[Επίσημο] Nokia 7610
Itchrist86
  • Απαντήσεις 4,8χιλ.
Αρχικό Μήνυμα από το μέλος argi_7 (12 Μάρ. 2004 , 22:39)
τοσο καλη δουλεια.ψηλο αποκλειεται
Αν ήταν real γιατί όπως είπε και ο Unbreakable στην οθόνη όλα τα εικονίδια είναι application ? :worry:
Αρχικό Μήνυμα από το μέλος Exposed_Bone (13 Μάρ. 2004 , 16:09)
τι να σας πω και εγω ρε παιδια εκτος απο την οθονη ολλο το υπολοιπο φενεται αληθινο
mpa ta xromata fenontai ligo moufa opos prosexa kai kati allo gia i analisi einai toso xalia edo me ena 7650 i foto tha itan pio kathari kai tha xexorizame ta panta telos panton as perimenoume na doume an tha bgri pot estin paragogi
:ninja:
Nokia 7610 phone
Kαι ομως το ανακοινωσε σημερα :)
http://www.nokia.com/nokia/0,8764,54665,00.html
http://www.nokia.com/nokia/0,,54676,00.html
What's New?
The Nokia 7610 phone with its sleek, compact design stands out in any crowd.
Cut a cleaner profile with 1 megapixel camera and 4x digital zoom. Quality prints are all the proof you need of your cutting edge savvy.
Score a perfect 10 with up to 10 minutes of video. Edit and shape your vision with the Movie Director application.
Your time is precious. Get a quick introduction to your Nokia 7610 phone with the integrated Welcome Demo.
Show some style with Nokia Xpress-on™ Style Packs' coordinated covers with keymats and wrist straps with matching wallpapers and screensavers.
Key Features
Integrated 1 megapixel (1152 x 864 pixels) camera with 4x digital zoom for quality prints
Integrated video recorder with audio function and 4x digital zoom for video clips up to 10 minutes long
Standard and night camera modes and self-timer
Movie Director - combine video clips, add music, or change styles
Created and downloaded digital content (images, sounds, videos) with Gallery storage
Welcome Demo for a quick start as well as a Help application that guides you through your phone's many features.
65,536 color-display, 176 x 208 pixels
Bluetooth wireless technology and USB connectivity
MMS, email, and instant messaging
Advanced XHTML browser
Personalized user interface themes
Full Specifications
Tri-band Operation
Tri-band coverage on up to five continents (GSM 900/1800/1900 or GSM 850/1800/1900)
Automatic switching between bands
Size
Weight: 118 g
Dimensions: 108.6 mm x 53 mm x 18.7 mm, 93.5 cc
Display and User Interface
Bright active matrix TFT color display
65,536 colors
176 x 208 pixel resolution
Graphical user interface with selectable themes
5-way navigation key
Symbian operating system 7.0s
Series 60 platform
Integrated Digital 1 megapixel Camera
Resolution 1152 x 864 pixels (1 megapixel)
4x digital zoom
Picture modes: standard, night
Self timer
Displayed formats: JPEG, GIF87a/89a, EXIF, DCF, WBMP, BMP, MBM, PNG
Video Recorder
Resolution: 128 x 96 or 174 x 144 pixels (Sub QCIF or QCIF)
Time: Up to 10 minutes
4x digital zoom
Supported formats: 3GPP, MPEG-4, H.263, Real Video
Memory Functions
8 MB internal dynamic memory for contacts, text messages, multimedia messages, ringing tones, images, video clips, calendar notes, to-do list, and applications
64 MB Reduced Size MultiMediaCard (MMC)
RealOne Player
Download and play multimedia files (video + music)
Stream media files through any supported media portals
Formats: 3GPP, RealMedia, MP3, AAC
Messaging
Multimedia messaging: Combine image, video, text and voice clip and send as MMS to compatible phone or PC; use MMS to tell your story with a multi-slide presentation
Automatic resizing of your megapixel image to accommodate fit MMS. (max.100KB attachment size)
Email: Access email accounts whether work or personal; supports SMTP, POP3, and IMAP4 protocols
Text messaging: Supports concatenated SMS; picture messaging; SMS distribution list
Predictive text input: Support for all major languages in Europe and Asia-Pacific
Presence
Instant Messaging
Presence-enhanced contacts
Connectivity
USB with Pop-Port™
Local synchronization of contacts & calendar to PC using PC Suite
Remote over-the-air synchronization with SyncML
Send and receive images, video clips, graphics and business cards
Browsing
Support for HTML, XHTML and WML
Full-screen mode
OMA mDRM - forward lock for content protection
Wallet: Convenient online use and storage of your numbers and passwords
Data Transfer
Up to 40.2 kB/s in GPRS networks
Call Management
Contacts: Advanced contacts database with support for multiple phone and email details per entry, also supports thumbnail picture and groups
Speed dialing
Logs: Keeps lists of your dialed, received, and missed calls
Automatic redial
Automatic answer (works with compatible headset or car kit only)
Supports Fixed Dialing Number, which allows calls only to predefined numbers
Conference call
Java™ Applications
Downloadable Java™ MIDP 2.0 applications
Voice Features
Voice dialing
Voice commands
Voice recorder
Integrated handsfree speaker
Digital Services
Symbian applications available from Nokia Software Market
Graphics, icons, animations, logos
Games: Possibility to download new games
Ringing tones: True Tones, polyphonic tones
Themes: Possibility to download new themes
Sales Package Contents
Nokia 7610 imaging phone
Reduced Size MultiMediaCard (64MB)
Adapter for Reduced Size MultiMediaCard (MMC)
Li-ion Battery Cell (BL-5C)
Travel Charger (ACP-12)
USB Connectivity cable (DKU-2)
Wrist strap
CD-ROM
User's Guide
Power Management
Battery Capacity Talk time Standby
BL-5C 900 mAh Li-lon Up to 180 min. Up to 10.4 days
iPhone 5S Space Grey
Αρχικό Μήνυμα από το μέλος argi_7 (18 Φεβ. 2004 , 12:31)
series 40 ειναι το συγκεκριμενο.οπου οντος το πληκρολογιο ειναι λιγο χαλια :cry: αλλα δεν το νομιζω με τις δυνατοτητες που εχει να πειραζε κανενα
Tελικα ειναι Series 60
Αρχικό Μήνυμα από το μέλος nervous (17 Μάρ. 2004 , 17:04)
Nokia 7610 phone
What's New?
Key Features
Full Specifications
Tri-band Operation
Size
Weight: 118 g
65,536 colors
Series 60 platform
4x digital zoom
Self timer
Video Recorder
4x digital zoom
Memory Functions
RealOne Player
Messaging
Presence
Instant Messaging
Connectivity
USB with Pop-Port™
Browsing
Full-screen mode
Data Transfer
Call Management
Speed dialing
Automatic redial
Conference call
Java™ Applications
Voice Features
Voice dialing
Voice commands
Voice recorder
Digital Services
Wrist strap
CD-ROM
User's Guide
Power Management
παντως δεν ειναι πολυ ωραιο???δεν συμφονειτε??και με τις δυνατοτητες που εχει ειναι τελειοοοοοοοοοοοοοοοοο(το πληκρολογιο δεν ειναι λιγο στριμοκολ.....)
Αρχικό Μήνυμα από το μέλος aggeloz (17 Μάρ. 2004 , 17:22)
ολοι εδω
http://www.myphone.gr/forum/showthread.php?s=&postid=308841#post308841
Aφου ειναι series 60 λοιπον :) συμφωνω με τον
aggeloz
  • 2 months later...
Nokia 7610
(RH-51)
http://www.forum.nokia.com/Devices/Device_specifications/7610/7610_main.jpg
http://www.forum.nokia.com/Devices/Device_specifications/7610/7610_detail1.jpg http://www.forum.nokia.com/Devices/Device_specifications/7610/7610_detail2.jpg http://www.forum.nokia.com/Devices/Device_specifications/7610/7610_detail3.jpg
______________________________________
Announced Date:
18 March 2004
Device Description:
The Nokia 7610 imaging phone features an integrated 1-megapixel camera with 4x zoom. In addition to the recording and playback of video clips, the device supports advanced messaging, including MMS, e-mail, and instant messaging (IM). The Nokia 7610 phone is suited to both business and mobile lifestyle applications.
Code name:
Catalina
Profile
Technical Specs
Photos
Press Release
Edited by Itchrist86
The "unwired" revolution began...
_http://www.myphone.gr/forum/image.php?type=sigpic&userid=6201&dateline=1272991407
Wirelessly posted (NokiaN-Gage/1.0 (4.03) SymbianOS/6.1 Series60/0.9 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Auto pou mou kanei entiposi einai oti i nokia tonizei pantou oti mporoume na traviksoume up to 10 min video. Kai omos apo ta prototipa kseroume oti exei 3 epiloges gia video: 1.gia mms 2.eos 10 lepta kai 3.simfona me ton eleu8ero xoro. Elpizo na iparxei i 3i epilogi sta telika montela. Oxi oti 10lepta einai ligo. Ka8e allo. :) ti les re powerZ :) makari na mporousa na'grafa ellinika.
Kαποιος απο Φιλανδια το αγορασε σημερα:
"Well... I got it... First inpression... WOW... it's so small and beautiful. I will charge it up and let you know what I think "
Οι φωτος δεν ειναι πολυ καλες ,αλλα ετσι για να μπαινουμε στο κλιμα
http://www.howardforums.com/attachment.php?postid=3070545
http://www.howardforums.com/attachment.php?postid=3070549
http://www.howardforums.com/attachment.php?postid=3070554
Wirelessly posted (:!:!Wireless Power!:!:: Nokia3650/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Αρχικό Μήνυμα από nervous
Mipos mporeis na valeis ta link anti gia tis photos gia na tis doume kai emeis pou exoume wap!:o
Pliris paketo mporw na pw! An evazan kai kanena hands free... Pou to diavases gia dwse ena link!
Αρχικό Μήνυμα από το μέλος killing_you2 ( 1 Ιούν. 2004 , 15:42)
Bεβαιως φιλε μου :)
http://www.howardforums.com/showthread.php?postid=3070740#post3070740
Wirelessly posted (:) :o :* :stupid: :up: :down:: SonyEricssonP900/R101 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Το κινητό περιέχει: Το τηλέφωνο, φορτιστή, μπαταρία,mmc,καλώδιο σύνδεσης με πι σι,βιβλίο με οδηγίες,λουράκι. :)
Με την Wind κάνεις πράγματι οικονομία...αφού δεν έχεις ποτέ σήμα, δεν μιλάς, δεν στέλνεις μηνύματα, δεν χρεώνεσαι...
Wind Όσα παίρνει ο άνεμος
Σ'αυτο το βελγικο site το δινουν 599.99€
http://gsmfactory.be/index.php?cPath=149_17_355
Γιατί το έχει τόσο ακριβά; Ρε παιδιά, λέτε να είναι τόσο ακριβώς και να μας την κάνει η νόκια την τσατσιά και να το έχει τόσο ακριβά; :worry:
