[Επίσημο] Nokia E90 Communicator
nervous
The Nokia E90 unboxed...
Το Ε90 με την νεότερη αναβάθμιση:
V 07.21.0.0
21-05-2007
RA-6
Nokia E90 01
Το πρότυπο AD2P είναι παρόν και απότι φαίνεται, το τελικό προιόν θα το υποστηρίζει πλήρως.
Η στιγμή της επίσημης κυκλοφορίας του πλησιάζει.
  • Απαντήσεις 1,8χιλ.
Το πληρωμα του χρονου εφτασε για να αποκτησω κι εγω το communicator που παντα ηθελα.
Η μη υπαρξη καμερας μεχρι στιγμης ηταν το μονο μειον.
Τωρα...προς ολοταχως!!
Το κινητο ειναι απιστευτο!!
Konstantinos
http://briefcase.pathfinder.gr/download/kostas_kostas/21443/337474/0/GR-FLAG.gif
Review of GSM/UMTS-communicator Nokia E90
http://www.mobile-review.com/review/nokia-e90-en.shtml
iPhone 5S Space Grey
Forum Nokia has published the document S60 Platform: Scalable UI Guideline,which describes how to develop scalable S60 applications and contains the latest information for features introduced in S60 3rd Edition, Feature Pack 2.
Although the document is about FP2, it also contains quite a lot about the E90 and its inner screen with a "custom" screen size of 800 x 352 pixels. The document discusses the design issues with the portrait orientaion mode and landscape orientation mode and the switch between the two display modes, among other things. From page 19-20:
3.3 Designing for custom screen sizes
The Nokia E90 Communicator presents a special case with the landscape 352 x 800 display on the PDA side. Full-scale optimization for the Nokia E90 with custom components is likely to render the application significantly less usable in a standard display.
3.3.1 Optimization for landscape
Some applications may quite naturally use the available space in a large, letter-box display; for example, a Web browser, text editor, or map application would easily use up all the available display space.
However, other applications may have difficulty effectively utilizing all of the available space.
Consider the Contacts application in the Nokia E90:
Figure 11: Permanent preview pane in the Nokia E90 Contacts application
The view is split into two: the details for the currently focused item are shown on the right side of the display for as long as the focus stays on the item on the list. This is implemented using the Preview pop-up component that is available only for the Nokia E90. This way, detailed information regarding the selected item can be viewed immediately, without having to open the item separately.
Another natural way of utilizing the extra space in the Nokia E90 is stretching two-row list to one line with several columns.
3.3.2 Working with two separate displays
In addition to the custom landscape display, the Nokia E90 includes a separate portrait QVGA display. Closing or opening the device cover triggers a display change, a layout switch occurs, and applications are automatically transferred to the new active display.
While an application may be optimized for the PDA display, it should still remain usable when used from the QVGA display. Consider if there are some application features that should be removed when used in the QVGA display. For example, show the permanent preview pane component in the landscape display and replace it with the normal floating preview component with a timeout in the QVGA display.
Do not fill the PDA view with custom components that cannot fit or scale to the QVGA view. Remember that using common S60 components is always safer than using custom components.
Πηγή: http://my-symbian.com
Το βρήκα και σε κατάστημα ΑΛΕΞΑΝΔΡΟΣ στη Θεσσαλονίκη. 820ευρώ μου είπαν. Έφτασα πολύ κοντά να το παραγγείλω αλλά τελικά παρήγγειλα το Ν95 λόγω μεγέθους
Τί λέτε, θα το μετανιώσω?
RX8Club.GR
Επίσημα Αναγνωρισμένο
Σωματείο Φίλων & Ιδιοκτητών RX8 Ελλάδος
δηλαδη εχει ερθει??
εχουνε ετοιμοπαραδοτο??
η το παραγγελνεις και θα περιμενεις μεχρι θα
φτασει στην ελλην.αγορα??
Μου είπαν ότι Τρίτη θα το είχα στα χέρια μου
RX8Club.GR
ενδιαφερον...:shifty: :shifty:
παντως δεν αργησε πολυ σε σχεση με το ν95.
Τι κατάστημα είναι αυτό το ΑΛΕΞΑΝΔΡΟΣ; Οι τύποι με τους οποίους μίλησες, ξέρουν τι λένε; Σε ρωτάω γιατί δεν έχω καμία επαφή με Θεσσαλονίκη.
Το Ε90 δεν έχει ξεκινήσει επίσημα να παράγεται, όχι απλά να κυκλοφορεί. Άρα, πως είναι δυνατόν να σου υπόσχονται οτι θα το έχεις στα χέρια σου την Τρίτη;
Επίσημα, η παραγωγή των πρώτων συσκευών του Ε90, ξεκιάει την 23η βδομάδα του 2007.
Ο Αλέξανδρος είναι μία αλυσίδα καταστημάτων κινητης τηλεφωνίας. Αρκετά διαδεδομένη εδώ στη Θεσσαλονίκη.
Συμφωνώ ότι ειναι ΑΠΙΘΑΝΟ να πρόκειται για Ε90.
Μήπως κατάλαβαν Ε60i??:worry: :p
Beta testing.
Είναι τα προτότυπα που δίνουν σε κάποια συγκεκριμένα άτομα οι οποίοι χρησιμοποιούν την συσκευή και σημειώνουν τις ελείψεις, τα κολλήματα και γενικά την απόδοση της συσκευής.
Η εταιρίες, λαμβάνουν υπόψιν τις παρατηρήσεις τους και προσπαθούν να εξαλείψουν τα όποια προβλήματα της συσκευής.
Το σημαντικότερο είναι οτι αυτές οι συσκευές κυκλοφορούν μόνο για δοκισμαστικούς λόγους και απαγορεύεται ηρτά να πωλούνται.
Εγώ αυτό που ξέρω είναι ότι είχαν το dummie στην βιτρίνα -δεν το έχω δει αλλού- και γι'αυτό μπήκα να ρωτήσω. Δεν είπα ότι θα υπάρχει σε επάρκεια. Είπαν ότι θα μου βρουν ένα από βδομάδα, μάλλον Τρίτη. Το μαγαζί είναι δίπλα στο μαγαζί μου οπότε δεν είμαστε άγνωστοι μεταξύ μας
RX8Club.GR
nice video... οκ καθαρά S60 3ης γενειάς... πραγματικά δεν με χαλάει καθόλου...:p :happy:
To most people, the sky is the limit. To those who love aviation, the sky is home.
Ρε παιδια να κανω μια ερωτηση εχετε κανενα νεο για το ποτε ερχετε το ρημαδι ??? εχω βαρεθει να περιμενω:(:(:(:(:(
μπορείς να μην ξύνεις πληγές τώρα????
πάντως από το Nokia Shop Ελληνικού αυτό που που είπαν τα παιδιά είναι ότι θα είναι Καλοκαίρι...αλλά δεν μπορούν να συγκεκριμενοποιήσουν ημερομηνία... :( δυστυχώς θα περιμένουμε...
:lol: :lol: Ποιό καλοκαίρι δεν διευκρίνησαν!!:cry:
Εγω να δω που θα βρω μια καταραμενη αναβαθμιση για το Ε90 γιατι μου εχει σπασει τα νευρα.... Εχει κανεις καμια ιδεα... ??? :(
