m4gma Δημ. May 26, 2006 Δημ. May 26, 2006 Είσαι απλά θεός! ότι και να πω θα είναι λίγο. Προσπαθώ εδώ και 2 ώρες με τον 15.95 και δεν γίνεται τίποτα! Ευχαριστώ! Με τον 15.94 στο τεστ μου έβγαλε αυτά. Μια απορία μόνο. Εκεί που λέει you must use CID49 files υπάρχει κάποια λεπτομέρεια που πρέπει να προσέξω ή είναι τα αρχεία που είπες? Client Version 15.94 **** READING CID STARTED **** Turn off the phone. Hold "C" button and plug USB cable. Phone attached! Detected SonyEricsson: K750/D750/W800/W550/Z520/Z530. CsLoader Accepted Ok! Status Ok, OTP Close, CID49, PAF1 IMEI: χχχχχχ-χχ-χχχχχχ Phone CID 49, Color RED You must use CID49 Flash Files For this phone! Press button - "Get Files From Web" and download free firmware Execution Time - 00:00:04 Done! Παράθεση magma ------- iPhone 4GB - FW 2.1 - QuickPwned :D
geovass Δημ. May 26, 2006 Δημ. May 26, 2006 Client Version 15.94 Getting data from server... Connection ok! Data recieving... Credits: 1, Counter: 0 Turn off the phone. Hold "C" button and plug USB cable. Phone attached! Detected SonyEricsson: K750/D750/W800/W550/Z520/Z530. CsLoader Accepted Ok! Status Ok, OTP Close, CID49, PAF1 IMEI: xxxxxx-xx-1xxxxx Loading Main File. Please wait... Getting Flash File boot block... Getting data from server... Connection ok! Data recieving... Flash Color RED, Phone Color RED Loading Main File. Ok! Loading FS File. Please wait... Getting Flash File boot block... Getting data from server... Connection ok! Data recieving... Flash Color RED, Phone Color RED Loading FS File. Ok! W810/Z530 recognized! Flash Color RED, Phone Color RED Flash File CID49, Phone CID49 Flashing 342 blocks. Ok! Flash Color RED, Phone Color RED Flash File CID49, Phone CID49 Flashing 161 blocks. Ok! Flash Finalization Started! Wait while process will be finished! CsLoader Accepted Ok! System Initialization. Please Wait... Getting data from server... Connection ok! Data recieving... Sign 1 ok. Sign 2 ok. CsLoader Unlocked! Appliyng CDA:CDA102555/4 Please wait... Flash Finalization - successfull !!! Exiting Test mode. Please wait... Execution Time - 00:05:17 Done! :lol: :lol: :lol: :lol: Παράθεση
geovass Δημ. May 26, 2006 Δημ. May 26, 2006 W810_R4CK003_MAIN_EU-EMEA-US.DVT W810_R4CK003_FS_MEDITERR.DVT AYTA ακριβως τα δυο εβαλα και το W810 εγινε Ελληνικο! Ασφαλως χρειαζονται και τα δυο! ΠΡΟΣΟΧΗ! Χρειαζεται ΜΟΝΟ ο client 15.94, ειδικα για το W810. Ο τελευταος που εχει το davinci για download ΔΕΝ κανει. Καντε search για να βρειτε αυτον που σας λεω! Με την τελευταια που εβαλα δεν υπαρχει κανενα προβλημα...ουτε το φλας αναβοσβηνει, ουτε πεφτουν οι κλησεις...τουλαχιστον εδω στη Γαλλια! Για να μπορεις να κανεις ελευθερα αναβαθμισεις θα πρεπει ΣΥΓΧΡΟΝΩΣ να αλλαξεις και το CDA στον client και να βαλεις CDA102555/4. Αυτο ειναι το unbranded Ελληνικο. Θα μπορεις σιγουρα να αναβαθμιζεις μετα ελευθερα γιατι το εχω δοκιμασει με πολλα Κ750 που ηταν Βοδιαφον καθως επισης και με το w900 μου που το "ξεβοντανιασα" και καπακι το αναβαθμισα απο την SE! Επισης στον client, κατω απο το CDA, εχει 4 τετραγωνακια για τσεκαρισμα. Να ΜΗΝ τσεκαρεις ΚΑΝΕΝΑ! Να σε ρωτησω. Εαν πας menu - setting - ipdate service - software version βλεπεις το παρακατω? CXC1250316 R4CK003 000000 :blink: :blink: Γιατι εχω μηδενικα αντι για το CDA μου ? Παράθεση
m4gma Δημ. May 26, 2006 Δημ. May 26, 2006 Το πάτησα, το πάτησα! Όλα καλά! (αν και έχασα 1-2 χρόνια από τη ζωή μου μέχρι να τελειώσει και να ανοίξει το κινητό με επιτυχία) Βέβαια, πάνω που είχα αρχίσει να συνηθίζω το VL menu, άλλαξε :lol: Μια απορία έχω μόνο. Πριν το πάνω βελάκι του τζόυστικ, πήγαινε στη συντόμευση (αυτό τώρα το κάνει το δεξί) και το δεξί πήγαινε στο ημερολόγιο. Όμως τώρα το πανω πάει στο playing now , το οποίο είναι ολίγον τι άχρηστο αφού υπάρχει το πορτοκαλί κουμπί αριστερά. Υπάρχει τρόπος να αλλάξει? Όχι οτι με νοιάζει πολύ, αφού (με τη βοήθεια σας) κατάφερα να ξεφορτωθώ το VL, δεν με νοιάζει τπτ! Παράθεση magma ------- iPhone 4GB - FW 2.1 - QuickPwned :D
m4gma Δημ. May 26, 2006 Δημ. May 26, 2006 γιατί δεν το ήξερα! Ευχαριστώ (για άλλη μια φορά!) Καλά τα flash themes απλά ΣΠΕΡΝΟΥΝ!!!!!!!!! Παράθεση magma ------- iPhone 4GB - FW 2.1 - QuickPwned :D
OratIos Δημ. May 27, 2006 Δημ. May 27, 2006 W810_R4CK003_MAIN_EU-EMEA-US.DVT W810_R4CK003_FS_MEDITERR.DVT AYTA ακριβως τα δυο εβαλα και το W810 εγινε Ελληνικο! Ασφαλως χρειαζονται και τα δυο! ΠΡΟΣΟΧΗ! Χρειαζεται ΜΟΝΟ ο client 15.94, ειδικα για το W810. Ο τελευταος που εχει το davinci για download ΔΕΝ κανει. Καντε search για να βρειτε αυτον που σας λεω! Με την τελευταια που εβαλα δεν υπαρχει κανενα προβλημα...ουτε το φλας αναβοσβηνει, ουτε πεφτουν οι κλησεις...τουλαχιστον εδω στη Γαλλια! Για να μπορεις να κανεις ελευθερα αναβαθμισεις θα πρεπει ΣΥΓΧΡΟΝΩΣ να αλλαξεις και το CDA στον client και να βαλεις CDA102555/4. Αυτο ειναι το unbranded Ελληνικο. Θα μπορεις σιγουρα να αναβαθμιζεις μετα ελευθερα γιατι το εχω δοκιμασει με πολλα Κ750 που ηταν Βοδιαφον καθως επισης και με το w900 μου που το "ξεβοντανιασα" και καπακι το αναβαθμισα απο την SE! Επισης στον client, κατω απο το CDA, εχει 4 τετραγωνακια για τσεκαρισμα. Να ΜΗΝ τσεκαρεις ΚΑΝΕΝΑ! Exo NON live w810i me thn Rc4 kai thelo na thn anavathmiso sthn R4ck. Me auto ton tropo tha ginei apla i anavathmisi i tha alla3ei kai kati allo kai tha exo argotera provlima?? Einai eukolo se kapoion na dosei odhgeies gia thn anavathmisi ayth giati anttimetopizo provlima!!Kat'arxas ta 2 arxeia pou katevasa fandazomai oti prepei na einia mesa ston fakelo flashes. Apo ekei kai pera anoigo ton unlocker, pao sthn kartela flash ftiaxno tis ruthmiseis kai.......???? Ta koumpia flash kai Flash get files den kanoun kati giati zitoun connection. To trito koumpi leei hold 'C' and plugin mobile....To kano alla kolaei ekei......!!!!Kamia idea????? Παράθεση
zzz750 Δημ. May 27, 2006 Δημ. May 27, 2006 Το πάτησα, το πάτησα! Όλα καλά! (αν και έχασα 1-2 χρόνια από τη ζωή μου μέχρι να τελειώσει και να ανοίξει το κινητό με επιτυχία) Βέβαια, πάνω που είχα αρχίσει να συνηθίζω το VL menu, άλλαξε :lol: Μια απορία έχω μόνο. Πριν το πάνω βελάκι του τζόυστικ, πήγαινε στη συντόμευση (αυτό τώρα το κάνει το δεξί) και το δεξί πήγαινε στο ημερολόγιο. Όμως τώρα το πανω πάει στο playing now , το οποίο είναι ολίγον τι άχρηστο αφού υπάρχει το πορτοκαλί κουμπί αριστερά. Υπάρχει τρόπος να αλλάξει? Όχι οτι με νοιάζει πολύ, αφού (με τη βοήθεια σας) κατάφερα να ξεφορτωθώ το VL, δεν με νοιάζει τπτ! Μακρια απο VL παιδια! Οι τυποι δε εχουν ιδεα απο αισθητικη και λειτουργικοτητα! Παιρνουν ενα κινητακι ωραιο και του μα...νε τη μανα!!!!:blink: Μεγειες!!!!! Παράθεση
L10nH34Rt Δημ. May 27, 2006 Δημ. May 27, 2006 Χμ.. παρατήρησα ότι άμα δεν έχεις συντόμευση για παράδειγμα στο 'δεξιά' και το πατήσεις σε ρωτάει αμα θεσ να δημιουργήσεις μια συντόμευση. Άμα το κάνεις έτσι μόλις κλείσεις και ξανανοίξεις το κινητό αυτή χάνεται! Πρέπει να το κάνεις από το μενού των Ρυθμίσεων... Bug το οποίο υπάρχει και στα κ750 αν δεν κάνω λάθος... Παράθεση
geovass Δημ. May 27, 2006 Δημ. May 27, 2006 Χμ.. παρατήρησα ότι άμα δεν έχεις συντόμευση για παράδειγμα στο 'δεξιά' και το πατήσεις σε ρωτάει αμα θεσ να δημιουργήσεις μια συντόμευση. Άμα το κάνεις έτσι μόλις κλείσεις και ξανανοίξεις το κινητό αυτή χάνεται! Πρέπει να το κάνεις από το μενού των Ρυθμίσεων... Bug το οποίο υπάρχει και στα κ750 αν δεν κάνω λάθος... Με την νεα εκδοση δεν το κανει !!!:lol: :lol: :lol: :p :p Το εφτιαξαν !:D Παράθεση
m4gma Δημ. May 27, 2006 Δημ. May 27, 2006 Έχεις δίκιο, αυτό παρατήρησα και εγώ, μόνο στο δεξί βελάκι. Οπότε το απενεργοποίησα και όλα οκ (την απενεργοποίηση την κρατάει τουλάχιστον) ΥΓ: Ωραία τα flash themes αλλά πολύ βαριά! Κολλάει στο αρχικό μενού το κινητό συχνά, μέχρι να τα φορτώσει όλα. geovass ποια έκδοση λες. Εγώ έβαλα τα αρχεία που είπε ο φίλος hike (R4CK003) και το κάνει ακόμα. Το φλας βέβαια διορθώθηκε Παράθεση magma ------- iPhone 4GB - FW 2.1 - QuickPwned :D
toledo Δημ. May 27, 2006 Δημ. May 27, 2006 Εάν θέλει κάτι απλό και φθηνό από Sony Ericsson, υπάρχει το ροζ J300 http://www.sonyericsson.com/spg.jsp?cc=gr&lc=el&ver=4000&template=pp1_loader&php=php1_10247&zone=pp&lm=pp1&pid=10247 επίσης πολύ ωραία και παν' απ' όλα fashion είναι τα 7360, 7370 και 7380 της Νόκια http://europe.nokia.com/nokia/0,,83040,00.html ακόμα πέραν του ροζ Motorola V3 Razr υπάρχουν και τα ροζ Motorola L6, Nokia 6111, Nokia 3250, Samsung E530 και το LG u880. sas eyxaristo poli paidia gia tis apantiseis mallon tha pao sto motorola giati einai pio goustoziko (kai pio elafri:D ) Παράθεση kathe kinito einai oraio an antapokrinete stis prosdokies sou
m4gma Δημ. May 27, 2006 Δημ. May 27, 2006 Exo NON live w810i me thn Rc4 kai thelo na thn anavathmiso sthn R4ck. Me auto ton tropo tha ginei apla i anavathmisi i tha alla3ei kai kati allo kai tha exo argotera provlima?? Einai eukolo se kapoion na dosei odhgeies gia thn anavathmisi ayth giati anttimetopizo provlima!!Kat'arxas ta 2 arxeia pou katevasa fandazomai oti prepei na einia mesa ston fakelo flashes. Apo ekei kai pera anoigo ton unlocker, pao sthn kartela flash ftiaxno tis ruthmiseis kai.......???? Ta koumpia flash kai Flash get files den kanoun kati giati zitoun connection. To trito koumpi leei hold 'C' and plugin mobile....To kano alla kolaei ekei......!!!!Kamia idea????? Λοιπόν απο οτι κατάλαβα αυτά τα 2 αρχεία είναι αυτά που μας ενδιαφέρουν για ελλάδα/unbranded. Απλά τα κατεβάζεις. Δεν μπορείς να κάνεις get files, χωρίς login details από τον davinci. Τα αρχεία τα κατεβάζεις από το ftp που γράφω σε ένα μήνυμα πιο πάνω. Εγκαθιστάς το Sony Ericsoon Update Service από το site της SE (για να εγκατασταθούν οι drivers του καλωδίου) Εγκαθιστάς τον client 15.94 και τεστάρεις το καλώδιο ακολουθώντας τις οδηγίες. (επιλέγεις το DCU-60 πάνω δεξιά, αντί για COM1) Παίρνεις και ένα credit από davinci (σου έρχονται τα username/password σε email) και... ανοίγεις το πρόγραμμα. Ξετικάρεις όλα τα κουτάκια κάτω από τα αρχεία. Τικάρεις τα MAIN και FS και φορτώνεις τα αρχεία που κατέβασες. ΤΙΚΑΡΕΙΣ ΤΟ FINALISATION!!! Πατάς flash. Ακολουθείς τις ίδιες διαδικασίες για να συνδέσεις το κινητό, όπως όταν τέσταρες το καλώδιο, και περιμένεις και προσεύχεσαι. Όταν τελειώσει, βγάζεις τη μπαταρία, περιμένεις για 5-10 δευτερόλεπτα και μετά τη βάζεις και το ανοίγεις. Θα αργήσει λίγο να φορτώσει το νεό firmware. Ελπίζω να τα είπα όλα. Εγώ έτσι το έκανα. Ας πουνε και οι άλλοι. Καλή τύχη Παράθεση magma ------- iPhone 4GB - FW 2.1 - QuickPwned :D
X-GogoZ Δημ. May 27, 2006 Δημ. May 27, 2006 re paidia molis pira to w810i ths vodafone!pws ginetai na bgalw to menu ths vodafone kai na exw to authentiko ths sony? sorry an to exete pei alla den eimai kai poli sxetikos me auta!epishs mporei na allaksei prosopsi?auto to rwtaw apla enimerwtika euxaristw ek twn proterwn Παράθεση
toledo Δημ. May 27, 2006 Δημ. May 27, 2006 kalispera paidia, exo to tilefono apo to proigoumeno sabbato kai trizei poli i mallon arxise na trizei otan patao tin othoni me to piso kapaki kanei ena krik krik to exei paratirisei kanenas i mono sto diko mou to kanei? ti lete dokimaste to an einai na pao na to allakso!!! den exei pesei kato kai apo tin proti mera to exo se mia bodyglove thiki Παράθεση kathe kinito einai oraio an antapokrinete stis prosdokies sou
m4gma Δημ. May 27, 2006 Δημ. May 27, 2006 Ναι και εμένα το πάνω κουμπί τρίζεί λίγο, αλλά φαντάζομαι είναι θέμα κατασκευής, γιατί η αίσθηση του είναι κανονική. Ελπίζω να είναι και ανθεκτικό. Παράθεση magma ------- iPhone 4GB - FW 2.1 - QuickPwned :D
toledo Δημ. May 27, 2006 Δημ. May 27, 2006 Ναι και εμένα το πάνω κουμπί τρίζεί λίγο, αλλά φαντάζομαι είναι θέμα κατασκευής, γιατί η αίσθηση του είναι κανονική. Ελπίζω να είναι και ανθεκτικό. tora pou to les kai se mena to paratirisa alla den ksero an se ligo kairo arxizei na trizei olokliro alla apo thema kataskeyis fenete poli stibaro den ksero ti ginete ma kala toso mapa plastika bazoun stin ericsson?:( an kana allo paidi exei problima as mas pei, an trizei patontas to mprosta plastiko (othonis) me to piso taytoxrona, perimeno apantiseis!!! Παράθεση kathe kinito einai oraio an antapokrinete stis prosdokies sou
OratIos Δημ. May 27, 2006 Δημ. May 27, 2006 Λοιπόν απο οτι κατάλαβα αυτά τα 2 αρχεία είναι αυτά που μας ενδιαφέρουν για ελλάδα/unbranded. Απλά τα κατεβάζεις. Δεν μπορείς να κάνεις get files, χωρίς login details από τον davinci. Τα αρχεία τα κατεβάζεις από το ftp που γράφω σε ένα μήνυμα πιο πάνω. Εγκαθιστάς το Sony Ericsoon Update Service από το site της SE (για να εγκατασταθούν οι drivers του καλωδίου) Εγκαθιστάς τον client 15.94 και τεστάρεις το καλώδιο ακολουθώντας τις οδηγίες. (επιλέγεις το DCU-60 πάνω δεξιά, αντί για COM1) Παίρνεις και ένα credit από davinci (σου έρχονται τα username/password σε email) και... ανοίγεις το πρόγραμμα. Ξετικάρεις όλα τα κουτάκια κάτω από τα αρχεία. Τικάρεις τα MAIN και FS και φορτώνεις τα αρχεία που κατέβασες. ΤΙΚΑΡΕΙΣ ΤΟ FINALISATION!!! Πατάς flash. Ακολουθείς τις ίδιες διαδικασίες για να συνδέσεις το κινητό, όπως όταν τέσταρες το καλώδιο, και περιμένεις και προσεύχεσαι. Όταν τελειώσει, βγάζεις τη μπαταρία, περιμένεις για 5-10 δευτερόλεπτα και μετά τη βάζεις και το ανοίγεις. Θα αργήσει λίγο να φορτώσει το νεό firmware. Ελπίζω να τα είπα όλα. Εγώ έτσι το έκανα. Ας πουνε και οι άλλοι. Καλή τύχη Xmmmmmm kala to upopsiazomoun!!!!Thelei credit gia username kai pass.....Thank u pantos!!!! Alitheia apo to episimo update kai apo thn stigmi pou uparxei sto ftp, giati den to vriskei to neo fw?? Παράθεση
m4gma Δημ. May 27, 2006 Δημ. May 27, 2006 Όντως αφού είναι unbranded θα έπρεπε να το βρει. Πριν 3 λεπτά έκανα αναβάθμιση το W800 ενός φίλου μέσω του SEUS ανετότατα και χωρίς να χαθούν μάλιστα τα δεδομένα από το κινητό του. Παράθεση magma ------- iPhone 4GB - FW 2.1 - QuickPwned :D
airb Δημ. May 27, 2006 Δημ. May 27, 2006 Σε άσπρο ;) http://www.mobile-review.com/uploads/w810_white_1.jpg http://www.mobile-review.com/uploads/w810_white_2.jpg Παράθεση
akis_k Δημ. May 27, 2006 Δημ. May 27, 2006 Xαζομάρα σε άσπρο :rolleyes: Και μάλλον δεν θα το δούμε στην Ελλάδα γιατί και το επίσημο site της SonyEricsson δεν το αναφέρει καν. Μάλλον PhotoShop φαίνετε να είναι. Παράθεση
jimbou Δημ. May 27, 2006 Δημ. May 27, 2006 Εμένα μου αρέσει πάρα πολύ σε άσπρο! Έχετε δεί πουθενά να πουλάνε καμμια τέτοια πρόσοψη για να την αλλάξουμε? Παράθεση Πέρασαν...panasonic g500,sony z1,motorola startac,ericsson 768,nokia 3210,sony z5,siemens sl45i,sonyericsson t68i,nokia 7210,panasonic gd87,sonyericsson p800,orange spv,nokia 6600,qtek 8080,sonyericsson t610,samsung sgh-i530,qtek 8010,qtek s100,treo 650,motorola mpx220,nokia n70,qtek 8310,qtek s200,ubiquio 401,htc TyTN, htc p3300, apple iphone 2G, iphone 3G, iphone 3GS, iphone 4, Motorola Droid Razr, HTC One X, Samsung S3, S4, Sony Z1, 1+1, Note4 ...... :p
toledo Δημ. May 28, 2006 Δημ. May 28, 2006 kalispera paidia, epeidi proti fora dokimazo tis texnikes toy update katebasa apo tin ericsson to update service 2.6.4.9. meta ti kano?:rolleyes: Παράθεση kathe kinito einai oraio an antapokrinete stis prosdokies sou
OratIos Δημ. May 28, 2006 Δημ. May 28, 2006 kalispera paidia, epeidi proti fora dokimazo tis texnikes toy update katebasa apo tin ericsson to update service 2.6.4.9. meta ti kano?:rolleyes: .........Tipota!!!Den exei vgei akomi to teleutaio update!!!! Pantws to kaneis kanonika setup kai akoloutheis ta vimata....Einai analutikotato kai den katalavaino giati exeis provlima..!!! Παράθεση
toledo Δημ. May 28, 2006 Δημ. May 28, 2006 .........Tipota!!!Den exei vgei akomi to teleutaio update!!!! Pantws to kaneis kanonika setup kai akoloutheis ta vimata....Einai analutikotato kai den katalavaino giati exeis provlima..!!! apla tora katebazo to update service kai mexri na katebei eithela kapoies dieykriniseis eyxaristo otan katebei tha to dokimaso!! thanks!!! A kai otan bgei to update gia to 810 as mas pliroforisei kapoios!!! gia na fygei ayto to problimataki me to flash!! Παράθεση kathe kinito einai oraio an antapokrinete stis prosdokies sou
kgg Δημ. May 28, 2006 Δημ. May 28, 2006 Καλησπερα παιδες...Δεν ειμαι ιδιαιτερα ενεργος στο forum λογω επαγγελματικων υποχρεωσεων.Ειμαι ιδιαιτερα ικανοποιημενος απο το k750i,αλλα επειδη εχει βγει μια καλη επιδοτηση σκεφτομαι αυριο παρω το w810i.Ερωτηση προς οσους ειχαν πριν το κ750i...Οι φορτιστες,οι βασεις για το αυτοκινητο,τα hands free του 750 ειναι ιδια με αυτα του 810?Δηλαδη θα εφαρμοζουν και θα δουλευουν στη νεα συσκευη?Σας ευχαριστω εκ των προτερων... Παράθεση
