Incasinato Δημ. April 4, 2020 Δημ. April 4, 2020 (edited) I installed the version: [10/03/2020] EUI30s_v23_Official Written by CBG with its TWRP. It is normal that on restarting the message appears: "welcome to cuoco release"? p.s. update, I tried to make and receive a phone call: the audio in the capsule is a bit low but you can hear it, the interlocutor also hears me well. If I activate the speakerphone the audio in the capsule is no longer heard, if I deactivate the speakerphone the audio in the capsule returns. This is for calls, while the problem remains for the other audio files. Edited April 4, 2020 by Incasinato Παράθεση
sso Δημ. April 4, 2020 Δημ. April 4, 2020 ... update, I tried to make and receive a phone call: the audio in the capsule is a bit low but you can hear it, the interlocutor also hears me well. If I activate the speakerphone the audio in the capsule is no longer heard, if I deactivate the speakerphone the audio in the capsule returns. This is for calls, while the problem remains for the other audio files. Did you see this answer? http://www.myphone.gr/forum/showthread.php?p=7996540#post7996540 Παράθεση Ω ξειν, αγγέλλειν πατράσι ότι τήδε κοιμόμεθα τοις κείνων χρήμασι τρεφόμενοι Mi Mix 2S, Le Max2, Meizu Pro 6 Plus
Incasinato Δημ. April 4, 2020 Δημ. April 4, 2020 yes I saw it, but I didn't understand how I should overcome encryption. Furthermore, I confirm that when the phone is restarted, it appears first written: welcome to the version of Cuoco, who is a rom developer. Παράθεση
sso Δημ. April 5, 2020 Δημ. April 5, 2020 yes I saw it, but I didn't understand how I should overcome encryption. Furthermore, I confirm that when the phone is restarted, it appears first written: welcome to the version of Cuoco, who is a rom developer. I am talking about sound/speaker issue:) Παράθεση Ω ξειν, αγγέλλειν πατράσι ότι τήδε κοιμόμεθα τοις κείνων χρήμασι τρεφόμενοι Mi Mix 2S, Le Max2, Meizu Pro 6 Plus
Incasinato Δημ. April 5, 2020 Δημ. April 5, 2020 Sorry but I did not understand what you mean again: the audio on call is heard, but if I put on speakerphone the audio is not heard. Did you mean this? Παράθεση
sso Δημ. April 5, 2020 Δημ. April 5, 2020 I mean, there's probably a problem with the speaker, which was obviously caused by the fall. You can hear your interlocutor from the headset but not from the speaker. This is why you cannot hear sound from another source e.g. music. Παράθεση Ω ξειν, αγγέλλειν πατράσι ότι τήδε κοιμόμεθα τοις κείνων χρήμασι τρεφόμενοι Mi Mix 2S, Le Max2, Meizu Pro 6 Plus
vasillis2 Δημ. April 5, 2020 Δημ. April 5, 2020 Sorry but I did not understand what you mean again: the audio on call is heard, but if I put on speakerphone the audio is not heard. Did you mean this? Αλλαξε ρομ να το τσεκαρης...:) Παράθεση Le max 2 x829/6x128/ - RROS-Q-8.7.3-20210920-x2-Official
Incasinato Δημ. April 5, 2020 Δημ. April 5, 2020 Thanks for the reply. I have already tried two Roms by completing a clean install. I also replaced TWRP, but nothing. Do you think at this point I need to replace the speaker? Παράθεση
vasillis2 Δημ. April 5, 2020 Δημ. April 5, 2020 I installed the version: [10/03/2020] EUI30s_v23_Official Written by CBG with its TWRP. It is normal that on restarting the message appears: "welcome to cuoco release"? Με βαση αυτο που γραφεις εδω, το οποιο (ΔΕΝ ειναι φυσιολογικο,) σημαινει οτι, εχεις κανει, καποιο λαθος... ΟΠΟΤΕ.. Μονο ο CrisBal μπορει να σε βοηθειση, υπευθυνα.. Κανε λιγο υπομονη.. Καποια στιγμη, θα δει το μηνυμα, και αν υπαρχει λυση, θα σου πει σιγουρα.. Παράθεση Le max 2 x829/6x128/ - RROS-Q-8.7.3-20210920-x2-Official
sso Δημ. April 5, 2020 Δημ. April 5, 2020 ... Do you think at this point I need to replace the speaker? Replace the speaker Παράθεση Ω ξειν, αγγέλλειν πατράσι ότι τήδε κοιμόμεθα τοις κείνων χρήμασι τρεφόμενοι Mi Mix 2S, Le Max2, Meizu Pro 6 Plus
Incasinato Δημ. April 5, 2020 Δημ. April 5, 2020 I installed the version: [10/03/2020] EUI30s_v23_Official Written by CBG with its TWRP. It is normal that on restarting the message appears: "welcome to cuoco release"? Με βαση αυτο που γραφεις εδω, το οποιο (ΔΕΝ ειναι φυσιολογικο,) σημαινει οτι, εχεις κανει, καποιο λαθος... ΟΠΟΤΕ.. Μονο ο CrisBal μπορει να σε βοηθειση, υπευθυνα.. Κανε λιγο υπομονη.. Καποια στιγμη, θα δει το μηνυμα, και αν υπαρχει λυση, θα σου πει σιγουρα.. I'm aware of it, but I don't know how to get out of it. I formatted the whole phone, but the one that always comes up. Παράθεση
sso Δημ. April 5, 2020 Δημ. April 5, 2020 (edited) To check Hardware (Version, Sensors, Battery, Radio, Speakers) Type: *#*#64663#*#* Edited April 6, 2020 by sso Παράθεση Ω ξειν, αγγέλλειν πατράσι ότι τήδε κοιμόμεθα τοις κείνων χρήμασι τρεφόμενοι Mi Mix 2S, Le Max2, Meizu Pro 6 Plus
Incasinato Δημ. April 6, 2020 Δημ. April 6, 2020 Thanks but to me that sequence on this phone does not work, instead it works on my xiaomi mi max3. Παράθεση
sso Δημ. April 6, 2020 Δημ. April 6, 2020 Thanks but to me that sequence on this phone does not work, instead it works on my xiaomi mi max3. Yes, does not work with all roms. For me didn't work with AICP Rom. Yesterday I flashed miui 11, by Cris, and this secret code works. I would advise you to flash a stock rom, or miui 11 (now we know that this secret code works), to check if is hardware (speaker) problem.:) Παράθεση Ω ξειν, αγγέλλειν πατράσι ότι τήδε κοιμόμεθα τοις κείνων χρήμασι τρεφόμενοι Mi Mix 2S, Le Max2, Meizu Pro 6 Plus
Incasinato Δημ. April 6, 2020 Δημ. April 6, 2020 Rom changed, test performed: failed. I proceed to order the speaker from Aliexpress. Do you happen to have a reliable dealer? Παράθεση
sso Δημ. April 6, 2020 Δημ. April 6, 2020 I told you from the first moment that it is probably a speaker problem:p http://www.myphone.gr/forum/showthread.php?p=7996540#post7996540 I don't know any reliable seller on AliExpress I would prefer ebay (paypal) Παράθεση Ω ξειν, αγγέλλειν πατράσι ότι τήδε κοιμόμεθα τοις κείνων χρήμασι τρεφόμενοι Mi Mix 2S, Le Max2, Meizu Pro 6 Plus
CrisBal Δημ. April 6, 2020 Δημ. April 6, 2020 I 1. installed the version: [10/03/2020] EUI30s_v23_Official Written by CBG with its TWRP. It is normal that on restarting the message appears: "welcome to cuoco release"? 2. update, I tried to make and receive a phone call: the audio in the capsule is a bit low but you can hear it, the interlocutor also hears me well. If I activate the speakerphone the audio in the capsule is no longer heard, if I deactivate the speakerphone the audio in the capsule returns. This is for calls, while the problem remains for the other audio files. 1. That's because Cuoco includes splash image with his nickname inside. You can flash splash.img separate being back stock in. 2. This might have to do with speaker as him self. Told you before. Try to flash a stock rom or mine 30s to check if working or not. If doesn't work you should think to search on AliExpress and buy a new one. Παράθεση LeMax2-X820 LegionOS / LeMax2-X822 DerpFest Xiaomi RN3Pro-MIUI10_9.3.14 Xiaomi RN9Pro-MIUI-12.5.5-RJWMIX
Incasinato Δημ. April 6, 2020 Δημ. April 6, 2020 Unfortunately the translator plays tricks on me in translation. can you tell me which Rome should i try? Thanks, even if it doesn't work, so I will proceed with the purchase of the speaker. Παράθεση
CrisBal Δημ. April 6, 2020 Δημ. April 6, 2020 Unfortunately the translator plays tricks on me in translation. can you tell me which Rome should i try? Thanks, even if it doesn't work, so I will proceed with the purchase of the speaker. Try to flash clean . Make wipes..system data dalvik and cache if you are on EUI MM.. If you are on Q make format data and then all others.. Use my 3.2.1-1. TWRP for EUI only. http://www.myphone.gr/forum/showthread.php?p=7986412#post7986412 Παράθεση LeMax2-X820 LegionOS / LeMax2-X822 DerpFest Xiaomi RN3Pro-MIUI10_9.3.14 Xiaomi RN9Pro-MIUI-12.5.5-RJWMIX
aposporis Δημ. April 6, 2020 Δημ. April 6, 2020 Σε περίπτωση που κάποιος θέλει να αλλάξει την αρχική αρχική εικόνα όταν ανοίγει το κινητό (όχι το boot animation!) οδηγίες εδώ. Παράθεση
CrisBal Δημ. April 7, 2020 Δημ. April 7, 2020 New Official DerpFest Build For LeEco-x2-LeMax2 By : @CrisBalGreece Build Date: 07/April/2020 ⬇️ G-drive Download https://drive.google.com/file/d/1d2T7UXfukMnKxpHA_qNaLQueD_9gDBNT/view?usp=sharing Changelog https://github.com/CrisBalGreece/derp_Updater-Stuff/blob/master/x2/Changelog.txt Derp Website https://derpfest.org/ Telegram Group http://t.me/CBG_LeMax2 Instructions : Clean Flash Recommended or try to go dirty from previous 03.28.2020 Flash Guide : - Make Sure You have my latest 3.3.1-3 TWRP or official 3.3.1-0 - Make wipe two caches , data and system (optional vendor) - Flash Rom - Flash Magisk 20.3 to pass CTS (optional) - Reboot to system - Enjoy Derpfest... NOTE Pixel Gapps included. DO NOT flash other's. Παράθεση LeMax2-X820 LegionOS / LeMax2-X822 DerpFest Xiaomi RN3Pro-MIUI10_9.3.14 Xiaomi RN9Pro-MIUI-12.5.5-RJWMIX
mosxotrelos Δημ. April 8, 2020 Δημ. April 8, 2020 (edited) Καλησπέρα. Κατά αρχήν να βάλεις ένα νεώτερο firmware γιατί από ότι βλέπω είσαι με 20s ακόμα. https://mega.nz/#!UORUEQqS!kHZ40NqPT4D4wkgEmEYsNV_cx_PtNSnsxXuK7PtFLAE Kai modem https://drive.google.com/file/d/0BzEfccsbwlFUSzZCMHN0S2ZCU2s/view Μετά από ROM όσες θες.. Φυσικά εάν δεν έχεις θα αλλάξεις και TWRP https://drive.google.com/file/d/1yDiUxYzcJjt_Ng3mYZkCXqcHlU57BWZd/view?usp=sharing Μετά θα κάνεις ένα factory reset και vendor και θα βάλεις την Derp ή την ROS η AICP AOSIP LOS 17.1 Εσύ αποφασίζεις Καλησπερα Cris επειδη δεν ειχα προσβαση τωρα ειδα την απαντηση σου...εβαλα τα νεα firmware kai modem που μου ειχες πει τωρα για να βαλω την derp που ανεβασες σημερα θα πρεπει να κανω factory reset και clean to vendor και στην συνεχεια απλα βαζω αυτην την ρομ? Ευχαριστω εκ των προτερων και με υγεια παντα Edited April 8, 2020 by mosxotrelos Παράθεση
CrisBal Δημ. April 8, 2020 Δημ. April 8, 2020 Καλησπερα Cris επειδη δεν ειχα προσβαση τωρα ειδα την απαντηση σου...εβαλα τα νεα firmware kai modem που μου ειχες πει τωρα για να βαλω την derp που ανεβασες σημερα θα πρεπει να κανω factory reset και clean to vendor και στην συνεχεια απλα βαζω αυτην την ρομ? Ευχαριστω εκ των προτερων και με υγεια παντα Ναι..αν έχεις επάνω τουλάχιστον το 3.3.1-0 και κάνεις όλα τα wipe είσαι μια χαρά.. Παράθεση LeMax2-X820 LegionOS / LeMax2-X822 DerpFest Xiaomi RN3Pro-MIUI10_9.3.14 Xiaomi RN9Pro-MIUI-12.5.5-RJWMIX
vasillis2 Δημ. April 8, 2020 Δημ. April 8, 2020 New Official DerpFest Build For LeEco-x2-LeMax2 By : @CrisBalGreece Build Date: 07/April/2020 ⬇️ G-drive Download https://drive.google.com/file/d/1d2T7UXfukMnKxpHA_qNaLQueD_9gDBNT/view?usp=sharing Changelog https://github.com/CrisBalGreece/derp_Updater-Stuff/blob/master/x2/Changelog.txt Derp Website https://derpfest.org/ Telegram Group http://t.me/CBG_LeMax2 Instructions : Clean Flash Recommended or try to go dirty from previous 03.28.2020 Flash Guide : - Make Sure You have my latest 3.3.1-3 TWRP or official 3.3.1-0 - Make wipe two caches , data and system (optional vendor) - Flash Rom - Flash Magisk 20.3 to pass CTS (optional) - Reboot to system - Enjoy Derpfest... NOTE Pixel Gapps included. DO NOT flash other's. Αρχηγε.. Δεν σταματας να προσφερης!!!!! Σ ευχαριστουμε! Παράθεση Le max 2 x829/6x128/ - RROS-Q-8.7.3-20210920-x2-Official
mosxotrelos Δημ. April 9, 2020 Δημ. April 9, 2020 Ναι..αν έχεις επάνω τουλάχιστον το 3.3.1-0 και κάνεις όλα τα wipe είσαι μια χαρά..τα κατάφερα την πέρασα αλλά έχω ένα θέμα με το Quick charge ενώ το έχω ενεργοποιήσει δεν φορτίζει και ένα θέμα με το WiFi αλλά σε αυτό μπορεί να φταίει η σύνδεση της wind Sent from my LEX820 using Tapatalk Παράθεση
