Υπηρεσίες δεδομένων [GPRS/3G/HSDPA]
Global moderator
  • Απαντήσεις 2,9χιλ.
Gia telestet den prepei na exei oyte Username oyte pass prepei na einai kena... Ayto edo kai 2 mines peripoy.....
Apo xthes ekana energopoiisi GPRS meso COSMOTE (Etsi gia dokimi mias kai exo logariamo me syndesi)...... Teleios alli aisthisi.... Syndesi sferati.... den yparxoyn ta kolimata tis Telestet Kalitero Downloand.... GENIKA KAMIA SXESI me tin Telestet.....
To mono ASXIMO poy exei? Ta dipla € to mina..... :(
Ekana ayti tin dokimi giati tis teleytees 2 ebdomades eixan spasei ta neyra moy.... Exo to C55 tis Siemens kathe deyteri mera imoyna sti Siemens... fenotan na fteei to tilefono... den syndeotan, ekleine mono toy (Syndesi me USB opote fortize mono toy) kai gia ta kolimata den leo tipota giati einai gnosto problima tis Telestet...
Ypopsin oti me Telestet exo 3 monades sima stis 4 kai Apo Cosmote exo 2 monades sima stis 4.....
Telika oti plironeis perneis ..... 5.000drx +FPA to mina i Telestet.... 10.000drx to mina i Cosmote..... Mprosta sto spasimo neyron omos poy eixa kai tis meres poy exo xasei trexontas stin Siemens.... tis ateleiotes ores poy exo xasei me to 1231 tis Telestet (kai akri na min briskeis) PISTEPSTE ME AXIZEI NA DOSEI KAPIOS TA 15 € parapano to mina kai na exei to kefali toy ysixo...
(Cosmote den xreiastike kan na paro tilefono fia rithmiseis klp... syndethike me tin proti)
Filika Aris
Xaxasa na sas po oti me to to kalodio syndesis tis MA pali den syndeete... Mono me to ORIGINAL kalodio tis Simens
H Siemens meta tin V18 (gia to C55) kati exei alaxei sto softwere kai ta kalodia tis MA ta exei bgalei off....
Filika Aris
De xerw poia einai ta kalytera kinhta gia na mpainei kaneis gprs alla me to samsung v200 mou pantws mpainw mia xara.Sthn arxh vevaia eixe kapoia provlimatakia alla kseperastikan.
To kalo me thn Telestet einai oti de vazei ogkoxrewsh.Gia poso kairo omws arage???
Opws polloi parathrhsa ki egw oti kanei disconnect ana 1 - 1,5 wra alla kyriws se wres aixmhs.To prwi gia paradeigma h arga to vrady paei sfaira gia wres. :p
Αρχικό Μήνυμα από τον frantzeska
Ογκοχρέωση δεν πρόκειται να μπεί ποτέ. Μπορεί να αυξηθεί λίγο το πάγιο αλλά η υπηρεσία θα παραμείνει ως έχει. Οσον αφορά τα disconnects, μπορεί να παρουσιάζονται συχνά σχετικά τις ώρες αιχμής αλλά γενικά είναι σε υποφερτό βαθμό και αν βάλεις auto-reconnect ξανασυνδέεται σε 5 δευτερα. Αυτό που ήταν εκνευριστικό ήταν το πάγωμα της σύνδεσης, το οποίο ήθελε disconnect, restart του κινητού και σύνδεση ξανά. Ευτυχώς αυτό έχει σταματήσει εδώ και πολύ καιρό, τουλάχιστον σε μένα, και έχω βρει την ησυχία μου :)
Phantom Of The Opera
Αρχικό Μήνυμα από τον Angeldust
Pagwma sth syndesh den exw idiaitera.Oute xreiazetai na kanw restart to kinhtaki.Apla einai eknevristiko ta disconnects pou ginontai.As elpisoume na lythei ki afto to provlima kai meta h telestet tha einai h kalyterh!
Αρχικό Μήνυμα από τον haki
Και εγω πρεπει να ομολογησω οτι ειδικα τον τελευταιο μηνα το GPRS της Telestet πηγαινει σφαιρα, χωρις καμια διακοπη, κολληματα κλπ. Ακομη και σε ωρες αιχμης παει πολυ καλα εδω στην επαρχια. Tο Τ610 με καλωδιο κατεβαζει μεταξυ 4-5.5kbps/sec.
Εχω να μαλωσω με το 1231 πανω απο 2 μηνες!!! :'(
Μου λειπουν λιγο οι καβγαδες με το cc!!! :(
Αν είσαι στην Αθήνα είναι λογικό να πηγαίνει σφαίρα αυτές τις μέρες. Κι εγώ είδα σημαντική βελτίωση τις τελευταίες 10 μέρες, που δεν ξέρω αν οφείλεται στο ότι άρχισε να φεύγει ο κόσμος και άδειασε η Αθήνα...
this signature is under heavy construction
Αρχικό Μήνυμα από τον ng78
Εμενα γιατι σημερα μου εχει κανει πανω απο 15 disconnect απο τις 10 το πρωι που ειμαι On line.... (15.20 τωρα)
Σημειωση: εχω full σημα, συνδεση με bluetooth (2 μετρα το κινητο μακρια)
bILL
If it isn't Amstrad, it isn't good enough
Amstrad CPC 6128, Zilog Z80, 4 MHz, 128 kb RAM, 64 kb ROM, 27 colours (16 on screen) 3+1 sound channels, Disk Drive 3" 178k, AMSDOS-CP/M
Χαχα ... εγω γιατι βλεπω συνεχεια disconnect σου Φραντζεσκα; :p :D
bILL
Hello!
Εχω ενα Τ310 και το USB καλώδιο 8910P της MobileAction. Mήπως θα μπορούσε να μου πει κάποιος τις ρυθμίσεις που εισάγω κατα την εγκατάσταση του driver του κινητού (που έρχεται μαζι με το cd του καλωδίου) με τις οποίες δημιουργεί το DialUp Networking εικονίδιο των Windows?
Συγκεκριμένα, ζητάει APN, username και password και DNS IP.
Επίσης, ισχύει κάτι που είχα διαβάσει παλιότερα, δηλ. οτι αν βαλεις το ΑΤ+CGDCONT=1,"IP","gnet.b-online.gr" πρέπει να αλλάξεις τον αριθμό κλήσης απο *99# σε *99***1# ?
Ευχαριστώ!
Πόσοι χρήστες είμαστε περίπου στην Αθήνα;
Εγκαταλείψτε την ελπίδα για ένα καλύτερο παρελθόν!
triti mesimeri telestet GPRS-nokia 6510
35 kbits/sec stathera.
ego 1h fora vlepo tetoies taxitites
Οι υπογραφές μπορούν να περιέχουν 1 εικόνα, η οποία ωστόσο δεν θα πρέπει να έχει διαστάσεις μεγαλύτερες από 420 x 150 pixels και το μέγεθός της δεν θα πρέπει να ξεπερνά τα 16.384 bytes.
Ξέρει κανείς κάποιον αξιόπιστο public proxy server?Λέγοντας αξιόπιστο εννοώ να είναι ανοιχτός συνεχώς, γιατί βαρέθηκα να δοκιμάζω proxies οι οποίοι υποτίθεται οτι ελέγχθηκαν πρόσφατα και να είναι όλοι κλειστοί.
Αρχικό Μήνυμα από τον ipparxos
Αυτή τη στιγμή δεν πρέπει να έχουμε μείνει στην Αθήνα ούτε το 20% των χρηστών Telestet GPRS. Γι' αυτό πηγαίνει καλά τις τελευταίες μέρες.
Κάτσε να αρχίσουν να επιστρέφουν από το τέλος του μήνα και θα δεις maximum ταχύτητες 4,8 Kbps πάλι ;)
xoris na theoro to euato mou gourou tou GPRS apo to forum tou unwired poli kairo prin eixa pei oti ta provlimata tis telestet sto GPRS einai kathara thema xoritikotitas.
Oi liseis pou edine kata kairous o camclone aplos miroveltionan tin katastasi.
Pantos emena peripou 6 mines pou to xrisimopoio 4-5 meres exa taxitites 4,8 kbits pou les .
Oi sinithes taxitites mou einai 15-20 ta mesimeria kai 20-30 ta vradia.
eekeines tis imeres aplos den mpaino internet ti na kanoume na paithanoume?
Exei kaneis sindiasmo nokia 6510-winXP(sp1)-ma620 kai mpainei internet xoris provlimata?
Πριν παρω το siemens c55 αποκλειστικα για gprs εμπαινα με τον συνδιασμο που γραφεις αλλα με Nokia 6610 (δεν νομιζω να εχει σημασια....). :) :) :)Χωρις κανενα προβλημα. :) :)
Φιλικά Γιάννης
Αρχικό Μήνυμα από τον evagelos
Για λιγο καιρο που εμπαινα με αυτο τον συνδυασμο δεν ειχα περισσοτερα προβληματα απο αυτα που συνηθως εχω με το S45 εκτος απο κατι ανεξηγητα κολληματα των υπερυθρων που ομως δεν θυμαμαι περισσοτερες λεπτομερειες
ΕΙΤΕ ΧΙΟΝΙΖΕΙ ΕΙΤΕ ΒΡΕΧΕΙ ΜΕΝΕΙ ΛΕΥΚΟ ΤΟ ΓΙΑΣΕΜΙ...
Αρχικό Μήνυμα από τον hcivil
Τα Windows XP έχουν γενικό πρόβλημα με τα υπέρυθρα modems και τρώνε μεγάλα κολλήματα. Υπομονή ως το Service Pack 2 :)
Κι εγώ δεν τρελαίνομαι φίλε :)
Αν δουλεύει καλώς. Αν δεν δουλεύει δεν μπαίνω καθόλου, ή μπαίνω με PSTN/ISDN, παίρνω στο 1231, τους ρίχνω και 4-5 μπινελίκια για να μην ξεχνιόμαστε και αυτό ήταν όλο :)
Μόνο όταν έχω να κάνω κάτι σημαντικό εν κινήσει και έχει φάει κόλλημα το GPRS είναι το μεγάλο πακέτο, αλλά τι να κάνουμε Telestet θέλαμε... Απλά κάνω υπομονή 2-3 μήνες μέχρι να λήξει η ανανέωση του συμβολαίου
και μετά... άντε γεια Telestet.
Shmera dokimasa TStet GPRS me to 6510 mou meta apo 1 xrono sxedon kai mporw na pw pws itan athlia! Den mu egrafe sto icon sto systray to speed (egrafe 115k) alla itan xeirotera kai apo 28ari modem!!
Ti lete na fteei? Prepei na valw orismena settings?
To speed kai i apodosi tu GPRS epireazetai apo to poso kalo shma exeis i oxi?
Hmm kalispera katarxin
Molis simera ekana simvoleo me stet.Eimai katoxos enos P800 kai tha me endiefere an ginotan na sindeome web apo ton forito me stet gprs..
Einai dinato na gini auto kai pos ? i sindesi tou kinitou me ton forito ginete meso bluetooth.. tora mou menoun oi rithmisis tou kin kai tou foritou :P osoi mporite help me :)
tnx
Μέγιστο μέγεθος εικόνας υπογραφής 420x150 pixels και 16ΚΒytes.
Αρχικό Μήνυμα από τον N1GHTM4R3
tnx
Παρε δωρεαν απο το κινητο σου το 1231 να σου στειλουν ή με sms ή με fax τις ρυθμισεις.Μετα φτιαχνεις μια νεα συνδεση χωρις ονομα και κωδικο με αριθμο κλισης *99# και αυτο ειναι ολο...... :) :) :) :)
Φιλικά Γιάννης
Να καταλάβω κάτι ...
Αν έχεις σύνδεση GPRS με το μηνιαίο πάγιο, μπορείς να μπαίνεις ελεύθερα στο WAP του τηλεφώνου όση ώρα θέλεις χωρίς εξτρα κόστος ?
Μπορείς να λάμβάνεις ή να στέλνεις email στη συσκεή σου (όχι μέσω PC ) χωρίς άλλο κόστος ή άλλη υπηρεσία ?
Τέλος αν είσαι στο εξωτερικό ισχύουν τα παραπάνω ή είναι αδύνατη η σύνδεση ?
Someone, Somewhere in Summer Time
Αρχικό Μήνυμα από τον papi Να καταλάβω κάτι ...
An exeis GPRS boreis na kaneis OLA ta parapano pou proaneferes XORIS KAPOIO EPIPLEON KOSTOS, oson afora to eksoteriko, h ypiresia parexetai pros to paron sthn Italia, Souidia kai Tsexia :)
Thanx Dromeas
Μόνο στις συγκεκριμένες χώρες δεν έχεις κόστος ή οι άλλες χώρες δεν διαθέτουν καν την υπηρεσία (πχ Αγγλία Γερμανία Κύπρος κλπ)?
Τέλος όταν λαμβάνεις e mail είναι απλά μία ειδοποίηση ή έχεις και το κείμενο?
