v@gelis Δημ. May 6, 2013 Δημ. May 6, 2013 Το νεο Surface θα καθυστερησει -κατα τα φαινομενα... http://www.tabletpcreview.com/default.asp?newsID=4082&news=Microsoft-Surface-2-Windows-8-Tablet-Screen-Size An industry analyst claims to have some of the details of the much-rumored smaller version of the Microsoft Surface Windows tablet that's supposedly in development. According to Richard Shim with NPD DisplaySearch, the device is going to have a 7.5-inch touchscreen with a resolution of 1400 x 1050. That will give it a pixel density of 233ppi. By contrast, the current Surface Pro has a 10.6-inch display at a 1920 x 1080 resolution and 208ppi. The Surface RT also has a 10.6-inch screen but at a 1366 x 768 resolution and 148ppi. These days, smaller and less expensive tablets are outselling their larger counterparts. Microsoft is apparently following this trend. According to Shim, the second-generation Surface won't reach full production until the first quarter of 2014, although he says it's possible that production could begin before then. This means the device won't be out for many months, which seems to contradict a recent report that it's going to be unveiled in June. The analyst says Microsoft is working to make the device as inexpensive as possible. A separate unconfirmed report indicates that it could be as low as $400. Shim did not indicate whether this 7.5-inch model will run Windows RT or Windows 8 Pro. It's possible there will be two versions, just as there are of the first-gen Surface. Παράθεση
alextrela Δημ. May 6, 2013 Author Δημ. May 6, 2013 (edited) Κοιτά Βαγγέλη μπορεί όπως λες να αργήσουν τα νέα Surface,αλλα στάνταρ θα κυκλοφορήσουν και από άλλους κατασκευαστές και πιθανός πριν την περίοδο των Χριστουγέννων ή κατα την εορταστική εξίσου. Ας συνοδεύτουν με τους Bay Trail,ντινεζατα με premium υλικα και εδώ είμαστε να τα τιμήσουμε :p Εμένα 8 ιντσες με έχουν βολέψει πολύ και η φορητοτητα τους είναι ασυναγωνιστη(iPad mini) Ας στρωθουν οι OEM στη δουλειά και ας σοβαρευτούν διότι με βλέπω με τον διάδοχο του iPad mini με retina και μια χαρά θα με βολέψει εξισου;) Edited May 6, 2013 by alextrela Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
v@gelis Δημ. May 6, 2013 Δημ. May 6, 2013 Κοιτά Βαγγέλη μπορεί όπως λες να αργήσουν τα νέα Surface,αλλα στάνταρ θα κυκλοφορήσουν και από άλλους κατασκευαστές και πιθανός πριν την περίοδο των Χριστουγέννων ή κατα την εορταστική εξίσου. Ας συνοδεύτουν με τους Bay Trail,ντινεζατα με premium υλικα και εδώ είμαστε να τα τιμήσουμε :p Εμένα 8 ιντσες με έχουν βολέψει πολύ και η φορητοτητα τους είναι ασυναγωνιστη(iPad mini) Ας στρωθουν οι OEM στη δουλειά και ας σοβαρευτούν διότι με βλέπω με τον διάδοχο του iPad mini με retina και μια χαρά θα με βολέψει εξισου;) Ναι θα εχουν κυκλοφορησει σιγουρα αρκετες υλοποιησεις πριν την περιοδο των χριστουγεννων. Βεβαια και αυτο φανταζει -κι ειναι- μακρινο ακομα. Αλεξ καλες οι 8 ιντσες (θα παρω την Τεταρτη και ενα νοτελι 8), αλλα ειναι μονο για συγκεκριμενες - απλες δουλειες. Δεν ειναι σε θεση να υποστηριξουν δυνατες cpu/gpu και κατα συνεπεια ακομα και W8 υλοποιησεις θα ειναι "αδυναμες" για συνδεση με εξωτερικη οθονη/πληκτρολογιο και σοβαρη εργασια. Κατα συνεπεια καλα τα 8ιντσα (καλοδεχουμενο και το mini retina οταν ερθει), αλλα θα ειναι μια απο τα ιδια: Πλοηγηση στο διαδικτυο, pdf reading, pim management (απλο) και... τελος... Παράθεση
alextrela Δημ. May 7, 2013 Author Δημ. May 7, 2013 Ναι θα εχουν κυκλοφορησει σιγουρα αρκετες υλοποιησεις πριν την περιοδο των χριστουγεννων. Βεβαια και αυτο φανταζει -κι ειναι- μακρινο ακομα. Αλεξ καλες οι 8 ιντσες (θα παρω την Τεταρτη και ενα νοτελι 8), αλλα ειναι μονο για συγκεκριμενες - απλες δουλειες. Δεν ειναι σε θεση να υποστηριξουν δυνατες cpu/gpu και κατα συνεπεια ακομα και W8 υλοποιησεις θα ειναι "αδυναμες" για συνδεση με εξωτερικη οθονη/πληκτρολογιο και σοβαρη εργασια. Κατα συνεπεια καλα τα 8ιντσα (καλοδεχουμενο και το mini retina οταν ερθει), αλλα θα ειναι μια απο τα ιδια: Πλοηγηση στο διαδικτυο, pdf reading, pim management (απλο) και... τελος... Βαγγέλη οι Bay Trail από την Intel θα παρέχουν κατα πολύ πιο βελτιωμένες επιδόσεις από τους παρόν Atom;) 1.Θα υποστηρίζουν αναλύσεις οθόνης πάνω από full hd 2.Pure SSD support Sata 3καμία σχέση με τις flash memory των σημερινών tablet με Atom 3.DDR3 μνήμη θα υποστηρίζουν από DDR2 των Atom και με υποστήριξη και πάνω από 2GB εγκατεστημένη μνήμη 4.Direct X 11 support 5.USB 3.0 support εξίσου 6. Επιδόσεις HD4000 στο τομέα γραφικών Και όλα αυτά με τις σημερινές αυτονομίας των σημερινών Atom Clovai Trail. Άρα μια χαρά θα σηκώνει και συνεργασία με οθόνες και ποντικο πληκτρολόγιο και άνετα θα αντεπεξέλθουν σε πλήθος εφαρμογών και παιχνίδια εξίσου.:p;) Φτάνει να κυκλοφορήσουν στην ώρα τους εκεί είναι το ζητούμενο. Εγω δηλαδη σκέφτομαι ένα 8ρι σε ιντσες tablet για super φορητοτητα και ένα 11.6 με 13.3 για το σπίτι και full laptop replacement αρκεί να βρω κάποιο μοντέλο να μου κάνει κλικ όπως το Book και στάνταρ το θέλω με backlit keyboard και μπαταρία στο dock και βέβαια τους Haswell στην καρδιά του. Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
v@gelis Δημ. May 7, 2013 Δημ. May 7, 2013 Ετσι ειναι Αλεξ, αναμονη για να δουμε ωραια πραγματα το φθινοπωρο. Επειδη ομως το φθινοπωρο ειναι μακρια και εμεις εκτος θεματος, θελω να γραψω οτι πλεον εχω στα χερια μου και τα 2 πληκτρολογια για το Surface μου. Touch cover και απο σημερα και το Type Cover (μολις αφιχθη απο Αμερικη και ευχαριστω και απο εδω το φιλο doctor_gio για την εξυπηρετηση) και μπορω να πω οτι το type cover ειναι κατα πολυ ανωτερο. Κι ο λογος ειναι οτι περαν του οτι υπαρχει κανονικο feedback, αρα το τυφλο συστημα δουλευεται πολυ σωστα, δεν ειναι τοσο παχυ οσο το περιμενα και κατα συνεπεια η υπαρξη του touch cover δεν εχει και ιδιαιτερο νοημα. Παράθεση
Starback Δημ. May 8, 2013 Δημ. May 8, 2013 Καλησπέρα και χρόνια πολλά και από εμένα! Μιας και δεν υπάρχει νήμα για το Surface RT αποφάσισα να σας "την πέσω" εδώ! Βαγγέλη με γειά και καλοδούλευτο και παρατηρώ ότι κινούμαστε σε παράλληλους δρόμους, Ativ Pro εσύ, Ativ εγώ, Surface Pro εσύ, Surface εγώ! Η αλήθεια είναι ότι αν και πολύ πρόσφατος κάτοχος του Surface RT είμαι πολύ ευχαριστημένος, απίστευτη ποιότητα κατασκευής, φαίνεται να έχει καλές αυτονομίες και δεν με προβλημάτισε στην ταχύτητα ακόμα. Η βασική του έλλειψη θα έλεγα ότι είναι το digitizer, καθώς όπως και εσύ έχω καλομάθει με το NOTE II και τα ATIV και NOTE 10.1. Παρόλα αυτά διαπίστωσα ότι δεν το χρησιμοποιούσα τόσο ώστε να μου είναι απαραίτητο και φλερτάρω με την ιδέα να πάρω ένα Adonit Jot Pro που διάβασα πολύ καλά σχόλια για την ακρίβεια του σαν capacitive stylus. Όσο για το touch cover το δούλεψα λίγο και νομίζω ότι με λίγη συνήθεια θα με καλύψει όταν το χρειάζομαι. Παράθεση Samsung Galaxy Note 9
v@gelis Δημ. May 11, 2013 Δημ. May 11, 2013 Καλησπέρα και χρόνια πολλά και από εμένα! Μιας και δεν υπάρχει νήμα για το Surface RT αποφάσισα να σας "την πέσω" εδώ! Βαγγέλη με γειά και καλοδούλευτο και παρατηρώ ότι κινούμαστε σε παράλληλους δρόμους, Ativ Pro εσύ, Ativ εγώ, Surface Pro εσύ, Surface εγώ! Η αλήθεια είναι ότι αν και πολύ πρόσφατος κάτοχος του Surface RT είμαι πολύ ευχαριστημένος, απίστευτη ποιότητα κατασκευής, φαίνεται να έχει καλές αυτονομίες και δεν με προβλημάτισε στην ταχύτητα ακόμα. Η βασική του έλλειψη θα έλεγα ότι είναι το digitizer, καθώς όπως και εσύ έχω καλομάθει με το NOTE II και τα ATIV και NOTE 10.1. Παρόλα αυτά διαπίστωσα ότι δεν το χρησιμοποιούσα τόσο ώστε να μου είναι απαραίτητο και φλερτάρω με την ιδέα να πάρω ένα Adonit Jot Pro που διάβασα πολύ καλά σχόλια για την ακρίβεια του σαν capacitive stylus. Όσο για το touch cover το δούλεψα λίγο και νομίζω ότι με λίγη συνήθεια θα με καλύψει όταν το χρειάζομαι. Καλως το Γιαννη. Καλοριζικο και σε σενα ευχομαι! Να υποθεσω οτι εφυγες κι εσυ απο τη σαμμυ για το γνωστο λογο (γελοια υλικα)? Το surface pro, συγκρτικα με το ativ pro σε αυτο τον τομεα, ειναι η μερα με τη νυχτα. Απο εκει και περα, ναι, να κανεις την κινηση, αφου το ξερεις οτι ειμαστε εθισμενοι με τη γραφιδα. Ηταν και ο μοναδικος λογος που εφυγα απο acer w700 και πηγα στο surface pro - ο Wacom digitizer. Για το touch cover, συμφωνω, για λιγη δουλιτσα ειναι ιδανικο και προστατευει και την οθονη. Εγω εχω στην κατοχη μου και τα 2, αλλα τελικα πιο πολυ χρονο αυτο θα εχω κουμπωμενο ;) Παράθεση
unforgiven Δημ. May 15, 2013 Δημ. May 15, 2013 Βγήκε και ο driver της Wacom που υποστηρίζει πλήρως όλα τα προγράμματα, πχ Photoshop, Paint κτλ... Παράθεση Ποτέ μην λογομαχείς με έναν βλάκα... Θα σε ρίξει στο επίπεδό του και θα σε νικήσει λόγω πείρας.
v@gelis Δημ. May 16, 2013 Δημ. May 16, 2013 Βγήκε και ο driver της Wacom που υποστηρίζει πλήρως όλα τα προγράμματα, πχ Photoshop, Paint κτλ... Δωσε ένα link αν σου είναι εύκολο... Παράθεση
unforgiven Δημ. May 24, 2013 Δημ. May 24, 2013 Δωσε ένα link αν σου είναι εύκολο... Άργησα να ξαναμπώ... Ο driver από εδώ. Παράθεση Ποτέ μην λογομαχείς με έναν βλάκα... Θα σε ρίξει στο επίπεδό του και θα σε νικήσει λόγω πείρας.
v@gelis Δημ. May 26, 2013 Δημ. May 26, 2013 Άργησα να ξαναμπώ... Ο driver από εδώ. Οκ σε ευχαριστω. Μηπως εχεις ακολουθησει και τον οδηγο του xda για το σωστο screen calibration? Ειχε επιτυχια στη συσκευη σου; Παράθεση
unforgiven Δημ. May 27, 2013 Δημ. May 27, 2013 Δεν πολυασχολήθηκα να σου πω... Και σήμερα ανακάλυψα πως ο γιος μου εξαφάνισε το stylus από εκεί που, νόμιζα πως, το έκρυβα. Παράθεση Ποτέ μην λογομαχείς με έναν βλάκα... Θα σε ρίξει στο επίπεδό του και θα σε νικήσει λόγω πείρας.
v@gelis Δημ. May 29, 2013 Δημ. May 29, 2013 Δεν πολυασχολήθηκα να σου πω... Και σήμερα ανακάλυψα πως ο γιος μου εξαφάνισε το stylus από εκεί που, νόμιζα πως, το έκρυβα. Χαχα, ναι το ατιμο, χανεται ευκολα. Επρεπε να εχει slot, ειναι απο τα λιγα πραγματα που μου εχουν λειψει απο το ativ pro... Παράθεση
unforgiven Δημ. June 4, 2013 Δημ. June 4, 2013 Χαχα, ναι το ατιμο, χανεται ευκολα. Επρεπε να εχει slot, ειναι απο τα λιγα πραγματα που μου εχουν λειψει απο το ativ pro... Ναι, μεγάλο φάουλ. Τελικά το βρήκα. Ευτυχώς, γιατί είναι και ακριβό. Παράθεση Ποτέ μην λογομαχείς με έναν βλάκα... Θα σε ρίξει στο επίπεδό του και θα σε νικήσει λόγω πείρας.
alextrela Δημ. September 23, 2013 Author Δημ. September 23, 2013 (edited) Μολις πριν λιγα λεπτα ανακοινωθηκε απο τη MS ο διαδοχος του Surface Pro με τους Haswell και ανανεωμενα αξεσουαρ(dock keyboard-stand) http://www.engadget.com/2013/09/23/microsoft-new-surface-pro-2-gets-official/ http://reviews.cnet.com/tablets/microsoft-surface-pro-2/4505-3126_7-35827901.html Εδω απο τα νεα αξεσουαρ (docking station, Power Cover and Type Cover 2) http://www.engadget.com/2013/09/23/microsoft-surface-pro-2-accessories/ http://img818.imageshack.us/img818/4621/rq0v.jpg Edited September 23, 2013 by alextrela Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
v@gelis Δημ. September 23, 2013 Δημ. September 23, 2013 Μολις πριν λιγα λεπτα ανακοινωθηκε απο τη MS ο διαδοχος του Surface Pro με τους Haswell και ανανεωμενα αξεσουαρ(dock keyboard-stand) http://www.engadget.com/2013/09/23/microsoft-new-surface-pro-2-gets-official/ Εδω απο τα νεα αξεσουαρ http://www.engadget.com/2013/09/23/microsoft-surface-pro-2-accessories/ http://img818.imageshack.us/img818/4621/rq0v.jpg Μπραβο, ενα εξαιρετικο tablet pc εγινε σχεδον τελειο. Μεγαλυτερη αυτονομια (κατα πολυ), πολλες επιλογες συνδεσιμοτητας και configuration (μεχρι 512GB/8GB RAM απο οτι ειδα), μπολικα αξεσουαρ διαθεσιμα (το power cover εξαιρετικο), γενικα εξαιρετικη αναβαθμιση... Παράθεση
alextrela Δημ. September 23, 2013 Author Δημ. September 23, 2013 (edited) Μπραβο, ενα εξαιρετικο tablet pc εγινε σχεδον τελειο. Μεγαλυτερη αυτονομια (κατα πολυ), πολλες επιλογες συνδεσιμοτητας και configuration (μεχρι 512GB/8GB RAM απο οτι ειδα), μπολικα αξεσουαρ διαθεσιμα (το power cover εξαιρετικο), γενικα εξαιρετικη αναβαθμιση... Οντως Βαγγελη εξαιρετικη αναβαθμιση μαλιστα εξοπλισε το dock keyboard με extra μπαταρια και backlit παρακαλω. ''Microsoft announces thinner Touch Cover 2 with backlight for its new Surface tablets'' http://www.theverge.com/2013/9/23/4761720/microsoft-announces-new-touch-cover-2-for-for-its-new-surface-tablets http://www.theverge.com/2013/9/23/4761448/microsoft-surface-power-cover-battery Και καποια extra features μαζι με καθε tablet pc ''Microsoft reveals Surface Music Cover, gives DJs more musical tools '' http://www.engadget.com/2013/09/23/microsoft-surface-music-cover/ ''Surface and Surface Pro 2 buyers get 200GB SkyDrive storage for two years, free international Skype calls for one year '' http://www.engadget.com/2013/09/23/surface-2-free-skydrive-skype/ Εδω καποια πρωτα hands-on http://www.theverge.com/2013/9/23/4759902/surface-pro-2-hands-on http://www.engadget.com/2013/09/23/microsoft-surface-pro-2-hands-on/ Αναλυτικα τα χαρακτηριστικα εδω -Οθόνη 10.6” Full HD (1920 x 1080) με υποστήριξη γραφίδας -Επεξεργαστής Intel Core i5 Haswell -Μνήμη RAM 4GB/8GB -Αποθηκευτικός χώρος 64/128GB (4GB RAM) και 256/512GB (8GB RAM) -Υποδοχές USB 3.0, microSD στο tablet και στο dock extra usb θυρες συν Mini DisplayPort, Ethernet connection and audio input / output. -Λειτουργικό σύστημα Windows 8.1 -Μπαταρία 42Wh (7.5 ώρες αυτονομία, έως 12 ώρες με το νέο Power Cover) -Διαστάσεις 274.6 × 173 × 13.5 mm -Βάρος 900gr http://img837.imageshack.us/img837/3891/l5uk.png http://img513.imageshack.us/img513/4514/4jqs.jpg Edited September 23, 2013 by alextrela Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
alextrela Δημ. October 20, 2013 Author Δημ. October 20, 2013 (edited) Πρωτες επισημες τιμες για το tablet απο γνωστη διεθνης αλυσιδα προιοντων τεχνολογιας στα 64 και 128gb ssd. http://www.mediamarkt.at/mcs/product/MICROSOFT-Surface-Pro-2-64GB,10255,438609,958960.html?langId=-15 http://www.mediamarkt.de/mcs/product/MICROSOFT-6CX-00004-SURFACE-PRO-2-128GB-4GB-RAM,48353,462856,974163.html?langId=-3 Edited October 20, 2013 by alextrela Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
Starback Δημ. October 23, 2013 Δημ. October 23, 2013 Καλησπέρα μετά από καιρό! Όντως πολύ ενδιαφέρον το Surface Pro 2. Εγώ πάντως εδώ και δύο μέρος πήρα από φίλο μέσα από εδώ το Surface Pro (ευτυχώς έχω γυναίκα με κατανόηση και με αφήνει να δοκιμάζω tablets μέχρι να καταλήξω κάπου, αρκεί να της κανονίζω συχνά spa :-) ) και επιτέλους μπορώ να πω ότι δουλεύω Office με την άνεση μου! Το μόνο που "ζορίζει" λίγο την κατάσταση είναι η περιορισμένη αυτονομία του, αλλά αναμένω το power cover το 2014 και ψάχνω εναγωνίως και για το type cover 2 στο ενδιάμεσο. Παράθεση Samsung Galaxy Note 9
alextrela Δημ. October 27, 2013 Author Δημ. October 27, 2013 Καλημερα,εφοσον το power cover ειναι συμβατο με την πρωτη γενια του Surface-λογικα πρεπει να ειναι- θα ειναι μια πολυ καλη αναβαθμιση μιας και θα σου προσθεσει επιπλεον ωρες αυτονομια βαλε επισης και το backlit που ειναι ενα + επιπλεον. Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
Starback Δημ. October 28, 2013 Δημ. October 28, 2013 Καλησπέρα Alex, Είναι όντως συμβατό με το power cover και είναι μια από τις αγορές που σίγουρα θα κάνω το 2014 και μάλιστα σύμφωνα με το http://www.winsupersite.com το Pro 1 με το power cover έχει μεγαλύτερη αυτονομία από ότι το Pro 2 (χωρίς το power cover). Γενικά είμαι πολύ ευχαριστημένος και ακόμα ψάχνω από που μπορώ να αγοράσω το type cover 2 στο ενδιάμεσο που επίσης είναι backlit. Παράθεση Samsung Galaxy Note 9
alextrela Δημ. October 28, 2013 Author Δημ. October 28, 2013 (edited) Καλησπέρα Alex, Είναι όντως συμβατό με το power cover και είναι μια από τις αγορές που σίγουρα θα κάνω το 2014 και μάλιστα σύμφωνα με το http://www.winsupersite.com το Pro 1 με το power cover έχει μεγαλύτερη αυτονομία από ότι το Pro 2 (χωρίς το power cover). Γενικά είμαι πολύ ευχαριστημένος και ακόμα ψάχνω από που μπορώ να αγοράσω το type cover 2 στο ενδιάμεσο που επίσης είναι backlit. Να τσεκαρεις εδώ τακτικά που ανανεώνεται σε καθημερινή βάση για διαθεσιμότητες/καταστήματα και τιμές http://skinflint.co.uk/eu/microsoft-surface-power-cover-5vx-00003-a1006178.html http://skinflint.co.uk/eu/microsoft-surface-type-cover-2-black-n3w-00011-a1006101.html http://skinflint.co.uk/eu/microsoft-surface-type-cover-2-blue-n7w-00012-a1006149.html Edited October 28, 2013 by alextrela Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
Starback Δημ. November 2, 2013 Δημ. November 2, 2013 Σε ευχαριστώ για τις πληροφορίες Alex! Τελικά πήρα ένα wedge keyboard και mouse καθώς το 2014 σκοπεύω να πάρω το power cover και θα έμπαινε σε αχρηστία το type cover. Παράθεση Samsung Galaxy Note 9
jtheogr Δημ. November 27, 2013 Δημ. November 27, 2013 Ξερετε κανενα αξιοπιστο site απο το εξωτερικο για αγορα του pro 2 Παράθεση
alextrela Δημ. November 27, 2013 Author Δημ. November 27, 2013 Ξερετε κανενα αξιοπιστο site απο το εξωτερικο για αγορα του pro 2 Απο amazon άμεσα διαθέσιμο είναι http://www.amazon.de/gp/aw/d/B00FZW4UCM/ref=mp_s_a_1_1?qid=1385579671&sr=8-1&pi=AC_SX110_SY165_QL70 Ο ίδιος πωλητής το δίνει και στο αγγλικό. Σε 64 και 128αρα version. Υπάρχουν και άλλοι πωλητές με λίγο ψάξιμο τους βρίσκεις,αμαζον πάντα. Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
