Daffymaria Δημ. March 22, 2004 Δημ. March 22, 2004 Koita Alex,na sou pw kati ? Thn eksypnada allou .. TO PATISA apla den egine k tpt ..giayto k se rwtisa ean enoouses ayto,oso gia ta alla eyxaristw. Filika, Triantafyllos http://www.opensource.org & http://www.gnu.org
Alexkass Δημ. March 22, 2004 Author Δημ. March 22, 2004 πλάκα έκανα. take your time... Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Daffymaria Δημ. March 22, 2004 Δημ. March 22, 2004 I will mate,dont worry ;) thanks http://www.opensource.org & http://www.gnu.org
jgs69 Δημ. March 23, 2004 Δημ. March 23, 2004 gia na min psaxneis sto irc, boreis na pas stin HP kai na katevaseis to HP mobile printing, tha sou perasei to clear view me viewer gia to word, to excel kai to ppt http://www.danasoft.com/sig/jgs69.jpg JGS
Daffymaria Δημ. March 23, 2004 Δημ. March 23, 2004 8a to koitaksw k ayto, eyxaristw polu Filika, Triantafyllos http://www.opensource.org & http://www.gnu.org
Alexkass Δημ. March 23, 2004 Author Δημ. March 23, 2004 υπάρχει και το αντίστοιχο viewer clearvue για pdf ;) Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
jgs69 Δημ. March 24, 2004 Δημ. March 24, 2004 Re paidia poio programa na xrisimopoiiso gia na ftiaxo themes gia to 1940 ?? Yparxoun alla etoima ektos apo auta pou dinei i MS ?? http://www.danasoft.com/sig/jgs69.jpg JGS
Alexkass Δημ. March 24, 2004 Author Δημ. March 24, 2004 υπάρχουν σε διάφορα sites αλλά δεν θυμάμαι κάποιο λινκ. κατέβασε το theme maker της M$ από το σάιτ της (ppc power toys) Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Επισκέπτης Δημ. March 24, 2004 Δημ. March 24, 2004 Αρχικό Μήνυμα από το μέλος jgs69 (24 Μάρ. 2004 , 13:56) Re paidia poio programa na xrisimopoiiso gia na ftiaxo themes gia to 1940 ?? Yparxoun alla etoima ektos apo auta pou dinei i MS ?? http://www.pocketpcthemes.com/ :cool:
Prof.Wizard Δημ. March 30, 2004 Δημ. March 30, 2004 Ρε παιδιά μήπως θα έπρεπε αυτό το FAQ να ξαναγίνει απ'την αρχή όπως αυτό του Palm section; :( Έχει γίνει πολύ δυσανάγνωστο έτσι... (δείτε λίγο τη δουλειά που έκανε ο xpan με των Palm και πείτε τη γνώμη σας γιατί το thread αυτό σχεδόν δε διαβάζεται από έναν n00b)
panaros Δημ. March 31, 2004 Δημ. March 31, 2004 παιδια μηπως εχει κανεις σας σπασμενο το p*nread*r ελληνικα για wmb 2003?
Alexkass Δημ. March 31, 2004 Author Δημ. March 31, 2004 το έχει το irc. αλλά οχι όλοι οι σερβερς :( ακόμα το ψάχνω. Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
panaros Δημ. March 31, 2004 Δημ. March 31, 2004 και αλλη μια ερωτησουλα. εχω το ipaq1940, και το motorola v600 για gprs modem μεσω bt. Μου εστειλε ρυθμίσεις η hp, μου εστειλε ρυθμισεις η Tim, συνδέονται οι συσκευες, αλλα δεν μπαινω net. Αν εχει κάποιος τις παραπανω ρυθμίσεις, παρακαλώ ας μου τις στείλει στο ntzamaras@asset.gr. Thanks
babis Δημ. April 2, 2004 Δημ. April 2, 2004 Αρχικό Μήνυμα από το μέλος Alexkass (31 Μάρ. 2004 , 14:17) το έχει το irc. αλλά οχι όλοι οι σερβερς :( ακόμα το ψάχνω. Καποια τυχη με το προγραμμα? Αφου ο Αγγλος δεν γραφει : “ Χάου αρ γιου” ΕΣΥ ΓΙΑΤΙ ΓΡΑΦΕΙΣ “ti kaneis” ?;;;;;;;;;;;?;;;;;;;;;;;; ΟΧΙ ΑΛΛΑ GREEKLISH!
alepapa66 Δημ. April 4, 2004 Δημ. April 4, 2004 Γειά σας! Πριν μια εβδομάδα απέκτησα το iPAQ 2210. Μπορώ να πω ότι είμαι πολύ ικανοποιημένος, καθώς το μηχανάκι είναι πολύ γρήγορο και έχει αρκετά καλή οθόνη. Παρόλα αυτά, αντιμετωπίζω ορισμένα προβληματάκια: α) Το craddle που δίνει η HP είναι μεν εντυπωσιακό και βολικό, αν το συνδέσεις σε desktop. Σε περίπτωση που θέλεις εύκολη μεταφορά (π.χ. συχνά ταξίδια και σύνδεση σε laptop) δεν εξυπηρετεί. Αν πάρω το Sync'n'charge καλώδιο USB που δίνει η expansys, θα κάνω τη δουλειά μου χωρίς να κουβαλάω φορτιστή+μετατροπέα πρίζας+craddle? Το πρόβλημα εστιάζεται στο ότι κάθε φορά που θα το συνδέω για συγχρονισμό, έστω και για λίγο, θα φορτίζεται και η μπαταρία. Μήπως αυτό της κάνει ζημιά; β) Του έβαλα μια CF 128 MB που είχα από μια ψηφιακή φωτογραφική μηχανή, η οποία, όμως, είναι πολύ αργή. Οι SD είναι πιο γρήγορες; Τι συμφέρει να πάρω, συνυπολογίζοντας κόστος, ταχύτητα και την ύπαρξη της CF που ήδη έχω; γ) Υπάρχει τρόπος να εκτυπώσω κατευθείαν σε HP LaserJet 6p, που διαθέτει θύρα IR; δ) Το κατέβασμα MP3 και, γενικότερα, αρχείων μεγάλου μεγέθους παίρνει πολλή ώρα. Φταίει η USB του iPAQ ή αυτή του PC, που είναι απλή 1.1; ε) Το IR πληκτρολόγιο της Belkin (http://www.expansys.com/product.asp?code=107436&asource=105739) είναι συμβατό με τα ελληνικά της Sunnysoft; Βολεύει ή είναι καλύτερο να πάρω ένα από αυτά που συνδέονται στη θύρα του PPC; στ) Υπάρχει εφαρμογή που να επιτρέπει την αναγνώριση ελληνικού κειμένου που γράφεται στην οθόνη; Ευχαριστώ προκαταβολικά όλους όσους κάνουν τον κόπο να απαντήσουν.
Alexkass Δημ. April 4, 2004 Author Δημ. April 4, 2004 α) όχι δεν χαλάει η μπαταρία. β), δ) αργή σχετικά με τη ραμ πάντα. χρησιμποίησε card reader. στ) ο penreader ;) Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Exposed_Bone Δημ. April 4, 2004 Δημ. April 4, 2004 Αρχικό Μήνυμα από το μέλος alepapa66 ( 4 Απρ. 2004 , 03:25) Γειά σας! Πριν μια εβδομάδα απέκτησα το iPAQ 2210. Μπορώ να πω ότι είμαι πολύ ικανοποιημένος, καθώς το μηχανάκι είναι πολύ γρήγορο και έχει αρκετά καλή οθόνη. Παρόλα αυτά, αντιμετωπίζω ορισμένα προβληματάκια: α) Το craddle που δίνει η HP είναι μεν εντυπωσιακό και βολικό, αν το συνδέσεις σε desktop. Σε περίπτωση που θέλεις εύκολη μεταφορά (π.χ. συχνά ταξίδια και σύνδεση σε laptop) δεν εξυπηρετεί. Αν πάρω το Sync'n'charge καλώδιο USB που δίνει η expansys, θα κάνω τη δουλειά μου χωρίς να κουβαλάω φορτιστή+μετατροπέα πρίζας+craddle? Το πρόβλημα εστιάζεται στο ότι κάθε φορά που θα το συνδέω για συγχρονισμό, έστω και για λίγο, θα φορτίζεται και η μπαταρία. Μήπως αυτό της κάνει ζημιά; β) Του έβαλα μια CF 128 MB που είχα από μια ψηφιακή φωτογραφική μηχανή, η οποία, όμως, είναι πολύ αργή. Οι SD είναι πιο γρήγορες; Τι συμφέρει να πάρω, συνυπολογίζοντας κόστος, ταχύτητα και την ύπαρξη της CF που ήδη έχω; γ) Υπάρχει τρόπος να εκτυπώσω κατευθείαν σε HP LaserJet 6p, που διαθέτει θύρα IR; δ) Το κατέβασμα MP3 και, γενικότερα, αρχείων μεγάλου μεγέθους παίρνει πολλή ώρα. Φταίει η USB του iPAQ ή αυτή του PC, που είναι απλή 1.1; ε) Το IR πληκτρολόγιο της Belkin (http://www.expansys.com/product.asp?code=107436&asource=105739) είναι συμβατό με τα ελληνικά της Sunnysoft; Βολεύει ή είναι καλύτερο να πάρω ένα από αυτά που συνδέονται στη θύρα του PPC; στ) Υπάρχει εφαρμογή που να επιτρέπει την αναγνώριση ελληνικού κειμένου που γράφεται στην οθόνη; Ευχαριστώ προκαταβολικά όλους όσους κάνουν τον κόπο να απαντήσουν. Γ) μέσα στο cd (αν θυμάμαι καλά) και έχει πρόγραμμα για να εκτυπώνεις
Επισκέπτης Δημ. April 14, 2004 Δημ. April 14, 2004 Eipa na mhn kanw new topic opote elpizw na tairiazei kalytera edw! :cool: This contains updated SDIO drivers for the iPAQ Pocket PC h2200 Series with ROM version 1.00 and 1.10. Software information: Fixes: Limits the power consumption a SDIO card or peripheral can draw during standby or sleep mode. Fixes SD Card initialization issue. Prerequisites: Rom version 1.00 or 1.10 Notes: This is an initial release. Installation HOW TO USE: Download the SoftPaq to a directory on your hard drive. The file downloaded is a self-extracting executable with a filename based on the SoftPaq Number above. Establish an Activesync connection between your iPAQ Pocket PC and host PC. Execute the downloaded file and follow the on-screen instructions. Perform a normal reset on the iPAQ Pocket PC. http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/download/20674.html :)
Athanasios Δημ. April 15, 2004 Δημ. April 15, 2004 θελω να μαθω πωσ επιτελουσ θα μπορεσω να περασω ena dvd se divx . κατεβασα τα προγραμματα που πρεπει αλλα δεν γινεται.πχ το dvd to pocket pc den spa**ei me tipota.mhpws kanw kapoio la8os? mporw na to ftiaksw me ena aplo programma gia divx px flashmpeg. logika nai alla den kserw ti ri8mhseis prepei na balw gia na einai mirko. kai na xwraei sthn o8onh. kaneis poy kserei na moy pei ΤΙ ΕΧΩ ΚΑΝΕΙ Ο ΤΡΕΛΛΟΣ...
Alexkass Δημ. April 15, 2004 Author Δημ. April 15, 2004 δες εδώ και στα λινκ που δίνει: http://discussion.brighthand.com/showthread.php?s=&threadid=103685 :) και βασικά εδώ: http://divx.ppccool.com/ Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
MIXALISZ Δημ. April 17, 2004 Δημ. April 17, 2004 Μπορεί κάποιος να μου στείλει το link για το irc? Nokia N95, SonyEricsson W960i, HTC TyTN II, HTC Touch Dual, Nokia N95 8 GB, HTC Touch Diamond, SE C902, Samsung SGH i-900 Omnia, HTC Touch HD, SE Xperia X1, LG Arena, SE W995, Samsung i8910 HD, Samsung i8000 Omnia II, iPhone 3GS, HTC HD2, iPhone 4, Xperia Mini, iPhone 4S, Galaxy Note II, Sony Xperia S, Galaxy S4, Galaxy Note3, LG Nexus 5, Galaxy Note 8, Galaxy Note 10.1 LTE 2014 Edition, LG G3, Galaxy Note 4, iPhone 6S Plus, iPhone 7 Plus.
Alexkass Δημ. April 17, 2004 Author Δημ. April 17, 2004 http://www.mirc.com to katevazeis, meta server efnet, channel #pocketwarez (sto mirc ata) ke ise etoimos gia na psaksis ke na katevaseis. Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
ili Δημ. April 18, 2004 Δημ. April 18, 2004 Παιδια γεια σας! Εχω εδω και δυο βδομαδες μπει εστω και λιγο καθυστερημενα στον υπεροχο κοσμο των pocket pc και δεν ξερω γιατι τοσο καιρο παιδευομουν με smartphones... Πλεον με τον συνδιασμο 6230 + iPaq 4150 πεταω στα συννεφα και δεν χορταινω να το χαζευω το iPaqάκι!!! Σας εχω μια ερωτηση ομως... Ακομα δεν εχω καταφερει να βγαλω ακρη με το πως βαζουμε καποιο attachment στα mail που συνθετω. Μου βγαζει ενα μηνυμα οτι δεν μπορει να εισαχθει καμια επισυναψη γιατι δεν βρισκει την καρτα που σωζονται οι επισυναψεις κατι τετοιο.... Εχει κανεις καμια ιδεα? http://www.myphone.gr/gallery/data/500/5226DragonTiger.jpg
Alexkass Δημ. April 18, 2004 Author Δημ. April 18, 2004 pas ston file explorer ke kamis `send via email` :) (me paratetameno patima) gia na min bleksis me to email klp klp. Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
