Τροποποιήσεις Ε710 - κωδικοί - Software
gmat
kalhmera paidia..
egw douleuw to italiko kai oi kwdikoi mou douleuoun ektos
Software Version
Hardware Version
Sim Infos
Battery & Field Infos
ola ta alla mou douleuoun kanonika.
den xerw giati den douleuoun se esas.
ex8es parathrhsa oti se update pou ekana se ena 710 me to italiko den alaxe to imei kai krathse to diko tou.den katalaba pws egine ,giati den flasara mono ths alages.
  • Απαντήσεις 1,1χιλ.
kalhmera kai apo emena paidia molis teleiwsato flasharisma me to italiko FW apo thn arxh xwris alages kai ap oti eida krateise to imei pou eixa kai prin oxi to diko mou
den exw provlhma me ayto alla afou to exou alaxei kai alloi aporw giati den ginete kai se mena
exoun fygei oi shmaies kai emfanisthkan wria backrounds me tis epoxes tou xronou....
to all of u out there if someone knows how to change the f.....g IMEI pls post something here ......
thanks
gmat ti prospatheis na vreis kai exeis kollhsei?
pios exei ftiaxei to new FW......?
se ena kinhto TIM exei to idio menu me ayto pou flasharame oloi mas twra?
poly mperdema re paidia
fobamai mhn exoume kana blacklist apo to imei giati se polous einai to idio opws ston gmat kai se mena
kai meta tha trexoume kai den tha ftanoume......
WHAT U SEE IS NEVER WHAT U EXPECT TO SEE
To na 3eskizeis mia suskeuh pou exeis agorasei kai sou aneikei den sto apagoreuei kanenas... einai dikaiwma sou na kaneis o,ti 8eleis...
To problhma prokeiptei an zhthseis na sthn 3anarapsoun...
Kaneis den 8a se kunhgaei epeidh alla3es firmware... alla 8a adiforhsoun otan tous peis "ftiaxte to" kai 8a sou poun "apo thn stigmh pou ebales xeri sthn suskeuh... eisai monos sou filarako"
Ρίξτε μια ματιά και εδώ, ίσως υπάρχει κάτι που σας ενδιαφέρει:
http://users.panafonet.gr/giannarisd
file musifon
ex8es opws sou eipa xana dokimasa to v200imei kai perasa ena allo imei sto kinhto gia na dw pws ginetai.
pernas to diko sou imei sto new imei kai meta kaneis reset phone ,meta to unlock kai meta xana pernas to imei to diko sou.
edw exei kako omws ,xaneis oti rh8mhshs exeis kai fotografies kai video kai wap kai mms.
hparxh kai allh lhsh,pernas to arxhko fw kai meta to italiko fw pou parathrhsa oti den allazh to imei pou exeis.
elpizw na boh8hsa.
filarako sorry se sena kai se olo to forum sas exw zalisei
alla ta kanw ola opws les kai tipota
se ola kanei pass
otan pataw omws to wrt imei mou bgazei ena security parathyro me ena generator key kai ena password
pataw ok kai meta den deixnei na kanei kati
ektos an thelei poly wra na perimenw
exw katebasei kai alla progs apo to easy unlock alla oute kan fortwnoun sto pc
leipoun .dll kai mal......es gia registry entries leei....
anyway tha flasharw to original vodafone kai elpizw ola na epanelthoun opws prin ( vasika mono to imei thelw)
see u guys
MUSIFON ΣΟΥ ΜΕΤΑΦΕΡΩ ΤΙ ΕΧΕΙ ΚΑΝΕΙ ΚΑΠΟΙΟΣ ΠΟΥ ΤΟ ΕΧΕΙ ΚΑΤΑΦΕΡΕΙ
KEEP THE SIM OUT. PHONE IS OFF--CONNECT UR CABLE ..
MAKE SURE YOUR ON BATTERY POWER .
CABLE IS ON D/L SWITCH
RUN THE SOFTWARE.....FIRST.
BEFORE YOU DO ANYTHING...............
PRESS THE ON BUTTON (RED) - POWER ON
CLICK IN THE NEW BOX
PHONE MAY START NORMAL THEN/OR IT WILL ENTER SERVICE MODE
PASSWORD PROMPT... CLICK OK OR 8 ZERROS
DON'T WORRY
CLICK ON THE NEW IMEI BOX or WRITE BOX
TRY AGAIN IF EITHER ONE DONT WORK
TYPE YOUR NUMBER ON UR FONE BOX OR BACK BEHIND THE BATERY
WRITE IT - CLICK ON THE WRITE BOX -- RIP IT
WINDOWS XP MAY CRASH BUT IT WAS WRITTEN...
REMOVE CABLE- THEN THE BATTERY(FONE MAY LOCK UP)
INSERT BATTERY---POWER UP.....
TYPE *#06#
YOUR CORRECT IMEI # SHOULD BE THERE.
ΕΛΠΙΖΩ ΝΑ ΤΑ ΚΑΤΑΦΕΡΕΙΣ
Perito na sas pw oti exw kourastei na allazw firmwares...
kai auto to misawro gia to flasharisma mou fainetai aiwnas oloklhros twra pia... eixa synh8isei me ta patchakia twn .s3 kai twra bariemai...
kamia allagoula 8eletai?
kanena animation backround as poume?
dokimase to
avistuffbyag gia to optiflash
paidia ebala to italiko FW meta apo to original ths vodafone gia na exw kai pali to diko mou to imei...ta katafera to imei epanhlthe alla exw kai thn yparxh to gkri kollhmatwn otan paw na steilw MMS xaxaxxa
ti ginete edw pera re kai opws einai fysiko mms den stelnei
tha palavwsoume paidia..... petaei gkri othonh kai kanei reboot mono tou......
Ακολουθώ και γω την συμβουλή ....... :o
Τώρα flashάρω το Original της VODAFONE και μετά θα βάλω
από πάνω το Ιταλικό. :D
Και μετά θα ξαναβάλω τις ρυθμίσεις....... :cry:
Ελπίζω να μην έχω τόσες πολλές γκρί οθόνες.....
αλλιώς θα γυρίσω στο δικό μου το FW....
:whistle:
ωραία τα μπλεδάκια .... αλλά μου κάναν κουρέλι τα νευράκια. :lol:
Για να κατεβάσετε το firmware που φτιάχνω επισκευτείτε την παρακάτω διεύθυνση
ftp://myphone:myphone@81.86.136.8/myphone
διαβάστε και το README αρχείο.
egw flashara to italio panw sto olympic exasa tis rythmiseis
flashara to original panw sto italiko
epanilthe opws htan xwris rythmiseis vodafone live
kai apo panw flashara to italiko
exasa oles tis rythmiseis
shmera evala to italiko pali panw apo to italiko den exasa rythmiseis
den exw gkri o8ones alla den mporw na steilw mms me tipota
tha doume ti tha kanw
Βάζοντας το ORIGINAL και από πάνω το Ιταλικό
στα settings του WAP έχω αυτά της ΤΙΜ και κάτι άλλα.
Αντε πάλι αλλαγές.....
ΤΕΛΕΥΤΑΙΑ ΦΟΡΑ ΠΟΥ ΤΟ ΚΑΝΩ ..... ΒΑΡΕΘΗΚΑ !!!!
Αν δεν μου κάτσει και το Ιταλικό γυρνάω στα κοκκινάκια.....
ΔΩΡΟΝ-ΑΔΩΡΟΝ.
gmat to idio kai egw prospatheise na steileis mms kai pes mou ti kanei
dexomai alla den pairnw .....
ekana oti kai o myst nwritera apenergopihsa to vodafone live alla tipota
mono dexomai
den mporw na steilw....
Βάζοντας το ORIGINAL και από πάνω το Ιταλικό,
έχασα μόνο τα wap settings (σκασίλα μου) αλλά δεν
έχασα τα MMS settings.
Εστειλα MMS στον εαυτό μου και το έλαβα ΚΑΝΟΝΙΚΑ.
Σημ: είχα κάνει πριν *2767*WAP# (δεν έχει καμία ρύθμιση)
τα wap settings δεν τά΄χω βάλει ακόμα. Το Ιταλικό βάζει ΤΙΜ.
ΠΑΡΑΓΓΕΛΙΑ ΤΟΥ ΦΙΛΤΑΤΟΥ MYST.
TO ΜΟD ΑΛΛΑΖΕΙ ΤΟΝ 9ο ΤΟΝΟ ΣΤΑ SMS ΜΕ ΓΥΝΑΙΚΕΙΑ ΦΩΝΗ
" ΚΑΙΡΟΣ ΗΤΑΝ, ΕΧΕΤΕ ΜΗΝΥΜΑ "
ΑΝ ΔΕΝ ΣΑΣ ΑΡΕΣΕΙ ΕΧΕΙ ΜΕΣΑ ΚΑΙ ΤΟ ORIGINAL .s3
EINAI ΦΤΙΑΓΜΕΝΟ ΓΙΑ ΤΟ ΙΤΑΛΙΚΟ ΑΛΛΑ ΜΑΛΛΟΝ ΚΑΝΕΙ ΚΑΙ ΓΙΑ ΤΟ ΟΛΥΜΠΙΑΚΟ FW
gr_mynhma.zip
3o sth seira flasharisma shmera
italiko----italiko----olympic-----original voda-----italiko
mms den mporousa na steilw oute kai me to original
kati mallon den paei kala dexomai alla den mporw na steilw
tha xanakamw tis rythmiseis apo thn arxh kai an den ta kataferw tha bgalw thn mpataria gia kamia mera kai tha prospatheisw me thn boitheia ths vodafone meta
kalo kouragio paidia
exei melako lako h fava!!!!!!
kalo tha htan na perimenoume kapio kalo update apo tous filous mas tous italous h apo ton sleta pou kata pasa pithanothta tha einai kokkalo se kapio beach bar ths zakynthou ayth th stigmh
take care ta leme otan tha exw nea sas
fantazomai o filos gmat tha ta exei parei kanonika twra me oles tis !@#$%%% pou ginontai
file musifon giati den pigenhs sto site ths vodafon ,ekei pou leei pu8mhshs suskeuwn ,vodafon mms,meta epelexe sundromiths,meta samsung v200
bale to thlefonw sou kai 8a sou er8ei ena mhnhma pou 8a kaneis apo8hkeush me ths ru8mhshs tou mms.
TELOS KALO OLA KALA
OLA BACK TO NORMAL
MMS=OK
VODA/LIVE=OK
IMEI=OK
PEIRA KAI MIA XARA TO PRWI NOMIZA PWS TO SITE TIS RANOVA LEITOURGEI
ALLA KATHE FORA POU EKANA DOWNLOAD ENA JAVA GAME STO 96% ME EKOVE SYNAIXEIA
MHPWS XEREI KANEIS KANA KALO SITE GIA JAVA?
KAIROS NA ARXISOUME NA FTIAXNOUME KAI KANENA BACKROUND
KAI ENA TELEYTAIO....EINAI ALHTHEIA PWS TO ITALIKO/OLYMPIC
KYKLOFOREI KAI STHN ELLHNIKH AGORA MESW TIM??????
XE XE XEEEEEE
η κακία στο μεγαλείο της....ΟΧΙ ΔΕΝ ΤΑ 'ΧΩ ΠΑΡΕΙ.....ΑΚΟΜΑ!
αλλά όλες αυτές οι (*&^(@^$(*^*&^&%$@^$#^ αλλά Ιταλικά
μου'χουν κάνει τα νεύρα σπαγγέτι.
Τουλάχιστον σταθεροποιήθηκα σε ένα FW, το ΙΤΑΛΙΚΟ.
(O Θεός να βάλει το χεράκι του)
Πάντως όταν έβαλα το Ιταλικό η defualt gprs σύνδεση ήταν ΤΙΜ.
Αν ήταν ΤΙΜ-international ή TIM-di ITALLIA ντεν ξέρει.
Αρχίζω τα ΜΟD's έχω μπόλικο υλικό για άλλαγμα, πρώτο και καλύτερο το grid menou γιατί με μπερδεύει ΠΑΡΑ ΠΟΛΥ ^%$&&^%* δεν ξέρω τι είναι πού...
Αυτά προς το παρών.......
ΚΑΛΟ ΜΗΝΑ ΣΕ ΟΛΟΥΣ.....
A MILLIORI AGOURI APO MISKO .... ΚΡΟΝΙΑ POLLA.
