alextrela Δημ. November 2, 2014 Author Δημ. November 2, 2014 (edited) Μόλις είδα ότι έβγαλε τελικά νέο firmware update με μπόλικες βελτιώσεις.:!: http://www.microsoft.com/surface/en-us/support/install-update-activate/pro-3-update-history October 28 release The following updates will be listed as “System Firmware Update – 10/28/2014” when you view your update history. Note When Surface updates are provided via the Windows Update service, they are delivered in stages to Surface customers. As a result, not every Surface will receive the update at the same time, but the update will be delivered to all devices. If you have not received the update then please manually check Windows Update later. Surface Pro UEFI update (v3.11.250.0) enhances the system stability, increases the reliability of the graphics display performance, and adds a status bar to the experience when applying future System Firmware Updates. Surface Pro Embedded Controller Firmware update (v38.7.50.0) increases the reliability of sleep state transitions with a Surface Pro 3 Docking Station connected. Surface Integration update (v2.0.1168.0) addresses setting the Hibernate value in Windows 10. Intel® 8 Series PCI Express Root Port #3 - 9C14 update (v2.0.1151.0) addresses cases when the Wi-Fi adapter is not available upon resuming the system from sleep. Wireless Network Controller and Bluetooth driver update (v15.68.3059.117) improves Wi-Fi throughput, especially after rebooting with Bluetooth devices that are paired, enhances power consumption situations, and addresses instances of system instability. Δεν το περνάω ακόμα και βλέπουμε στην πορεία,αφού κομπλέ είμαι. Δώστε feedback όσοι το περάσουν αφού συμπληρωθει μια εβδομάδα 10 ημέρες. Edited November 2, 2014 by alextrela Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
geovass Δημ. November 2, 2014 Δημ. November 2, 2014 Αυτό πέρασε σε μένα. Το System Firmware Update - 28/10/2014 Παράθεση
alextrela Δημ. November 2, 2014 Author Δημ. November 2, 2014 Μερικά αξεσουάρ ακόμη: http://www.amazon.com/gp/product/B00KGLBZO8/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B00KGLBZO8&linkCode=as2&tag=digitren08-20&linkId=OH2FYKU26ZHTSKQ5 http://ecx.images-amazon.com/images/I/91STirwq4DL._SL1500_.jpg ] Αυτή την θήκη την σκεφτόμουν καιρό να την πάρω μιας και ιδιαίτερα λεπτή ειναι,αλλα ειναι μόνο για το tablet όχι μαζί με το πληκτρολόγιο(ίσως την τιμήσω τελικά,θα δούμε) USB Hub χρησιμοποιώ αυτό εδώ και ας ειναι USB 2.0 http://www.skroutz.gr/s/3137043/D-Link-DUB-H4-New.html Έτσι κι αλλιώς θα βγουν έως τέλη του 15 με 3.1 lighting άρα δεν αξίζει η επένδυση σε 3.0. ----- προσθήκη μηνύματος 5 λεπτά μετά την υποβολή του προηγούμενου ----- Αυτό πέρασε σε μένα. Το System Firmware Update - 28/10/2014 Μολις πριν λίγο την πρόσεξα ότι βγήκε. Θα διαβάσω και εξωτερικό εντυπώσεις και βλέπουμε. Έως τότε στα αυγά μου:p Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
kek Δημ. November 3, 2014 Δημ. November 3, 2014 (edited) Τρεις ερωτησεις σε κατοχους: 1. Οταν φορτίσει πληρως, (με κλειστή τη συσκευή) δε σβήνει το φωτάκι πανω στο μαγνητικό βύσμα ??? 2. Το Type cover δεν έχει μαγνητικό κλείσιμο απ'οτι βλέπω,σωστά ? 3. Το Pen loop αφήνει κατάλοιπα κολλας ? Φεύγει εύκολα ? Edited November 3, 2014 by kek Παράθεση
alextrela Δημ. November 3, 2014 Author Δημ. November 3, 2014 Τρεις ερωτησεις σε κατοχους: 1. Οταν φορτίσει πληρως, (με κλειστή τη συσκευή) δε σβήνει το φωτάκι πανω στο μαγνητικό βύσμα ??? 2. Το Type cover δεν έχει μαγνητικό κλείσιμο απ'οτι βλέπω,σωστά ? 3. Το Pen loop αφήνει κατάλοιπα κολλας ? Φεύγει εύκολα ? 1.Οχι δεν σβήνει ποτέ είτε ανοιχτό είτε κλειστό το φορτίζεις. Το καταλαβαίνεις μόνο αν αγγίξεις το φορτιστή στην υποδοχή της πριζας και το νιώσεις κρύο, όταν φορτίζεις κλειστό μιλάμε. 2.Οχι δεν έχει σε στυλ cover σε iPad. Εγώ όσες φορές το είχα πακέτο με το πληκτρολόγιο πάντα το έκλεινα με τον κλασικό τροπο οπως στα pc/laptop και έτσι δεν ξέρω αν ειναι όταν το έχεις σε αναμονή και το ανοίξεις σε στυλ cover θα "ξυπνήσει" το tablet. 3.Δεν το ξέρω διότι δεν το έχω. Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
kek Δημ. November 3, 2014 Δημ. November 3, 2014 1.Οχι δεν σβήνει ποτέ είτε ανοιχτό είτε κλειστό το φορτίζεις. Το καταλαβαίνεις μόνο αν αγγίξεις το φορτιστή στην υποδοχή της πριζας και το νιώσεις κρύο, όταν φορτίζεις κλειστό μιλάμε. 2.Οχι δεν έχει σε στυλ cover σε iPad. Εγώ όσες φορές το είχα πακέτο με το πληκτρολόγιο πάντα το έκλεινα με τον κλασικό τροπο οπως στα pc/laptop και έτσι δεν ξέρω αν ειναι όταν το έχεις σε αναμονή και το ανοίξεις σε στυλ cover θα "ξυπνήσει" το tablet. 1. Θα ηταν καλο να εσβηνε ομως να ξερουμε -οπτικα- ποτε εχει φορτισει ! 2. Εννοουσα αν εχει καποιο μαγνητη να το κραταει καπως....οχι πως φευγει αλλα λεμε.... Μολις το δοκιμασα,μολις αναπτυχθει το type cover ανοιγει ο φωτισμος και μολις πατηθει ενα πληκτρο ξυπναει και η συσκευη. Παράθεση
alextrela Δημ. November 3, 2014 Author Δημ. November 3, 2014 1. Θα ηταν καλο να εσβηνε ομως να ξερουμε -οπτικα- ποτε εχει φορτισει ! 2. Εννοουσα αν εχει καποιο μαγνητη να το κραταει καπως....οχι πως φευγει αλλα λεμε.... Μολις το δοκιμασα,μολις αναπτυχθει το type cover ανοιγει ο φωτισμος και μολις πατηθει ενα πληκτρο ξυπναει και η συσκευη. Δεν με ενοιασε να βλεπω αν φορτισε η οχι ειναι η αληθεια. ουτε στο 2 με ενοιαζε αυτη η παραμετρος:p Ναι μαγνητη εχει οτον το εχεις κουμπωμενο στο tablet. εγω νομιζα οτι εννοουσες αν κανει οπως το cover σε ipad που με το που κλεισεις τα "καπακι" ακους αυτο το χαρακτηριστικο ηχο και ετσι καταλαβαινεις οτι πηγε για υπνο(αναμονη) το backlit βεβαια ολα τα λεφτα ετσι:lol: Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
kek Δημ. November 3, 2014 Δημ. November 3, 2014 Ναι μαγνητη εχει οτον το εχεις κουμπωμενο στο tablet. σιγουρα ? δηλαδη το cover εσενα κρατιετε στην ακρη του και δεν ανοιγει ?? περιεργο γιατι εμενα ανοιγει ευκολα απόσο διακρινω.... Παράθεση
alextrela Δημ. November 4, 2014 Author Δημ. November 4, 2014 σιγουρα ? δηλαδη το cover εσενα κρατιετε στην ακρη του και δεν ανοιγει ?? περιεργο γιατι εμενα ανοιγει ευκολα απόσο διακρινω.... Ναι βέβαια κρατιέται και δεν ανοίγει εννοείται εύκολα Είναι αρκετά σφιχτό και θέλει μια δύναμη για το βγάλεις. Φαντάζομαι το έχεις κουμπωσει καλά στο tablet; Μόνο όταν το κουμπώσεις(ανασηκώνεις) στο δεύτερο επίπεδο σε λαπτοπ στυλ εκεί μόνο είναι λιγότερο σφιχτό και βγαίνει πιο εύκολα. Αν όπως λες ανοίγει ευκολα δεν είναι φυσιολογικό καθόλου. Ίσως πρέπει να σκεφτείς αντικατάσταση το type cover. Μπες στο ms acount και μιλάς με live chat στην ελληνική σελίδα και τους αναφέρεις το πρόβλημα,λογικα θα σου πουν οι ίδιοι ότι θα σου στείλουν καινούργιο. Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
alex_gate_7 Δημ. November 4, 2014 Δημ. November 4, 2014 Alex νομίζω ότι άλλο λέει ο kek... Να έχει μαγνήτη στο πάνω μέρος έτσι ώστε όταν το κλείνεις να κουμπώνει και να μην ανοίγει όταν περπατάς σαν βιβλίο πχ.... Δηλαδή εδώ: http://i797.photobucket.com/albums/yy259/alexgate7/sp3_zpsdc92be5a.jpg Παράθεση Powerd by OnePlus 7 Pro
alextrela Δημ. November 4, 2014 Author Δημ. November 4, 2014 (edited) Alex νομίζω ότι άλλο λέει ο kek... Να έχει μαγνήτη στο πάνω μέρος έτσι ώστε όταν το κλείνεις να κουμπώνει και να μην ανοίγει όταν περπατάς σαν βιβλίο πχ.... Δηλαδή εδώ: http://i797.photobucket.com/albums/yy259/alexgate7/sp3_zpsdc92be5a.jpg Αν εννοούσε αυτό,τότε ναι δεν έχει μαγνήτη. Edited November 4, 2014 by alextrela Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
kek Δημ. November 4, 2014 Δημ. November 4, 2014 Ναι βρε παίδες,αυτο που λεει ο alex_gate_7 εννοούσα !! :lol::lol::lol::lol: Όλα καλώς λοιπον.:cool: πάντως όντως εχει πανίσχυρους μαγνήτες !!! Παράθεση
kek Δημ. November 4, 2014 Δημ. November 4, 2014 (edited) Περασα απο ΣΚΛΑΒΕΝΙΤH σημερα στην Εθνικη οδο στο υψος της Ν.Φιλαδελφειας....και βρηκα μια Sleeve θηκη Μαυρη με 3.80 ευρω Ειναι για tablet εως 13'' και με το Surface 3 πληρες με το Type cover εχει κενο μισο εκατοστο περιπου ανα πλευρα ,χωρις να "κολυμπαει" δηλαδη εχει κι ενα πολυ μικρο κενο ασφαλειας. Για τη τιμη της ειναι σουπερ ! Ειναι σαν αυτη: (υπαρχει σε διαφορα χρωματα αλλα χωρις την ασπρη γραμμη,ειναι μονοχρωμη ολη η θηκη) http://kaenaa.com/image/cache/data/Neoprene%203-500x500.jpg Edited November 4, 2014 by kek Παράθεση
alextrela Δημ. November 4, 2014 Author Δημ. November 4, 2014 Τέλος καλό ολα καλά λοιπόν :lol: Και η θήκη να δέσει το γλυκο:p Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
kek Δημ. November 4, 2014 Δημ. November 4, 2014 (edited) παναθεμα σε ,με τρομαξες. :p:p:p :lol::lol::lol::lol: προσωρινη ειναι η θηκουλα.... περιμενω αυτη: http://i.ebayimg.com/00/s/ODAwWDgwMA==/z/dOEAAOSwGvhUKg4M/$_57.JPG Edited November 4, 2014 by kek Παράθεση
alextrela Δημ. November 4, 2014 Author Δημ. November 4, 2014 Όταν παραλάβεις δώσε feedback μήπως παραγγείλω την ίδια. Μου αρέσει η άλλη η λεπτή από Amazon αλλα φοβάμαι μην ειναι σκληρό πλαστικό στις 4 γωνιές και με το βάλε-βγάλε μου αφήσει σημάδια. Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
kek Δημ. November 4, 2014 Δημ. November 4, 2014 Όταν παραλάβεις δώσε feedback μήπως παραγγείλω την ίδια. Καλως,καλως.:cool: Μου αρέσει η άλλη η λεπτή από Amazon αλλα φοβάμαι μην ειναι σκληρό πλαστικό στις 4 γωνιές και με το βάλε-βγάλε μου αφήσει σημάδια. Αυτη λες ? http://www.amazon.com/Microsoft-Surface-Tablet-Protect-L-With-Keyboard-Black/dp/B00KSYX8TS/ref=cm_cr_pr_product_top την εχω σταμπαρει κι εγω...."δερματινη" ειναι.Δε νομιζω να υπαρχει θεμα φθορας και σημαδιων στη συσκευη. Εκτος αν εννοεις αλλη. Παράθεση
kek Δημ. November 4, 2014 Δημ. November 4, 2014 Κατάλαβα ποια λες.... Αυτή λες: http://www.amazon.com/gp/product/B00KGLBZO8/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B00KGLBZO8&linkCode=as2&tag=digitren08-20&linkId=OH2FYKU26ZHTSKQ5 ..... αυτή όμως σου αχρηστευει το kickstant! Άσε που - μάλλον- δε θα αποβάλλει εύκολα τη θερμοκρασία! Παράθεση
alextrela Δημ. November 5, 2014 Author Δημ. November 5, 2014 Κατάλαβα ποια λες.... Αυτή λες: http://www.amazon.com/gp/product/B00KGLBZO8/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B00KGLBZO8&linkCode=as2&tag=digitren08-20&linkId=OH2FYKU26ZHTSKQ5 ..... αυτή όμως σου αχρηστευει το kickstant! Άσε που - μάλλον- δε θα αποβάλλει εύκολα τη θερμοκρασία! Ναι αυτή εννοούσα. Βασικά δεν τη θέλω μόνιμα να την έχω,μόνο όταν μεταφέρω το tablet,απλα με ενδιαφέρει μην αρχίσει να τρώει τις γωνίες αν είναι από σκληρό υλικό με το βαλε-βγαλε. Παρέλαβε την δικιά σου και ανάλογα βλέπω μιας και amazon που την είδα δεν έχει ούτε μια κριτική. Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
kek Δημ. November 5, 2014 Δημ. November 5, 2014 το σκέφτομαι.... http://www.ebay.co.uk/itm/201174558636?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Παράθεση
kek Δημ. November 6, 2014 Δημ. November 6, 2014 Unlock All Power Options On Surface Pro 3 High performance mode, cpu ang gpu options ulocked Παράθεση
alextrela Δημ. November 6, 2014 Author Δημ. November 6, 2014 το σκέφτομαι.... http://www.ebay.co.uk/itm/201174558636?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Φαίνεται καλή περίπτωση μιας και μπόλικα κομμάτια έχει διαθέσει. Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
kek Δημ. November 6, 2014 Δημ. November 6, 2014 Making Music with My Surface Pro 3 (Lioem Ab) :cool::blink: Παράθεση
nkoasidis Δημ. November 6, 2014 Δημ. November 6, 2014 Making Music with My Surface Pro 3 (Lioem Ab) :cool::blink: Αλεξ χθες εκανα την παραγγελια από γερμανια το Surface Pro 3 i5 8gb και το ethernet adapter.Το περιμενω στις 14 του μηνος με βαση το tracking της UPS.Type cover 3 απο bestdeals. Παράθεση Iphone 6s Plus-MS Surface Pro 3 Ipad Pro 9,7-ZTE Axon 7
alextrela Δημ. November 7, 2014 Author Δημ. November 7, 2014 Αλεξ χθες εκανα την παραγγελια από γερμανια το Surface Pro 3 i5 8gb και το ethernet adapter.Το περιμενω στις 14 του μηνος με βαση το tracking της UPS.Type cover 3 απο bestdeals. Με το καλό να παραλάβεις. Παίζει και 1-2 ημέρες νωρίτερα να παραλάβεις αν ειςαι Αθήνα. Btw εγω είμαι ο Alex.:p Unlock All Power Options On Surface Pro 3 High performance mode, cpu ang gpu options ulocked Δεν πιστεύω να το ρίξεις σε hard core gaming διότι θα το γονατίσεις το μηχάνημα και θα σου κλατάρει στο πι και φί :lol: Άντε πες κανα football manager η asphalt 8 μια στο τόσο να παίξεις κανα μισάωρο βεβαια όχι με τις ώρες.:p Παράθεση OnePlus Nord 4 - Motorola Edge 60 Pro
