[Επίσημο] Motorola A1000
dpapa
  • Απαντήσεις 332
na kano mia erothsh!! to a1000 exei ellhniko menou? episis gia na trexeis route66 h tomtom theleis exoterikh keraia bluetooth h trexei me to gps tou kinitou?
to menu einai se agglika kai se 6 alles glwsses ektos apo ellhnika to mono poy mporeis na kaneis einai na valeis to programma input me ellhniko t9 leksiko gia na grafeis kai na diavazeis ta sms mms pdf kai office sta ellhnika oso gia to route66 kai tom tom xreiazesai ekswterikh karta mnhmhs ka8ws epishs kai ekswterikh keraia bluetooth gia na exeis 16 doryforous kai na exeis full aksiopoihsh twn programmatwn an se endiaferei mono to stigma mesw doryforou mporeis na xrhsimopoihseis thn eswterikh keraia me allo programma.....
Samsung Galaxy S I-9000 CM10 RuLeZ ;)
tha thela na rothso epidi douleuo me laptop mporo na flasaroto motorola etsi kai oxi se kanoniko pc?Giati sto mpx200 den mporesa na to anabathmiso se win2003 otan eixa prospathhsei na to kano pali me to laptop thanks
Από 1/9/2009 απαγορεύεται η γραφή σε greeklish και η γραφή τύπου sms.
egw laptop xrhsimopoiw gia to flash kai ola ta update
(centrino 760 me 1gb kai 100gb hd kai ati 256mb)
an apofasiseis na kaneis to flasharisma 8elei poly prosoxh giati an kaneis la8os............
an 8es soy stelnw odhgies
an mporeis kavatzoulas steile kai thanks
loipon soy kanw copy paste ton odhgo sta agglika an exeis allh aporeia p.m me PROSOXH KANEIS AKRIVWS OTI LEEI!!!
First of all you will need todecide which Firmware version you want to use.
Please check here for Information & a comparison of all the Firwares available.
Please note that The firmwares 51.14.15 , 51.82.00 , 51.92.08 & 51.95.00 All use the Original Motorola Bootloader
All other versions use the newer Bootloader Version (please check the forums for details)
NB o*nce the Bootloader is over written it is not possible to go back using the below method
Using any non-generic Firmware will almost certainly simlock your phone to a provider even
if it had already been unlocked.
All generic versions at the time of writing will not lock the phone, But also will not unlock a locked Phone either.
This guide was based o*n the 51.92.08 Firmware but the procedure is exactly the same for any firmware upgrade.
Before you read deity's guide please remember Read this Guide a few times so that you
understand what to do.
And remember
Flash Twice and Master Reset/Clear
Headset information after flashing with new firmware:
Machine: Reference platform
RAM: 32MB
Version: REL_51.92.08
Baseband: A1000_U_2A.43.0AP-s39
Flex: UIA1000IOTR342_002
AP Config: A1000_Generic_APCONFIG_014
A list of improvements of this new firmware is available at:
http://machman.gotdns.com/index.php?name=PNphpBB2&file=viewtopic&t=1455
and
http://machman.gotdns.com/index.php?name=PNphpBB2&file=viewtopic&t=1468
Before flashing the phone here are the cautions:
a) *** Flashing your A1000 with a new firmware will NOT UNLOCK your phone if it has been locked to a network, however, flashing it with some firmware might LOCK your phone to a certain network (not necessarily the original network). The 51.92.08 (generic) firmware available o*n this site will NOT LOCK your phone to any network if it has already been unlocked, but also will NOT UNLOCK your phone, it would simply remain locked to the same network. ***
b) *** Everything stored o*n the internal memory would be lost after a firmware flash, it might NOT be possible and normally NOT RECOMMENDED to perform a restore from backups (by Desktop Suite) of the phones with other firmware version. *** You might consider doing backup using some 3rd party software, or synchronise your contact book with Outlook/ outlook express in advance. Regarding your existing SMS, please refer to this thread by TzeenieWheenie: http://machman.gotdns.com/index.php?name=PNphpBB2&file=viewtopic&t=946&highlight=
If you have software installed o*n the internal drive, make sure you backup/copy all the data files and license files
c) If the reason that you want to reflash your phone is because you have were running low o*n internal storage memory (Free Space o*n C: Drive) that is causing your problems (very very slow respond time and lengthly boot up time <- reports/experiences suggest that it could take over 15 minutes to finish a boot up but it should eventually managed to boot up), there is another solution available, see the Tips Section: http://machman.gotdns.com/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=22&page=1
d) you might also want to write down the Internet/SMS/GPRS/WAP/E-mail/Voicemail/Video Gateway setting of your current network before doing the flashing, because you would need to enter them to the flashed phone.
Requirements:
i) MS Windows XP Service Pack 2 (SP2) or XP hot fix file Q814560,Q816843,Q810400 & Q822603
ii) Motorola USB Data Cable and with the Main Charger plugged into the USB cable
iii) Program- RSD lite 1.9.1 (4.2MB) Available here:
http://machman.gotdns.com/modules.php?name=UpDownload1&req=viewdownloaddetails&lid=283&ttitle=RSD_Lite_1.9.1
iv) Firmware for the A1000 (28.7MB) Located here
http://machman.gotdns.com/modules.php?name=UpDownload1&req=viewdownloaddetails&lid=290&ttitle=A1000_51.92.08_Generic_Firmware_Part_1
and
http://machman.gotdns.com/modules.php?name=UpDownload1&req=viewdownloaddetails&lid=291&ttitle=A1000_51.92.08_Generic_Firmware_Part_2
v) The P2K driver may be needed:
http://machman.gotdns.com/modules.php?name=UpDownload1&req=viewdownloaddetails&lid=304&ttitle=P2k_Driver_Files
Procedure:
1) Make sure you have SP2 or the hotfixes installed
2) Unrar/unzip the files to somewhere handy (eg desktop) Go to http://www.rarlab.com/ for software to unrar/unzip (decompress) the files you downloaded form this site (for those who are not familar with using the .rar format, you need to download both Part 1 and Part 2 of the Generic firmware, but you o*nly need to open Part 1 using winrar, and it would automatically search for Part 2, etc. if you put the files in the same directory)
3) Go to the directory where you have decompress the P2K.zip, right click o*n the P2K.INF file and select "Install"
4) Install RSD lite. But don't start the program yet.
5) If running XP, open up task manager (Ctrl-Alt-Del) and shut down (go to Processes view, right click o*n the process and then choose End Process Tree) the 3 programs running with the Motorola Desktop suite. (the two MRouter files: mrouterruntime.exe and mrouterconfig.exe and MDS.EXE <- my Desktop Suite ver 1.1.0.1018 uses the file name: desktopsuite.exe instead and as I recall I didn't end the desktopsuite.exe task when I was doing my flashing. Without mrouter running, desktopsuite should not be able to interfere with your phone)
5) Switch off your A1000, remove the battery, hold down the two game buttons (on top) and plug in USB cable with charger attached. Phone will enter the firmware upgrade screen.
6) Start RSDlite, allow windows to install all necessary drivers, just allow Windows XP to automatically to search for the drivers (if XP could not find the drivers, you might try to point it to search the directory where you unzipped the P2K drivers and also the RSD lite directory, but this should not be necessary)
7) In the RSDlite screen, your A1000 will show as A920 or unknown. The phone screen will read connected. Click the box with the 3 dots next to the start button. Locate the downloaded firmware file. Now click start. It takes a while, your phone screen will finally indicate something other that Motorola 3G, halfway through you might even see more drivers being installed, again if asked, just tell XP to automatically search for the drivers.
8 ) User experience varies at this point, some users (including myself) will see a successfully flashing as reported by RSDLite and the phone (phone should restart itself). Others report that o*nce it reaches 100% the process will say failed, and feedback from users who have experience in flashing their A100 with older firmware claim that the flash is actually a success regardless of RSDLite saying otherwise. However, they also recommend to repeat the above flashing procedure a second time even it reports a successful flash (this may be old bug/feature from previous firmware/RSD lite which is no longer necessary, I personally o*nly have flashed o*nly o*nce) To reflash again: close RSD Lite, switch off phone (1/0 switch o*n the right side of the phone), unplug phone from USB cable and start from 5)
9) Do all the initial settings (language, time etc.)
10) RSD lite will show: status finished; result PASS
11) Now you may close RSD lite and unplug USB cable
12) Reboot/restart your phone and you might be presented with more initial settings (like the screen calibration)
13) Now you will need to enter your network setting to the "new" phone. Take a look at the Tips and Guide section o*n this website and if you are with 3 UK, then the following URL:
http://machman.gotdns.com/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=1&page=1
14) and reinstallation of all of your favourite softwares
euxaristo gia ton odhgo makari na tan kai sta ellhnika:rolleyes: anyway prepei to thlefono na to flasaro 2 fores gia na doulepesi kala?
θα προσπαθησω μεχρι το σαββατοκυριακο να στο μεταφρασω γιατι δινω μα8ημα στη σχολη
συνηθως το πρωτο flash σου δινει μηνυμα λαθους λογω drivers με το δευτερο ειναι οκ.απλα ακολουθεις πιστα τις οδηγιες
αν δεν βιαζεσε θα γραψω τον οδηγο στα ελληνικα
με το τελευταιο firmware update αν διαωασεις τα προηγουμενα topic θα δεις τι διορθωνται..
νεα εκδοση λειτουργικου συστηματος για το α1000
εκδοση 54.08 διαδοχος του 54.07.11 σε χρονους πεσαμε στα 30 δευτερολεπτα εκκινησης και αλλες εκπληξεις που θα ανακοινωσω συντομα μολις τελειωσω το τεστ
γεια σε ολους.επειδη ενδιαφερομαι για αγορα κινητου και το συγκεκριμενο το α1000 ειναι σκετη τρελα που θα μπορουσα να το παραγγειλω?κυκλωφορει ακομα στην αγορα?σε οσα μαγαζια εψαξα ελληνικα δεν το βρηκα πουθενα.και απο τιμη ποσο παει το μαλλι?
File moy an se endiaferei kati kalo se elafros metaxeirismeno koita edo
Stin ellada den kikloforise pote.Kai pleon den tha to vreis efkola kai apo to eksoteriko...opote an se endiaferei...koita to link pou sou edosa kai to kouvediazoume!
loipon to a1000 pwleitai kanonika sthn italia sthn ekdosh all black limited edition sth timh 499euro me eggyhsh 2 etwn pros8eteis kai 15 euro gia na to ksekleidwseis gia na leitoyrgei se ola ta dixtya elladas kai ekswterikou
8a synexisei na kykloforei kanonikotata gia pollous mhnes akoma giati o antikatastaths toy a1010 apla den 8a vgei sto emporio logw allaghs project apo th motorola
sthn ellada den 8a kykloforhsei epishma pote giati apla apo nomo8esia h ellada epitrepete na exei mono 3 etairies kinhths thlefwnias kai h 3 poy to vgazei den exei dikaiwma na exei adeia sthn ellada
ellhniko menu den exei akoma an kai kati kala paidia edw sthn italia to prospa8oyme alla exei ellhnika gia na grafeis sms kai pdf kai word .
oso gia metaxeirismeno an exeis prosvash sto ebay mporeis na to vreis apo 80/150 euro syn 20 euro gia metaforika einai h kalyterh agora apo agglia gia metaxeirismena sxedon se aristh katastash.apo italia 8a to vreis pio akriva mexri kai 250euro .
mia mnhmh 512mb exei 40 euro
ayta
kalws hr8es sto club
Έχει κάποιος καμιά ιδέα γιατί όταν κάνω εγκατάσταση το route66 στο Α925 και πάω μετά να το ανοίξω από το εικονίδιο γράφει
Program Mobile 2006
Reason code KERN-EXEC
Reason number 3
και βέβαια δέν δουλεύει!!
Είναι <<αγορασμένο >> από το ίντερνετ υπάρχει περίπτοση να μην έχει κατέβει σωστά;
Program Mobile 2006
Reason number 3
an exeis dsl mporw na sto steilw mesa apo msn
σήμερα ήρθε και αύριο θα κάνω την ενεργοποίηση οπότε θα σου κάνω ένα pm γιά να μου το στείλεις thanks
loipon opoios 8elei na kanei update sthn 54.08 na perimenei kai na parameinei sth 54.07.11 giati yparxei ena mikro bug sto teleytaio firmware mexri na dior8w8ei loipon parameinete sth 54.07.11 poy einai h kalyterh mexri stigmhs .molis exw newtera 8a eidopoihsw
Γεια σε όλους,
μόλις απέκτησα ένα a1000 (από ένα φίλο που μου το πούλησε). Δυστυχώς, ενώ έχω το καλώδιο, δεν έχω κανένα πρόγραμμα, ούτε καν το πρόγραμμα για synchronization. Ξέρει κανείς που μπορώ να το βρω?
Επίσης, αξίζει να βάλω κάποιο νέο firmware?
Και, τέλος, ποιά προγράμμα αξίζει να εγκαταστήσω?
Ευχαριστώ πολύ
(το ξέρω πως θα έπρεπε πρώτα να διαβάσω τα προηγούμενα μηνύματα. Αυτό κάνω, μόνο που είναι πολλά!!)
Let me be your fantasy
GUYS, ΒΟΗΘΗΣΤΕ ΛΙΓΟ ΕΔΩ ΑΝ ΜΠΟΡΕΙΤΕ. ΑΛΛΑΞΑ ΑΠΟ VODA ΣΕ COSMOTE ΚΑΙ ΔΕΝ ΜΠΟΡΩ ΝΑ ΦΤΙΑΞΩ ΤΑ SETTINGS ΤΟΥ ΓΙΑ ΙΝΤΕΡΝΕΤ Ή MMS.
ΗΤΑΝ ΠΟΛΥ ΑΠΛΟ ΜΕ VODA, ΑΛΛΑ ΤΩΡΑ ΔΕΝ ΜΠΟΡΩ ΝΑ ΤΑ ΒΡΩ ΚΑΙ ΑΣ ΔΟΚΙΜΑΖΩ ΤΑ ΔΙΑΦΟΡΑ ΠΟΥ ΔΙΑΒΑΖΩ.
ΕΧΩ ΤΟ 51.95.00 ΤΟ MODIFIED (FULL).
ΑΝ ΞΕΡΕΙ ΚΑΝΕΙΣ...
paidia mipos jerei kanenas apo pou mporo na agoraso to kinito auto giati me endiaferei polli
kainoyrgio mono apo agglia h italia sthn italia exei 499euro mazi me to bluetooth kai einai h ekdosh all balck limited edition exei bgei mono italia.
metaxeirismeno koita sto ebay an exeis prosbash kai kyriws apo agglia ka8ws einai fthnotera kai mporeis na to pareis to poly 200euro mazi me ta metaforika apo italia den sto synistw apo ebaygiati ta perissotera einai kleidwmena to bootloader kai dyskola mporeis na ta ksekleidwseis sthn ellada.
trith lysh einai apo aggelies sthn ellada .
odhgies prin thn agora toy kinhtoy metaxeirismenoy.
na dokimaseis panw apo 2 kartes diaforetikwn dixtywn kai na kaneis klhsh,na mhn exei gratzoynies h o8onh ,na mhn leipei to penaki ,na yparxei to kalwdio usb ka8ws kai oi 2 fortistes taksidioy kai h bash kai na koitakseis to imei toy kinhtoy poy einai grammeno sto pisw meros toy kinhtoy na einai to idio me ayto poy emfanizete otan patas to kwdiko se diaforetikh periptwsh shmainei oti einai klemeno kai exoyn allaksei to imei.
oso gia thn eksodh leitoyrgikoy an endiaferese na kaneis modding kalo einai na vreis kapoio poyexei palia ekdosh opws 51.14 h 51.86 mexri kai to 51.95 PROSOXH se kamia periptwsh mhn pareis to 54.08 giati einai kleidwmeno.kalyterh ekdosh mexri shmera einai h 54.07,11
kalh agora kai kalws hr8es sto club a1000
Παιδιά προσοχή με την εγκατάσταση των firmware.Εβαλα την 54 07 11 Και κληδοσε.μου γράφει USIM EMERGENCY ONLY, Τώρα τρέχω,πέρασα την 51 95 00 ούτε να την βλέπει δεν θέλει , μετά πέρασα την 54 07 00 hybrid αυτή την βλέπει αλλά πάλι είναι κληδομενο,αν γνωρίζει κανένας user τίποτα ας γράψει κάτι.
Στο α925 η 35 80 61 είναι πολύ καλή έκδοση περαστέ την ανεπιφύλακτα.
Τώρα μετάξει Vodafone και Cosmote η cosmote μου φένετε πιο εύκολη, αν κάποιος φίλος θέλει κάτι να ρωτήσει ας μου στείλει ένα e-mail.
η εκδοση 54.07.11 δεν κλειδωνει το κινητο φιλε μου διαβασε και αλλα site στο εξωτερικο και θα μαθεις περισσοτερα προφανως δεν πετυχε το flash η εκδοση 54.07 ειναι η εκδοση που εχει βγαλει η 3 italia και ξανακλειδωνει το κινητο .αν ειχες διαβασει ολα τα προηγουμενα topic θα εβλεπες οτι τα γραφω αναλυτικα>
Firmware REL 54.07.00 A1000 U_34.30.01P 000 1FF Brand 3 κλειδωνει bootloader και ξανακλειδωνει το κινητο και επαναφερει τισ ρυθμισεις τις 3.
Firmware REL_54.08.00_A1000_NO_LOCK_U_34.30.03P_SE5056AE8W8_001_1FF δεν κλειδωνει τιποτα δεν εχει αναφερ8ει κανενα προβλημα
Firmware Generic Lite per la 54.07 ver 1.7 δεν κλειδωνει τιποτα δεν εχει αναφερ8ει κανενα προβλημα δεν χρειαζετε το προγραμμα nop ex κανει install κατευ8ειαν στην εξωτερικη μνημη
Firmware 54.07.11 A1000 Generic Plus δεν κλειδωνει τιποτα δεν εχει αναφερ8ει κανενα προβλημα δεν χρειαζετε το προγραμμα nop ex κανει install κατευ8ειαν στην εξωτερικη μνημη
μεχρι σημερα υστερα απο 2 χρονια σχεδον η καλυτερη εκδοση που εχω χρησιμοποιησει ειναι η 51.95 generic και η 54.07.11 generic
αλλη φορα οταν γραφεις κατι να φροντιζεις να το επιβεβαιωνεις και κυριως να το ψαχνεις στη τεραστεια εγκυκλοπαιδεια που λεγετε GOOGLE.
Tο προβλημα που ανεφερες εχει ξανασυμβει και οφειλετε οτι δεν εγινε σωστα το flash οταν εκανες το firmware update.τωρα το κινητο κλειδωσε στην 3 απο τη χωρα που το ειχες αγορασει και επιτρεπει μονο την καρτα που ειχε αγοραστει.δυστηχως τα κακα νεα για σενα φιλε μου ειναι οτι μεχρι σημερα δεν εχει βγει ακομα το ξεκλειδωμα καθως εχει κλειδωσει το bootloader kai to operator lock.
Ευχαριστώ φίλε για τα άσχημα νέα σου,αν μάθεις κάτι είμαι σίγουρος ότι θα το αναφέρεις, όσο για το κλήδομα του τηλεφώνου, διαβασμένος πήγα να κάνω την αναβάθμιση ,άλοστε ασχολούμαι πολύ αφού έχω 1 μότο 925 και 2 μότο α1000,
και παρακολουθώ σχεδόν τα πάντα για αυτά τα τηλέφωνα .Να σου πω την αλήθεια την πάτησα γιατί προσπάθησα να αλλάξω τα εικονίδια στο μενού (home) και να τα κάνω Ελληνικά από τότε μου κλείδωσε . Έχω κατεβάσει ένα σωρό πράγματα από το internet, αν καταφέρω κάτι θα το αναφέρω, πάντως πρέπει να σιγουρευτώ για τα κλειδώματα – ξεκλειδόματα αν τα καταφέρω θα του αλάξω τα φώτα γιατί του αξίζει. ΜΟΤΟΡΟΛΑ ΟΛΑ ΓΙΑ ΟΛΑ ΓΕΑ.
Υ.Γ Με το Α 1200 ΤΙ ΓΙΝΕΤΑΙ ΠΩΛΕΙΤΑΙ ΣΤΟ E-BAY? ΣΤΗΝ ΙΤΑΛΙΑ ΠΟΤΕ ΘΑ ΚΥΚΛΟΦΟΡΗΣΕΙ
exoun bgei nees firmware sto http://www.a1k.co.uk opou 2 apo autes tis ekanan sto planetmobile.it tis exei dokimasei kaneis?Ego thelo na tis dokimaso alla lene merikoi gia bugs.Pos den anoigei to to do kai to ringtone manager.
Kai by the way exei kaneis to programa me to opio flashareis to kinhto?DHladh to pst h to rsd lite kati tetio kai mporei na mou to stilei?to mail mou einai manolis_varnassinger@yahoo.com thanks
