petr00kos Δημ. November 3, 2006 Δημ. November 3, 2006 pws ginete na alla3o ti seira twn 2 basikwn koubiwn de3ia kai aristera ? perasa ena neo firmware kai h diagrafh pige sto aristero pliktro kai i epilogh sto de3i kai einai spastiko ? kamia idea ? Παράθεση
bomber21 Δημ. November 3, 2006 Δημ. November 3, 2006 pws ginete na alla3o ti seira twn 2 basikwn koubiwn de3ia kai aristera ? perasa ena neo firmware kai h diagrafh pige sto aristero pliktro kai i epilogh sto de3i kai einai spastiko ? kamia idea ? Έτσι λύνεται το πρόβλημα σου. http://www.motox.info/showthread.php?t=25807&highlight=swap :) Παράθεση
NIK_TAX Δημ. November 4, 2006 Δημ. November 4, 2006 OTAN BLEPEIS FOTO H VIDEO KAI KATA THN DIARKEIS POY TO BLEPEIS PATHSEIS # H * MPOREIS NA TO DEIS SE FULL SCREEN? Παράθεση ))))))((((((
petr00kos Δημ. November 4, 2006 Δημ. November 4, 2006 bomber, meta to upgrade tou software exo 2 problems, to ena me ta koubakia pou sou eipa de3ia kai aristera pou ekana seem editing me to pk tools alla dn ginete tpt , den mporo na katalabw ti ennoei kanw check kai uncheck to bit 5 alla den allazei tpt, kai episis den mporw na oriso hxo klhshs mp3 , mono ta basika tou kinitoy... auta ta 2 mou proekipsan meta to update tou firmware. Παράθεση
bomber21 Δημ. November 4, 2006 Δημ. November 4, 2006 bomber, meta to upgrade tou software exo 2 problems, to ena me ta koubakia pou sou eipa de3ia kai aristera pou ekana seem editing me to pk tools alla dn ginete tpt , den mporo na katalabw ti ennoei kanw check kai uncheck to bit 5 alla den allazei tpt, kai episis den mporw na oriso hxo klhshs mp3 , mono ta basika tou kinitoy... auta ta 2 mou proekipsan meta to update tou firmware. Για το δεύτερο πρόβλημα υπάρχουν πολλά fixes. Aπό το MotoX: 11. I cannot access my ring details after deleting sounds Ring styles Fix There are a few fixes: 1. Open p2kman Delete MyToneDB.db & TempToneDB.bd from the /a/mobile/audio directory and do a master reset (security code 000000) 2. Open PST create go to file>new>feature file choose GSM and make sure all values are set to 0 and click on the write to phone button 3. Open Motokit and use the fix ringstyles option-THIS IS EASIEST! 4. Open p2ktools go into p2k mode, connect phone, refresh list. Hit all silent at the top of screen, then restart phone. 5. Using p2kman upload these seems to your phone SILENT RINGSTYLES 6. Another method with p2kman: 1. Delete the 2 db files and restart the phone. 2. Go into the audio or sounds menu NOT I repete NOT the Ringstyles menu and pick a ringtone from there> Hit the top middle button and scroll down to Apply as Ringtone and apply it. 3. Now go into the Ringstyles menu and see if you can change it. Όσον αφορά το πρώτο πρόβλημα,ξέρεις να κάνεις seem editing? Δες αυτόν το οδηγό: Guide to SEEM Editing Step-by-Step guide to performing seem edits Παράθεση
Deadly_Sin1629395575 Δημ. November 7, 2006 Δημ. November 7, 2006 μια λιγο χαζη απορια :O Το βιολετι χρωμα υπαρχει κανονικα? ρωταω επειδη μονο σε ασημι το εχω δει μεχρι τωρα. Παράθεση
nikos2005 Δημ. November 7, 2006 Δημ. November 7, 2006 μια λιγο χαζη απορια :O Το βιολετι χρωμα υπαρχει κανονικα? ρωταω επειδη μονο σε ασημι το εχω δει μεχρι τωρα. Ναι υπάρχει αλλά είναι να σου αρέσει. Ζήτησε να σου ανοίξουν το κουτί πριν το αγοράσεις. Παράθεση
Montoya_f1 Δημ. November 7, 2006 Δημ. November 7, 2006 Μήπως μπορεί να μου απαντήσει καποιος , το v3i δεν έχει ειδοποίηση στην εξωτερική οθόνη για αναπάντητη κλήση? Ευχαριστώ Παράθεση Θανάσης
nikos2005 Δημ. November 7, 2006 Δημ. November 7, 2006 Μήπως μπορεί να μου απαντήσει καποιος , το v3i δεν έχει ειδοποίηση στην εξωτερική οθόνη για αναπάντητη κλήση? Ευχαριστώ Υπάρχει ειδοποίηση και δείχνει μεχρι και την φωτο αυτού που σε παίρνει. Αν δεν το δεις και ανέβει ο screen saver τότε βλέπεις μόνο το ρολόι και έχεις την υπενθήμηση σε τακτα χρονικά διαστήματα ότι έχεις μήνυμα ή αναπάντητη. Παράθεση
Montoya_f1 Δημ. November 8, 2006 Δημ. November 8, 2006 Υπάρχει ειδοποίηση και δείχνει μεχρι και την φωτο αυτού που σε παίρνει. Αν δεν το δεις και ανέβει ο screen saver τότε βλέπεις μόνο το ρολόι και έχεις την υπενθήμηση σε τακτα χρονικά διαστήματα ότι έχεις μήνυμα ή αναπάντητη. Eυχαριστώ για την απάντηση αλλά ενοοώ όχι όταν δέχεσαι την κλήση αλλά όταν δεν έχεις απαντήσει.Γράφει η οθόνη π.χ 1 αναπάντητη κλήση ή απλά χτυπάει σε τακτά χρονικά διαστήματα? Παράθεση Θανάσης
nikos2005 Δημ. November 8, 2006 Δημ. November 8, 2006 Eυχαριστώ για την απάντηση αλλά ενοοώ όχι όταν δέχεσαι την κλήση αλλά όταν δεν έχεις απαντήσει.Γράφει η οθόνη π.χ 1 αναπάντητη κλήση ή απλά χτυπάει σε τακτά χρονικά διαστήματα? Βλέπεις 1 Αναπάντητη για ένα λεπτό μόνο. Μετα από ένα λεπτό από την στιγμή της κλήσης ανεβαίνει το ρολόι και σου σβύνει το μία αναπάντητη από την εξωτερική οθόνη. Παράθεση
NIK_TAX Δημ. November 8, 2006 Δημ. November 8, 2006 ΕΙΜΑΙ ΕΤΟΙΜΟΣ ΝΑ ΠΑΩ ΝΑ ΤΟ ΠΑΡς ΤΟ V3I ΑΛΛΑ ΔΕΝ ΕΙΜΑΙ ΑΚΟΜΑ 100% ΣΙΓΟΥΡΟΣ ΑΝ ΕΙΝΑΙ ΚΑΛΗ ΑΓΟΡΑ? ΜΗΠΟΣ ΜΟΥ ΠΡΟΤΗΝΕΤΕ ΚΑΝΕΝΑ ΑΛΛΟ ΣΤΑ ΙΔΙΑ ΛΕΦΤΑ ΠΕΡΙΠΟΥ ΔΕΝ ΜΕ ΕΝΔΙΑΦΕΡΕΙ Η ΧΡΗΣΗ ΤΟΥ ΣΑΝ ΜΡ3 PLAYER ΓΙΑΤΙ ΕΧΩ... ΚΑΙ ΚΑΤΙ ΑΛΛΟ ΣΤΟ ΠΑΚΕΤΟ ΑΓΟΡΑΣ ΤΗ ΕΧΕΙ? ΚΑΡΤΑ ΕΧΕΙ?ΑΝ ΝΑΙ ΣΕ ΤΗ ΜΕΓΕΘΟΣ? Παράθεση ))))))((((((
petr00kos Δημ. November 9, 2006 Δημ. November 9, 2006 ta sms moy ystera apo anaba8misi firmware periorizonte se 40 xaraktires per sms , ti mporw na kanw ? Παράθεση
bomber21 Δημ. November 9, 2006 Δημ. November 9, 2006 ta sms moy ystera apo anaba8misi firmware periorizonte se 40 xaraktires per sms , ti mporw na kanw ? Οδηγός:Αύξηση Μνήμης Μηνυμάτων Ισως σε βοηθήσει. Παράθεση
petr00kos Δημ. November 9, 2006 Δημ. November 9, 2006 bomber den ennow ta SMS san ari8mo ennow oti periorizete o ari8mos XARAKTHRWN ana SMS , unicode legete kapws etsi... Enw kanonika einai 160 xaraktires ana SMS twra exo 40 / sms h kapou toso ... ayto pws lynete ? :) Παράθεση
Montoya_f1 Δημ. November 9, 2006 Δημ. November 9, 2006 ΕΙΜΑΙ ΕΤΟΙΜΟΣ ΝΑ ΠΑΩ ΝΑ ΤΟ ΠΑΡς ΤΟ V3I ΑΛΛΑ ΔΕΝ ΕΙΜΑΙ ΑΚΟΜΑ 100% ΣΙΓΟΥΡΟΣ ΑΝ ΕΙΝΑΙ ΚΑΛΗ ΑΓΟΡΑ? ΜΗΠΟΣ ΜΟΥ ΠΡΟΤΗΝΕΤΕ ΚΑΝΕΝΑ ΑΛΛΟ ΣΤΑ ΙΔΙΑ ΛΕΦΤΑ ΠΕΡΙΠΟΥ ΔΕΝ ΜΕ ΕΝΔΙΑΦΕΡΕΙ Η ΧΡΗΣΗ ΤΟΥ ΣΑΝ ΜΡ3 PLAYER ΓΙΑΤΙ ΕΧΩ... ΚΑΙ ΚΑΤΙ ΑΛΛΟ ΣΤΟ ΠΑΚΕΤΟ ΑΓΟΡΑΣ ΤΗ ΕΧΕΙ? ΚΑΡΤΑ ΕΧΕΙ?ΑΝ ΝΑΙ ΣΕ ΤΗ ΜΕΓΕΘΟΣ? Φίλε μου και εγώ τέτοιο πρόβλημα είχα .Να το αγοράσω ή οχι Εγώ το αγόρασα ( είμουν κάτοχος του 6270) Εχει αδυναμίες αλλά όχι κάτι φοβερό όπως όλλα τα κινητά άλλωστε.Η μία εταιρεία διαφέρει απο την άλλη. Το πακέτο περιέχει κάρτα μνήμης 128 Εξαρτάται από τις ανάγκες σου.Η τιμή του ειναι πλέον πολύ καλή.Επίσης σε design για μένα είναι αξεπέραστο. Εύχομαι να κάνεις καλή αγορά Παράθεση Θανάσης
NIK_TAX Δημ. November 9, 2006 Δημ. November 9, 2006 MESO TOY LIVE UPDATE MPOROYME NA KANOYE ANABA8MISH STO KIN XORIS KANENA PROBLHMA ? TWRA TO KATEBAZW MESO TOY MOTOROLA TOOLS POY EIXE STO CD META TH KANW? Παράθεση ))))))((((((
bomber21 Δημ. November 9, 2006 Δημ. November 9, 2006 bomber den ennow ta SMS san ari8mo ennow oti periorizete o ari8mos XARAKTHRWN ana SMS , unicode legete kapws etsi... Enw kanonika einai 160 xaraktires ana SMS twra exo 40 / sms h kapou toso ... ayto pws lynete ? :) Sorry,έχεις δίκιο! :O Mπορείς να πας στο p2k tools,στο other features/messages,να πατήσεις get,να αλλάξεις την επιλογή ''sms unicide'' και μετά ''SET''. MESO TOY LIVE UPDATE MPOROYME NA KANOYE ANABA8MISH STO KIN XORIS KANENA PROBLHMA ? TWRA TO KATEBAZW MESO TOY MOTOROLA TOOLS POY EIXE STO CD META TH KANW? Δεν κατάλαβα τι εννοείς ακριβώς.Αναβάθμιση κάνουμε με το RSD Lite. Παράθεση
iassael Δημ. November 9, 2006 Δημ. November 9, 2006 sorry an exei apanti8ei alla elliniko language pack pu vriskw? Παράθεση
bomber21 Δημ. November 9, 2006 Δημ. November 9, 2006 sorry an exei apanti8ei alla elliniko language pack pu vriskw? Eλληνικά Lang Packs http://grmoto.blogspot.com/2006/09/e.html Παράθεση
iassael Δημ. November 9, 2006 Δημ. November 9, 2006 ti dilwseis einai autes :) K episis flash to kanw me to rsd lite 3.2? Giati otan paw kolaei sto bootloader... Παράθεση
iassael Δημ. November 9, 2006 Δημ. November 9, 2006 episis tha protimusa reflash. Poio na valw k apo pu? Euxaristw para poly Παράθεση
bomber21 Δημ. November 9, 2006 Δημ. November 9, 2006 Άμα κολλάει στο bootloader mode,προσπάθησε να ξαναεγκαταστήσεις τους drivers και σιγουρέψου ότι περνάς το σωστό αρχείο. Παράθεση
iassael Δημ. November 12, 2006 Δημ. November 12, 2006 Kalispera. Telika ekana flash. Alla apo prin opws k twra to v3i enw mporei na parei email dn mporei na steilei exw TIM k mu vgazei "server not availiable". Ti na kanw? Παράθεση
bomber21 Δημ. November 16, 2006 Δημ. November 16, 2006 Nέο Firmware R479_G_08.B5.3DR http://www.motox.info/showthread.php?t=30379 Προσέξτε ποιό αρχείο θα κατεβάσετε από όλα.Αυτό που αναβαθμίζει το software ΜΟΝΟ και δεν αλλάζει τα δεδομένα και τις ρυθμίσεις σας είναι το Reflash_mlp_mdrm™ [Firmware minus LP & DRM] . Aπό το MotoX.info Για μη iTunes τηλέφωνα (R479) Παράθεση
