Alexkass Δημ. August 6, 2003 Author Δημ. August 6, 2003 ένα μικρό review για το 2215 από τον Jim Lynch http://common.ziffdavisinternet.com/util_get_image/2/0,3363,sz=1&i=26641,00.gif ...The Verdict on the HP iPAQ 2215 Frankly, I love this little sucker. It's got a few warts but overall it's working out great and it will be my daily use PDA. I don't regret buying it at all. It's comfortable to hold, works well wirelessly and comes with enough applications to be useful right out of the box. I still wish there was more games bundled with it but I can always buy more as I go. After using the 2215 for a couple of days, I wasn't missing my old 3835 at all. In retrospect, I'm sure glad I didn't go with a Palm or even a Linux based PDA. Don't get me wrong, there's nothing wrong with owning a Palm or Linux PDA. But why settle for less when you can have something as great as the 2215? In some ways I feel like I dodged a PDA bullet. Whew! πηγή: http://www.extremetech.com/article2/0,3973,1208618,00.asp Παράθεση Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Alexkass Δημ. August 6, 2003 Author Δημ. August 6, 2003 Αρχικό Μήνυμα από τον Exposed_Bone Φαίνεται να έχει καλή οθόνη λογικά σαν αυτή του δικού σου (1915) αλλά έχω ακουσει σχόλια ότι είναι χειρότερη από αυτή του 5450 :D Παράθεση Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Alexkass Δημ. August 21, 2003 Author Δημ. August 21, 2003 Παρουσίαση: HP iPAQ h5550/h5555 By: Jørgen Sundgot @ http://www.infosyncworld.com When Compaq first introduced its iPAQ series, the company aimed squarely for the high-end market with a device which has often been attributed to driving the growth of the entire platform. Following its merger with Hewlett-Packard, the iPAQ brand has survived, as has the original thought behind the iPAQ: delivering a powerful and versatile tool. The iPAQ h5550 is so far the ultimate result of an evolution that has progressed for three years, and boy does it pack a punch... http://www.infosync.no/news/2003/08/20/gfx/hp_ipaq_h5550_01.jpg HP's new iPAQ h5550 is a veritable powerhouse ...Offering a large display, powerful processor and a large amount of on-board memory, the iPAQ h5550 certainly stands out in a crowd by its specifications alone. Add biometric identification and a multitude of connectivity options and this high-end device should satisfy the needs of every potential handheld owner - but there are also drawbacks, such as poor battery life and its massive size. For those who can live with the latter two, the iPAQ h5550 comes highly recommended, despite a hefty price tag. What's positive: Screen size; excellent connectivity options; powerful What's negative: Size; weight; poor battery life; pricey λινκ: http://www.infosyncworld.com/reviews/n/3967.html Παράθεση Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Starback Δημ. August 21, 2003 Δημ. August 21, 2003 Καλησπερα σε ολους! Κατοπιν προτροπης σας και αφου εδω και δυο μερες ειμαι ο πανευτυχης κατοχος ενος Ipaq 2210 λεω να μοιραστω μερικες εντυπωσεις μου. Καταρχην ειναι παναλαφρο και πολυ μικρο, ανετα μπαινει σε τσεπη πουκαμισου και δεν σε βαραινει και πολυ. Απο αυτονομια τωρα, το manual συνιστα 4ωρη φορτιση, με λιγο φορτιο που ειχε η μπαταρια out of the box (35%) μετα απο 2 ωρες ειχε φορτισει, το δουλευω, περιστασιακα βεβαια, τιποτα heavy, εδω κι δυο μερες και ειναι ακομα στο 50%!! Οταν το εβγαλα απο τον φορτιστη εδειχνε 8,5 ωρες remaining! Απιθανη οθονη, ζωντανα χρωματα, τελεια και ακριβης αποκριση του stylus, πολυ καλες αντιθεσεις και μεσα αλλα και εξω στον ηλιο!Πλουσιο software, ειδικα αυτο το nevo ειναι απιθανο!Πολυ γρηγορο, σε σχεση με το Loox που δουλευα και χωρις bugs, τουλαχιστον ακομα δεν ανακαλυψα κανενα, πλην ενος κολληματος που τρωει οταν εχω ενεργο το Journal Bar και το Battery Pack 2003 μαζι. Οταν κανεις reset οντως κανει παραπανω χρονο να ξεκινησει και τρωει απο την μπαταρια. Αν θελετε να μαθετε κατι αλλο στη διαθεση σας!! Παράθεση Samsung Galaxy Note 9
azeppos Δημ. August 21, 2003 Δημ. August 21, 2003 Καπου ειχα διαβασει οτι η βαση φορτισης εχει και εξτρα θεση για φορτιση δευτερης μπαταριας. Ισχυει κατι τετοιο? ;) Παράθεση http://www.strikebc.gr/memoriam.html
Alexkass Δημ. August 21, 2003 Author Δημ. August 21, 2003 Αρχικό Μήνυμα από τον Starback Καλησπερα σε ολους! Κατοπιν προτροπης σας και αφου εδω και δυο μερες ειμαι ο πανευτυχης κατοχος ενος Ipaq 2210 λεω να μοιραστω μερικες εντυπωσεις μου. Καταρχην ειναι παναλαφρο και πολυ μικρο, ανετα μπαινει σε τσεπη πουκαμισου και δεν σε βαραινει και πολυ. Απο αυτονομια τωρα, το manual συνιστα 4ωρη φορτιση, με λιγο φορτιο που ειχε η μπαταρια out of the box (35%) μετα απο 2 ωρες ειχε φορτισει, το δουλευω, περιστασιακα βεβαια, τιποτα heavy, εδω κι δυο μερες και ειναι ακομα στο 50%!! Οταν το εβγαλα απο τον φορτιστη εδειχνε 8,5 ωρες remaining! Απιθανη οθονη, ζωντανα χρωματα, τελεια και ακριβης αποκριση του stylus, πολυ καλες αντιθεσεις και μεσα αλλα και εξω στον ηλιο!Πλουσιο software, ειδικα αυτο το nevo ειναι απιθανο!Πολυ γρηγορο, σε σχεση με το Loox που δουλευα και χωρις bugs, τουλαχιστον ακομα δεν ανακαλυψα κανενα, πλην ενος κολληματος που τρωει οταν εχω ενεργο το Journal Bar και το Battery Pack 2003 μαζι. Οταν κανεις reset οντως κανει παραπανω χρονο να ξεκινησει και τρωει απο την μπαταρια. Αν θελετε να μαθετε κατι αλλο στη διαθεση σας!! λογικά θα είδες και το πολύ καλό clear type, αλλά και το κορυφαίο bt που επιτέλους είναι και audio. από cf κάρτες του έχεις βάλεις τίποτα??? :o Παράθεση Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Starback Δημ. August 21, 2003 Δημ. August 21, 2003 Λοιπον...η βαση φορτισης οντως εχει μια πολυ διακριτικη και πρακτικη υποδοχη για φορτιση 2ης μπαταριας. Η ευκρινεια του και το Clear Type επισης πολυ καλο, το bluetooth αψογο, audio profile δεν δοκιμασα αλλα με τον wizard καταφερα να κανω sync με το desktop μου μεσα σε 5 λεπτα, ενω με το Loox μου πηρε 1 μερα να το πετυχω!(Ισως βεβαια να εχω γινει πολυ πιο εξυπνος απο τοτε-δηλαδη μια βδομαδα πριν! :p ) Απο CF δοκιμασα την Sandisk CF WLAN Card, κορυφαια καρτα και με PCMCIA adapter και τωρα κανω sync και wireless!! Τελος εβαλα και μια MMC 128MB και εχω την εντυπωση οτι και η διαμεταγωγη εχει βελτιωθει πολυ αλλα δεν εχω νουμερα ακομα. Αυτα προς το παρον... Ετοιμος για νεες ερωτησεις! Παράθεση Samsung Galaxy Note 9
Alexkass Δημ. August 21, 2003 Author Δημ. August 21, 2003 κλασικό δείγμα του κορυφαίου τεχνολογικού πσκέτου: iPAQ 2210 & windows mobile 2003 ;) συγχαριτήρια φίλε Starback :) Παράθεση Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Alexkass Δημ. August 24, 2003 Author Δημ. August 24, 2003 για δείτε εδώ, τιμές καλύτερες από το expansys.com κατά πολύ και πολλές είναι σαν αυτές στην αμερική. 1910: 349 ευρώ ($299) 5450: 614 ευρώ ($649) 5550: 698 ευρώ ($649) λινκ: http://www.cylife.de/shop/cPath/44_40?osCsid=3113a9ae903d3017122a10eacadf4eb0 έχουν βέβαια γερμανικό λειτουργικό αλλά δεν ξέρω αν αλλάζει. :worry: Παράθεση Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Alexkass Δημ. August 25, 2003 Author Δημ. August 25, 2003 δεν ξέρω αν γίνεται, στο loox 600 πάντως δεν γινόταν :( frontier μπορείς να μας διαφωτίσεις;;; :) Παράθεση Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
akatsim Δημ. August 26, 2003 Δημ. August 26, 2003 Kυκλοφορησαν και τα 2210, 5550 στην Ελλαδα !!! Σημερα που ηρθε τιμοκαταλογος και διαθεσιμοτητα. Παράθεση
geokaza Δημ. August 26, 2003 Δημ. August 26, 2003 Αρχικό Μήνυμα από τον akatsim Kυκλοφορησαν και τα 2210, 5550 στην Ελλαδα !!! Σημερα που ηρθε τιμοκαταλογος και διαθεσιμοτητα. Τιμες με ΦΠΑ;; Σε ποιο καταστημα;; Παράθεση http://www.gkazazis.com
akatsim Δημ. August 26, 2003 Δημ. August 26, 2003 Αρχικό Μήνυμα από τον geokaza Τιμες με ΦΠΑ;; Σε ποιο καταστημα;; Kαταστηματα δεν ξερω. Ξερω χονδρικη απο Πουλιαδη και quest σαν συνεργατης οτι παιρνω 470+ΦΠΑ για το 2210, και αν θυμαμαι καλα 640+ΦΠΑ για το 5550. Παράθεση
Alexkass Δημ. August 26, 2003 Author Δημ. August 26, 2003 Αρχικό Μήνυμα από τον akatsim Kαταστηματα δεν ξερω. Ξερω χονδρικη απο Πουλιαδη και quest σαν συνεργατης οτι παιρνω 470+ΦΠΑ για το 2210, και αν θυμαμαι καλα 640+ΦΠΑ για το 5550. λοιπόν αποστόλη, αν είναι θα σου πω να πάρω ένα 2210 και ένα 5550 για να τα δοκιμάσω :) Παράθεση Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Exposed_Bone Δημ. August 26, 2003 Δημ. August 26, 2003 Και μετά την δόκιμη θα μου το δόσεις σε εμένα Παράθεση
Alexkass Δημ. August 26, 2003 Author Δημ. August 26, 2003 Αρχικό Μήνυμα από τον Exposed_Bone Και μετά την δόκιμη θα μου το δόσεις σε εμένα αλητάκο :D HP h1935 iPAQ To Sell For $199 After $50 Rebate HP is ready to release the h1935 iPAQ. Externally, it is identical to the h1940 that has been for sale since June. Just like its $299 brother, it has an SDIO slot, Windows Mobile 2003 for Pocket PC and the new Samsung processor. The processor is running at 203MHz though rather than 266MHz as it does in the 1940 series. The 1935 also lacks bluetooth and has a smaller FlashROM. The 1940 has a 14MB ROM file store whereas the 1935 doesn't have one. Both have 56MB of usable RAM. The other difference is the 1940 has a 1 year warranty and the 1930 has a 90 day warranty. I personally never recommend buying an extended warranty, but in the case of an electronic device costing $200 that only comes with a 90 day warranty, I might reconsider that opinion. http://www.pocketpcthoughts.com/images/hansberry/ipaqh1900.gif So, how does the 1930 and 1940 series compare to the X-Scale based 1910 that came out late last year? "That continues a trend by HP to go with Samsung's chip in its low-priced models. In addition to its lower cost, HP executives have said the Samsung processor outperforms Intel's XScale on a megahertz-to-megahertz basis. HP still uses XScale chips in its higher-end models. Dayan said the h1945 with the 266MHz Samsung chip offers up to 87 percent higher performance than the h1910. "It (has) higher performance even with the 203MHz (Samsung) chip," he said, although some of the performance gain also is attributable to the operating system. λινκ: http://news.com.com/2100-1041_3-5067859.html?tag=fd_top Παράθεση Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
DON Δημ. August 29, 2003 Δημ. August 29, 2003 Εκτός από τα e-shops πόυ έχουν αναφερθεί, μπορώ να βρώ το iPAQ h2210 σε κάποιο κατάστημα ( με φυσική υπόσταση!! ) εδώ στήν Αθήνα? Ξέρει κανείς κάτι? :cool: Παράθεση
geokaza Δημ. August 29, 2003 Δημ. August 29, 2003 Αρχικό Μήνυμα από τον DON Εκτός από τα e-shops πόυ έχουν αναφερθεί, μπορώ να βρώ το iPAQ h2210 σε κάποιο κατάστημα ( με φυσική υπόσταση!! ) εδώ στήν Αθήνα? Ξέρει κανείς κάτι? :cool: Ναι βρε παιδια, σημαντικοτατη ερωτηση η πιο πανω. Οπως επισης ΟΧΙ ΜΟΝΟ το 2210, 2215 αλλα και αλλα iPaq, οπως το 1935, 1940 κλπ ΠΟΥ μπορουμε να τα βρουμε στην Αθηνα;;; Παράθεση http://www.gkazazis.com
Exposed_Bone Δημ. August 29, 2003 Δημ. August 29, 2003 Γιατί να μην το πάρετε από κάποιο e-shop ? Το έχει πιο φτηνό Παράθεση
Alexkass Δημ. December 1, 2003 Author Δημ. December 1, 2003 νέα παρουσίαση του 5550 ... έξω από τα δόντια... Bottom line.... Vibrating alarm, the biometric fingerprint reader, the extra 64mb RAM, and the slightly larger display = $200. Are these items worth $200 to you? ... :o Παράθεση Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Stigmabuster Δημ. December 3, 2003 Δημ. December 3, 2003 the answer is NO Παράθεση http://stigmabuster.blogspot.com
21century Δημ. December 3, 2003 Δημ. December 3, 2003 Apo oti eida to 2210 to exei kai to Plaisio pou me de endiaferei gia na to dokimaso, telika to ppc 2003 Aleksi einai ontos kalutero apo to 2003 kai pio sta8ero? To leo giati ta soft reset sto packard bell me exoun mourlanei, ase pou ta eftuse h mpataria tous.. Παράθεση
gkp Δημ. December 3, 2003 Δημ. December 3, 2003 Αρχικό Μήνυμα από τον Alexkass νέα παρουσίαση του 5550 ... έξω από τα δόντια... Bottom line.... Vibrating alarm, the biometric fingerprint reader, the extra 64mb RAM, and the slightly larger display = $200. Are these items worth $200 to you? ... :o Ksexasan na anaferoun oti iparxei kai to WiFi... Epomenos me tis parapano diafores + oti exei kai to WiFi i apantisi gia mena einai NAI. Kai kati akoma. Polloi nomizoun oti ta 64 MB pou exei perissoteri mnimi den exei diafora se sxesi me ta mixanimata pou diathetoun sinolika 64 MB. Ego pou ta exo dokimasei kata koron ta PPC mporo na po oti anoigeis OSA PARATHIRA THELEIS xoris to mixanima na sernetai. Einai to korifaio ppc pou iparxei auti ti stigmi sto emporio kai as iparxoun arketoi epikrites. Eksallou gnorizoume oti osa den ftanei i alepou ta kanei kremastaria. Παράθεση Ο καλύτερος μου φίλος FLEX (9/4/2000 - 19/06/2010). Θα σε θυμόμαστε για πάντα
