P800/P900: Accessories
Fokias
Na rwthsw kati asxeto me ayto pou syzhtate.
Exw ena 6 in 1 card reader. To MS dyo to blepoun?
An oxi, pws pernate ta megala arxeia sthn karta? Me to usb kalwdio?
Eyxaristw
Κωστας - Κατερινη
  • Απαντήσεις 884
lipon 8a sas giriso kata kapiotropo sta palia me to HBH-200 kai p800
8a i8ela kapios pou exi p800 kai exi to HBH-200 xoris na exi kani kamia anava8misi sto p800 you na mou pi pos akrivos litourgi se afton kai mexri se pio simio iposirizete apo to p800 !!
episis iparxi periptosi se mia anava8misi tou p800 na ipostirizi to HBH-200? kai episis an xani klisis !
Efxaristo poli :)
~ If YoU ArEn'T EuRo YoU ArE ZeRo!! ~ :up:
http://img29.imageshack.us/img29/3507/SEbabe.gif
Αρχικό Μήνυμα από το μέλος Johnies (20 Ιαν. 2004 , 20:06)
Efxaristo poli :)
To exo edo kai 1 ecdomada(me to P800). Stin arxi eixa to bluetooth sto "auto" kai exana kapies kleiseis, otan to evala sto "on" einai OK. Dystixos i "call list" kai to caller ID" den doulevoun sto P800. Gia mellontika firware updates den exei akoustei tipota edo kai poly kairo apo tin SE meta tin R2F. Fenete oti Ericsson exei paratisei teleios tin anapticsi tou P800 kai asxolite mono me to P900..or P1000 :)
... είναι τα βλέφαρά μου διάφανες αυλαίες.
Όταν τα ανοίγω, βλέπω εμπρός μου ότι κι αν τύχει
όταν τα κλείνω, βλέπω εμπρός μου ότι ποθώ - (Ανδρέας Εμπειρίκος)
Αρχικό Μήνυμα από το μέλος HuskerDu (20 Ιαν. 2004 , 23:35)
Exw ksananafer8ei sto 8ema alla 1 akoma den blaptei.
Eidika me to HBH-200 den einai 8ema tou oti h SE exei paratisei to P800 kai asxoleitai me P900 h otidipote allo. Makari na itan etsi giati 8a leitourgouse kala se emena (P900 exw).
Kainourio kinito, kainourio kai panakribo handsfree kai epikoinwnia metaksi asta na pane. Xtypaei iserxomeni klisi sto kinito kai ayto tis perisoteres fores adi na sinde8ei me to handsfree sindete me Cairo....
Ena megalo bravo stin SE pou katafere ta bluetothh twn siskeuwn tis na exei tosi megali embeleia.
Anksiopisti siskeuh, poli apla h SE Nokiopeite kai kala kanei afou blepei oti h koroidia kai h ekmetaleusei pernaei-poulaei ston katanalwti pou exei mnimi xrisopsarou (blepe pwliseis Nokia)
A na min ksename episis oti to flash tis SE den einai symbato me tis nauarxides tis etairias P800/P900. Ti psaxneis na breis meta. Sobarotita miden.
Αρχικό Μήνυμα από το μέλος Fetzisjr (17 Ιαν. 2004 , 04:18)
Aυτο εδω διπλα ειναι το ασπρο ετσι? http://www.sonyericsson.com/images/spgc/CWS31AFW_9050_45_0_1040.jpg
Η μηπως ειναι το ασημι! Βασικα σε αυτην την φωτο δεν νομιζω να υπαρχει τοσο μπλε στην οθονη και στο γυρο-γυρο! Ε?
Χαχα...το ασημι ειναι και ειναι ακριβως ετσι και στην πραγματικοτητα.... :)
Αρχικό Μήνυμα από το μέλος htrul18 (18 Ιαν. 2004 , 12:25)
Όχι, είναι το ασημί.
Ένας τρόπος να τα ξεχωρίζετε είναι το χρώμα του καλωδίου. Το ασημί έχει άσπρο καλώδιο ενώ το άσπρο έχει καφέ.
Εγω που εχω το ασημι,το καλωδιο του ειναι ασπρο... :confused:
Αγόρασα χτες το car100, αλλά παρ' όλες τις προσπάθειές μου, δεν κατόρθωσα να το κάνω pair (δηλ. να το "δουν" ως bluetooth συσκευή), ούτε με το Ρ800, ούτε με το Ζ600, ούτε με το Τ-610 !
Η διαδικασία που κάνω είναι:
1) Συνδέω το αυτοκινητάκι με το κινητό για να φορτίσει
2) Έχοντας ενεργοποιημένο το Bluetooth στο κινητό, κάνω αναζήτηση για νέα συσκευή.....αλλά τπτ!
Επίσης, δοκίμασα να κάνω reset το car100, χωρίς πάλι να πετύχω κάτι.
Ξέρει κανείς τι μπορεί να φταίει ;
Έχει πρόβλημα το αυτοκινητάκι, ή κάνω κάτι λάθος ;
Exo to T610 kai exo vare8ei na plirono ta HF me to kalodio (HPB-20).
Eixa apofasisei na agoraso kapoio Bluetooth (HBH-65, HBH-35, HBH-200 mexri kai kapoio Motorola pou eida), alla omologo pos exo mperdeftei ligo afou diavasa tis 24(!!) selides tou forum.
Epeidh 8eoro ta forum tou myphone koryfaia, 8a i8ela na rotiso :
- Vgainei tora konta P1000 ?
- Exei diavasei kaneis ti diafores 8a exei apo P900 ?
- Poio BT mou proteinete gia to T610 pou 8a mporousa na doulepso kai me P900 or P1000 ?
- Na paro BlueTooth ??
gia to 1 8a sou pw oti den argei polu ;) gia diafores afto akoma den egine gnwsto egw pisteuo oti kata kalokairi meria 8a einai konta sto release tou diafore mones pou exoun akousti an kai einai rumors einai wifi kai kati allo all twra de 8imame :(
http://www.myphone.gr/gallery/data/500/10396meerjungfrau.gif
Αρχικό Μήνυμα από το μέλος vkyriakop (26 Ιαν. 2004 , 01:12)
ΗΒΗ-200 φίλε μου,δοκιμασμένο με Τ610 :cool: απλά κορυφαίο!!!
NO ONE LIVES FOREVER
http://briefcase.pathfinder.gr/download/pasxos/16349/209847/0/vba0de3e06e.gif
Αρχικό Μήνυμα από το μέλος ariskard (24 Ιαν. 2004 , 13:33)
Ta idia eixa perasei kai egw....Akou loipon bale to autokinitaki panw sto P800 giati mono gia eki kserw na sou pw!!!Pata to koumpi pou exei pathmeno enw einai epano sto kinito.Gia polu wra toulaxiston 40 deuterolepta mexri na ginei portokali to lampaki.Molis ginei portokali to lampaki bgale to autokinitaki apo to kinito epanw.Pigene stis rithmiseis Bluetooth kai bale thn leitourgia : Me dunatothta anixneusis. kai apo katv an kai den paizei rolo bale panta lipsi.pigene meta prosthiki neas syskeuhs kai kane anazhthsh.Alla pata pali pathmeno to koumpi sto amaksaki pathmeno mexri na ginei prasino kai kokkino.Molis sto brei san Car100 tote tha sou zhthsei kvdiko o opoios einai 0000 tessera mhdenika.Prosekse giati an kaneis katarghsei ths suskeuhs Car100 pou orises tha prepei na to ksana kaneis apo thn arxei olo auto.Meta to mono pou thes einai na katevaseis to Car 100 kai na to doulepseis giati xwris programma den douleuei...To Car 100 einai edw http://www.mobilityworld.tk/portal/dload.php?action=file&id=610
Molis to egkatesthseis pigene sto Help kai tha sou pei pos tha to doulepseis...Kalo odhghma.... ;)
Νόμιμος κάτοχος Imate Jasjar :superman:
http://s1.bitefight.gr/c.php?uid=20539
:) Σε ευχαριστώ πολύ. Δουλεύει μια χαρά τώρα! Μόνο που είναι κάπως δύσκολο στο χειρισμό. Προτιμώ το χειρισμό διαμέσου Ζ600. Ευχαριστώ και πάλι.
Υπαρχει καμια διαφανης θηκη για Ρ800 ωστε οταν μας καλουν να το βλεπουμε? Γιατι μεσα στην θηκη την αρχικη δεν καταλαβαινω οτι περνουν τηλεφωνο μεσα σε δυνατη μουσικη και δεν θελω να το εχω εξω!
Αρχικό Μήνυμα από το μέλος Fetzisjr (26 Ιαν. 2004 , 20:21)
http://shop.brando.com.hk/martinfieldsp800siliconejacket.php
:rolleyes: ;)
Μη γκρινιάζεις που δε σου 'ρθε η ζαριά, τζογάρισε στο όνειρο κι είσαι έτοιμος για όλα!
Αρχικό Μήνυμα από το μέλος stamdd (24 Ιαν. 2004 , 13:59)
Paidia, yparxei kanena tsantaki gia P900 poy na exei θηκες me fermouar gia ta akoustika kai 2-3 memory stick??
Βρηκα μια καλη θηκη αλλα δεν εχει χωρο για τα ακουστικα:
http://shop.brando.com.hk/bwp900case.php ;)
WELCOME
TO THE WORLD
WITH NO FUTURE...
S.T.A.L.K.E.R.
SHADOW OF CHERNOBYL
