b_bil2 Δημ. January 20, 2006 Δημ. January 20, 2006 http://www.expansys.com.gr/product.asp?code=126950 εδω κατι λεει Παράθεση
manos the greek Δημ. January 22, 2006 Δημ. January 22, 2006 Rom update for Atom is out!!! http://www.seeo2.com/support/XdaAtom/template/XdaAtom_ROMUpgrade_Jan2006.vm My ROM upgrade experience: ok, think i'm a bit slow here as i was waiting to see some reviews of the ROM upgrade before i do mine... let me say, before my upgrade, my atom is functioning well, few hangs, no problems with ringing, missed calls etc... only thing is that application loading is abit slow, especially with skype, PI, Resco explorer and ilauncher installed - all trial version. biggest complain was that the camera took like 12 seconds to load and another 10 secs to close... that really pisses me off... ROM upgrade - took 15 minutes from start to end "Clean" atom after upgrade tested: - overall speed improved significantly - camera loading took slightly under 7 secs (this time, autoset to landscape mode) - camera closing took 2 secs (wow) - program memory similar to previous clean version @ 32.92mb - storage memory increases to 17.77mb - storage card remain unchange @ 43.86mb Conclusion: much happier than before... love my atom! recommend this upgrade to all atom users! ps: will critique more after i start syncing and loading more softwares... till then. :) Παράθεση Με την Wind κάνεις πράγματι οικονομία...αφού δεν έχεις ποτέ σήμα, δεν μιλάς, δεν στέλνεις μηνύματα, δεν χρεώνεσαι... Wind Όσα παίρνει ο άνεμος
Ilias74 Δημ. January 24, 2006 Δημ. January 24, 2006 Αναλυτικό review του Atom από αυστραλιακό site: http://www.mtekk.com.au/browse/page1139.html Παράθεση [sIGPIC][/sIGPIC]
ghosteos Δημ. January 25, 2006 Δημ. January 25, 2006 Και πάνω που είχα αποφασίσει να πάρω το 9100... Πάλι μου αλλάζει τα δεδομένα!!!:dizzy: Μήπως τελικά να το περιμένω??? :confused: Μήπως να το πάρω από έξω??? Μήπως να πεταχτώ μία βόλτα κατά Χονγκ Κόνγκ μεριά??? Φαίνεται πάντως να έχει στρώσει με την αναβάθμιση... Βέβαια είχε τόσα πολλά να διορθώσει που ήταν αδύνατο να μην βελτιωθεί αφού χειρότερο δεν γινόταν!!! Και από την άλλη και για το 9100 δεν έχω ακούσει τα καλύτερα.. το reset του θέλει συχνά-πυκνά για να συνέρχεται! Προσωπικό αποτέλεσμα προβληματισμού: Στο ψυγείο για λίγο ακόμα, να διαβάσουμε κανένα review ακόμα για το atom, να δούμε αν υπάρξει και καμιά ανακοίνωση για Ευρώπη (για Έλλάδα μάλλον ζητάω πολλά) και αν στο ενδιάμεσο βαρεθώ να περιμένω, στην χειρότερη ..τρώω τα λεφτά μου κάπου αλλού! :lol: :p Παράθεση
jml Δημ. January 26, 2006 Δημ. January 26, 2006 file mou exw to dopod 818 pro to opoio pira meta apo to 9000.fovero to megethos kai i poiotita foto kai sinarpastiko to wm 5.0 pou trexei xwris kollimata.an kai o 200aris prossesor einai omap kai trexei ta panta.. leipei vevea to flashaki,to radio kai ta dio speakers front alla den masaei to goustarw poli http://www.fleamarket.gr/lotimage18/dopod1.jpg Παράθεση ΔΕΝ ΘΕΛΩ ΓΩ ΣΤΟ ΤΑΦΟ ΜΟΥ ΚΟΛΙΒΑ ΚΙΑΡΤΟΥΛΑΚΙΑ,ΜΟΝΟ ΤΟ CHIVAS ΑΦΘΟΝΟ ΜΕ ΜΠΟΛΙΚΑ ΠΑΓΑΚΙΑ BLACKOPS/QX9770 ON PHASE/DDR3 4GB 2.0GHZ/300GB VELOCIRAPTOR/DUAL 4870X2/1300W/ CHIFTEC BLACKDRAGON[sIGPIC][/sIGPIC]
Ilias74 Δημ. January 26, 2006 Δημ. January 26, 2006 να δούμε αν υπάρξει και καμιά ανακοίνωση για Ευρώπη (για Έλλάδα μάλλον ζητάω πολλά) ΄ ίσως υπάρχουν ελπίδες εφόσον θα το κυκλοφορήσει η HP Παράθεση [sIGPIC][/sIGPIC]
Ilias74 Δημ. January 26, 2006 Δημ. January 26, 2006 o 200aris prossesor einai omap kai trexei ta panta.. QUOTE] ρε παιδιά τι γίνεται με αυτόν το ΟΜΑΡ;;;;;;; κοντεύω να πειστώ ότι είναι ο τέλειος επεξεργαστής! Όλοι (μα όλοι) ευχαριστημένοι είστε; δηλαδή δεν τον βρίσκετε καθόλου αργό; Όλα αυτά που έχουν γραφεί τι είναι; προϊόντα φαντασίας;;; Παράθεση [sIGPIC][/sIGPIC]
djdog Δημ. January 26, 2006 Δημ. January 26, 2006 o 200aris prossesor einai omap kai trexei ta panta.. QUOTE] ρε παιδιά τι γίνεται με αυτόν το ΟΜΑΡ;;;;;;; κοντεύω να πειστώ ότι είναι ο τέλειος επεξεργαστής! Όλοι (μα όλοι) ευχαριστημένοι είστε; δηλαδή δεν τον βρίσκεται καθόλου αργό; Όλα αυτά που έχουν γραφεί τι είναι; προϊόντα φαντασίας;;; Tha to petaksw to Eten M600 me to samsung 400...O OMAP einai o koryfaios epeksergasths...Paei sfaira..:p Παράθεση "Earth has its boundaries, but human stupidity is limitless” Gustave Flaubert
Jean-Paul Δημ. January 28, 2006 Δημ. January 28, 2006 ρε παιδια πουλαει κανεις μηπως κανενα xda atom η ψηνεται για ανταλλαγη με 9090 αριστο? Παράθεση http://www.myphone.gr/gallery/data/500/6396my_car.jpg https://www.facebook.com/JpaulsCarWash?ref=hl ^^Autoglym Detail Center^^ βιολογικοί καθαρισμοί, γυάλισμα-κέρωμα
jml Δημ. January 28, 2006 Δημ. January 28, 2006 auti h foto einai apo k750i: http://www.fleamarket.gr/lotimage18/DSC00369.JPG ligo nwris gia to atom file mou Παράθεση ΔΕΝ ΘΕΛΩ ΓΩ ΣΤΟ ΤΑΦΟ ΜΟΥ ΚΟΛΙΒΑ ΚΙΑΡΤΟΥΛΑΚΙΑ,ΜΟΝΟ ΤΟ CHIVAS ΑΦΘΟΝΟ ΜΕ ΜΠΟΛΙΚΑ ΠΑΓΑΚΙΑ BLACKOPS/QX9770 ON PHASE/DDR3 4GB 2.0GHZ/300GB VELOCIRAPTOR/DUAL 4870X2/1300W/ CHIFTEC BLACKDRAGON[sIGPIC][/sIGPIC]
jml Δημ. January 28, 2006 Δημ. January 28, 2006 kai auti apo to dopod!!! vevea xwris flash kai fws http://www.fleamarket.gr/lotimage18/IMAGE_000061.jpg Παράθεση ΔΕΝ ΘΕΛΩ ΓΩ ΣΤΟ ΤΑΦΟ ΜΟΥ ΚΟΛΙΒΑ ΚΙΑΡΤΟΥΛΑΚΙΑ,ΜΟΝΟ ΤΟ CHIVAS ΑΦΘΟΝΟ ΜΕ ΜΠΟΛΙΚΑ ΠΑΓΑΚΙΑ BLACKOPS/QX9770 ON PHASE/DDR3 4GB 2.0GHZ/300GB VELOCIRAPTOR/DUAL 4870X2/1300W/ CHIFTEC BLACKDRAGON[sIGPIC][/sIGPIC]
Jean-Paul Δημ. January 28, 2006 Δημ. January 28, 2006 Λιγο νωρις εννοεις οτι δεν κυκλοφορει ? η οτι ειναι ακριβο ? Παράθεση http://www.myphone.gr/gallery/data/500/6396my_car.jpg https://www.facebook.com/JpaulsCarWash?ref=hl ^^Autoglym Detail Center^^ βιολογικοί καθαρισμοί, γυάλισμα-κέρωμα
kostas_mob Δημ. January 28, 2006 Δημ. January 28, 2006 θα εννοεί και τα δύο. και δεν κυκλοφορεί και είναι ακριβό. παιδεύομαι να το βρω από γνωστό στην ο2 αγγλίας αλλά δεν έχω καταφέρει. δεν ξέρω αν θα κυκλοφορήσει από την αγγλική ο2... Παράθεση
Jean-Paul Δημ. January 28, 2006 Δημ. January 28, 2006 ναι δεν κυκλοφορει ελλαδα προφανως εννοεις i got it finally !!! γιατι τωρα τοδα στο expansys alla 530 λιρια σορρυ αλλα δεν τα δινω. μενω στο πολυποθητο 9090 μου για την ωρα..... Παράθεση http://www.myphone.gr/gallery/data/500/6396my_car.jpg https://www.facebook.com/JpaulsCarWash?ref=hl ^^Autoglym Detail Center^^ βιολογικοί καθαρισμοί, γυάλισμα-κέρωμα
manos the greek Δημ. January 29, 2006 Δημ. January 29, 2006 Rom update for Atom is out!!! http://www.seeo2.com/support/XdaAtom/template/XdaAtom_ROMUpgrade_Jan2006.vm My ROM upgrade experience: ok, think i'm a bit slow here as i was waiting to see some reviews of the ROM upgrade before i do mine... let me say, before my upgrade, my atom is functioning well, few hangs, no problems with ringing, missed calls etc... only thing is that application loading is abit slow, especially with skype, PI, Resco explorer and ilauncher installed - all trial version. biggest complain was that the camera took like 12 seconds to load and another 10 secs to close... that really pisses me off... ROM upgrade - took 15 minutes from start to end "Clean" atom after upgrade tested: - overall speed improved significantly - camera loading took slightly under 7 secs (this time, autoset to landscape mode) - camera closing took 2 secs (wow) - program memory similar to previous clean version @ 32.92mb - storage memory increases to 17.77mb - storage card remain unchange @ 43.86mb Conclusion: much happier than before... love my atom! recommend this upgrade to all atom users! ps: will critique more after i start syncing and loading more softwares... till then. :) Xda Atom ROM upgrade released http://msmobiles.com/news.php/4851.html :) Confirmed: The O2 XDA Atom Can Do Bluetooth Stereo Audio: http://msmobiles.com/news.php/4852.html :) Παράθεση Με την Wind κάνεις πράγματι οικονομία...αφού δεν έχεις ποτέ σήμα, δεν μιλάς, δεν στέλνεις μηνύματα, δεν χρεώνεσαι... Wind Όσα παίρνει ο άνεμος
Ilias74 Δημ. January 29, 2006 Δημ. January 29, 2006 Φαίνεται Μάνο ότι έχεις πολύ πιο έγκυρη ενήμερωση απ ότι το msmobiles !!! Με αυτά και με τ΄άλλα όλο και βελτιώνεται το Atom Ας παρακολουθούμε πάντως και τις κινήσεις της HP....διότι όπως αναφέρει το msmobiles: ... the same model is coming soon also from HP - branded as HP iPaq hw6800 series (i.e. hw6815 and hw6810 probably) Παράθεση [sIGPIC][/sIGPIC]
manos the greek Δημ. January 29, 2006 Δημ. January 29, 2006 Μετά από πολύ χρόνο και βγάζοντας τα μάτια μου σε κινέζικα/ταιβανέζικα/κορεάτικα/ιαπωνικά fora κάτι μαθαίνω... :) Παράθεση Με την Wind κάνεις πράγματι οικονομία...αφού δεν έχεις ποτέ σήμα, δεν μιλάς, δεν στέλνεις μηνύματα, δεν χρεώνεσαι... Wind Όσα παίρνει ο άνεμος
katsj Δημ. January 29, 2006 Author Δημ. January 29, 2006 Tha to petaksw to Eten M600 me to samsung 400...O OMAP einai o koryfaios epeksergasths...Paei sfaira..:p djdog giati ta peirazeis ta paidia? :p Simazepsouuuuuuuuuu! Pantos eilikrina akoma den exo katalabei tin psixosi pou exei faei o kosmos me ton OMAP (milao panta gia katoxous tou sigkekrimenou epeksergasti). Gnomi mou einai oti thelei giouxxarisma i HTC gia tin strofi pros tous OMAP! Giauto alloste kai tin prodosa me tin ETEN :lol: Παράθεση
kirileman Δημ. January 29, 2006 Δημ. January 29, 2006 Ιούδα!!! Πάντως διάβαζα απόψε ότι βγαίνουν συνεχώς νέες ROM και ότι έχει βελτιωθεί πολύ η απόδοσή του. Περιμένουν, λένε, και άλλη η οποία, λένε, ότι θα βελτιώσει και άλλο την ταχύτητα (που σημαίνει ότι είναι ακόμα αργό). Αυτό που μου άρεσε είναι ότι μπορείς να βάλεις έναν σταθμό ραδιοφώνου αντί για ήχο στο ξυπνητήρι ενώ μάλλον το χειρότερο χαρακτηριστικό του ΑΤΟΜ είναι η οθόνη του. Παράθεση
djdog Δημ. January 29, 2006 Δημ. January 29, 2006 djdog giati ta peirazeis ta paidia? :p Simazepsouuuuuuuuuu! Pantos eilikrina akoma den exo katalabei tin psixosi pou exei faei o kosmos me ton OMAP (milao panta gia katoxous tou sigkekrimenou epeksergasti). Gnomi mou einai oti thelei giouxxarisma i HTC gia tin strofi pros tous OMAP! Giauto alloste kai tin prodosa me tin ETEN :lol: Koita...Ta pragmata einai apla.H HTC ekane mia strofh pros ta Phone-PPC,afhnontas th kathgoria PPC-Phone se allous kataskeyastes... O OMAP einai mia xara epeksergastis gia ena THLEFWNO to opoio mporei na diaxeiristei kai kapoies "elafres" efarmoges enos PPC... Oses kainouries ROM kai na vgaloun,de prokeitai POTE ena mhxanaki me OMAP 200 Mhz na ginei ena plhres PPC... Opws kai to ETEN,oses ROM kai na vgaloun de prokeitai na apokthsei 2.0 mp camera,radiofwno (h keyboard opws to 9100). Einai apla thema epiloghs.Opoios pernei OMAP,thelei perisotero THLEFWNO kai oxi PPC. Teleia kai pavla. Kai to Atom parolo pou exei Intel 416 Mhz einai argo,apla giati o Samsung 400 Mhz,diaxeirizetai kalytera ta WM5.Kai se ayth th periptwsh omws,yparxei kai to thema kostous...Einai poly akrivo re magkes...To ETEN me 568 euro einai pragmatika AXTYPHTO. Παράθεση "Earth has its boundaries, but human stupidity is limitless” Gustave Flaubert
manos the greek Δημ. January 29, 2006 Δημ. January 29, 2006 Να θυμήσω εγώ πως με την αναβάθμιση, τα registry tweaks και το pocket hack master ή άλλα προγράμματα για overclocking το Atom πλέον απλά πετάει σύμφωνα με χρήστες ασιατικών σελίδων. Λένε ότι είναι πλέο το απόλυτο ppc της αγοράς... Τώρα, τι να σας πω, αυτοί ξέρουν! :) Λινκ: http://www.ppcsg.com/index.php?showtopic=69436 Παράθεση Με την Wind κάνεις πράγματι οικονομία...αφού δεν έχεις ποτέ σήμα, δεν μιλάς, δεν στέλνεις μηνύματα, δεν χρεώνεσαι... Wind Όσα παίρνει ο άνεμος
katsj Δημ. January 30, 2006 Author Δημ. January 30, 2006 Koita...Ta pragmata einai apla.H HTC ekane mia strofh pros ta Phone-PPC,afhnontas th kathgoria PPC-Phone se allous kataskeyastes... O OMAP einai mia xara epeksergastis gia ena THLEFWNO to opoio mporei na diaxeiristei kai kapoies "elafres" efarmoges enos PPC... Oses kainouries ROM kai na vgaloun,de prokeitai POTE ena mhxanaki me OMAP 200 Mhz na ginei ena plhres PPC... Opws kai to ETEN,oses ROM kai na vgaloun de prokeitai na apokthsei 2.0 mp camera,radiofwno (h keyboard opws to 9100). Einai apla thema epiloghs.Opoios pernei OMAP,thelei perisotero THLEFWNO kai oxi PPC. Teleia kai pavla. Kai to Atom parolo pou exei Intel 416 Mhz einai argo,apla giati o Samsung 400 Mhz,diaxeirizetai kalytera ta WM5.Kai se ayth th periptwsh omws,yparxei kai to thema kostous...Einai poly akrivo re magkes...To ETEN me 568 euro einai pragmatika AXTYPHTO. Pantos h camera tou M600 einai gia klamata! O monos logos pou den me xalaei einai giati exo to K750i pou einai koryfi. Pantos to M600 se taxitita einai makran oti kalytero me mono melano shmeio tin eleipsi MMX entolon enanti tou XScale se efarmoges multimedia. Pantos einai gegonos oti ta WM5.0 kathontai kalytera se Samsung. Παράθεση
kirileman Δημ. January 30, 2006 Δημ. January 30, 2006 Να θυμήσω εγώ πως με την αναβάθμιση, τα registry tweaks και το pocket hack master ή άλλα προγράμματα για overclocking το Atom πλέον απλά πετάει σύμφωνα με χρήστες ασιατικών σελίδων. Λένε ότι είναι πλέο το απόλυτο ppc της αγοράς... Τώρα, τι να σας πω, αυτοί ξέρουν! :) Λινκ: http://www.ppcsg.com/index.php?showtopic=69436 Καταλαβαίνω ότι γίνεται τρομερή προσπάθεια να αποδείξουν ότι έχει γίνει (σχεδόν, όπως γράφουν) το πιο γρήγορο ppc της αγοράς (που ως επιστημονική μέθοδος είναι παντελώς λάθος, το αντίθετο έπρεπε να αναζητούν) αλλά από τη στιγμή που όλοι παραδέχονται ότι το ράδιο είναι χάλια (φρέσκο νέο για μένα) και η οθόνη ακόμα πιο χάλια (παλιό), τότε εγώ τουλάχιστον αισθάνομαι ευτυχής που δεν το πήρα (γιατί ψηνόμουν) και που απέφυγα να μπω σε ένα μακρόσυρτο γαιτανάκι για να αποδείξω ότι δεν πέταξα τα λεφτά μου (αφού τα μοναδικά χαρακτηριστικά του για τα οποία θα έδινα τα παραπάνω χρήματα δεν βελτιώνονται με αναβάθμιση)... και να κάνω φυσικά το ppc μου και μοναδικό κινητό να δουλεύει απλά καλά, κάτι που ίσως στο τέλος να το πετύχαινα, αλλά μετά από κόπο, με άλλα λόγια, Απαράδεκτο για τόσα χρήματα. Που καιρός για πειραματισμούς! Ενώ τώρα, το μόνο που με απασχολεί είναι να βρω κάνα αξιόλογο προγραμματάκι που θα μπορούσε να μου είναι χρήσιμο. Παράθεση
Ilias74 Δημ. January 30, 2006 Δημ. January 30, 2006 Αν και ανήκω σε αυτούς που ενδιαφέρονται να αποκτήσουν το Atom (ασφαλώς δεν έχω πειστεί ακόμα, εξακολουθώ να ελπίζω) δεν μπορώ παρά να συμφωνήσω με την ανάλυσή σου Kirileman. Μπορεί να μου εξηγήσει κάποιος το πρόβλημα με την οθόνη και τι σημαίνει αυτό σε σύγκριση με το ΕΤΕΝ; Παράθεση [sIGPIC][/sIGPIC]
kirileman Δημ. January 30, 2006 Δημ. January 30, 2006 Αν και ανήκω σε αυτούς που ενδιαφέρονται να αποκτήσουν το Atom (ασφαλώς δεν έχω πειστεί ακόμα, εξακολουθώ να ελπίζω) δεν μπορώ παρά να συμφωνήσω με την ανάλυσή σου Kirileman. Μπορεί να μου εξηγήσει κάποιος το πρόβλημα με την οθόνη και τι σημαίνει αυτό σε σύγκριση με το ΕΤΕΝ; Αν εννοείς αυτό που γράφω παραπάνω, η οθόνη απλά είναι μέτριας φωτεινότητας, γωνίας θέασης κλπ. Αυτά διάβασα, αυτά μεταφέρω. Αυτό και η κακή λήψη του ραδιοφώνου είναι που με χάλασαν πολύ όταν τα έμαθα, γιατί τα άλλα, κουτσά στραβά διορθώνονται απ'οτι φαίνεται. Παράθεση
