Ολα για PS2 και XBOX Mod-Chips - Chips
Jim22378
υπάρχουν πολλών ειδών chips για ps2 και x-box . Να μερικά :
http://www.modchip.com/images/dms4lite_mini.jpg
The legendary DMS line of Modchips enters the Fourth generation with many more added features, improved ease of installation, software support and much much more.......
DMS4 opens a whole new era in the evolution of Modchips. It is available in two flash memory sizes with a differentiation of features. The DMS4 Lite offers great features, with undeniable value for money. The Pro version caters for those who require advanced features and a greater flash memory size.
- Compatible with all PS2 versions (V1-V11)!
http://www.modchip.com/images/dms3plussmall.jpg
The DMS3 PLUS Modchip is a vastly improved version of the revolutionary and innovative DMS3 modchip series. Improvments include reduced wire count and improved upgrade function. DMS 3 PLUS (Devolution Memory System 3) is the most complete and advanced PS2 Modchip. It really has all the features all other modchips have all together, but it is also a top quality chip, with bullet proof stability and reliability.
Extra features: DVD region free, Flash upgrade feature.
http://www.modchip.com/images/slidecard3small.jpg
With the Slide-Card you no longer have to install a Modchip to be able to play your PS2 backups or original import games. You do not even have to open the console, therefore your warranty stays intact. Normally when installing a backup or import solution, you have to open your console, and "split" the warranty sticker on the back. Thats all history now....
- No soldering required!
:!: περισσότερες πληροφορίες εδώ http://www.modchip.com :!:
only crossfit...
  • Απαντήσεις 116
Αυτό το thread ειναι οτι επρεπε γιατι λεω μετά απο 3 χρόνια να το chipαρω επιτέλους. Λοιπον ειδα από το http://www.modchip.gr ότι κάποια chips είναι συμβατά με ps2 version 3,4,κλπ και πάει λέγοντας.
1) Πως βλέπω version?
2) Ποιο προτείνετε μέχρι άντε το πολύ 50 ευρώ.
Αναμένω συμβουλή, Ευχαριστω.
Χριστόφορος :music:
1)την version νομιζω την λεει στο κατω μερος του ps2 , ή στο κουτι του ;)
2)σου προτεινω αυτο: DMS3 v9
DMS3 v9. Chip για Playstation2.
Τρέχει όλα τα buckup Ps2/Psx χωρίς boot cd. Συμβατό με όλα τα games και εφαρμογές για Ps2.
- Υποστηρίζει DVD9 format.
- Απενεργοποιεί το macrovision.
- Τρέχει όλες τις ζώνες DVD.
- Διορθώνει το πράσινο χρώμα στην tv.
- Δυνατότητα boot εφαρμογών από τη memory card ή το σκληρό δίσκο(Div-x, Mp3, Logo etc).
- Αναβάθμιση με software cd.
- Απενεργοποιείται για online games.
- Διακρίνεται για την αξιοπιστία και την σταθερότητα λειτουργίας του.
- Συμβατό με τις version 50004 v9-v10 .
http://www.modchip.gr/catalog/images/dmsv9_100_100.gif
ελπιζω να βοηθησα :)
only crossfit...
Αρχικό Μήνυμα από το μέλος teorizo (18 Νοέ. 2004 , 18:19)
Με βοήθησες αλλα ειδα το κουτι και λεει model number SCPH-3004-R (Απο οτι θυμαμαι το ειχα παρει αρχες 2002). Δεν λεει πουθενα version number...Στην τελικη δεν ειναι μεγαλο προβλημα αφου αμα το παω σε ενα μαγαζι θα ξερουν αυτοι ποιο κανει και ποιο δεν κανει, απλα ηθελα πριν το παω να δω στο internet τι υπαρχει διαθεσιμο και να κανω μια συγκριση μη βαλω καμμια πατατα= chip :) . Ευχαριστω για την βοηθεια.
Χριστόφορος :music:
to 8ema einai re paidia...na paroume to chip fthna alla na min mas zitisoun k alla tosa gia na to egkatastisoun!
giati zhtane apo 100e k panw gia na sou valoun ena chipaki
eno sto site tis modchip.gr ta dinoun 40 k 50 e alla poios ka8etai na ta ftia3ei me kollhthria k istories?
k poios 8a parei tin eu8ini na ta kollisei xoris na ginei kamia stravi?
μεγαλη προσφορα!!
PS2 NEO 2.2 MODCHIP
Compatible with V1-V6 PS2 main boards Plays all PS2 Backups and also PS1 Backups Not compatible with SCPH-39001/2/3/4 (V7) AR2 disk is required to play PS2 backups Disclaimer: Sony and Playstation© are trademarks of Sony Computer Entertainment Inc. This website is not affiliated with Sony Computer Entertainment Inc. All Trade Marks Acknowledged
http://grteamelectronics.gr/modules/catalog/images/ps2/ps1_2mod.gif
απο 10,00 €!!!! :cool:
here!!! ;)
only crossfit...
Επειδή είναι chip και μπαίνει σε πλακέτα αγαπημένη παιχνιδομηχανής η ταπεινή μου γνώμη είναι να αφήσετε τον άνθρωπο που το πουλάει να σας τοτοποθετήσει διότι είναι πολύ λεπτοδουλειά εκτός και αν φυσικά έχετε σπουδάσει ηλεκτρονικός γνωρίζετε καλά από ψιλές κολλήσεις οπότε και πάρω πάσο!!η τιμή με τοποθέτηση είναι 80€ αν θυμάμαι καλά για το messiah 3.8 και απαιτείται μία εργάσιμη από τον κύριο.
http://www.imageshack.gr/files/61ds253tht5lqjmqm8sd.jpg
"Οι έρωτές μου είναι γεμάτοι από σταυρούς..."
Αρχικό Μήνυμα από το μέλος RadiactiveToy (18 Νοέ. 2004 , 21:56)
Αν θυμάμε καλά αυτή ήταν η πρώτη version του ps2 και είχε αρκετά προβλήματα με την κεφαλή όταν του έβαζες τσιπάκι.
Σε εμένα που είχα αυτή την version μετά απο κανα 7μηνο με χρόνο δεν μπορούσε να διαβάσει σχεδόν κανένα cd-dvd και αναγκάστηκα να το αλλάξω...
Φιλικά Δημήτρης
