Κινητή Τηλεφωνία Κύπρου
Ξερετε που μπορω να βρω τα settings mms for siemens M65?
thanks in advance
It’s nice to be important but it’s more important to be nice.
  • Απαντήσεις 612
Siemens M55
1. select "setup" and then "connectivity"
2. select "GPRS" and activate the GPRS, press "yes"
3. then press "data services", "MMS, WAP"
4. select an empty profile and press "option", "rename"
5. then insert the following data
* profile name: areeba
6. press "save" and "edit". A message will be appeared and by pressing "yes" you select "GPRS –settings" and "edit"
then insert the following data:
* login name: mms
* password: mms
7. from the menu select "message", "message setup" and "MMS"
8. select an empty profile and then "options" and "rename"
9. then insert the following data: profile name areeba
10. press "save" and then choose "options" and "change settings"
11. then insert the following data:
* expiry time: maximum, press activate and the red button once to returned back
* "def. priority, choose what you prefer low/normal/high
* Retrivial automatic, press ok
* MMS relaysrv: http://10.22.0.50/mmsc or http://mms.areeba.com.cy/mmsc , press ok
* IP settings, IP address:10.22.0.50
* Port: 9201
* 2nd address: 10.22.0.50
* 2nd port: 9201
* Conn. Profile: areeba, press select
mages mborei na mou apantisei kaneis se 2 erwtisoules????exw parei ena SE T630 me sindesi stin cyta.
1)pws pernaw tis rithmiseis gia MMS kai Wap/GPRS se SE T630??prepei na kalesw kapoio arithmo tis cyta apo to kinito mou stin kipro i na steilw kapou sms?toulaxiston sta ellinika diktia(VODA,TIM,COSMOTE) etsi ginete.
2)poios einai o aritmos exipiretiseis pelatwn otan kaleis apo kinito kai otan kaleis apo stathero tis cyta???einai tzampa i xrewnete???thanx
http://briefcase.pathfinder.gr/download/laios23/38168/578002
Το γούστο μου είναι πολύ απλό. Είμαι πάντα ικανοποιημένος, έχοντας το καλύτερο...''Oscar Wilde
Αρχικό Μήνυμα από το μέλος zchristos ( 3 Οκτ. 2004 , 22:53)
http://www.cytamobile-vodafone.com/default.asp?id=76
http://www.cytamobile-vodafone.com/default.asp?id=77
http://ota.cyta.com.cy
call centre: 132 kai apo kinito kai apo stathero kai ine dorea
thanx man!! :rolleyes:
Γεια σας παιδιά. έχω ακούσει ότι αν δεν αλλάξω την SIM κάρτα μου σε CytaVodafone ως τα Xριστούγεννα θα ακυρωθεί και θα χρειάζεται να πληρώσω 15 λίρες για να γίνει η μετατροπή σε vodafone. Έχετε ακούσει κάτι? Έχω σύνδεση με κανονικό πακέτο.
Αρχικό Μήνυμα από το μέλος michalis1984 (23 Οκτ. 2004 , 13:11)
to exo akousei kai ego auto pou les file, alla epidi i cyta theli na nomizi oti ine eksipni den to leei sto kosmo, etsi oste na to kseroune oso ginete ligoteroi kai meta na erthi na sou pei dose mou 15 lires gia na sou doso nea karta(i opia tha ine ipoxreotiki) gia na mporis na exeis tis ypiresies tis pou plironis gia autes
Ρε παιδια δεν νομίζω.... Θα χάσει πελάτες
NEC DB2000 (1999), Nokia 3210 (2000), EricssonR320s (2001), Ericsson T65 (2002), Nokia 6600 (2003), Palm Treo650 (2005), iPhone (2007), HTC Hero (2009), Samsung Galaxy Mini (2010), iPad (2010), Samsung Omnia W (2011), Samsung Galaxy Note (2012), iPad Air (2014), Samsung Galaxy Note 3 (2014), OnePlus 2 (2015), Meizu M5 Note (2017), Samsung Note 8 (2017), iPad 6 (2018)...
http://www.everythingaboutebooks.com
apo ti cyta ola na ta perimenis afu gia na fantastis tora p ime areeba ipa na tous piraxo ligo k tous kanw ton asxeto k tous lew ekana search apo to mob m k m vrike to diktio sas ena allo dikto to CY 1O k tous rwtisa ti einai to diktio CY 10 ? k m lene einai diktio twn agglwn sto akrotiri.Exallou ligoi exou enimerothoi gia to neo diktio areeba dioti tous kimizei me tin sinergasia tis me ti vodafone afou akoustike episis oti i cyta tha figei k tha meinei mono i vodafone etsi epidi elaxistoi xeroun ti ginete pragmatika etsi dn endiaferonte na mathoun
Maybe you were right
But baby I was lonely
I don't want to fight
I'm tired of being sorry ...:shifty:
Πάντως το γεγονός ότι η Vodafone συνεργάζεται με την CYTA έχει διαφημιστεί τόσο καλά που στον περισσότερο κόσμο έχει περάσει σαν μια "κοσμοϊστορική" εξέλιξη! Χωρίς κανένας βέβαια να ξέρει τι ακριβώς σημαίνει αυτή η συνεργασία...
Αν και δεν έχω κατέβει Κύπρο, βλέπω πολλούς φίλους που έρχονται από εκεί και μου λένε " η Vodafone ήρθε στην Κύπρο" και τους απαντώ "σιγά τα λάχανα"...
Αντίθετα το σημαντικό γεγονός, της εισαγωγής δηλαδή μίας ανταγωνιστικής εταιρείας στην αγορά, δεν το γνωρίζει πολύς κόσμος...
an omws ixeran oti an dn enoithe apilimeni i cyta oute p tha skeftotan na sinegrastei me opoian dipote alli eteria kin til.
Αυτό είναι το καλό για μας, φίλε chryant. O ανταγωνισμός συμφέρει τον καταναλωτή. ΕΚΤΟΣ και εαν οι δύο εταιρείες τα βρούν μεταξύ τους και προσφέρουν τιμές ή υπηρεσίες ίδιες. Πράγμα το οποίον σε αυτή την περίοδο μου φαίνεται απίθανο, διότι η Areeba προσπαθεί να διεισδύσει στην αγορά.
egw pali an sigrinw cyta me areeba an k i areeba einai akoma stin arxi lew areeba me TERASTIA diafora
Δεν μας αναλύεις λίγο την τεράστια διαφορά; Τουλάχιστο αν αξίζει τον κόπο να την κάνουμε και εμείς την αλλαγή...
kata tin gnomi mou pou meletisa ligo to thema, ine oti sigoura exeis kaliteri eksipiretisi, otan den plirosis to stathero den iparxi periptosi na mou diakopsoune tis ekserxomenes kliseis giati tha ime me areeba, i akoma kai to antitheto, i mpataria tou kinitou sou diarkei perisoteri ora giati to diktio tis areeba ine pio dinato kai ine olo se 1800 kai oxi 900 opos tis cytas. i sindesi pou pernis ine paketo me xrono omilias pou me auto tha mporis na elexis posa tha sou erthi to mina, oi xreoseis ine pio ftines kai idika to pay as you talk ine poli ftinotero apo to soeasy, kai kati allo pou to idame sti praksi ine otan exei provlima antamivi to pelati me dorea xrono omilias san antalagma gia tin ora pou tha ine kato to diktio, elpizo auto na min xriasti pote, exei GPRS class 10, osous den gnorizoune ine pio grigoro apo auto tis cytas, fisika prepei kai to kinito sou na ypostirizi class 10 gia na deis ti diafora, ta MMS ine dorea mexri telos dekevriou.
ta arnitika ine oti akoma den exei kalipsi se oli tin kypro, alla ekei pou den exei mporis na pernis diktio apo ti cyta(me tis idies xreosis afou exoune simfonisi re national roaming), den mporis na stilis MMS otan vriskese kato apo to diktio tis cyta.
episis pio grigori sim pio grigori diekpereosi twn klisewn (osi exou so easy katalambenoun gia ti milw)reports k poli kaliteri fonitiki epikoinonia k xwris tis diakopes tis cytas se merikes perioxes (xerete ta parasita).thx zchristos me kalipses se ola ta alla. :)
k episis tora thimithika to 3g teliwsan i dokimes me pliri epitixia k tora prosferete se olous tous pelates tis
Ise sigouros?
xerei kaneis tpt gia to nokia 6630....?
kapoia timi, an vgike kai pou.
http://www.danasoft.com/sig/stoNeheadsgf.jpg
ξερει κανεις το τροπο για να σπουδασω... προσπαθω αλλα δεν τα καταφερνω................
Αρχικό Μήνυμα από το μέλος soul_x2x ( 9 Νοέ. 2004 , 18:43)
Περιμενε ως τα χριστουγεννα γιατι ακομα να βγει πουθενα
Ποσα ειπες;;;
Oι γονεις σε βοηθουν να ξεπερασεις προβληματα που δεν θα ειχες αν εισουν ορφανος. :whistle:
Οσοι ειναι ανεγκεφαλοι να ΜΗΝ πατησουν εδω
Αρχικό Μήνυμα από το μέλος chryant (10 Νοέ. 2004 , 17:46)
630 me 590 liroudes
pou to ivres 590
