Viper Δημ. July 28, 2005 Δημ. July 28, 2005 Yeap. Το WinFS θα γίνει διαθέσιμο στα WinXP. Φιλε μου, αναφερομουν στα Vista. Μαλλον δεν διατυπωσα καλα την ερωτηση. :O Τα Vista δεν θα εχουν WinFS οπως λεγοταν αρχικα. Και ερωτω: Υπαρχει περιπτωση να το διαθεσουν σε καποιο Service Pack των Vista ή θα το δουμε στα Windows 2010? :D ΥΓ: Αφου δεν θα το βαλουν στα Vista, δεν νομιζω να το διαθεσουν στα XP οπως λες.
Demis_CY Δημ. July 28, 2005 Δημ. July 28, 2005 Φιλε μου, αναφερομουν στα Vista. Μαλλον δεν διατυπωσα καλα την ερωτηση. :O Τα Vista δεν θα εχουν WinFS οπως λεγοταν αρχικα. Και ερωτω: Υπαρχει περιπτωση να το διαθεσουν σε καποιο Service Pack των Vista ή θα το δουμε στα Windows 2010? :D ΥΓ: Αφου δεν θα το βαλουν στα Vista, δεν νομιζω να το διαθεσουν στα XP οπως λες. Einai idi mesa sto Longhorn.. What is "WinFS"? "WinFS" is the active storage subsystem in "Longhorn" that is used for searching, organizing, and sharing data. "WinFS" maintains a store of items and their properties, and provides a system service in "Longhorn" to retrieve information when it's needed. Because "WinFS" allows organization and retrieval of items based on properties (such as author or title), users can find things more quickly. Users can also organize, relate, and act on their documents, music, photos, e-mail, calendar information, and other types of items more efficiently. What are the benefits of Using "WinFS" In "WinFS," how information is organized is separate from how that information is stored physically. How users and applications organize information is also separate from how the information is saved. Data can be organized using a connected folder structure, namespaces, properties, tables, invariant identities, or relationships. To benefit developers, the "WinFS" platform supports unified data services for all end-user applications. Integrated data services such as synchronization, notification, a unified store, and a common security model, and their integration with other technologies such as peer-to-peer networking and directory services, make data sharing among applications easier. These data services enable you to write applications that exchange data with applications built by other software developers. Also, "WinFS" works with other Windows-based technologies to allow information sharing remotely with both "WinFS" and non"WinFS" stores. What is "WinFS" capable of? "WinFS" supports efficient indexing of file content, which enables rich querying that is very difficult to achieve with other file systems. For example, in "WinFS" it is easy to search files based on their content and other criteria such as file name, title, author, or date of publication. This would be difficult, if not impossible, in a traditional file system such as NTFS. In addition, "WinFS" still has efficient streaming capabilities—the cornerstone of traditional file systems—to handle large data values. "WinFS" can also be used with computers running earlier versions of Windows that support the NTFS file system. Files stored in "WinFS" can be accessed using the new "WinFS" API or the existing Win32 API. Therefore, existing Win32 applications can work with files stored in "WinFS" with little or no modification. In "Longhorn," files can be stored either in "WinFS" or on NTFS, but "WinFS" is more efficient and effective than NTFS for organizing, searching for, and sharing files. "WinFS" is particularly useful for storing data that needs to be queried or shared by users or applications. Advantages are largely because "WinFS" data is schematized, and the items can be related to each other in more than one way and, therefore, can be searched in multiple ways. You can still use NTFS for storing files that have few or no searching and sharing requirements. In fact, "Longhorn" uses NTFS for all the Windows system files needed for starting up and running the system. Instagram : http://www.instagram.com/demiscy[/url]
Cool19 Δημ. July 28, 2005 Δημ. July 28, 2005 Δεν είναι μέσα στα Longhorn το WinFS. Είχε προβλήματα και δεν προλαβαίνουν να το έχουν έτοιμο σε ένα χρόνο(!!) που θα κυκλοφορήσουν τα Vista. Και απ' ό,τι λένε, θα είναι διαθέσιμο αργότερα με διορθωτικό πακέτο(όπως και άλλες λειτουργίες). Επίσης θα είναι διαθέσιμο και για τα XP. Αν και έχω ακούσει επίσης ότι δε θα βγει καθόλου το WinFS. Μόνο η Μ$ ξέρει τελικά!
Flamenerve Δημ. July 28, 2005 Δημ. July 28, 2005 Για όσους ενδιαφέρονται το (DVD) ISO των WinVi Beta1 είναι 1.76GB. Τουλάχιστον τόσο ήταν η 64bit έκδοση που κατέβασα εγώ, γιατί υπάρχει και μια 32bit. Επίσης πέρα του serial που θέλει το setup υπάρχει και περιορισμός για activation εντός 30 ημερών, αλλά δεν έχω δει προς το παρόν να κυκλοφορεί "κάτι" ;) για να τον απενεργοποιεί... :(
Cool19 Δημ. July 28, 2005 Δημ. July 28, 2005 Φίλε Flamenerve, μπορείς να μου πεις από που κατέβασες την Beta(με ΠΜ για να μη μας κράξουν)?
Demis_CY Δημ. July 28, 2005 Δημ. July 28, 2005 To DVD ISO gia to 32bit einai 2,42GB Date Posted 7/26/2005 1:17:00 PM File en_longhorn_beta1_dvd.iso, ISO-9660 CD Image Size 2.42 GB Minimum Estimated Download Times T1 3 hours, 42 minutes 128 KB 45 hours, 6 minutes 64 KB 101 hours, 36 minutes 28.8 KB 225 hours, 48 minutes Description Windows Vista (formerly code-named Windows "Longhorn" is a substantial advance in Windows, with significant innovations in the developer platform. Windows Vista makes it easier than ever before to build applications that are more secure, reliable, and manageable. Windows Vista also enables developers and designers to create user-experience breakthroughs that improve usability and enable greater relevance to the work users do. Finally, Windows Vista makes it easy to connect to information, systems, people, and devices though a number of innovative integration technologies. Attention! In order to install this version of Windows XP, you must get a retail product key. This key may be used to activate 10 PCs per the terms of the MSDN End-User License Agreement. For the answers to common questions regarding the use of software included in your MSDN subscription, please see the MSDN License FAQ. Instructions An ISO-9660 image file is an exact representation of a CD, including the content and the logical format. The most common use of an image file is to write it to a blank CD-R resulting in an identical copy of the original CD including file name and volume label information. ISO Images can also be extracted directly to a file location by many CD-R utilities. For more information about image files, please visit the MSDN FAQ. Related Sites/Topics http://msdn.microsoft.com/windowsvista Nomizw merikoi prepei na thimithoun pws emiaze to prwto beta gia ta windows xp: http://winsupersite.com/images/reviews/whistler_beta1_0001.gif Instagram : http://www.instagram.com/demiscy[/url]
potmos Δημ. July 28, 2005 Δημ. July 28, 2005 Και γιατί βγαίνουν σε DVD τα Vista; Τί θα περιέχουν; Σε 2-2,5ΜΒ DVD βγαίνουν ολόκληρες διανομές Linux, με 2 σουΐτες Office, ένα κάρο browsers, web/ftp/file/mysql servers, 4-5 διαφορετικά περιβάλλοντα εργασίας (με καμμιά 10ριά θέματα το καθένα), DVD/MP3/CD/κλπ players, καμμιά δεκαριά επίσης filesystems, και, και, και... Απ΄ ότι καταλαβαίνω, μάλλον το λειτουργικό σκέτο, γυμνό και άχαρο θα πιάνει καναδυό GB έτσι στο νερό. Οπότε μάλλον θά ΄πρεπε να τα ονομάσουν windows... sVista... Λουκάς Σταμέλλος
Demis_CY Δημ. July 28, 2005 Δημ. July 28, 2005 Min 3exnate oti ena freskoformarismeno PC me MONO windows xp panw exei idi katilimmena 1.5GB ston disko... pou simenei oti auti tin fora den einai kai toso compressed ta setup files panw sto DVD. Instagram : http://www.instagram.com/demiscy[/url]
Cool19 Δημ. July 28, 2005 Δημ. July 28, 2005 Μπορεί και να είναι συμπιεσμένα! Και αν τα ΧΡ που είναι ένα cd πιάνουν 1,5GB, τα sVista που είναι τριπλάσια θα πιάνουν 4,5GB. :w00t: :wacko:
hydro Δημ. July 29, 2005 Δημ. July 29, 2005 παιζει και να ειναι τα μοναδικα windows που θα αγορασω στην ζωη μου
Demis_CY Δημ. July 29, 2005 Δημ. July 29, 2005 Paizei na einai kai ta akrivotera... REDMOND, Wash.--Microsoft CEO Steve Ballmer told analysts Thursday that Microsoft is planning new, higher-priced versions of both Windows and Office in the coming years as part of its effort to grow sales. Ballmer said that the company will add both high-end desktop editions and new server options in the next versions of Windows and Office. http://news.com.com/Ballmer+High-end+Windows%2C+Office+coming/2100-1016_3-5808554.html?tag=nefd.top Instagram : http://www.instagram.com/demiscy[/url]
geovass Δημ. July 29, 2005 Δημ. July 29, 2005 Paizei na einai kai ta akrivotera... REDMOND, Wash.--Microsoft CEO Steve Ballmer told analysts Thursday that Microsoft is planning new, higher-priced versions of both Windows and Office in the coming years as part of its effort to grow sales. Ballmer said that the company will add both high-end desktop editions and new server options in the next versions of Windows and Office. http://news.com.com/Ballmer+High-end+Windows%2C+Office+coming/2100-1016_3-5808554.html?tag=nefd.top με τετοια πολιτικη, δεν θα τα "αγορασω" απο την M$. ;)
Cool19 Δημ. July 29, 2005 Δημ. July 29, 2005 LOL! Γιατί, με την προηγούμενη πολιτική τα αγόραζε κανείς? :D
murex Δημ. July 30, 2005 Δημ. July 30, 2005 Σε μια 3ετία θα δουλεύεις σε MacIntel. Δηλαδή θα έχεις και εκεί Windows! :P Ναι θα έχω, μπορώ να κάνω και αλλιώς αφού τα περισσότερα προγράμματα που τρέχω υπάρχουν μόνο για windows? Ένα Pcάκι dual boot ή με virtual PC και καθάρισα. Όσο για το μέγεθος εγκατάστασης: εκτός από τα αρχεία του λειτουργικού, τα win έχουν και το pagefile που πιάνει δεν πιάνει 0,5-1gb? Δεν είναι αυτό το κριτήριο για μένα: ας είναι σταθερό, γρήγορο και ας πιάνει και 5. Αμ δε όμως! http://briefcases.pathfinder.gr/download/597036If you are not paying for it, you're not the customer; you're the product being sold.
potmos Δημ. July 30, 2005 Δημ. July 30, 2005 Α, και παρεμπιπτόντως, το Genuine Advantage το έσπασαν ήδη μέσα σε 24 ώρες. Επομένως, η πειρατεία θα συνεχίσει ανενόχλητη. Λουκάς Σταμέλλος
hydro Δημ. July 30, 2005 Δημ. July 30, 2005 νομιζετε οτι ηθελαν δεν μπορουσαν να βρουν τροπο(οχι οτι δεν ξερουν)να σταματησει η πειρατεια? αφου απο μια αποψη ζουν και απο αυτην δεν ειναι δυσκολο να βρεθει ενας τρελος αλγοριθμος με ολογραματα περασμενα στο καθε cd ετσι ωστε να ειναι πρακτικα αδυνατο να αντιγραφει κατι...
Cool19 Δημ. July 30, 2005 Δημ. July 30, 2005 Ότι και να γίνει, αργά ή γρήγορα θα σπαστεί! Για κάθε καινούργιο κόλπο που βγάζουν λένε ότι δεν σπάει εύκολα κλπ κλπ αλλά πάντα κάποιος βρίσκει τρόπο. ;)
geovass Δημ. July 30, 2005 Δημ. July 30, 2005 Εν αναμονη τωρα να σπασουν και τις 30 μερες activation των Vista! ;)
hydro Δημ. July 30, 2005 Δημ. July 30, 2005 Ότι και να γίνει, αργά ή γρήγορα θα σπαστεί! Για κάθε καινούργιο κόλπο που βγάζουν λένε ότι δεν σπάει εύκολα κλπ κλπ αλλά πάντα κάποιος βρίσκει τρόπο. ;) χμμ επειδη εχω μαθει μερικα πραγματα γυρω απο αυτα ειναι φυσικος αδυνατον αμα κανουν αυτο που σου ειπα να σπαστει κατι διοτι ειχα μιλησει(τυχαια) με εναν τυπο ο οποιος ειχε σχεδια να ανοιξει γραφεια μεγαλης εταιρειας παιχνιδιων και μου το ειπε αυτο ολες το ξερουν απλως δεν το κανουν διοτι θα χασουν πολλα λεφτα... :X
Cool19 Δημ. July 30, 2005 Δημ. July 30, 2005 Εν αναμονη τωρα να σπασουν και τις 30 μερες activation των Vista! ;) Νομίζω ότι το έχουν σπάσει! ;) χμμ επειδη εχω μαθει μερικα πραγματα γυρω απο αυτα ειναι φυσικος αδυνατον αμα κανουν αυτο που σου ειπα να σπαστει κατι διοτι ειχα μιλησει(τυχαια) με εναν τυπο ο οποιος ειχε σχεδια να ανοιξει γραφεια μεγαλης εταιρειας παιχνιδιων και μου το ειπε αυτο ολες το ξερουν απλως δεν το κανουν διοτι θα χασουν πολλα λεφτα... Ότι δεν τους συμφέρει, σίγουρα. Τώρα για το αν μπορεί να σπαστεί, δεν ξέρω. Μέχρι στιγμής πάντως δεν υπάρχει κάτι που να μην έχει σπαστεί. Αλλά και σ' αυτή την περίπτωση, κάτι θα έβρισκαν για να το σπάσουν. :confused:
MIB Δημ. July 31, 2005 Δημ. July 31, 2005 edw se selides pou prepei kai den 8eloun na spastoun (CIA...ktl.) parabiazontai kai me to parapano! (den nomizw i CIA na 8elei na spaei gia na poulaei perisotero ;) :p So this is how liberty dies, with thunderous applause
hydro Δημ. July 31, 2005 Δημ. July 31, 2005 edw se selides pou prepei kai den 8eloun na spastoun (CIA...ktl.) parabiazontai kai me to parapano! (den nomizw i CIA na 8elei na spaei gia na poulaei perisotero ;) :p η σελιδα της cia δεν εχει καμια σχεση με την ιδια πιστευω να το ξερεις αυτο οπως η δικη μας ε.υ.π :p :p
porcupine Δημ. July 31, 2005 Δημ. July 31, 2005 τα στησα. 4.78gb Περιπου με standard installation. αρχιζει το παιχνιδι λοιπον.... "Ash nazg durbatulûk, ash nazg gimbatul, ash nazg thrakatulûk agh burzum-ishi krimpatul." [sIGPIC][/sIGPIC]
bomber21 Δημ. July 31, 2005 Δημ. July 31, 2005 τα στησα. 4.78gb Περιπου με standard installation. αρχιζει το παιχνιδι λοιπον.... Για πες εντυπωσεις...
hydro Δημ. July 31, 2005 Δημ. July 31, 2005 τα στησα. 4.78gb Περιπου με standard installation. αρχιζει το παιχνιδι λοιπον.... εχεις πολλη δουλεια πρωτα πρωτα ss απο πολλα πραγματα :p μετα στειλε μου σε pm απο που τα κατεβασες :p :p
