Τεχνολογικοί προβληματισμοί... γενικά!
  • Απαντήσεις 12,4χιλ.
koitaxte ti leei h Jabra gia auto to thema:
Dear Ioannis,
Thank you for your mail.
Unfortunately we have not done a lot of testing in this area, the only thing we
can say is that if the device, mentioned in your mail, supports the following
then it should be able to be used with our Bluetooth headsets:
- Bluetooth profile version 1.1.
- Headset or Handsfree profile (Handsfree profile requires a JABRA BT200
headset with enhanced software)
- Bluetooth DATA and VOICE enabled
This only provides you with that basic technology to communicate between the
JABRA headset and your device, it does not, however, guarantee that you can
control the device from the headset, in other words you would need to control
the media player from your device. You will probably need to change the playback
to Bluetooth audio.
Tip:
To remove the tone melody, tap on the upper button on the unit very briefly and
the beep will stop and playback can be heard through the headset.
On a computer, using windows XP, the audio device automatically changes playback
via Bluetooth when the headset is connected and resets to the hardware default
when disconnected, so there is no need to change it manually.
In additon we believe that your Bluetooth device requires driver version of
1.4.2.0 or above.
We kindly ask you to visit your local PC/PDA/Laptop supplier for detailed info
on exact specifications on the above.
We hope this mail answers some of your questions.
We would be happy to answer any future questions you may have about our
products, so
please do not hesitate to contact us again.
Please visit us at CeBIT, Hall 12, Stand nr. D49
Thank you for contacting JABRA Customer Service, Europe
Best regards
Sophie Herschtel
Customer Service Specialist
GN Netcom, Mobile Division (Copenhagen, Denmark)
Αρχικό Μήνυμα από το μέλος panosFL (19 Φεβ. 2004 , 00:20)
Τεχνολογικός προβληματισμός: Πως γίνεται ο εντοπισμός κινητού μέσω δορυφόρου ( :blink: ) και που απευθυνόμαστε (με τα 3000 ευρώ στο χέρι) για να μας το βρούνε; :confused:
Eλα μου ντε :wacko: :wacko: :wacko:
Proud Owner of:PS1,GB,NES,GbASP,Sega Saturn,Sega DC,PS2,Xbox,Wii,XBOX360(phat),PSP(J)v1.50,(2x)PSP(E),PS3, PSP-Go,(2X)ΧΒΟΧ360SLIM,PS Vita,PS4 Batman Collectors Edition,Wii U,X-ONE,N3DS,X-ONE S,mini NES,Switch,mini PS1,Switch PIKACHU Edition,PS4 Days of Play,XBOX ONE Gears of War 4 Limited Edition 2TB,Xbox One X Cyberpunk 2077 Limited Edition 1TB,XBOX Series S,X, C64mini, Amiga mini, ROG ALLY💘,PS5, PS5 30th Anniversary, Asus Rog XBOX Ally X.
Μακριά από εμένα, αλλά γούστα είναι αυτά.
Ξέρω άτομο που κατεβάζει πολλά παιχνίδια και ήχους από το live. Aν δεν το είχε απλά δε θα κατέβαζε γιατί βαριέται να ασχοληθεί να συνδέσει το κινητό στο PC ή να χρησιμοποιήσει το WAP. Κοινώς η vodafone βρήκε την κότα με τα χρυσά αυγά.
Wirelessly posted (siemens s55: SIE-S55/20 UP.Browser/6.1.0.5.c.6 (GUI) MMP/1.0)
Αρχικό Μήνυμα από panosFL
Αρχικό Μήνυμα από το μέλος Nantia (18 Φεβ. 2004 , 19:08)
entopismos einai leei mesw doryforou k paei 3.000 eyro, myrio koinws...
sto fbi :lol:
και μυνηση να κανεις αφου ξερεις ποιοι ειναι δεν θα κανεις τιποτα αν δε βρεθει το κινητο στην κατοχη τους (που δε θα βρεθει). Καλυτερα μην μπλεξεις και ξεχασε το (εκτος αν εχεις τιποτα φουσκωτους φιλους και τους τουμπανιασεις τους κλεφτες, αλλα παλι αυτοι ειναι κλικες και ειναι επιφοβο). Παντως ξερω πως ενιωσες και σε καταλαβαινω... ενα Τ10 μου πηραν μεσα απο την τσαντα μου και παραλιγο να τον τσακωνα τον μικρουλη ασιατη και θα τον εκανα τουμπανο με τα νευρα που ειχα αλλα ητανε τοσος δα κι εξαφανιστηκε! Ακομα δεν εχω ξαναμπει σε λεωφορειο απο τοτε!!!!
http://briefcase.pathfinder.gr/download/princessofthedawn/11956/308444/0/101_0139.jpg
Lord, let me be the person my dog thinks I am
Wirelessly posted (Panasonic-GAD87/A21 UP.Link/1.1)
Αρχικό Μήνυμα από arfi-gorgona
epistimoniki fantasia einai allo to na pernei sd kai allo na ypostirizei wifi kai to loitourgioko,
Koita den einai toso apisteyto,idi yparxoyn pda me sd wifi ara ena smartphone,(poy'xei to idio os),de tha'tan toso dyskolo...Pane sta MyNews&tha deis oti pros ta'kei pame...
Αρχικό Μήνυμα από το μέλος Yi@nni (19 Φεβ. 2004 , 18:38)
ypothetika tha boreis na exeis wirelles microphone kai earphone
Το bluetooth ακουστικο της motorola λειτουργει ωραιοτατα με το ακολουθο dongle
_http://www.digicom.it/digisit/schedpro.nsf/ENProdottiIDX/PalladioUsbBluetooth100M
Αρχικό Μήνυμα από το μέλος gregorisvas (20 Φεβ. 2004 , 14:16)
Μπα!!Η Vodafone το καλυτερεψε το μενου του GX20.Ειδα φωτογραφια πως θα ηταν εαν ΔΕΝ ηταν η Vodafone στη μεση και τομενου ηταν ΕΛΕΕΙΝΟ!!
Μπορεις να μου δωσεις κανα url να τη δω και εγω?
Ναι γίνεται, απλά αντί για τον αριθμό του κινητού βάζεις το email του
παραλήπτη.
"We don’t see things as they are, we see things as we are."
με ΤΙΜ δουλευει κανονικα με μενα
Έρωτας: Κορυφαίο ιδιοτελές συναίσθημα, αναφέρεται μόνο στις ερωτικές σχέσεις (όπως δείχνει και το όνομα του). Δίνεις τα πάντα στον άλλο και περιμένεις τα πάντα από αυτόν. Παραδίδεσαι ψυχή τε και σώματι και επιθυμείς το ίδιο από το ταίρι σου. Για μένα ο αληθινός μεγαλειώδης έρωτας, αυτός που θα σταματήσει το χρόνο, είναι πιο σπάνιος και προσωπικά πιο επιθυμητός από την αγάπη.
douleuei kanonika kai me tis treis etaireies..
ekei pou thelei prosoxi einai ston tropo grafhs tou e-mail..
prepei ola ta grammata na einai latinika, akoma kai an uparxei to gramma ''o'' mesa stin dieuthinsi prepei kai auto na einai latiniko..
Αρχικό Μήνυμα από το μέλος lewton (20 Φεβ. 2004 , 21:09)
άντι να περνάει από pc κάνενα midi ή java τζάμπα προτιμάει να τα πληρώνει χρυσά... γούστα είναι αυτά... :whistle:
Wirelessly posted (Nokia3510i/1.0 (04.44) Profile/MIDP-1.0 Configuration/CLDC-1.0)
Αρχικό Μήνυμα από Stratos
mipos stelneis se hotmail?
exw akousei oti kapoies fores trwne porta ta emails meso kinitou...
an nai, dokimase kapoion allo paroxea...
Emena pantws pou exoun paei pros hotmail...
