[Επίσημο] Qtek 9000 (Imate Jasjar / Vodafone v1640 / Universal)
geovass
kalispera
To pira apiteloys simera (o2 Exec) alla exo xasei tin mpala.
-To active sync (4.0) den vgazei epiloges gia to singxronismo??? den mporo na oriso apo poo folder tha kanei sync kai pos tha epilyontai oi diples egraffes?
-Pos kano hard reset kai poies oi diafores anamesa sta corporate klp versions???Poia na valo? (Ok ta vrika)
-Den mporo na katalavo an exei sim lock... Vazo tin vodafone sim (UK) kai anti gia to simataki me to g stin pano mpara vgazei ena me U...Alla exei diktyo.Mia UTMS Vodafone kai mia Vodafone UK.Mperdeytika :-( (Akyro)Katalava :D
-Poy mporo na vro rythmiseis gia voda?
PLEASE HELP
Me to s100 ola itan toso apla.
Ksero oti mporei na kraksete alla pragmatika den exo xrono na psakso. Eimai se assignment week. Apo tetarti den tha ksanarotiso tipota alla tora prepei na ftiakso ayta ta vasika pragmata.
Eyxaristo oloys
ps. Exo tom tom 5.1 poy paizei sto exec. apoios thelei mporo na prospathiso na to steilo sto mail toy. 45mb xorismeno se 7aria klp
edit: oyte enas kalos anthropos na paro kai ego ta mms moy???? :worry:
http://www.qtek.gr/9090_vodafone.html ;)
  • Απαντήσεις 6,4χιλ.
thanx geovass alla toylaxiston ayto to dokimasa prin zitiso help.
xreiazomai Uk voda. Simera katafera na ftiakso to gprs / 3g kai mporo na mpo internet alla pali ta mms den theloyn na doylepsoyn.
Any ideas?
Αλέξανδρος
Πολυ καλο προγραματακι για να "κλεινετε" τις εφαρμογες σας στο Jasjar !!
Εχει και batery meter! ;)
Magic Button for pocket pc
Version 2.0 (Build 51023)
http://www.trancreative.com/mb.aspx ! ;)
Why Magic Button worth considering to download and replace your existing one:
* It is free.
* Does not take up any of your screen real estate, yet easy to access.
* Located on title bar but does not cover any standard info, i.e. Sound icon, notification icon.
* Very small foot print (memory usage). Only 71 KB executable file does it all (help file is 8 KB extra).
* Makes close button really close applications. Just in case you haven't noticed, the default one only minimizes them.
* Compatible with latest and greatest Windows Mobile 5.0 (new in version 2.0).
Magic Button looks clean and blends surprisingly well with the Pocket PC theme. For those who do not want too fancy or too complicated Task Manager, this is for you.
If you have installed the software, here is how to master the tool:
* To unload (shutdown) Magic Button: Tap and hold on Close button, then tap and hold on Home icon.
* To show/hide the taskbar: tap and hold the OK/Minimize/Close button.
* To show the application menu that has Settings and Exit menu items: tap and hold Today (Home) icon when it is visible.
* Map a PocketPC application button to Magic Button software then you can show/hide the bar easier by pressing the button.
* To close an individual window: tap and hold its window icon on the task bar.
* To change Close Button behaviour (Close instead of Minimize) for an application: tap and hold on the app icon and select "Keep Alive" option.
Magic Button runs on Pocket PC 2002, 2003, 2003SE and Windows Mobile 5.0. VGA screen is supported.
Kalispera sto forum,
mia erotisoyla... :O
Mipos exei kaneis prosvasi sto club i mate? psaxno ta cub arxeia poy yparxoyn ekei gia na katafero na ftiakso tis rythmiseis moy gia voda uk payg.
ksero ligo apithano alla leo ego tora... :D
eyxaristo
Αλέξανδρος
eyxaristo
dvse email... ;)
Να χαιρετησω κι εγώ το thread ως ακόμα ένας ευτυχής κάτοχος του Universal με το brand name της O2, δηλαδή το XDA Exec.
Κάτι πολύ σημαντικό που θέλω να ρωτήσω είναι το εξής!!!
ΕΧΕΙ ΚΑΤΑΦΕΡΕΙ ΚΑΝΕΙΣ ΝΑ ΒΑΛΕΙ ΕΛΛΗΝΙΚΑ ΜΕ ΤΟΝΟΥΣ ΣΤΟ AEKMAP???
Παιδιά, δε μου απαντήσατε αν τελικά το Universal υποστηρίζει video-calls! Θα το εκτιμούσα απεριόριστα.
Ναι υποστηριζει
Η συζήτηση έχει υπερεκτιμηθεί ως μέσο επίλυσης διαφορών
re paidia ti pezi me to Orange M5000 mipos epidi einai apo Uk exoyne klidosi to thl.gia alli xwra?? to brika 570 eyr peripoy lete na exo ayto to problima 8a einai off se alli xwra...-8a moy to stiloyne apo uk 8a pane na to paroyne apla i kopela 8a einai ligo asxeti kai den 8a mporo na ti po tipote apla 8a to pari- :)
kapio help...
spyros
:cool:
GIVE ME YOUR MIND AND I'M A OPEN IT,NAME A LAW AND I'VE ALREADY BROKEN IT,CAUSE I DON'T GIVE A FUCK ABOUT THE SYSTEM-----By_Fidel
απο προτερη εμπειρια, τα orange και ο2 smartphones/pda ειναι γενικα κλειδωμενα, δηλαδη παιζουνε μονο με την αντίστοιχη sim.
Καλο θα ηταν πριν το παρει να ρωτησει απλά αν παιζει και με sim αλου δικτύου, παντως η τιμη που λες πρεπει να ειναι με συμβόλαιο ή σε λίρες, και όχι σκέτη συσκευή. (εκτος αν κανει τη συνδεση η φίλη σου). Αυτη τη στιγμή το φθηνότερο Universal μπορεις να το βρεις στο mobilejoker.de το mda Pro με 722 ευρώ, και απλά να φλασάρεις την αγγλική rom του jasjar με το upgrade no id. ;)
xmm..diladi xlomo :) ean tin flasaro thn rom thn aggliki logika den 8a exi kai eggisi kapos etsi..kalitera na perimeno ... ;)
αυτο το site ειναι συνηθως το πρωτο που ξεκλειδωνει τις συσκευες της orange. φυσικα εναντι καποιας αμοιβης. δεν βλεπω να εχουν ακομα κατι για το M5000. μπορεις ομως να το τσεκαρεις και οταν εμφανιστει το unlock το παιρνεις!!;)
oleeeeeeeeeeeeeeeeeeeee :D :D :D
Πώς θα κάνω συγχρονισμό μέσω Bluetooth; Δεν έχει επιλογές για προφίλ οπότε όταν κάνω bond με το PC δεν μου δίνει δυνατότητα να κάνω Activesync partnership.
Απαντάω στην ερώτησή μου. :)
Πρέπει να δημιουργήσεις χειροκίνητα μια bt com στις θύρες com των option του bluettoth στο pc και μετά να δημιουργήσεις ένα partnership με το ppc. Αν δεν πετύχει με την πρώτη να βγάλει δυνατότητα συγχρονισμού αμέσως μετά από το bonding θέλει μερικές προσπάθειες...
Για θήκη παίζει τίποτα καλό; Βασικά θα προτιμούσα της Krusell που έχω και κάποια κλιπς από παλαιότερες θήκες αλλά δεν βλέπω να έχει βγάλει τίποτα ακόμη.
Από την μέχρι τώρα εμπειρία μου με το universal έχω παρατηρήσει τα εξής ελαττώματα, τα οποία ναι μεν ελάχιστα μπροστά στα καλά αλλά πολύ ενοχλητικά δε.
1) Όταν έχεις κλειστό το καπάκι της οθόνης θα έπρεπε να ανοίγει η οθόνη όταν το ανοίγεις ή τουλάχιστον να σου δίνει την επιλογή να επιλέξεις.
2) Όταν σε παίρνουν τηλέφωνο θα έπρεπε να ανοίγει μόνο του το bluetooth αν έχεις συνδέσει bluetooth handsfree έστι ώστε να προωθείται η κλήση. Μπορείς βέβαια να το αφήσεις μόνιμα ανοιχτό αλλά δεν είναι λύση αυτή διότι θα εξαντλείται η μπαταρία.
3) Όταν έχεις κλειστό το καπάκι της οθόνης δεν έχεις δυνατότητα να δώσεις φωνητική εντολή δίχως να το ανοίξεις μαζί με την οθόνη. Αυτό ταυτόχρονα σημαίνει ότι δεν μπορείς να κάνει voice dial όταν οδηγείς αν δεν ανοίξεις πρώτα το pda!!
Αν έχει βρει κανείς λύση ή αν υπάρχει κάτι σε αυτά ας ενημερώσει.
Για το Νο 3 δεν ειναι ετσι. Εγω το εχω κλειστο και απλα παταω το κουμπι στο BT μου και λεω το ονομα που θελω να καλεσω!
Δουλευει 100%.
pare tilefono sto modern-talking
exei feri thiki.....
tin ida tin paraskevi
Current Multimedia BOX.: HTC ARTEMIS - P3300 :tease:
(mou kopsane ta polla polla.... ;-(( )
Δουλευει 100%.
Σε μένα όχι. Ίσως επειδή φοράει την rom της Ο2. Ποιο stack έχει το Jasjar?
το ιδιο με το δικο σου. Η rom που εχουμε στο jasjar ειναι η WWE_11353_137_10301 ενω η δικη σου (αν εχεις την πιο προσφατη) ειναι η launchromo2v113139, δηλαδη εχεις πιο καινουρια extended rom, οχι ομως και διαφορετικο bt stack. Αυτο που λεει ο geovass, γινεται απο το bt headset και σε μενα, με κλειστο το jasjar, αλλα προσεξε γινεται με συγκεκριμενα bt headsets. Για παραδειγμα με το παλιο motorolaki που ειχα με την αλκαλικη μπαταρία, bt voice dial δεν επαιζε
