Xbox 360
Flamenerve
  • Απαντήσεις 2,1χιλ.
XBOX / XBOX360 File Extraction Tool v1.0 Public - NOW RELEASED!
Mookie from adr forums has released XBOX / XBOX360 File Extraction Tool v1.0 public.X360FExT (XBOX / XBOX360 File Extraction Tool) is a simple tool designed to help users that wish to open XBOX and XBOX360 images to extract specific files or all files. Here is the information about this release:
As you can see from the screen shot, the tool has opened a PI XBOX360 image without any problems and fully extracts a 5.78 Gig image in 9 mins 43 seconds using a P3 500MhZ, 384 MB RAM running WINXP O/S.
The tool is also backwards compatible for XBOX1 users which is probably more useful since there's not much you could do with a XBOX360 image unless perhaps you wanted to do some reverse engineering, naughty, naughty!!
Not bad going for a single 17KB Windows program, a must for anyone who can not stand command line programs. Oh, and it is also quicker than the xtract360.exe that PI released.
AΥΤΟ ΣΗΜΕΝΕΙ ΟΤΙ ΜΠΟΡΕΙΣ ΝΑ ΒΑΖΕΙΣ ΟΤΙ ΘΕΣ ΣΤΟ 360?????
1. afto exi merikes meres pou vgike
2. diavazo prosehtika ola ta nea tou 360 apo diafora sites
3. to sigkekrimeno programa kani extract iso games tou xbox360 ston skliro tou disko i sto pc mas.
4. DILADI to mono pou kani ine extract pexnidia tou 360, tipota allo, to periexomenou tou extracted arxioun ine aplos gia na to vlepis, i na asxolounte me kati oi hacker, enoite oti den mporis na pexis afta ta pexnidia
5. Afto ine i arxi tis arxis, ke gia na pexoume piratika sto 360, isos, isos se 1 horno, ke an gini se 1 hrono tha ine rekor....
Δεν ξέρω αν κατάλαβα καλά αλλά νομίζω ότι η πιο εύκολη και καλή λύση για τον ήχο είναι να πάρεις ένα καλώδιο οπτικής ίνας για να συνδέσεις το 360 με τον ενισχυτή σου (το καλώδιο του 360 που υπάρχει στη premium έκδοση έχει πάνω στο βύσμα που μπαίνει στην κονσόλα υποδοχή για οπτική ίνα).
Sorry alla me exases..."optiki ina" ?????????? HUH? diladi to kitrino? kokkino? aspro?
lipon to skeftomoun poly xtes, kai skeftika kati. Mipos, ma leo Mipos mporo na paro to kitrino bisma na to valo stin thleorash, kai meta na paro to kokkino kai to aspro kai na ton valo ston enisxiti mou mazi me ta alla kalodia? diladi prasino mple ktlp.??? ginete ayto..diladi mono h ikona tha vlepo stin tileorasi. Katalavate? ginetai? ayto?
afou den mporeis na valeis paixnidia ston skliro, tote ti vazeis???mallon to kovo na pao gia tin apli ekdosi pou kanei 300eura...giati me 100euro pou exei parapano i full ekdosi, kai den ksero kai ti periexei as mou pei kapoios, me afta ta lefta agorazeis 2 games...
Μέγιστο μέγεθος εικόνας υπογραφής 420Χ150 και 16Κ
An exeis ta xrhmata na agorazeis games gia mia nea konsola pare thn kainourgia.An omws den ta exeis 8a ka8ese kai 8a thn koitas...Egw epidei blepw oti eisai arketa mikros,se symbouleuw na pareis tis eidi yparxouses,gia eunoitous logous...Meta apo ena xrono pou 8a exei "spasei" me to kalo,thn agorazeis.
http://www.myphone.gr/gallery/data/500/10396meerjungfrau.gif
tha to paro me doseis apo tin hlektronhkh athinon, kai den leei na doso se ena magazi 250 eura gia ena tsiparismeno ps3, dino 360e (me ton toko) gia to xbox, tin apli ekdosi kai teliono...tha to exo kai 5 xronia, oxi san to ps2 pou se enan xrono vgainei to ps3...meta to ps2 ti tha to kano, tha to fao???
pare oti thes monaxa stamata na rwtas asxeta pragmata!prin merikes meres vgikes kai mas koroidives pou thelame na paroume to 360 twra to thes kai esu meta thes antegramena games,ystera pali to metaniwneis kai thes to core system!rwta epitelous kati pou tha einai xrisimo gia na mathoume kai emeis pou theloume na mathenoume oson to dunato perisotera pragmata gia ayti tin consola!
Den exw prothesi na sou valw xeri alla na se prosanatolisw ligo gia to ti suzitame se auto to forum! ;)
Gia osous endiaferontai me peirane til simera apo plaisio kai mou stelnoun tin consola ayrio (xbox360 400euro)tin plousia ekdosi!tilefwniki paraggelia eixa kanei prin 3 meres sigoura tha yparxoun kai alles gia osous endiaferontai!
ego apantisa ston arfi, kai den sas karoidepsa, ego nomiza pos to xbox to aplo eixe 400e...kai ti se pirazei pou rotao autous pou exoun tin konsola, pia einai kaliteri, i apli i i full???
Λοιπών αν έχεις σκοπό να παίζεις μονο games,η απλή έκδοση είναι μια χαρά για σένα.Το κυριότερο προτέρημα τις full,πιστεύω ότι είναι το online gaming,μια και χρειάζεται σκληρό.Υπάρχει όμως η δυνατότητα να προστεθεί αργότερα σαν add on.Για αυτό αν τα χρήματα για εσένα είναι πρόβλημα πάρε την απλή και αργότερα παίρνεις και σκληρό. :) Η την απλή πάρεις η την full το μηχάνημα είναι το ίδιο δεν αλλάζει κάτι.Απλά η Full έχει κάποια extra όπως ασύρματο χειριστήριο,τον σκληρό βασικά αυτά είναι και τα κυριότερα..Να ξέρεις όμως ότι αν τα αγοράσεις σαν extra θα σου στοιχίσουν πολύ πιο ακριβά.
για σας ειμαι ετοιμος να παρω το Χ360 αλλα πρωτα θελω να παρω HDTV.μου αρεσει μια philips 32pf9966
αλλα δεν εχει υποδοχη component οπως αυτο το μοντελο 32pf9830
που ειναι και πανακριβο. τι λετε θα μπορω να κανω την δουλεια μου με τη philips 32pf9966;
τελικα αγορασα την sony bravia KLV-V32A10E που εχει και πολλες εισοδους τι λετε δεν θα κανει για το Χ360?
enoite na paris to full paketo, afou meta aman tha thes skliro disko tha dosis 99e extra, + asirmato moxlo alla ke 1 mina xbox live, axizi....
alla ke pali an den diathetis ta lefta pare to kanoniko, i kalitera perimene ligo kero na mazepsis lefta ke pare to full..
BENQ, Tileorasi, ayti kani gia to XBOX360? einai mono 1074 euro. Ti lete? Thelo ilikrina tin entyposi sas.
Eyxaristo.
Διαγώνιος 32" ιντσών
Τύπος 16:9
Ανάλυση 1366(x3) x768
Αντίθεση 800:1
Φωτεινότητα 500 cd/m2
Γωνία Θέασης 170/170
Απόκριση 12ms
Ήχος Στερεοφωνικός, Εφέ SRS TruSurround? XT Sound Effect
Ηχεία 2x10W
Υποσατήριξη PAL, SECAM, NTSC
Κανάλια 100
Συμβατη με HDTV (1080i, 720p, 480p, 480i)
Σύνδεση 2xScart, VGA, Component Video in, 3xS-Video, DVI-HDCP, 3xComposite Video/Audio, Audio Line in
Διαστάσεις 99,7x59,2x18cm
Βάρος 19Kgr
Επίσης κάτι που ξέχασαν οι παραπάνω ειναι οτι για hd εικονα, η ακριβή έκδοση διαθέτει και την καλωδίωση των χρωμοδιαφορών που στην οικονομική έκδοση δεν υπάρχει και θα πρέπει να την αγοράσεις έξτρα.
Ποιόν θ' "αρπάξω" σήμερα; [sIGPIC][/sIGPIC]
Eyxaristo.
Τύπος 16:9
Αντίθεση 800:1
Απόκριση 12ms
Ηχεία 2x10W
Κανάλια 100
Βάρος 19Kgr
ax makari na tin evriska Kypro ke malista me tosa lefta....
epaixa to most wanted sto x360!!! :w00t: i konsola g@m@Ei stin kirioleksia...ti perilambani akrivos i full ekdosi?exei ola ta eksartimata gia live?thelei kapoia sindromi???
nai kai ego to most wanted pira san proto paexnidi
i full perilemvani:
- HDD 20GB
- Asirmato joystick
- xbox live dorean gia ena mina
- Akoustika me mikrofono
- Ethernet kalodio
- Sirmata gia enosi me tileorasi
Oso afora to live, den xriazete tipota extra, esi aplos tha kanis neo account ke tha paris dorean ena mina,live. Mporis na enothis sto internet ite me tin ethernet me to pc i router, i me wifi, i me wifi router.
An thes omos na antallaxis arxia me to pc prpei sto pc na exia media connector, i windows xp media center.
provlima...mallon to pasxa tha to paro :cry: :cry: :cry: tora ta xristougena den vlepo na mazeuo ola ta fraga, dld 400 euro pou exei i full... pira prin ligo tin ilektroniki athinon kai mou eipan mono me pistotiki, i me tin eurobank...opote doseis, to ksexnao, alla oute autoi to exoun kai to perimenoun ta xristougena...tha doume, an mas katsoun ta fraga...poulao to papaki mou 800 euro opoios endiaferetai..........!!!!!!!!!!!
Την έκανα τη ζημιά. Πήγα την Τετάρτη στο The Mall και πήρα μια 40άρα Samsung TFT LCD TV HD και ένα XBOX 360. Μόλις είχε παραλάβει το Fnac XBOX 360 και πήρα ένα, όχι το core.
Κατέβασα από τη Microsoft το σχετικό αρχείο για compatibility και έπαιξα Halo 2. Δεν είδα καμμία ουσιαστική διαφορά στα γραφικά (πως θα μπορούσε άλλωστε) ωστόσο το Halo 2 φορτώνει πολύ πιο γρήγορα. :)
Το ασύρματο χειριστήριο πολύ καλό (θα έγραφα άλλή λέξη αλλά θα βγω εκτός ΟΠΧ :lol: ).
Από Δευτέρα που θα έχω και την τηλεόραση θα το συνδέσω HDTV και θα πάρω και ένα παιχνίδι για το 360. Ποιο μου προτείνετε από τα παιχνίδια που είναι για XBOX 360? :)
Has anyone really been far even as decided to use even go want to do look more like?
