[S60 3rd Edition] Nokia PC Suite / OVI Suite / Software Updater
nervous
Nokia PC Suite 7.1 Now Available For Download
http://dailymobile.se/wp-content/uploads/2008/12/pc-suite.jpg
After a period of beta testing, Nokia has rolled out a new version of the classic PC Suite that works with all Nokia devices. The new version 7.1 brings new features as well as bug fixes. Some highlights below.
  • The ability to manage your Calender from the Communication Centre that was recently integrated into the PC Suite is there.
  • So are options to manage calls from within it.
  • You can also create and delete contact groups on your device, add and remove group members.
  • The PC Suite will also warn you about if the phone reaches the low battery level.
The Nokia PC Suit 7.1 is now out of beta and can be download from here.
http://thesymbianblog.com/2008/12/12/nokia-rolls-out-new-pc-suite-v-71-with-added-features-bug-fixes/
http://www.allaboutsymbian.com/news/item/8637_PC_Suite_71.php
http://dailymobile.se/2008/12/12/nokia-pc-suite-71-now-available-for-download/
  • Απαντήσεις 895
Update - Nokia Software Updater 1.4.85
http://www.spaziocellulare.com/News/wp-content/uploads/2008/12/nsu1485.jpg
3210-3310-8210-8310-6510-7250-3100-6230-6060-6280-E65-N82+2630-C7-SIII Mini-Moto G 2014-Redmi Note2 prime-Redmi Note3 Pro-Redmi Pro Χ25-Redmi 5 Plus-Mi A2
  • 1 month later...
Καλησπερα , ξερει κανεις πως μπορω να βαλω ελληνικα σε ενα παλιο Ν70 που εχω και να κανω και firmware update μετα σε ελληνικα?
Καλησπερα .
Εισαι εκτος ενοτητας ομως :rolleyes:
Με λιγο ψαξιμο......................
http://www.myphone.gr/forum/forumdisplay.php?f=14
http://www.myphone.gr/forum/showthread.php?t=148056
http://www.myphone.gr/forum/showthread.php?t=67749
http://www.myphone.gr/forum/showthread.php?t=157264
iPhone 5S Space Grey
Nokia Software Updater planned maintenance break - 14 Feb 19:00GMT - 15 Feb 19:00GMT
There will be a planned maintenance break this weekend, during which time
the Nokia Software Updater service will not be available. We apologize for any inconvenience this may cause.
Καλημέρα.Έχω ένα πρόβλημα με τον nokia software uptader.Καταρχήν έχω ένα Ν95 και κατέβασα και εγκατέστησα τον updater v1.4.85gr.Τον ανοίγω μου βγάζει ένα μικρό παράθυρο που γράφει "εκκίνηση της εφαρμογής" και μένει έτσι όση ώρα και αν περιμένω.Δοκίμασα χωρίς αποτέλεσμα τα εξής.απεγκατάσταση-επανεγκατάσταση(με απενεργοποιημένο το antivirus),έκανα αυτό που λέει η nokia αν δεν ανοίγει ο updater(να απενεργοποιήσω κάποιες διεργασίες από την διαχείριση εργασιών των windows και επανεκκίνηση της εφαρμογής).Αν μπορούσε να με βοηθήσει κάποιος.Τι άλλο θα μπορούσα να κάνω?Έχει κανείς καμμιά ιδέα?Ευχαριστώ προκαταβολικά.
Δοκιμασε με την αγγλικη εκδοση.
Κανε και ενα windows update αφου το εγκαταστησεις.Αν δεν κανω λαθος ζηταει να υπαρχει το Microsoft .NET Framework για να λειτουργησει.
Nokia Software Updater Gets Updated v1.4.98
Nokia Software Updater received a minor Update yesterday to cater for new Nokia handsets,
bringing NSU to v1.4.98 from previous version of 1.4.86. You can download the latest
version of NSU by either launching Nokia Software Updater on your desktop, or go to the NSU site directly here. Its a 24.5MB file.
http://www.nokiausers.net/Applications/Nokia-Software-Updater-Gets-Updated-to-Cater-for-New-Nokia-Handsets.html
παιδιά έχω ένα πρόβλημα....
Έχω ένα Ν95 8gb και θέλω να του βάλω ελληνικά... Ακολουθώ κανονικά τον οδηγό που υπάρχει εδώ μέσα... Αλλάζω το product code... και μετά πάω στο nsu...Αυτό ξεκινάει κανονικά ψάχνει για την τελευταία έκδοση firmware και όταν τελειώνει απλά μου λέει ότι έχω την τελευταία έκδοση εγκατεστημένη και σταματάει δεν μου κάνει τπτ!!!
Έχω κολλήσει δεν μπορώ να του βάλω τα ελληνικά
iMac 21.5'', Apple iPhone 6s Rose Gold...
Δεν σου δίνει τη δυνατότητα επανεγκατάστασης της ίδιας έκδοσης λογισμικού το NSU;
Σε αυτή τη περίπτωση δεν μπορείς να κάνεις και πολλά.
Ή πας σε Nokia Shop να σου περάσουν εκ νέου το λογισμικό ή την περνάς μέσω Phoenix ή περιμένεις νέα έκδοση λογισμικού.
Δλδ μέσω phoenix θα δουλέψει? Υπάρχει κάποιος οδηγός γι αυτό το πρόγραμμα για να ακολουθήσω?
Update - Nokia Software Updater 1.5.12
http://www.spaziocellulare.com/News/wp-content/uploads/2009/03/nsu1512.jpg
  • 4 weeks later...
καλησπέρα και χρόνια πολλά,
έχει κανείς καταφέρει, και πως, να κάνει να δουλέψει αυτό το πρόγραμμα με windows vista; έχω δυο pc το ένα με vista και το άλλο με xp. αυτό με τα xp δουλέυει άψογα το άλλο πάπαλα, δεν φορτώνει το πρόγραμμα.
γνωρίζετε κάποια λύση;
ευχαριστώ
frastgr
Η τελευταία έκδοση του NSU συνεργάζεται με τα Win Vista, απ ό,τι ξέρω.
Κάνε το απεγκατάσταση το και κάνε εκ νέου εγκατάσταση.
Επίσης για τη λειτουργία του χρειάζεται το .Net Framework 3.5. Το έχεις εγκατεστημένο;
έχω και το τελευταίο pc suite και ο υπολογιστής μου είναι up to date σε όλα. το παράξενο είναι ότι πριν από λίγο χωρίς να κάνω τίποτα δούλεψε και το πρασπαθώ εδώ και ένα μήνα. για να δούμε θα συνεχίσει να δουλεύει; θα δείξει!!!!!!
ευχαριστώ για τις απαντήσεις
frastgr
Nokia Software Updater application version 1.6.11 released
This application version includes a new and much-requested feature that
shows what key improvements are included in the new software version. These may include
performance improvements, updated applications or new features. This service is currently
available for the most updated products only, but will soon cover all new releases.
The Nokia Software Updater is available from http://www.nokia.com/softwareupdates.
Καλημέρα παιδιά.
Έκανα update στο Ν82 ακολουθώντας όλες τις οδηγίες που προβλέπονται, μου βγάζει μήνυμα οτι η αναβάθμιση ολοκληρώθηκε αλλά η οθόνη του κινητού αναβοσβήνει, δέ μπορώ να κάνω τίποτα με το κινητό, ούτε ανοίγει ούτε κλείνει.
Τί μπορώ να κάνω για να το ανοίξω και να το λειτουργήσω;
MB Ε65 ΒΤ AMG
Καλημέρα παιδιά.
Καλημέρα .
'Εβγαλες την μπαταρία για λίγα λεπτά ?
Ναί, για 15 λεπτά περίπου. Μόλις το ανοίγω πάλι αναβοσβήνει η οθόνη και τίποτα άλλο.
Δοκιμασε και χωρις καρτα αποθηκευσης.
Δοκιμασε επιπλεον να κανεις hard format
http://www.myphone.gr/forum/showthread.php?p=2253385#post2253385
Τελος ,δεν ξερω αν σου δινεται η δυνατοτητα μεσω nokia updater ,
(εαν αναγνωριζεται η συσκευη) να περασεις παλι την αναβαθμιση .
