harley5 Δημ. August 28, 2015 Δημ. August 28, 2015 http://techmaniacs.gr/samsung-galaxy-note5-might-be-coming-to-europe-as-soon-as-august-28-63182-2/ Παράθεση [sIGPIC][/sIGPIC]
narcotic Δημ. August 28, 2015 Δημ. August 28, 2015 Τελικά? Κανένα νέο σχετικά με τη διάθεση του στην Ευρώπη? Παράθεση t18s - 3310 - 3310 - 8210 - t65 - 6510 - 7210 - n-gage - 7610 - 6290 - ks20 - tg01 - s2 & galaxy tab 10.1 - s3 - note 3 & note pro 12.2
Lippi Δημ. August 29, 2015 Δημ. August 29, 2015 Φήμες αναφέρουν ότι περνάει πιστοποίηση... Παράθεση Will go to heaven for the climate, to hell for the company...
narcotic Δημ. August 29, 2015 Δημ. August 29, 2015 Άρα πότε θα έρθει? Και με πόση ram? Παράθεση t18s - 3310 - 3310 - 8210 - t65 - 6510 - 7210 - n-gage - 7610 - 6290 - ks20 - tg01 - s2 & galaxy tab 10.1 - s3 - note 3 & note pro 12.2
alextrela Δημ. August 30, 2015 Δημ. August 30, 2015 Samsung Galaxy Note 5 (SM-N920A) Smartphone Review http://www.notebookcheck.net/Samsung-Galaxy-Note-5-SM-N920A-Smartphone-Review.149124.0.html Pro + Brighter and more accurate Super AMOLED 1440p display + Thinner and lighter than Galaxy Note 4 + Push-button feature works without issues + Metal edges and corners; Solid construction + High-performance Exynos 7420 SoC with 4 GB RAM + Good outdoor usability; High automatic brightness + Great SSD performance + Fingerprint sensor and heart rate monitor + Wi-Fi calling Cons - Non-removable battery - No Dual-SIM support - IR support removed - MHL support removed - MicroSD support removed - No USB Type-C - Plastic back cover - S Pen is uncomfortable for extended use - Same throttling issues as the Galaxy Note 4 - Unimpressive speaker Verdict Is the Galaxy Note 5 worth the upgrade if you already have a Note 4 or Galaxy S6? The push-button S Pen is genuinely ergonomic and more than just a novelty feature, while the brighter and more accurate display will easily draw in enthusiasts. For existing Note 4 owners, however, the Note 5 feels more like a sidestep than an upgrade since it takes away almost as many features (MHL, IR blaster, removable battery, MicroSD) as it adds (Fingerprint reader, push-button S Pen, improved display, thinner design). Meanwhile, S6 owners would simply be moving onto a larger display with essentially identical internal hardware. A more appropriate name for this model would have been the "Galaxy Note S6" as it doesn't feel like a true leap forward compared to the excellent Note 4. For everyone else, the Galaxy Note 5 is worth a closer hands-on test. Its S Pen in particular will make or break the deal as some users may find it incredibly useful for their daily tasks, while others may find the pen to be too small to comfortably hold for extended periods. This reviewer falls in the latter camp, but the dazzling display and promising S Pen features shouldn't be overlooked, either. It's an impressive device so long as buyers are aware of what exactly the Note 5 is lacking compared to its predecessor. Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
iganiats Δημ. August 30, 2015 Δημ. August 30, 2015 Βγάλανε και το MHL? Αντε να παίρνει σειρά και το USB OTG Παράθεση
v@gelis Δημ. August 30, 2015 Δημ. August 30, 2015 (edited) Plastic back cover? Μάλλον δε τα λέει καλά... http://www.phonearena.com/news/The-first-Galaxy-Note5-drop-test-tells-the-tale-of-broken-glass-video_id72789 Edited August 30, 2015 by v@gelis Παράθεση
stellio40 Δημ. August 31, 2015 Δημ. August 31, 2015 http://www.ebay.com/itm/New-Samsung-Galaxy-Note-5-SM-N920I-Octa-5-7-16MP-FACTORY-UNLOCKED-32GB-Phone-/281771703891 Παράθεση Galaxy Note 2 , Galaxy tab s 10.5
Vzoun Δημ. August 31, 2015 Δημ. August 31, 2015 Δεν ειναι καθολου ασχημη τιμη 658 ευρω! Απλα δεν εχεις την εγγυηση :p Παράθεση
Shuffle Δημ. September 1, 2015 Δημ. September 1, 2015 http://www.ebay.com/itm/New-Samsung-Galaxy-Note-5-SM-N920I-Octa-5-7-16MP-FACTORY-UNLOCKED-32GB-Phone-/281771703891 Και από Αμέρικα και με fedex.. τελωνείο γκαραντί..:lol: Παράθεση Google Pixel 5
galanakop Δημ. September 6, 2015 Δημ. September 6, 2015 Αγορά από Τουρκία. Samsung store. Πρέπει να πας από εκεί βέβαια. Το τηλ είναι από άλλο πλανήτη. Παράθεση Note 20 plus Snap/Ιphone 13 Pro Max/Ipad Pro 12.9 /Samsung Tab s6
narcotic Δημ. September 6, 2015 Δημ. September 6, 2015 Πόσο το πήρες φιλαράκι; Παράθεση t18s - 3310 - 3310 - 8210 - t65 - 6510 - 7210 - n-gage - 7610 - 6290 - ks20 - tg01 - s2 & galaxy tab 10.1 - s3 - note 3 & note pro 12.2
Te_salat Δημ. September 6, 2015 Δημ. September 6, 2015 Αγορά από Τουρκία. Samsung store. Πρέπει να πας από εκεί βέβαια. Το τηλ είναι από άλλο πλανήτη. Νίκο πόσο το έχουν στην Τουρκία? Εδώ το βρίσκω 800 ευρώ. Παράθεση Φιλικά, Κώστας [/b] [ HTC U11, iPad mini 4, iPhone 6, Galaxy S7 Edge, Xiaomi A1, Nexus 5X ,
galanakop Δημ. September 6, 2015 Δημ. September 6, 2015 Κάπου εκεί. Από 760-800 Παράθεση Note 20 plus Snap/Ιphone 13 Pro Max/Ipad Pro 12.9 /Samsung Tab s6
anergos13 Δημ. September 6, 2015 Δημ. September 6, 2015 Εδω με την καθυστερηση που θα εχει και με τα cc να κρατουν ακομα ...θα παει μακρια η βαλιτσα για να κατεβει κατω απο το ψυχολογικο οριο των περισσοτερων ...(θεωρω το 599€) ----- προσθήκη μηνύματος 108 δευτ. μετά την υποβολή του προηγούμενου ----- Αγορά από Τουρκία. Samsung store. Πρέπει να πας από εκεί βέβαια. Το τηλ είναι από άλλο πλανήτη. Σε σχεση με το edge πως ειναι το στησιμο του? Παράθεση 🔷 Samsung S24 Ultra-Samsung tab 9 -Samsung Watch 7🔷
stelioz350 Δημ. September 7, 2015 Δημ. September 7, 2015 Αν βγει σε 64 μέχρι τα Χριστούγεννα γιατί με 32 δεν βγαίνει θα το τσιμπήσω από εξωτερικό. Παράθεση
galanakop Δημ. September 10, 2015 Δημ. September 10, 2015 Επίσης μια παρατήρηση. Κάπου γράφτηκε ότι αν βάλεις ανάποδα το πενακι θα έχεις πρόβλημα κτλ. Δεν ισχύει κάτι τέτοιο. Μπαίνει και από τις δύο πλευρές κανονικά. Παράθεση Note 20 plus Snap/Ιphone 13 Pro Max/Ipad Pro 12.9 /Samsung Tab s6
stelioz350 Δημ. September 10, 2015 Δημ. September 10, 2015 Βγαίνει αν μπει μέχρι μέσα ανάποδα; γιατί κάτι δείχνετε και στο fixit στο YouTube αλλά δεν το είδα Παράθεση
galanakop Δημ. September 10, 2015 Δημ. September 10, 2015 Βγαίνει αν μπει μέχρι μέσα ανάποδα; γιατί κάτι δείχνετε και στο fixit στο YouTube αλλά δεν το είδα Κανονικά... Παράθεση Note 20 plus Snap/Ιphone 13 Pro Max/Ipad Pro 12.9 /Samsung Tab s6
Te_salat Δημ. September 10, 2015 Δημ. September 10, 2015 Κανονικά... Δεν φοβηθηκες βρε θηρίο να το δοκιμάσεις? Παράθεση Φιλικά, Κώστας [/b] [ HTC U11, iPad mini 4, iPhone 6, Galaxy S7 Edge, Xiaomi A1, Nexus 5X ,
galanakop Δημ. September 10, 2015 Δημ. September 10, 2015 Δεν φοβηθηκες βρε θηρίο να το δοκιμάσεις? Τι να φοβηθω ρε φίλε. Το έβαλα σιγά σιγά στην αρχή και κουμπωνε μια χαρά. Μετά το δοκίμασα κανονικά και όλα μια χαρά. Άλλη μια αστοχη παρατήρηση από κατά τα άλλα αξιόπιστα review που λένε ότι γουστάρουν. Παράθεση Note 20 plus Snap/Ιphone 13 Pro Max/Ipad Pro 12.9 /Samsung Tab s6
Superuser Δημ. September 10, 2015 Δημ. September 10, 2015 Από τη στιγμή που έχουν αναφερθεί προβλήματα αν τοποθετηθεί ανάποδα το πενάκι και μπορεί να προκληθεί ζημιά στις συσκευές, δεν καταλαβαίνω γιατί προτρέπεις τους άλλους να κάνουν κάτι που ενδεχομένως να επιφέρει βλάβη στις συσκευές τους. Ας είμαστε λίγο πιο προσεκτικοί σε αυτά που προτείνουμε! Παράθεση [sIGPIC][/sIGPIC] Νίκος Πρώην Super Moderator του «παλιού» καλού myphone.
galanakop Δημ. September 10, 2015 Δημ. September 10, 2015 Από τη στιγμή που έχουν αναφερθεί προβλήματα αν τοποθετηθεί ανάποδα το πενάκι και μπορεί να προκληθεί ζημιά στις συσκευές, δεν καταλαβαίνω γιατί προτρέπεις τους άλλους να κάνουν κάτι που ενδεχομένως να επιφέρει βλάβη στις συσκευές τους. Ας είμαστε λίγο πιο προσεκτικοί σε αυτά που προτείνουμε! Με την ίδια ευκολία μπαίνει από την μία και ακριβώς ίδια και με την άλλη. Με την ίδια ευκολία βγαίνει από την μία και ακριβώς και από την άλλη. Αν δηλαδή κάποιος από βιασύνη το βάλει ανάποδα δεν έχει κανένα θέμα. Αυτό βλέπω αυτό λέω. Παράθεση Note 20 plus Snap/Ιphone 13 Pro Max/Ipad Pro 12.9 /Samsung Tab s6
