[Επίσημο] Εφαρμογές symbian 7.0s
gkp
Αρχικό Μήνυμα από το μέλος asymvivastos (23 Αύγ. 2004 , 02:28)
Οντως επιασε μου βγαζει Evaluation Expires 02/09/2060.... :lol:
Θα το δοκιμασω μεχρι τοτε και αν μεινω ικανοποιημενος τοτε θα το αγορασω το προγραμμα. :whistle: :p
:D :D :up: :D :D :luck:
iPhone 5S Space Grey
  • Απαντήσεις 7,5χιλ.
Νεες Εφαρμογες :
Contact Transfer
Have you ever tried to copy the contacts database from one Series 60 based phone to another? Perhaps using a PC suite or SyncML? Perhaps you have noticed that something was missing in the end? No problem, with the Contact Transfer application you can copy the entire contents of the contacts database includig thumbnail images and caller groups from one phone to another via infra-red.
http://personal.inet.fi/private/riihimaki/s60/img/pbktrans.png
Η εφαρμογη ειναι freeware.Μπορειτε να την κατεβασετε απο ΕΔΩ . :)
:!: Μετα την εγκατασταση το εικονιδιο τοποθετειται αυτοματα στον φακελο Προσθετα :!:
World Traveller
Current weather and the latest four-day forecast of 1800 the most popular business and travel locations worldwide, local exchange rates of 140 currencies, world clock and world map. With such an array of features World Traveller will come very handy if you operate on an international scale.
http://www.psiloc.com/programy/s60/wt01.gif
Updated twice a day, the current weather and a four-day outlook of 1800 locations worldwide show five features: day and night temperature, sunshine, clouds, rain, wind and air pressure. With 140 local exchange rates the user can compare up to four currencies of choice. The Options menu shows a list with symbols and names of currencies. The rates are updated daily. With World Traveller you can manage up to eight alarms. Add, edit, delete alarms, make them one-off or repeated (daily, weekly, working days, etc.). Make them unique with a sound file of your choice.
Δυστυχως ειναι της Psiloc οποτε ειναι λιγο δυσκολο να την δουμε full. :o
re paidia pou mporw na brw programmatakia gia to 7610.ektos apo aivanet.....???? to irc pws xrhsimopoihtai??eyxaristw ek twn prwterwn!
Αρχικό Μήνυμα από το μέλος NEO24 (23 Αύγ. 2004 , 13:47)
Απο το irc καθως επισης και απο διαφορα groups που
εχουν ανοιξει ορισμενα παιδια. Ψαξε λιγο το forum,αναφερονται
αρκετα.
ΠΩΣ ΚΑΤΕΒΑΖΕΤΕ ΑΠΟ ΤΟ IRC
δεν υπαρχει κανενα κανονικο site οπου μπορω να κατεβασω εφαρμογες?δηλαδη να μπω και να κατεβασω οτι θελω αμεσως οπως και στο aivanet οχι να κανω 100 διαδικασιες!ενα site το οποιο να εχει ολες τις εφαρμογες σε μια στηλη!πολλα ζηταω?
ελλας for ever!
Αρχικό Μήνυμα από το μέλος nervous (21 Αύγ. 2004 , 14:30)
#aivanet, [bLUE|M00N] WEEKS 16 Onwards,Today :)
Προσπαθω να το βρω στο mirc αλλα δεν εχει /ctcp στο [bLUE|M00N] για να μπω.Μηπως θα μπορουσες να μου το στηλεις στο drioannis@vip.gr?Ευχαρυστω.
Αρχικό Μήνυμα από το μέλος mirrorofsorrow (23 Αύγ. 2004 , 14:26)
drioannis, στο έστειλα. Όποιος άλλος θέλει το sprite back up, θα το βρεί στο γκρούπ mirrorofsorrow της υπογραφής μου.
Δυστηχως δεν το εχω λαβει.Εαν ειναι εφικτο ξαναστηλε μου το στο drioannis@hotmail.com.
Ελπίζω να σου έρθει τώρα. :)
ΝΕΟ, μόλις μπείς στα yahoo groups, μπορείς να κάνεις μια αναζήτηση και να μπείς και σε άλλα πολλά εκτός απο τα δικά μας. Θα βρείς πάρα πολλά πράγματα και όλα φούλ. Μάθε και το irc γιατί εκεί υπάρχουν τα ΠΑΝΤΑ. Υπομονή θέλει. Και γω τώρα άρχισα να σχολούμαι με το mirc.
Αρχικό Μήνυμα από το μέλος asymvivastos (22 Αύγ. 2004 , 18:54)
Η εκδοση αυτη κυκλοφορει αρκετο καιρο στο mIRC.Δυστυχως ομως δεν υποστηριζει πληρως το 7610 αφου τραβαει φωτογραφιες με αναλυση 575 Χ 471 και οχι με 1152 Χ 864.Ομως γινεται να τραβηξεις μια φωτογραφια χωρις το Camera FX και μετα να την ανοιξεις με το προγραμμα για να χρησιμοποιησεις τα πολλα εφε και πλαισια και οτι σου προσφερει. ;)
EDIT: PIT μπορεις να τα κατεβασεις και τα 2 απο ΕΔΩ . ;)
ΕΥΧΑΡΙΣΤΩ ΠΟΛΥ asymvivastos!!!
Νεα εφαρμογη:
PowerNotes version 1.00
If you estimate your time and don't want to spend it on typing with the help of T9... If you need an application that will remind you about important events or ideas you need to implement at a certain time... Then you should definitely try PowerNotes, which greatly combines functions of voice notes and reminders and also has handy views for viewing events sorted by months, days, categories and a lot more.
How does it work:
  • PowerNotes works with 2 types of records: Voice reminders and Text reminders.
  • To create a new reminder you should select a corresponding command from Options - New.
  • New reminders can also be created with the help of Hot key, to define a hot key open dialog Settings(Options - Misc - Settings) and define hot keys and actions.
  • If you want PowerNotes to handle hot keys you should turn on Reminder state option.
http://www.symbianware.com/res/powernotes60/pn3.jpg
Περισσοτερα screenshots και λεπτομερειες εδω : PowerNotes . :)
Tελικα το Avia οπως το ξεραμε παει?
Η εγω κατι δε καταλαβα καλα?
Και οι μη εχοντες γνωση απο mirc τι θα κανουμε βρε παιδια?
Δε μπορει καποιος να τα ανεβαζει σε καποια πρωσοπικη του σελιδα ωστε και εμεις να βολευτουμε?Μηπως και αυτο ειναι παρανομο?
Αρχικό Μήνυμα από το μέλος andrewko (25 Αύγ. 2004 , 04:14)
Υπάρχουν αρκετά παιδιά μέσα στο forum που έχουν ανοίξει yahoo groups.Άμα ψάξεις θα βρεις πάρα πολλά ;)
Φιλικά Δημήτρης
Αρχικό Μήνυμα από το μέλος andrewko (25 Αύγ. 2004 , 02:14)
έχω κάνει και εγώ ένα site αλλα χρειάζομαι κάποια άτομα για να με βοηθήσουνε http://clubs.pathfinder.gr/6600games/ ;)
only crossfit...
Αρχικό Μήνυμα από το μέλος asymvivastos (24 Αύγ. 2004 , 16:28)
Νεα εφαρμογη:
How does it work:
Κυκλοφορησε full.Δεν ξερω αν υπαρχει και στο mIRC,παντως εγω το κατεβασα απο ΕΔΩ . ;)
Αρχικό Μήνυμα από το μέλος asymvivastos (25 Αύγ. 2004 , 12:49)
Καλο :up: thanks asymvivaste :)
Θυμάται κάποιος φίλος πως αποκτά ο Opera μια κάπως πιο "ελεύθερη" μορφή? :whistle:
Κάτι με το dat600 αν θυμάμαι καλά..
http://digitalviews.smugmug.com/photos/471912194_RABQF-Th.gif
Αρχικό Μήνυμα από το μέλος Global moderator (25 Αύγ. 2004 , 12:54)
What u need: 1) Opera s60 browser :P (any version) |
| 2) A file explorer app (fexplorer, seleq...) |
| 3) Brain (not nessesary :P) |
| 4) A mobile... |
| 5) Hands (recommented 2) |
| 6) Patiance we start :P |
| 7) The abuility to read my "english" spell :P |
| Here we go : Start the explorer app (fexplorer, seleq...). |
| Goto C:\data | find a file called "ousr600.dat". |
| Delete that file. |
| Create a folder named as the file (ousr600.dat) |
| DONE... THATS IT... |
| FAQ: |
| Q: What the **** did i just do??? |
| A: nothing much... u just deleted the file and replaced it |
| with a folder, witch dont stores data , so when opera goes |
| to see whats the exparation date... it dot get a shit... |
| Q:How do i fix this thing after??? |
| A: U just delete the folder and create a txt or anything else |
| file, so opera can store date on it... |
Αρχικό Μήνυμα από το μέλος nervous (25 Αύγ. 2004 , 13:00)
| 4) A mobile... |
| Delete that file. |
| FAQ: |
Παιδιά δεν είναι κατάσταση αυτή.Αργούμε πολύ :!:
Πέρασαν 6 ολόκληρα λεπτά από το request μου.Ήμαρτον :p
Την ευχή μου Νέρβους ;)
φιλε nervous μηπως ξερεις πως παιζουν οι ogg files στο 6600??εφτιαξα καποια τραγουδια τα περασα σε ενα sx1 και παιζανε τελεια καλυτερα και απο το mp3 που εχει μεσα και πολυ δυνατα, βεβαια δεν γινονται ηχοι κλησης για το sx1!!μετα εφτιαξα για το 6600 με την προυποθεση να ειναι μονοφωνικος ο ηχος και παντα σε 8bit η σε 16bit οποτε ομως το εβαζα να παιξει μου εγραφε οτι υποστηριζει μονο 8bit η16bit και με πεταγε εξω!!μα τα εκανα μονοφωνικα και 8bit και απο mp3 σε ogg και αυτο το βιολι του!!!το player για τους ogg files ειναι η τελευται version και ειναι για 6600!!!
Αρχικό Μήνυμα από το μέλος giogio (25 Αύγ. 2004 , 14:14)
Δυστυχως φιλε giogio , δεν μπορω να σε βοηθησω ,
δεν το εχω χρησιμοποιησει καθολου. :(
ενα πολυ καλο ρωσικο site ειναι http://www.zone60.org εχει μεσα παιχνιδια εφαρμογες μελοδιες γινεται πανικος και ngage games !!!!!ειναι φοβερο link!!!
http://nokiafree.org/forums/t67058/h/s.html τελικα βρηκα ακρη με τους ogg files δειτε αυτο εγω το εκανα και ειναι τελειο βαζεις mp3 σαν ηχο κλησης και ειναι καλυτερο απο wave και απο οτιδηποτε αλλο!!!!enjoy!!!!!!!
Αρχικό Μήνυμα από το μέλος giogio (25 Αύγ. 2004 , 13:40)
ωραιο αλλα δεν μπορώ να βγάλω άκρη !!! με το 7650forever.com ποιο εύκολα τα έβγαζα πέρα!! :o
only crossfit...
