Vangelakis4 Δημ. November 28, 2008 Δημ. November 28, 2008 In order to have the maps downloaded to your phone, you need to log on to http://www.mywayfinder.com, (with the username and password that you can find in your phone, in the main menu of the Wayfinder application, by choosing Settings > Comm/User). Once you are logged on, you need to choose Service > Downloads > "Maps to your mobile". You will be directed towards a page where you should download the Maploader. It is a PC application that allows you to download map areas to the phone. The downloaded map areas can be used in WF Navigator and WF Earth. Please note that the phone must be in mass storage mode and a memory card is required. Please follow the steps below in order to download maps to your mobile phone: •Connect mobile phone to PC using USB (not possible to install using Bluetooth) •Press “Connect” available memory (phone) will be shown Maps already installed to the phone will be shown with green map tiles •Select an area from the map by pressing on that particular map tile or: Deselect an area by pressing on the map tile •Press ”Update” Map Loader will automatically determine whether any maps are already installed on the phone. If newer maps than the ones already installed in the phone are available those will automatically be updated. When a new version of Maploader is available, Maploader will detect this and prompt the user to download and install this version. The user must download the new version in order to continue using Maploader. It is also important for you to know that the map files, once transferred and installed in the phone, cannot be visualized. But, each time you calculate a route from or to an address existent on the downloaded maps, the software will automatically use for navigation the downloaded maps. Please note that, with pre-installed maps on the phone the data consumption is reduced since no online download of maps is needed. When navigating in an area where downloaded maps are used the only data traffic is due to routing, which is much less data traffic compared to downloading maps. The internet data consumption varies according to the view you choose for navigation (map view, guide view etc.) Please find bellow some examples of data consumption: - Navigation in Guide-view requires a data consumption rate of 5 - 8 KB/h (e.g., for a route of 150km with an average speed of 100km/h, the data consumption would be estimated to 7.5 - 12 KB, which implies an estimated internet costs of € 0.011 – € 0.018) - Navigation in Map-view requires a data consumption rate of 150 - 300 KB/h (e.g., for a route of 150km with an average speed of 100km/h, the data consumption would be estimated to 225 – 450 KB, which implies an estimated internet costs of € 0.33 – € 0.67). Thus, you can reduce the internet costs by using the Guide View during the navigation (instead of the Map View) - since it requires less data transfer. The costs above are only estimative. Please refer to your mobile network provider in order to find out the exact costs performed by them for internet data transfer and for roaming. Please note that it is not possible to use Wayfinder Navigator without a GPRS/3G Internet connection. The application is an online based application. Even if downloading maps through Maploader the application will still need the internet connection to be able to calculate the route,view 'Points of Interest',etc. Επιτελους Ξεκαθαρισαμε το Θεμα του GPS :D Σε Ευχαρισουμε Πολυ Παράθεση Τα πιο μεγάλα ονειρα τα κάνεις οταν όλοι σε ξεχνάνε!!!
makismakis2004 Δημ. November 28, 2008 Δημ. November 28, 2008 Εμένα πάντως τελικά το έκανε το update σε C905 ADRIATIC CDF1214-0339 και λέει πως έχω την τελευταία αναβάθμιση. Παράθεση
parginos1 Δημ. November 28, 2008 Δημ. November 28, 2008 καλησπερα και απο εμενα, εχω το κινητο εδω και μια εβδομαδα. ολα πολυ καλα και σαν προχειρη ψηφιακη και σαν wifi κτλ, το μονο προβλημα μου και απο οτι διαβασα σε ξενα sites δεν ειμαι ο μονος, το κουμπι για πλοηγηση 'κατω' απ το d-pad δεν παταει οπως τα υπολοιπα (πανω, δεξια και αριστερα) παταει αλλα με δυσκολια. το πηγα σημερα στο καταστημα απο οπου το αγορασα και αμεσως μου προτεινε αλλαγη. εβγαλε ενα καινουριο απο το κουτι του και ειχε ακριβως το ιδιο προβλημα αλλα με το 'πανω' πηρε τηλεφωνο τον τεχνικο του Γερμανου και του ειπε να το κρατησω και αν χειροτερεψει θα το στειλουμε για αλλαγη. παραξενα πραγματα για κινητο που εδωσα 500 ευρω μετρητα για να το αγορασω. τι να κανω, αν το αλλαξω και εχω παλι το ιδιο προβλημα προβλεπεται αλλαγη με αλλο μοντελο? ευχαριστω Παράθεση http://img367.imageshack.us/img367/5659/untitled1copy0by.jpg
griniaris Δημ. November 28, 2008 Δημ. November 28, 2008 καλησπερα και απο εμενα, εχω το κινητο εδω και μια εβδομαδα. ολα πολυ καλα και σαν προχειρη ψηφιακη και σαν wifi κτλ, το μονο προβλημα μου και απο οτι διαβασα σε ξενα sites δεν ειμαι ο μονος, το κουμπι για πλοηγηση 'κατω' απ το d-pad δεν παταει οπως τα υπολοιπα (πανω, δεξια και αριστερα) παταει αλλα με δυσκολια. το πηγα σημερα στο καταστημα απο οπου το αγορασα και αμεσως μου προτεινε αλλαγη. εβγαλε ενα καινουριο απο το κουτι του και ειχε ακριβως το ιδιο προβλημα αλλα με το 'πανω' πηρε τηλεφωνο τον τεχνικο του Γερμανου και του ειπε να το κρατησω και αν χειροτερεψει θα το στειλουμε για αλλαγη. παραξενα πραγματα για κινητο που εδωσα 500 ευρω μετρητα για να το αγορασω. τι να κανω, αν το αλλαξω και εχω παλι το ιδιο προβλημα προβλεπεται αλλαγη με αλλο μοντελο? ευχαριστω δεν εχω καταλαβει για ποιο πληκτρο μιλας Παράθεση [sIGPIC][/sIGPIC]
Chris85 Δημ. November 28, 2008 Δημ. November 28, 2008 καλησπερα και απο εμενα, εχω το κινητο εδω και μια εβδομαδα. ολα πολυ καλα και σαν προχειρη ψηφιακη και σαν wifi κτλ, το μονο προβλημα μου και απο οτι διαβασα σε ξενα sites δεν ειμαι ο μονος, το κουμπι για πλοηγηση 'κατω' απ το d-pad δεν παταει οπως τα υπολοιπα (πανω, δεξια και αριστερα) παταει αλλα με δυσκολια. το πηγα σημερα στο καταστημα απο οπου το αγορασα και αμεσως μου προτεινε αλλαγη. εβγαλε ενα καινουριο απο το κουτι του και ειχε ακριβως το ιδιο προβλημα αλλα με το 'πανω' πηρε τηλεφωνο τον τεχνικο του Γερμανου και του ειπε να το κρατησω και αν χειροτερεψει θα το στειλουμε για αλλαγη. παραξενα πραγματα για κινητο που εδωσα 500 ευρω μετρητα για να το αγορασω. τι να κανω, αν το αλλαξω και εχω παλι το ιδιο προβλημα προβλεπεται αλλαγη με αλλο μοντελο? ευχαριστω Αλλαξε το σε μενα πατιουνται ολα πολυ καλα κ ειδικα το κατω ειναι πολυ ανετο.Ισως το πανω ειναι λιγο σκληρο αλλα σε καμια περιπτωση σε σημειο π να με ενοχλει Παράθεση
parginos1 Δημ. November 28, 2008 Δημ. November 28, 2008 δεν εχω καταλαβει για ποιο πληκτρο μιλας μιλαω για το πληκτρο κατευθυνσεων στο μενου chris μαλλον παω για αλλαγη. αλλα επειδη και το καινουριο που μου ανοιξε ειχε σχεδον το ιδιο προβλημα, υπαρχει περιπτωση αλλαγης μοντελου δηλαδη αντι για το 905 να παρω καποιο αλλο, δεν εχω ρωτησει και δεν γνωριζω. Παράθεση http://img367.imageshack.us/img367/5659/untitled1copy0by.jpg
Chris85 Δημ. November 29, 2008 Δημ. November 29, 2008 μιλαω για το πληκτρο κατευθυνσεων στο μενου chris μαλλον παω για αλλαγη. αλλα επειδη και το καινουριο που μου ανοιξε ειχε σχεδον το ιδιο προβλημα, υπαρχει περιπτωση αλλαγης μοντελου δηλαδη αντι για το 905 να παρω καποιο αλλο, δεν εχω ρωτησει και δεν γνωριζω. δεν θα βρεις καλυτερο μοντελο πιστεψε με..ειδικα αν πας στο ν85 στα ιδια λεφτα θα τρομαξεις απο την ποιοτητα...απλα βρες καποιο χωρις προβλημα στα κουμπια γιατι κ ανεπαισθητο να ειναι τωρα το προβλημα, με τον καιρο θα χειροτερεψει 100% Παράθεση
andreas1022 Δημ. November 29, 2008 Δημ. November 29, 2008 Εννοει δηλαδη πιο πανω οτι χρεωνεσαι μια φορα πχ 0,67Ε??? Παράθεση :w00t:
antonio_r Δημ. November 29, 2008 Δημ. November 29, 2008 μιλαω για το πληκτρο κατευθυνσεων στο μενου ολα αψογα ειναι. ισως η παρτιδα του γερμανου φταιει. Παντως το δικο μου ειναι απο πλαισιο. Παράθεση
andreas1022 Δημ. November 29, 2008 Δημ. November 29, 2008 ολα αψογα ειναι. ισως η παρτιδα του γερμανου φταιει. Παντως το δικο μου ειναι απο πλαισιο. Πλακα πλακα αληθευει οτι ο Γερμανος παιρνει τα κομματια κ συναρμολογει μονος του τα κινητΑ?? Παράθεση :w00t:
ταξιδιωτης22 Δημ. November 29, 2008 Δημ. November 29, 2008 Πλακα πλακα αληθευει οτι ο Γερμανος παιρνει τα κομματια κ συναρμολογει μονος του τα κινητΑ?? οχι φυσικα,σε καμια περιπτωση δεν αληθευει αυτο,τι δηλαδη,κανουν παραγωγη κινητων? Παράθεση Η υπομονή είναι πικρή,αλλά ο καρπός της είναι γλυκός.
andreas1022 Δημ. November 29, 2008 Δημ. November 29, 2008 Eτσι ειχα ακουσει καποτε..παιρνουν λεει τ κομματια κ τα συναρμολογουν μονοι τους..γιαυτο ειναι μερικα ειναι χαλασμενα... Παράθεση :w00t:
antonio_r Δημ. November 30, 2008 Δημ. November 30, 2008 Αναμονη, σε 24ωρη βαση, χωρις καμμια κληση, μου κρατησε 10 μερες!!! (του ειχα βαλει sim που δεν χρησιμοποιω, γιατι με την κανονικη μου sim, τεσταριζα καποια αλλα αυτο το 10ημερο) Παράθεση
Chris85 Δημ. November 30, 2008 Δημ. November 30, 2008 μπαταρια μετρια..χειροτερη απ του κ800 αλλα ειναι κ λογικο λογω της μεγαλυτερης οθονης κ επειδη ειναι λ 930mAh Παράθεση
andreas1022 Δημ. November 30, 2008 Δημ. November 30, 2008 Α ωραια..παλι βγαλαμε συμπερασμα... Παράθεση :w00t:
antonio_r Δημ. November 30, 2008 Δημ. November 30, 2008 μπαταρια μετρια..χειροτερη απ του κ800 αλλα ειναι κ λογικο λογω της μεγαλυτερης οθονης κ επειδη ειναι λ 930mAh Ε οχι και μετρια.. Επειδη εχω και το κ800, μερα με νυχτα η διαφορα υπερ του c905. Δεν ξερω αν του εκανες τις σωστες πρωτες εκφορτισεις - φορτισεις φιλε στο δικο σου.. Στο δικο μου παντως που του εκανα 5 πληρεις εκφορτισεις - φορτισεις, εφτασε τις 10 μερες+ αναμονης, ολο το 24ωρο ανοιχτο οπως προειπα. Παράθεση
manospipis Δημ. November 30, 2008 Δημ. November 30, 2008 8elo na bgalo to menoy my view apo to deksi plhktro kserete kati.. Παράθεση :D
Chris85 Δημ. November 30, 2008 Δημ. November 30, 2008 Ε οχι και μετρια.. Επειδη εχω και το κ800, μερα με νυχτα η διαφορα υπερ του c905. Δεν ξερω αν του εκανες τις σωστες πρωτες εκφορτισεις - φορτισεις φιλε στο δικο σου.. Στο δικο μου παντως που του εκανα 5 πληρεις εκφορτισεις - φορτισεις, εφτασε τις 10 μερες+ αναμονης, ολο το 24ωρο ανοιχτο οπως προειπα. το αν σου κραταει 10 μερες το κινητο δεν λεει κατι αν δεν κανεις χρηση.Η αληθεια ειναι πως η μπαταρια ειναι ικανοποιητικη για ενα κινητο με τετοια οθονη κ τετοιες λειτουργιες.Ωστοσο συγκριτικα με αυτη του κ800 ειναι χειροτερη.Δεν γινεται να ειναι καλυτερη οπως λες.Παρολα τα Power saving tricks που εχει το c905 δυστυχως φοραει μπαταρια 930mAh (950mAh το k800i) και εχει 2,4 inch οθονη, πολυ μεγαλυτερη του κ800.Οι φορτισεις/εκφορτισεις εχουν γινει σωστα εννοειται. Κ για να ειμαι πιο σαφης εχω παρατηρησει πως σε αναμονη καταναλωνει ελαχιστη μπαταρια αλλα σε παιχνιδια η βιντεο με αναμμενο το led καταναλωνει αρκετα. Για μενα ειναι μετρια η μπαταρια του συγκριτικά παντα με το κ800ι. Σε απολυτες τιμες βγαζει 2/ 2μιση μερες με αρκετη χρηση οποτε πιστευω οτι ειναι ικανοποιητικοι χρονοι. Δεν ειναι μειονεκτική η μπαταρια του για οσους απο σας σκεφτεστε να το αγορασετε, δεν ειναι ενας τομεας οπου μειονεκτει το κινητο απλως δεν ειναι κ κατι στο οποιο ξεχωριζει οπως οι δυνατοτητες του σε αλλους τομεις. Α ωραια..παλι βγαλαμε συμπερασμα... νομιζω πως η ειρωνια δεν χρειαζεται...ολοι εδω προσπαθουμε να βοηθησουμε-δεν θα τ ακουμε κ απο πανω. Για να βγαλεις συμπερασμα σου λεω πως η μπαταρια δεν ειναι κορυφη, δεν ειναι και αδυναμη ομως.Ειναι μετρια. Βεβαιως αν τη συγκρινεις με την μπαταρια του ν95 και αλλων παρομοιων κινητων, ειναι αρκετα καλυτερη.Γενικα το c905 ειναι καλο κ ισορροπημενο κινητο σε ολους τους τομεις, δεν νομιζω οτι απογοητευει καπου Παράθεση
Zizouts Δημ. November 30, 2008 Δημ. November 30, 2008 Paidia na rwthsw, h ekswterikh mnhmh poso mporei na epekta8ei? Παράθεση
Chris85 Δημ. November 30, 2008 Δημ. November 30, 2008 Paidia na rwthsw, h ekswterikh mnhmh poso mporei na epekta8ei? αναλογα με την καρτα που βαζεις μεσα, νομιζω ενας φιλος εχει 8 gb χωρις να αντιμετωπισει καποιο προβλημα Παράθεση
andreas1022 Δημ. November 30, 2008 Δημ. November 30, 2008 νομιζω πως η ειρωνια δεν χρειαζεται...ολοι εδω προσπαθουμε να βοηθησουμε-δεν θα τ ακουμε κ απο πανω. Για να βγαλεις συμπερασμα σου λεω πως η μπαταρια δεν ειναι κορυφη, δεν ειναι και αδυναμη ομως.Ειναι μετρια. Βεβαιως αν τη συγκρινεις με την μπαταρια του ν95 και αλλων παρομοιων κινητων, ειναι αρκετα καλυτερη.Γενικα το c905 ειναι καλο κ ισορροπημενο κινητο σε ολους τους τομεις, δεν νομιζω οτι απογοητευει καπου Kαλα ηρεμισε...δεν ειρωνευτηκα απλα το ειπα επειδη ειποθηκαν 2 διαφορετικες αποψεις..ολοι το ξερουμε οτι βοηθατε κ λετε τις αποψεις κ νασαι σιγουρος οτι ολοι οσοι θελουν να αγορασουν το συγκεκριμενο τηλεφωνο σας ακουνε(διαβαζουν μαλλον)προσεκτικα.. Παράθεση :w00t:
Chris85 Δημ. November 30, 2008 Δημ. November 30, 2008 Kαλα ηρεμισε...δεν ειρωνευτηκα απλα το ειπα επειδη ειποθηκαν 2 διαφορετικες αποψεις..ολοι το ξερουμε οτι βοηθατε κ λετε τις αποψεις κ νασαι σιγουρος οτι ολοι οσοι θελουν να αγορασουν το συγκεκριμενο τηλεφωνο σας ακουνε(διαβαζουν μαλλον)προσεκτικα.. μα δεν ειπα τπτ :) λογικο ειναι να ακουγονται διαφορετικες αποψεις μια που ο καθενας μας εχει διαφορετικες αναγκες απο ενα κινητο, εχει διαφορετικο μετρο συγκρισης κτλ.. Παντως σαν κινητο αυτη τη στιγμη πιστευω πως για τον μεσο χρηστη ειναι το καλυτερο Παράθεση
TN97 Δημ. November 30, 2008 Δημ. November 30, 2008 Πριν μιλήσουμε για την απόδοση μιας μπαταρίας, πρέπει να έχουμε στο μυαλό μας διάφορους παράγοντες, όπως: 1. Σε ποιο δίκτυο είμαστε 2. Πόσο καλή είναι η κάλυψη του δικτύου στο οποίο ανήκουμε στην περιοχή μας 3. Εάν μετακινούμαστε συχνά, καθώς κάποιος που κάνει π.χ. συνέχεια δρομολόγια αλλάζει συνέχεια κυψέλες άρα «τρώει» περισσότερη μπαταρία από κάποιον που είναι στο σπίτι του. 4. Η χρήση που κάνουμε. Ειδικά αυτό, είναι απέραντα υποκειμενικό μιας και η χρήση που κάνει ο καθένας είναι εντελώς διαφορετική. Σε γενικές γραμμές, οι πιο ενεργοβόρες λειτουργίες είναι οι φωτογραφίες με flash, η καταγραφή video, το WiFi και το BT. Για μένα πάντως, η απόδοση της μπαταρίας του C905 είναι ικανοποιητική για τα δεδομένα του, στα κλασσικά επίπεδα της SE. @Chris85, το Κ800 είχε μπαταρία χωρητικότητας 900 mAh αν δεν κάνω λάθος και όχι 950. :) Παράθεση
Chris85 Δημ. November 30, 2008 Δημ. November 30, 2008 TN97 thx 4 the info! δεν ξερω αν υπαρχουν κ αλλες εκδοσεις εγω εχω μπροστα μου την BST-33 950mAh!! Παράθεση
TN97 Δημ. November 30, 2008 Δημ. November 30, 2008 TN97 thx 4 the info! δεν ξερω αν υπαρχουν κ αλλες εκδοσεις εγω εχω μπροστα μου την BST-33 950mAh!! Τι να σου πω φίλε μου, μπορεί να κάνω λάθος. Δεν θυμάμαι, έχω να πιάσω Κ800 πολύ καιρό. :) Παράθεση
