Windows Media Player 11 (beta)
perdikos2000
πρόσεχε με το unistall γιατι -μπορει- με το unistall να κάνεις unistall όλον τον wmp11 και οχι rollback σε 10...Έχε ένα wmp10 installer και be cool.
btw εγώ δεν είδα κάτι τέτοιο σε avi-mpeg -wmv τουλάχιστον
  • Απαντήσεις 87
Η Microsoft δίνει τα παρακάτω για απεγκατάσταση :
Rolling back to a previous version of the Player
Windows Media Player is a feature of the Windows operating system and cannot be removed entirely. However, in Windows XP, you can roll back to the version of the Player that was previously on your computer.
You must be logged on as an administrator or a member of the Administrators group to perform the following procedure.
1.
Disconnect any portable music or video devices that might be attached to your computer.
For more information, see Issues with devices after removing Windows Media Player.
2.
In Category View of Control Panel, click Add or Remove Programs, and then click Remove a program.
3.
At the top of the list, select the Show updates check box.
4.
In the Windows XP - Software Updates section, click Windows Media Player 11, and then click Change/Remove.
5.
In each of the two confirmation dialog boxes that appear, click OK.
6.
When the rollback process is complete (it might take several minutes to complete), click Restart.
7.
8.
9.
In the Windows XP - Software Updates section, click Windows Media Format 11 Runtime, and then click Change/Remove.
If you installed a non-US English version of Windows Media Player 11, the instructions in the dialog boxes that are mentioned in steps 9, 10, and 11 might appear in English.
10.
In the first confirmation dialog box that appears, click OK.
11.
In the second confirmation dialog box that appears, select the Do you want to continue with the rollback? check box, and then click OK.
12.
13.
14.
Click Microsoft User-Mode Driver Frameworks Feature Pack 1.0, and then click Remove.
15.
Follow the instructions that appear in the Software Update Removal Wizard.
If the Wudf01000 confirmation dialog box appears, click Yes to continue. When the software removal process is complete (it might take several minutes to complete), click Finish.
μα καλά πλάκα μου κάνεις?δοκίμασα winamp και wmp11 και δεν είδα διαφορά
btw πριν απο το format μόλις άνοιγα το wmp 11 κολλούσε τώρα μετά το format
τίποτα απο αυτά.
μήπως tasosmaroulitsis πείραξες τις ρυθμίσεις γιατι πειράζετε και απο κει
(equalizer-srs wow effects)
Μεπως καποιος ξερει να μου πει αν γινεται να επιλεξω καποιο φακελο μεσα στη συσκευη που θελω να κανω sync να αποθηκευονται τα αρχεια.Τωρα αποθηκευονται χημα και δεν με βοηθαει αυτο.:)
iphone 3G & Nokia N82 owner
Up The RealPlayer...:up:
Αμάν!! Υπάρχει άνθρωπος που του αρέσει ο Real Player!!! :wacko: :wacko:
Να κηρυχθεί προστατευόμενο είδος τώρα!! :lol:
Btw, πολύ ωραίος ο WMP 11, το νέο interface μου αρέσει πολύ, και δεν έχω παρατηρήσει προβλήματα. Όχι ότι τον έχω χρησιμοποιήσει πολύ. Αν έβρισκε και το ρημάδι το album art......., αλλά εντάξει ΒΕΤΑ είναι.
-Candygram.
-Candygram, my foot. You get out of here before I call the police. You're the shark, and you know it.
-Wait. I-I'm only a dolphin, ma'am.
Παιδιά, μπορει να μου πει καποιος το κολπάκι για να μπει ο 11?
κοιταξε τις προηγουμενες σελιδες...;)
  • 1 month later...
Είχα το Windows Media Player 11 και όταν έβαλα το Vista Theme (Crystal XP), το WMP έγινε έτσι....
http://img71.imageshack.us/img71/4769/wmp11vistathemeoq9.th.jpg
Τι να κάνω; :(
Έχεις βάλει ένα theme που πειράζει πολλά τμήματα του λειτουργικού, αλλά και (όπως φαίνεται) τον media player. Έχεις βάλει και τον media player 11 που ακόμα είναι beta και προφανώς δεν υποστηρίζεται από το theme. Τι περίμενες να συμβεί; Λογικό είναι να υπάρχουν προβλήματα.
δες αυτο ;)
αν απαγορευεται ας σβηστει :O
1) Right click 'Microsoft Windows Media Player 11.exe' and click "extract files" - a WinRAR option.
2) In the extracted folder run 'wmfdist11.exe' - do not reboot yet.
3) In the extracted folder run 'wmp11.exe ' - reboot.
4) Media Player 11 should be installed. Run from your desktop or Start Menu.
btw, πολυ καλος και ειδικα ωραιος ;)
einai eksakrivomeno kai apo allous oti doylevi? :O
den exo kami oreksi gia format...:cool:
Help plz ..... sto pc m exw 3 xristes , katevasa to media player 11 sto onoma m ton ekana install k otan ton anoi3a eixa kanonika ola ta tragoudia m mesa, otan mpike o father m sto onoma tou omws dn eixe kanena tragoudi apo auta p eixe apo8ikeumena , help .......y.g. sto proigoumeno eixe "all music" p einai auto sto kainourio ???
Παίζει, δοκιμασμένο σε 3 υπολογιστές. Αν παρόλα αυτά δε παιξει και δεν ανοίγει ο wmp με ενα system restore είσαι μια χαρά.
Πρεπει να εχω sp2? και ναεχω και γνησια windows?
[imgalign]http://img140.imageshack.us/img140/3467/graphic12copy4pt.gif[/imgalign]
www.hlektronika.gr - Ο Κόσμος των Hλεκτρονικών!
  • 5 weeks later...
