[Επίσημο] Nokia 6230
Pimpsick
H 4.43 einai pleon gegonos kai oxi apla fimes....
Ektos apo asia pou lene poloi exei kykloforhsei kai agglia, apou nanai diladi katebainei.......
Sas parathetw kati apo ena kseno forum :
Now that I have had 4.43 for a few days I have a couple of comments on operation vs 3.15
1. I use bluetooth to communicate with mty desktop which runs Nokia PC Suite 6.2. Had various blue tooth problems the most repeatable being that the phone locked up if you attempted to switch off bluetooth while it was connected to the PC.
Operation under 4.43 has been flawless.
2. I have a 512K MMC card which I use with Music Play to play MP3's but phone often crashed during playing (usuallly within about 10 Mins.) No problem with 4.43
3. When headset connected incoming ring tones are routed to phone speaker and headset but message alerts go to headset only. This isn't an issue for me but I believe some were complaining about this behavior in 4.38???
4. The font seems to have been imroved in the phoe directory etc, now very dark and bold and very readable.
I am in Sydney and got my upgrade at the Chatswood Nokia Care Centre.
  • Απαντήσεις 6χιλ.
Αρχικό Μήνυμα από το μέλος Pzapad ( 1 Οκτ. 2004 , 07:40)
Nai file mou Dimitri.Akribws Etsi , Me Compaq NX9010 Laptop, me winXP Pro
Kai kati allo. me tis ir tou laptop nomizw pws douleyei kalytera to thl se anti8esh me ton MA 620 / 660 ir adapter, as me epibebaiwsei kapoios..
katarxin kalo mhna na exoume .
nai file mou Panouli, mono pou pleon ta audio , video wallpaper ta pernaw me card reader apo kathara periergia se rotisa. kai go win xp pro english exw . tha bgei update elpizw kapoia stigmh.
Αρχικό Μήνυμα από το μέλος Cue ( 1 Οκτ. 2004 , 14:19)
Να ρωτήσω κάτι.
Υπάρχει μεγαλύτερης χωρητικότητας μπαταρία για το κινητό καθώς επίσης και κάποιο άλλο είδος hands free πέρα από αυτό τις συσκευασίας?
Last time I checked δε μπορούσες να ακούσεις mp3/ράδιο από wireless headset. Μήπως έχει αλλάξει τπτ?
Thx :D
gia mpataria makari na yparxei alla xlwmo to kovw.
gia handfree hdh exw parei ena allo tis nokia ena aspro einai kai stereo fysika kapou 18 euro to eixa parei arketa kalo (Fashion nomizw exei onoma) Oti prepei einai gia to ghpedo,
xerw pws yparxei akoma allo ena handsfree me ena akoustiko (mono hxos) kapou 10 euro
ayta :)
Εντάξει ρε παιδιά ίσως βγει η 4.43 so what..?
Μην τρελένεστε...μια χαρά είναι και η 4.28!Μην γινόμαστε update-ομανής..!..τι είπα πάλι..:p
Καλό μήνα να έχουμε και καλώς σας βρίσκω,
μόλις πριν 2 μέρες ανακάλυψα το forum σχετικά με το 6230 (είμαι κάτοχος του περίπου μια εβδομάδα) και προσπαθώ να ανακαλύψω τα "μυστικά" του. Θέλω να σας κάνω μια ερώτηση και συγχωρήστε με γιατί ξέρω ότι έχει ήδη απαντηθεί , αλλά παρακαλώ ,γιατί είμαι εντελώς άπειρος χρήστης, θα ήθελα αναλυτικές πληροφορίες ή κάποια σελίδα που θα μπορούσα να απευθυνθώ για τα περαιτέρω (δηλ. διαδικασία, software και cables). Πώς γίνεται η αναβάθμιση του firmware χωρίς να μπω στη διαδικασία να πάω σε nokia club? Μου έχουν ξεμείνει τα καλώδια που είχα χρησιμοποιήσει για να κάνω upgrade το firmware στο nokia 8210, μήπως μπορώ να χρησιμοποιήσω τα ίδια?? Αν όχι από που μπορώ να τα προμηθευτώ. Έχω ήδη προμηθευτεί ένα usb to serial για να συνδέω το 6230 με τον υπολογιστή (από χαζομάρα μου δεν πρόσεξα ότι δεν είναι της nokia αλλά της mobileaction), υποψιάζομαι ότι δεν κάνει για το upgrade ε ?? :))
Αρχικό Μήνυμα από το μέλος clarco5 ( 1 Οκτ. 2004 , 19:43)
ΜΠΡΑΒΟ ΦΙΛΕ clarco5
ΑΥΤΑ ΕΙΝΑΙ ΣΗΜΑΝΤΙΚΕΣ ΚΙΝΗΣΕΙΣ ΓΙΑ ΕΝΑ ΤΟΠΙΚ!!!
ΕΓΩ ΠΡΟΣΩΠΙΚΑ Σ'ΕΥΧΑΡΙΣΤΩ...ΕΛΠΙΖΩ ΠΩΣ Κ ΤΑ ΥΠΟΛΟΙΠΑ
ΠΑΙΔΙΑ ΕΚΤΙΜΟΥΝ ΤΟ ΕΝΔΙΑΦΕΡΟΝ ΣΟΥ ΓΙΑ ΤΗΝ ΕΝΗΜΕΡΩΣΗ ΜΑΣ! ;)
Αρχικό Μήνυμα από το μέλος mspant ( 1 Οκτ. 2004 , 22:31)
ΦΙΛΕ mspant ΚΑΤ'ΑΡΧΗΝ ΚΑΛΩΣΗΡΘΕΣ ΣΤΟ ΤΟΠΙΚ ΜΑΣ.
ΕΛΠΙΖΩ ΠΩΣ ΘΑ ΦΑΣ Κ ΣΥ "ΚΟΛΛΗΜΑ" ΜΕ ΤΟ ΠΕΡΙΒΑΛΛΟΝ ΕΔΩ ΜΕΣΑ ΟΠΩΣ ΟΙ ΠΕΡΙΣΣΟΤΕΡΟΙ...
-ΛΟΙΠΟΝ,ΑΝΑΒΑΘΜΙΣΗ ΔΕΝ ΜΠΟΡΕΙΣ ΝΑ ΚΑΝΕΙΣ ΜΟΝΟΣ ΣΟΥ,ΜΟΝΟ ΝΟΚΙΑ.Το πας πρωι κ σε 2 ωρες το παιρνεις).
-Για τα καλωδια δεν ξερω να σου πω αν ταιριαζουν με το 6230.Γιατι δεν το δοκιμαζεις?Παντως χλωμο το "κοβω".
-Το καλωδιο που πηρες εχει ενα cd μεσα με δικα του προγραμματα.
Νομιζω πως δεν λειτουργει το καλωδιο αυτο με τα προγραμματα της ΝΟΚΙΑ (δηλαδη το pc suite) AΣ ΜΟΥ ΤΟ ΕΠΙΒΕΒΑΙΩΣΕΙ ΚΑΠΟΙΟΣ ΦΙΛΟΣ ΑΝ ΘΕΛΕΙ ΓΙΑ ΤΟΥ ΛΟΓΟΥ ΤΟ ΑΛΗΘΕΣ!!!
Αυτα προς το παρον....καλη συνεχεια και ξανα καλως μας ηλθες!!!
Αρχικό Μήνυμα από το μέλος arish ( 1 Οκτ. 2004 , 19:43)
Με την έκδοση 6.4 το έκανα και δουλεύει άψογα...!
εγω με την 6.3 που το προσπαθησα δεν καταφερα τιποτα!
Δεν ηξερα πως βγηκε 6.4
ΔΕ ΜΑΣ ΕΝΗΜΕΡΩΣΕ ΚΑΝΕΙΣ ΟΤΙ ΒΓΗΚΕ Η ΝΕΑ ΕΚΔΟΣΗ PC SUITE 6.4 (KAΚΩΣ)
ΠΑΝΤΩΣ ΠΑΙΔΙΑ ΑΝ ΜΑΘΑΙΝΟΥΜΕ ΚΑΤΙ ΝΕΟ ΓΙΑ ΟΤΙΔΗΠΟΤΕ,
ΝΑ ΤΟ ΓΡΑΦΟΥΜΕ ΑΜΕΣΩΣ ΓΙΑ ΝΑ ΕΝΗΜΕΡΩΝΩΜΑΣΤΕ!!! :cool:
ΠΑΝΤΩΣ ΕΥΧΑΡΙΣΤΩ ΦΙΛΕ arish!!!!!!!!!!!
ΡΕ ΠΑΙΔΕΣ,ΣΑΣ ΠΑΡΑΚΑΛΩ ΘΑ ΜΟΥ ΠΕΙΣ ΚΑΠΟΙΟΣ ΤΗ ΔΙΑΔΙΚΑΣΙΑ ΠΟΥ ΧΡΕΙΑΖΕΤΑΙ ΓΙΑ ΝΑ ΕΜΦΑΝΙΖΕΤΑΙ ΜΑΖΙ ΜΕ ΤΟ ΜΗΝΥΜΑ ΜΟΥ, ΜΙΑ ΕΙΚΟΝΑ(14kb), Η ΟΠΟΙΑ ΘΕΛΩ ΝΑ ΦΑΙΝΕΤΑΙ ΣΤΟ ΚΑΤΩ ΜΕΡΟΣ ΚΑΘΕ ΜΗΝΥΜΑΤΟΣ ΜΟΥ?
Αρχικό Μήνυμα από το μέλος singer ( 2 Οκτ. 2004 , 04:04)
Φιλε μου διαβασε το
http://www.myphone.gr/forum/misc.php?s=&action=bbcode
iPhone 5S Space Grey
Αρχικό Μήνυμα από το μέλος singer ( 2 Οκτ. 2004 , 03:50)
φιλε singer δεν ειμαι σιγουρος, νομιζω ομως οτι καποιος ειχε αναφερει πως γινεται να κανεις αναβαθμιση μονος σου, ομως θελεις ακριβο εξοπλισμο :) σαφως ομως η καλυτερη λυση ειναι να το πας σε ενα nokia club και να σου κανουν αυτοι την αναβαθμιση.
http://www.myphone.gr/gallery/data/500/27755aek_1.gif
ΑΕΚ ΓΙΑ ΜΙΑ ΖΩΗ
Αρχικό Μήνυμα από το μέλος nervous ( 2 Οκτ. 2004 , 05:24)
Φιλε μου διαβασε το
Το ειχα διαβασει και στο παρελθον αλλα δεν μπορεσα να καταφερω κατι.
Θες να με βοηθησεις λιγο?
Βασικα θελω να βαλω μια φωτο η οποια βρισκεται στα D:\Documents and Settings\giorgos\Τα έγγραφά μου\Οι εικόνες μου.
Η φωτο λεγεται "greece_football.jpg".
Τι εντολη δινω?
Πρέπει να την ανεβάσεις σε ένα briefcase σαν του pathfinder.gr
Aφού την ανεβάσεις θα την ανοίξεις και από κει δεξί κλικ και properties.
Αντιγράφεις την διεύθυνση και την βάζεις στο προφίλ σου με την μορφή
[*img]διεύθυνση από τα properties της εικόνας[/img]...χωρίς το αστέρι.
thats all
ΠΑΙΔΕΣ!!!
ΟΣΟΙ ΘΕΛΕΤΕ ΝΑ ΚΑΤΕΒΑΣΕΤΕ ΤΟ ΚΑΙΝΟΥΡΓΙΟ PC SUITE 6.4
KANTE KΛΙΚ ΕΔΩ
ΠΡΕΠΕΙ ΕΠΙΣΗΣ Ν' ΑΝΑΦΕΡΩ ΠΡΙΝ ΤΟ ΚΑΤΕΒΑΣΕΤΕ ΠΩΣ ΤΟ ΜΕΓΕΘΟΣ ΤΟΥ ΑΡΧΕΙΟΥ ΕΙΝΑΙ "ΜΟΛΙΣ" 22,8 ΜΒ!!! :eek:
Αρχικό Μήνυμα από το μέλος elteo ( 2 Οκτ. 2004 , 13:44)
thats all
ΠΟΛΥ "ΑΠΛΑ" ΤΑ ΛΕΣ ELTEO ΑΛΛΑ ΕΓΩ ΔΕΝ ΕΧΩ ΞΑΝΑΝΕΒΑΣΕΙ ΦΩΤΟ ΜΟΥ ΠΟΤΕ ΣΕ "briefcase" ΟΠΩΣ ΤΟ ΛΕΣ...
ΘΑ ΣΟΥ'ΚΑΝΕ ΚΟΠΟ ΝΑ ΜΟΥ ΔΕΙΞΕΙΣ ΠΩΣ ΓΙΝΕΤΑΙ?
ΘΑ ΚΡΑΤΗΣΩ ΤΗΝ ΑΠΑΝΤΗΣΗ ΠΟΥ ΜΟΥ'ΧΕΙΣ ΗΔΗ ΔΩΣΕΙ, ΓΙΑ ΜΕΤΑ.
ΦΧΑΡΙΣΤΩ...
Αρχικό Μήνυμα από το μέλος konv ( 2 Οκτ. 2004 , 15:00)
Ρε παιδιά ποια είναι η καλύτερη έκδοση oxygen phone manager για το 6230 και που μπορώ να τη βρω;
Κοιτα εδω ;)
ΑΕΚ ΓΙΑ ΜΙΑ ΖΩΗ
koita kai edw version 2.4.0.2 !!!!!!!!!!! :up: :up:
edw
xorhgia ayth thn fora tou akispanag
polla crashing diavazw makria eipame kathe ti neo pou tha bgenei tha diorthonei ta proigoumena mikro-bugs alla tha prosthetei kainourgia ! Exalou anavathmisi na kanoume mono an exoume provlima.
Thanks gia to enimerotiko info :)
anavathmisi den mporis na kaneis monos sou thes akrivo exoplismo kai empeiria. opote pigene se nokia club (an tin xreiazesai ) 45 lepta perimena egw kai tin pira enoeitai dwrean entos eggyisis, ektos eggyisis einai 14 euro apo tote pou eixa rotisei ;)
tis MA to kalwdio leitourgei telika apla xreiazesai na katebaseis tis Wincomm tous drivers kai na kaneis kapies diadikasies mias kai oi ""default"" drivers pou exei den einai kai toso kaloi :)
kalws irthes kai sto myphone kai sto forum mas edw !
Σας ευχαριστώ όλους για το καλωσόρισμα,
πράγματι είδα ότι με τους drivers της mobileaction έχω μπλε οθόνη μόλις συνδέσω το 6230 στο usb και να τρέχει το Nokia PC Suite 6.3.14 που έχω.
@dimitrisgr Σε παρακαλώ εξήγησέ μου που θα βρω τους wincomm drivers γιατί το mobileaction πρόγραμμα δεν το πολύ κάνω κέφι.
Αρχικό Μήνυμα από το μέλος Freeboss ( 3 Οκτ. 2004 , 03:23)
Re filarakia sorry gia ti ligo ilithia erotisi alla otan bgazo photo zoom mporo na kano? Milao gia prin tin bgalo oxi gia meta .
Φιλε Freeboss
η απαντηση ειναι ΟΧΙ.Μονο αφου τη "τραβηξεις" κ μετα μπορεις να ζουμαρεις.
Και δεν ειναι καθολου ηλιθια η ερωτηση σου,ολοι καποια στιγμη την καναμε αυτη την ερωτηση.
File singer epibebaiwnw ayto poy les gia to kalwdio ths MA den synergazete me to pc suite...
It&C My Company Dpt
