[Επίσημο] Nokia 7600
DON
Καλα..αλλά σε γκρι χρώμα και αν σκεφτείτε τις δυνατότητες που έχει δεν είναι και τοσο 'ασχημο!Full Specifications
Dual Mode Operation
WCDMA and GSM 900/1800 networks
Automatic switching between bands and modes
Size
Weight: 123 g (with Lithium Battery)
Dimensions: 87 mm x 78 mm x 18.6 mm, 103 cc
Display and User Interface
Bright active matrix TFT color display
65,536 colors
128x160 pixels
Graphical user interface
Built-in HF for speech, music, and polyphonic ringing tones
Three soft keys plus scroll key
Integrated Digital VGA Camera
Image/video resolution: 640x480/128x96
Self-time function (10 sec)
Video capture up to 15 frames per second
Phone display used as a viewfinder
29 MB dynamic memory for contacts, video clips, images, tones, messages, music files, add -on applications, calendar, and to-do notes.
Dedicated camera key for instant capturing of still images or videos
Digital Music Player
Digital Music Player for MP3 and AAC files
Music file download over-the-air or from a combatible PC via Nokia Audio Manager which is included in Nokia PC Suite
Listen with stereo headset or through internal loudspeaker
MP3 and AAC files as ringing tones
High-Speed Data
Up to 57.6 kilobits per second in circuit-switched data networks
Up to 384 kilobits per second (downlink) and 64 kilobits per second (uplink) in WCDMA packet transmission networks
Multitasking: Take and send pictures while you talk
Connectivity
Infrared
Bluetooth wireless technology
USB with Pop-Port™
Wireless phone connection to a compatible PC
Send/receive pictures, video clips, graphics
Messaging
Combine video/picture, text, and voice into multimedia messages
Embedded e-mail client
Concatenated text messages, picture messaging
Voice Features
Voice dialing
Voice recorder
Integrated handsfree speaker
Browsing
Advanced XHTML browser
WAP 2.0 over GPRS data in both GSM and WCDMA modes
Video Services
Video clip download up to 1.4MB
3GPP Streaming*
Applications
Pre-installed Java™ based games and applications
Downloadable Java™ applications, maximum download size 348kB per application
Software
PC Suite for Nokia 7600 phone in sales package
Nokia Audio Manager for music file transfer from a compatible PC is included in PC suite for Nokia 7600 phone
http://www.danasoft.com/sig/paris.jpg
  • Απαντήσεις 520
Bρε παιδιά, τι έχετε πάθει; Μάλλον το "μεγαλείο" του κινητού κάπου κάτι πείραξε....Δεν δικαιολογείται διαφορετικά η παράθεση των τεχνικών του χαρακτηριστικών, μιά σε κάθε σελίδα....Εκτός κι αν τα τεχνικά του χαρακτηριστικά είναι υπό διαμόρφωση ή δεν τα εμπεδώσατε ακόμα και θέλετε να σας τα ξαναγράψω...!!! :p
Wirelessly posted (Nokia 3650: Nokia3650/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Loipon ego auto de tha to kukloforousa.Tha to eixa spiti panta syndemeno me to pc.Diladi kai ego mono gia dunatotites.Alla den tha to agoraza giati exw sto mati to 6600.To mono parapanw autou tou kinitou einai to cdma kai to mp3/aac.Omws den einai symbian kai auto gia emena einai to vasikotero meionektima.
Αρχικό Μήνυμα από τον apostolidisathan
Ρε παιδιά , ξέρει κανένας αν έχει αναγνώριση κλήσης και αν στέλνει SMS των 160 χαρακτήρων;
Γιατί, ξέρεις κάποιο κινητό (Nokia τουλάχιστον) που ΔΕΝ κάνει τα παραπάνω;;;; :blink:
http://briefcase.pathfinder.gr/download/petros_pf/15778/181976/0/Petran.gif
Nokia Series 60 forum moderator (Ret.)
Γιατι ρε παιδια πλακα εχει... :p :p Εαν δεν ηταν το 6600 στη μεση μπορει και να το χτυπαγα..μου θυμιζει τις ταινιες sci-fi που εβλεπα μικρος...you know beem me up scottie!!! :alien: :alien:
D.T
Πολύ καλές δυνατότητες, κάπου διάβασα οτι τραβάει βίντεο ως 2,5 λεπτά. Αν όντως ισχύει αυτό είναι άψογο. Πολύ καλή η εσωτερική του μνήμη (29ΜΒ) άλλα δεν αναφέρεται πουθενά τίποτα για κάρτα μνήμης, οπότε μάλλον δεν έχει.
Tria pramata borw na pw
1) ...
2) Asteio htan auto?
3) Pali ******* eipes!
kai ena extra: Mhpws pairnei thlefwno? Xerei kaneis an exei auti th dynatothta?
Αγγελίες στο buy & sell μόνο!
Αρχικό Μήνυμα από τον oresti$
1) ...
Για το 2) και 3) δεν ξέρω! Πάντως με το 1) συμφωνώ!
einai trelo to tilefono!!!!!!!!!!!!
to thema einai oti den leitourgei se gsm800 diladi se vodafone telestet,simfona me to arthro,i einai lathos???i mipos na perimenoume to 3g stin ellada?xa kalo!
goodbye my Lord!
Αρχικό Μήνυμα από τον jioda
Κάπου τα έχεις μπερδέψει....Δεν υπάρχει GSM 800 αλλά μόνο GSM 900.To τηλέφωνο καλύπτει όλες τις προδιαγραφές, αφου :
Band-width: WCDMA and GSM 900/1800
To τηλέφωνο θα δουλεύει κανονικά σε όλα τα δίκτυα! :)
Εγω το κινητακι το βλεπω γαματο απο ολες τις πλευρες και θα το γουσταρα παρα πολυ γιατι εχει extreme design και διαφερει απο τα αλλα που ακολουθουν ενα μονοτονο σχημα και σχεδον ιδιο design. Πρωσοπικα μου αρεσε πως οταν μιλας θα το γυρνας σε σχημα ρομβου... :)
Re mages, me auto to prama pws tha grafeis sms??? To ena koubi edw to allo ekei... ti ginete???
Όπως θα γράφεις και με το SX1! :happy: Και όπως λένε οι υπεύθυνοι της siemens με αυτό το πληκτρολόγιο θα γράφεις ταχύτερα!
Κι εμένα μου άρεσε πολύ και μάλιστα με έβαλε σε μεγάλο δίλημμα. Μέχρι τώρα περίμενα πως και πως το SX-1 αλλά τώρα άρχισα να το ξανασκέφτομαι, αν και λάτρης των Siemens (S-25 και S-55). Με ενδιαφέρουν κυρίως οι φωτογραφίες. Για να δούμε τι θα δούμε στο θέμα αυτό (το ST-55 πάντως είναι για ...μπλιαχ σε ότι αφορά τις 640Χ480)
Λοιπόν τώρα οι Νοκιαδες δεν θα μπορούν να λένε ότι τα πλήκτρα του ΣΧ1 δεν είναι βολικά γιατί από τώρα η Νόκαι άρχισε να αντιγράφδει την Σιμενς και βγάζει το ίδιο στυλ κουμπιά.Για το κινητό ένα έχω να πω:
Από την παντόφλα(7650) στην μπανιέρα(3650)και τώρα στο σαπούνι(7600).Σύντομα αναμένεται το 5600 με Symbian series 60 με κάμερα στο μπροστινό μέρος(αληθινό 3G επιτέλους)και σε σχήμα σφογγαριού!Όλη η σειρά του μπάνιου από τα καταστήματα "Γερμανός" αποκλειστικά!!!!
Αρχικό Μήνυμα από τον earinos
Αν θέλεις καλές φωτογραφίες γιατί δεν παίρνεις το GX20? έχει άλλωστε την καλύτερη φωτογραφική σε κινητό....
Τι λέτε? Θα το βγάλει πριν το SX1?
Αρχικό Μήνυμα από τον UnReaL
GX20? Είμαι και ψιλοάσχετος :whistle: για γράψε κάτι περισσότερο :o
