Ταχύτητες ADSL σε kbps - Μετρήστε την σύνδεση σας!
Speed Test Results
Downstream 847.9 Kbps ( = 0.8 Mbps )
Upstream 208.1 Kbps ( = 0.2 Mbps )
  • Απαντήσεις 163
:::.. Download Stats ..:::
Download Connection is:: 246 Kbps about 0.25 Mbps (tested with 386 kB)
Download Speed is:: 30 kB/s
Tested From:: http://testmy.net/ (Server 2)Test Time:: 2006/06/10 - 12:27pm
Bottom Line:: 4X faster than 56K 1MB Download in 34.13 sec
Tested from a 386 kB file and took 12.843 seconds to complete
Download Diagnosis:: 90% + Okay : running at 100 % of your hosts average (33.235)
D-Validation Link:: http://testmy.net/stats/id-ISD281460
Host Average:: host:33.235 dl-avg:246Kbps
User Agent:: Mozilla/5.0 (Windows; U; Windows NT 5.1; el; rv:1.8.0.4) Gecko/20060508 Firefox/1.5.0.4 [!]
:::.. testmy.net test results ..:::
Download Connection is:: 441 Kbps about 0.44 Mbps (tested with 386 kB)
Download Speed is:: 54 kB/s
Upload Connection is:: 92 Kbps about 0.09 Mbps (tested with 386 kB)
Upload Speed is:: 11 kB/s
Tested From:: http://testmy.net (Server 2)Test Time:: 2006/06/11 - 9:47pm
D-Validation Link:: http://testmy.net/stats/id-OIW078SBV
U-Validation Link:: http://testmy.net/stats/id-HFOESZ93U
User Agent:: Opera/9.00 (Windows NT 5.1; U; en) [!]
Ναι..Είμαι αιμοδότης...
2006 Modenas Dinamik 71mm....
1998 Seat Ibiza S4 Turbo
1992 Suzuki RGV-Γ 250cc
2001 Suzuki FX 68.5mm
Από το http://speedtest.forthnet.gr/
Checking for Middleboxes . . . . . . . . . . . . . . . . . . Done
running 10s outbound test (client to server) . . . . . 115.25Kb/s
running 10s inbound test (server to client) . . . . . . 430.74kb/s
Και έχω 512/128! Είμαι από τους τυχερούς της προσφοράς της 1ης Ιουνίου:rocket: :shoot: :chair: :hunter: :down:
http://img262.imageshack.us/img262/7971/pub68112179146481597828td2.png
Wii number: 3236 8718 1653 5956
running 10s outbound test (client to server) . . . . . 115.36Kb/s
running 10s inbound test (server to client) . . . . . . 310.13kb/s
καλά τα πάω?
pocophone X3 NFC // huawei watch gt :!:
Δεν είναι άσχημα τα αποτελέσματά σου dude...
Εσύ τι αποτελέσματα έχεις? Παντώς μου φαίνεται οτι είναι λίγο το νούμερο για 512/384
δεν ειναι λιγο, ειναι οπως πρεπει για 512/128. οπως και η 384 πιανει 330 μεγιστο περιπου.
καλά τα πάω?
καλα ειναι, θα μπορουσε λιγο παραπανω αλλα οκ :)
running 10s outbound test (client to server) . . . . . 115.44Kb/s
running 10s inbound test (server to client) . . . . . . 323.04kb/s
Your PC is connected to a Cable/DSL modem:worry: :worry:
running 10s outbound test (client to server) . . . . . 718.59Kb/s
running 10s inbound test (server to client) . . . . . . 1.78Mb/s
Information: Other network traffic is congesting the link
εστρωσε η vivodi :D
Έρωτας: Κορυφαίο ιδιοτελές συναίσθημα, αναφέρεται μόνο στις ερωτικές σχέσεις (όπως δείχνει και το όνομα του). Δίνεις τα πάντα στον άλλο και περιμένεις τα πάντα από αυτόν. Παραδίδεσαι ψυχή τε και σώματι και επιθυμείς το ίδιο από το ταίρι σου. Για μένα ο αληθινός μεγαλειώδης έρωτας, αυτός που θα σταματήσει το χρόνο, είναι πιο σπάνιος και προσωπικά πιο επιθυμητός από την αγάπη.
Κι εμένα σήμερα, αλλά και πολλών άλλων, τα pings πολύ καλά!
Λες να έγινε το update; :!:
Παιδια πως μαθαινουμε σε τι (μαρκα) DSLAM ειμαστε συνδεδεμενοι?
έχω κι εγώ την ίδια απορία...
there is no knowledge that is no power
στο adslgr.com υπαρχει ενα θεμα με τη σχετικη πληροφορια σε xls αν θυμαμαι μορφη :)
επειδή το κοίταξα αλλά δε βρήκα κάτι σχετικό, όποιος έχει ένα link θα βοηθούσε.
Τα δικα μου αποτελεσματα μου φαινονται δραματικα για 384!!!
TCP/Web100 Network Diagnostic Tool v5.2.1e
click START to begin
running 10s outbound test (client to server) . . . . . 88.56Kb/s
running 10s inbound test (server to client) . . . . . . 269.20kb/s
Είχα επικοινωνησει με την HOL τους ενημερωσα, δηλώσαν βλάβη στον ΟΤΕ αλλα απο τοτε δεν ειδα βελτιωσει. τι αλλο να κανω δεν ξέρω
Guest lagoudakis
εχεις παντα αυτες τις μετρησεις;γιατι εγω πχ το πρωι 6-9 ειμαι στο 330 απο τις 10-10 στο 270 και μετα παω στο 300αρι
οχι δεν εχω πάντα αυτες τις τιμές, υπάρχουν και πιο κάτω, αλλά είναι φυσιολογικό? εσυ σε πια εταιρία εισαι? έχεις μιλήσει μαζί τους για την ταχυτητά σου?
κλασσικη περιπτωση γεματου dslam ειδικα αν εχετε δοκιμασει και αλλους ISPs. πιθανον να μη μπορεις να κανεις κατι εφοσον δεν εχει βλαβη η γραμμη, μονο να περιμενεις αναβαθμισεις του ΟΤΕ.
το παραδειγμα του lagoudakis ειναι χαρακτηριστικο, νωρις το πρωι που δε μπαινουν πολλοι εχει καλες ταχυτητες και την υπολοιπη ημερα που ολοι ειναι ξυπνιοι η ταχυτητα πεφτει.
running 10s outbound test (client to server) . . . . . 116.50Kb/s
running 10s inbound test (server to client) . . . . . . 323.05kb/s
Εχω 384/128. Ειναι καλες αυτες οι ταχυτητες? :worry:
Guest lagoudakis
φυσιολογικο δεν ειναι,το σωστο ειναι να ειμαστε πανω απο 300 μονιμα,αλλα παιζουν πολλα ρολο,πχ αν ειναι τιγκα το dislam της περιοχης σου,αν ειναι οκ η γραμμη του τηλεφωνου σου,αστα να πανε:O εχω μιλησει και μου ειπαν οτι το κοιταξαν και ολα ειναι μια χαρα:confused: σιγα βεβαια μην το κοιταξαν:p πριν 3 μηνες ειχα συχνες αποσυνδεσεις 3-4 την βδομαδα,τουλαχιστον τωρα σταματησαν,με οτενετ ειμαι
