρειών, που ιδρύονται και λειτουργούν με σκοπό το κέρδος, όπως αυτή. Παράθεση Γράφουμε όσα ζούμε: www.pella24.gr
makis_thess Δημ. February 11, 2005 Δημ. February 11, 2005 καλα τα λες και (εν μερη) το καταλαβαινω αλλα ενταξη ειναι μια υπηρεσια να μην την δινουν δωρεαν αλλα οχι και 14 μοναδες χρεωσης. και το δευτερο κακο ουτε στο τηλεφωνικο καταλογο ουτε στο χρυσο οδηγο ουτε στο οτεshop δεν αναγραφουν αυτες τησ χρεωσης αναλυτικα "ουτε καν στο τηλεφωνικο λογαριασμο" αυτο ειναι το κακο με τον Ποτε!! Παράθεση :up: Myphone Meeting @ Thessaloniki 14/12/14 ! XARISETO.GR Μην το πετάς... XariseTo.gr ! 2030.gr Οδηγος camping
